  3. Report Relay state to GW
7 Posts 2 Posters 1.7k Views 2 Watching
  • P
    P
    Philipp Geis
    Good morning everybody I have following Problem:
    My controller (pimatic) opens via Gateway my Relay which activates a magnetic valve to fill my pond. depending on the water level, measured by my distance sensor.
    By rule pimatic closes the relay if the distance is less or equal to 14cm. NOW: one out of ten my communication fails and pimatic changes the state of the switch in the frontend, therefor the controller thinks the relay is off (valve closed) But in the GW debug I see the the message to turn of was NOACK. Meaning the water keeps running and my pond overflows.
    After reading everything I found Pimatic does not resend when NOACK or refuses Statechange when noack. IS IT POSSIBLE to report the state of the relay to the controller periodically like every time a distance Message gets send? Like correcting the "Wrong" state in the controler?
    Here is my node Sketch:
     * Version 1.0 - Henrik Ekblad
     * Example sketch for a "light switch" where you can control light or something
     * else from both HA controller and a local physical button
     * (connected between digital pin 3 and GND).
     * This node also works as a repeader for other nodes
     * http://www.mysensors.org/build/relay
    #define MY_REPEATER_FEATURE
    #include <NewPing.h>
    #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
    #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
    #define CHILD_ID_RELAY 1   // Id of the sensor child
    #define RELAY_ON 1
    #define RELAY_OFF 0
    #define CHILD_ID_DIST 10
    #define TRIGGER_PIN  6  // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define ECHO_PIN     5  // Arduino pin tied to echo pin on the ultrasonic sensor.
    #define MAX_DISTANCE 300 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
    NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
    MyMessage msgDist(CHILD_ID_DIST, V_DISTANCE);
    int lastDist;
    bool metric = true;
    Bounce debouncer = Bounce();
    int oldValue=0;
    bool state;
    MyMessage msgRelay(CHILD_ID_RELAY,V_LIGHT);
    long previousMillis = 0;        // will store last time Distance was measured
    long interval = 10000;           // interval at which to measure (milliseconds)
      // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(1);
      pinMode(RELAY_PIN, OUTPUT);
      state = loadState(CHILD_ID_RELAY);
    void presentation()  {
      sendSketchInfo("Relay & Button Distance", "1.0");
      present(CHILD_ID_RELAY, S_LIGHT);
      present(CHILD_ID_DIST, S_DISTANCE);
    *  Example on how to asynchronously check for new messages from gw
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue && value==0) {
          send(msgRelay.set(state?false:true), true); // Send new state and request ack back
      oldValue = value;
      // here is where you'd put code that needs to be running all the time.
      // check to see if it's time to blink the LED; that is, if the
      // difference between the current time and last time you blinked
      // the LED is bigger than the interval at which you want to
      // blink the LED.
      if(currentMillis - previousMillis > interval) {
        // save the last time you blinked the LED
    int dist = metric?sonar.ping_cm():sonar.ping_in();
      Serial.print("Ping: ");
      Serial.print(dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
      Serial.println(metric?" cm":" in");
      if (dist != lastDist) {
          send(msgDist.set(dist));
          lastDist = dist;
     // sleep(SLEEP_TIME);
      if (message.isAck()) {
         // Change relay state
         state = message.getBool();
         // Store state in eeprom
         saveState(CHILD_ID_RELAY, state);
    • rejoe2R
      rejoe2R
      rejoe2
      It's pretty easy to send back the actual state of the relay.
      But imho there are several options to improve the behaviour of the whole thing:
      • if it's more secure to start the whole thing with the relay switched off instead of reading value from EEPROM. Then ask the controller about the desired state and keep it off until message arrives or button is pressed?
      • keep track of the actual state of your relay within the loop(). By now, the switching logic of the button/switch seems to be weired. Does this work as expected?
      • if it's a security function: let the node decide whether the relay should be switched off, dependend on the meassured value and the state of the relay. Just inform the controller it had been switched off.
      It might be necessary to add some overriding functionality (eg. keep relay on for x minutes if it has been switched on using the button and so on).
