  3. arduino ide says unable to compile on arduino what should i do
6 Posts 3 Posters 1.3k Views 2 Watching
  • J
    J
    Jasxvii
    Re: $8 Lamp (Outlet) "Smart Plug" Module
    • J Jasxvii
      @jasxvii how about posting the error message, with information about which arduino you are trying to use, which board version you have installed and which version of the Arduino IDE you are using?
      J 2 Replies Last reply
        J
        J
        Jasxvii
        @mfalkvidd i am using v 1.8.9
        J 1 Reply Last reply
        • J Jasxvii
          J
          J
          Jasxvii
          @jasxvii Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino Pro or Pro Mini, ATmega328P (5V, 16 MHz)"
          In file included from C:\Users\Asus\Desktop\RelayOutlet\RelayOutlet.ino:14:0:
          C:\Users\Asus\Documents\Arduino\libraries\MySensors/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
          exit status 1
          Error compiling for board Arduino Pro or Pro Mini.
            J
            J
            Jasxvii
            @mfalkvidd so i going to upload the code and then it said unable to compile the code to the arduino mini pro
            can i know what is the step by step procedure in coding the arduino
            what codes am i to download and what controller should i use and how to configure it ?
            • J Jasxvii
              exit status 1
              zboblamontZ
              zboblamontZ
              zboblamont
              @jasxvii Have a vague memory of coming across this error and found it linked to the library MyConfig being called, but as I went with a different sketch for that particular project did not investigate further. @mfalkvidd has considerably greater insight on the sequence of library calls, perhaps posting the sketch might help.
