  3. Powering NRF24l01+ with DC-DC Module Abaisseur Regulateur Tension Step Down
6 Posts 3 Posters 955 Views 3 Watching
  • SnyfirS
    SnyfirS
    Snyfir
    wrote on last edited by Snyfir
    Hello everybody,
    When i powered nrf24l01+ with this module or this one the nrf24l01+ is not working (unable to send / received).
    But if i use https://www.ebay.com/itm/200960749614 the same nrf24l01+ works perfectly.
    All regulator deliver 3.3V so i don't know why it doesn't work. The input DC is 12V for all
    Do you have a clue ?
    Thank you for your help.
    • C
      C
      cabat
      As i see, two first module is impulse, but third - linear?
      • SnyfirS
        SnyfirS
        Snyfir
        Yes two first modules are switching regulator an the third is linear.
        Nrf24l01+ are not compatible with switching regulator ?
        • SnyfirS Snyfir
          @snyfir a switching regulator (at least the cheap ones) does not deliver as stable power as a linear regulator. The nrf24 is extremely sensitive to unstable power.
          SnyfirS 1 Reply Last reply
            SnyfirS
            SnyfirS
            Snyfir
            @mfalkvidd
            I want to use a switching regulator ta avoid too lost of current and heat (12v to 3.3V). A LC filter can solve my issue ?
            • C
              C
              cabat
              wrote on last edited by cabat
              I am use switching DC-DC the same as you to get 5V from 12V and LDO XC6206 to power NRF24 module - all work good.
              Alarm module