      P 1 Reply Last reply
      • rejoe2R rejoe2
        P
        P
        Philipp Geis
        @rejoe2 Hi sorry but I never really solved this problem but u are totally right!
        since I am not really firm with writing sketch this was my first attempt. The sketch works as long as i have communication. to the controller as soon as I Dont have communication nothing works as it should.
        How can I ask the controller about the desired state?
        How can i make the button work on the node but report the state change to the controller?
        can i just kill the code where i update von eeprom?
        I would be greatfull for any indication!
        I will post my own attemps as soon as I figured out what i am doing :relaxed: :joy:
        Thanks Philipp
        • rejoe2R
          rejoe2R
          rejoe2
          Based on the great sketch korttoma posted here, the following could work:
          #define SN "RelayButtonArray"
          #define SV "1.0"
          #define RELAY_ON 0                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
          #define RELAY_OFF 1
          #define noRelays 4                     //2-4
          const int relayPin[] = {14, 15, 16, 17};       //  switch around pins to your desire
          const int buttonPin[] = {6, 7, 4, 5};   //  switch around pins to your desire
          class Relay             // relay class, store all relevant data (equivalent to struct)
            public:
              int buttonPin;                   // physical pin number of button
              int relayPin;             // physical pin number of relay
              boolean relayState;               // relay status (also stored in EEPROM)
          Relay Relays[noRelays];
          Bounce debouncer[noRelays];
          MyMessage msg[noRelays];
            void before() {
              pinMode(pin, OUTPUT);
                  digitalWrite(pin, RELAY_OFF); //digitalWrite(pin, loadState(sensor)?RELAY_ON:RELAY_OFF);
            wait(100);
            for (int i = 0; i < noRelays; i++) {
              Relays[i].buttonPin = buttonPin[i];              // assign physical pins
              msg[i].type = V_LIGHT;
              wait(100);
              //Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
          	// digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
              //send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
              wait(50);
              debouncer[i].interval(30);
              wait(50);
            sendSketchInfo(SN, SV);
            wait(100);
              present(i, S_LIGHT);                               // present sensor to gateway
              request(i, V_LIGHT); //...not sure if this is the right syntax
            wait(100);
            for (byte i = 0; i < noRelays; i++) {
              if (debouncer[i].update()) {
                if ( value == LOW) {
                  // save sensor state in EEPROM (location == sensor number)
                  //saveState( i, Relays[i].relayState );
            //wait(20);
              if (message.sensor < noRelays) {          // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                //saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
            wait(20);
          I tried to just comment out things not needed, so you might find it easier to understand the differences between loading from EEPROM and requesting the state from controller side.
          • rejoe2R rejoe2
            #define SV "1.0"
            #define RELAY_OFF 1
              public:
              void before() {
              wait(100);
                wait(100);
                wait(50);
                wait(50);
              wait(100);
              wait(100);
              //wait(20);
              wait(20);
            P
            P
            Philipp Geis
            @rejoe2 THANKS !!!! I Will post again with edited sketch... but will take some time! Thanks alot!
            • P
              P
              Philipp Geis
              wrote on last edited by Philipp Geis
              Think I got the button now working on the node and just informing the controler, cant figure out to ask the controller for the state on startup and how to send periodicly the relay state
                debouncer.update();
                    digitalWrite(RELAY_PIN, state?RELAY_ON:RELAY_OFF); //realy state change on the node?
                    send(msgRelay.set(state?false:true)); // Send new state
                oldValue = value;
                    send(msgRelay.set(state?false:true), true); //Do I send relay status here?
                    lastDist = dist;
                sleep(SLEEP_TIME);
              • rejoe2R
                rejoe2R
                rejoe2
                Asking the controller at startup: issue a request, see https://www.mysensors.org/download/sensor_api_20#requesting-data, imo you should as for V_STATUS.
                Then your controller should respond, the response is handled by the receive()-function (=no action needed), but to get this to work, your node should not sleep (you sketch seems to be incomplete wrt. that).
                But you should first switch off everyhing to have it in a defined state and avoid loading values from the EEPROM.
                Wrt. to regular status info: If that's necessary, you should try to use a so called "non blocking loop", use g**gle or similar for that. Imo, it's not necessary to update the value as it doesn't change. Better use the heartbeat funcionality instead (dependend on your controller).
