  3. Domoticz
  4. Ethernet Gateway delay issue
4 Posts 2 Posters 1.5k Views 3 Watching
  • A
    AterMentis
    Hi All,
    I currently have a full home automation system running on pi with domoticz and use arduino based mysensor nodes as expansions.
    Some of these go through USB communication but i also have several wired up as an ethernet gateway using a big W5100 ethernet shield.
    I used the example sketch from the mysensors site and just added devices and all is working well except for one issue...
    Sometimes when i switch a relay device from domoticz its instantaneous... but other times i get the following error messages:
    2019-09-20 20:54:42.414 Status: User: Admin initiated a switch command (854/Heating Zone3/On)
    2019-09-20 20:54:43.616 Error: MySensors: Repeating previous command (2/2)
    2019-09-20 20:54:44.817 Error: MySensors: Command not received by Node !! (node_id: 0, child_id: 3)
    If you wait a few seconds to a minute it will eventually send the command succesfully and all will work but this is quite an anoying delay that shouldn't be there in my opinion... I have been looking everywhere on forums and found input to other users about baudrate and how you should lower it from 115200 in the Myconfig.h file of the mysensors library and i have tried going to 9600 and 57600 but this did no change the situation for me...
    If anybody has any idea what else i could be doing wrong please feel free to share. Or if i can find it somewhere on this forum already written and i looked over it... my sincere apologies and thanks for pointing me in the right direction!
    Kind regards
    Jasper
    • A AterMentis
      Hi All,
      Kind regards
      Jasper
      Hi @atermentis, welcome to the forum!
      Which of the example sketches are you using? Could youpost the full sketch here?
      Are the relays wired directly to the ethernet gateway? If not, could you describe your setup? (What arduinos, what transport, how are the nodes powered)
      Does the problem happen only with the ethernet gateways, only with the usb gateways or both types?
      Turning on debug log is usually the quickest way to troubleshoot. Use the log parser to make it easier to interpret the logs.
      • A
        AterMentis
        Hi mfalkvidd!
        The sketch i am using is the following and is derived from the ethernet gateway and includes relays buttons and a one wire bus. I have tried excluding all different parts from the sketch so that only the relays where present to make sure that no delays or millis type of factors would cause any issues but it all remains the same and the delay i observe ocasionally is still present.
         * Version 1.0 - Henrik Ekblad
         * Example sketch for a "light switch" where you can control light or something
         * else from both HA controller and a local physical button
         * (connected between digital pin 3 and GND).
         * This node also works as a repeader for other nodes
         * http://www.mysensors.org/build/relay
        //#define MY_RADIO_NRF24
        //#define MY_RADIO_NRF5_ESB
        //#define MY_RADIO_RFM95
        #define MY_GATEWAY_W5100
        //#define MY_W5100_SPI_EN 4
        // radio on the same spi bus.
        //#if !defined(MY_W5100_SPI_EN) && !defined(ARDUINO_ARCH_SAMD)
        //#define MY_SOFTSPI
        //#define MY_SOFT_SPI_SCK_PIN 14
        //#define MY_SOFT_SPI_MISO_PIN 16
        //#define MY_SOFT_SPI_MOSI_PIN 15
        //#endif
        // Enable UDP communication
        //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
        #define MY_IP_ADDRESS 192,168,0,165
        //#define MY_IP_GATEWAY_ADDRESS 192,168,0,1
        #define MY_PORT 5003
        // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
        // Enable inclusion mode
        // Set blinking period
        // Flash leds on rx/tx/err
        #if defined(MY_USE_UDP)
        #include <EthernetUdp.h>
        #include <Ethernet.h>
        #include <OneWire.h>
        /*DEFINITION OF TEMPSENS*/
        #define ONE_WIRE_BUS 2 // Pin where dallase sensor is connected
        /*STUFF FOR TEMP */
        unsigned long MEASUREMENT_INTERVAL = 30000;       // Time to wait between reads (in milliseconds).
        int numSensors=0;
        bool receivedConfig = false;
        bool metric = true;
        boolean CURRENTLY_MEASURING = true;               // Used to indicate when the time is right for a new measurement to be made.
        boolean CURRENTLY_CALCULATING = false;            // Used to bridge the time that is needed to calculate the temperature values by the Dallas library.
        unsigned long CURRENT_MILLIS = 0;                 // The millisecond clock in the main loop.
        unsigned long PREVIOUS_MEASUREMENT_MILLIS = 0;    // Used to remember the time of the last temperature measurement.
        int16_t CONVERSION_TIME = 0;                      // Used to store the time needed to calculate the temperature from measurements.
        MyMessage msgTEMP(0,V_TEMP);
        /*RELAY CODE*/
        #define RELAY_PIN 3  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
        #define NUMBER_OF_RELAYS 7 // Total number of attached relays
        //BUTTON CODE
        #define CHILD_ID_B1 10
        #define BUTTON_PIN1  14  // Arduino Digital I/O pin for button/reed switch
        #define CHILD_ID_B2 11
        #define BUTTON_PIN2  15  // Arduino Digital I/O pin for button/reed switch
        #define CHILD_ID_B3 12
        #define BUTTON_PIN3  16  // Arduino Digital I/O pin for button/reed switch
        Bounce debouncerB1 = Bounce();
        Bounce debouncerB2 = Bounce();
        Bounce debouncerB3 = Bounce();
        int oldValueB1=-1;
        int oldValueB2=-1;
        int oldValueB3=-1;
        MyMessage msgBUTTON1(CHILD_ID_B1,V_LIGHT);
        MyMessage msgBUTTON2(CHILD_ID_B2,V_LIGHT);
        MyMessage msgBUTTON3(CHILD_ID_B3,V_LIGHT);
        void before()
            for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
                pinMode(pin, OUTPUT);
                digitalWrite(pin, loadState(sensor+20)?RELAY_ON:RELAY_OFF);
          sensors.begin();
          for(int i=0;i<MAX_ATTACHED_DS18B20;i++){lastTemperature[i] = 0;} //Pre-filling array with 0's.
          sensors.setWaitForConversion(false);  // requestTemperatures() will not block current thread
         // Setup the button
          pinMode(BUTTON_PIN1,INPUT);
          pinMode(BUTTON_PIN2,INPUT);
          pinMode(BUTTON_PIN3,INPUT);
          // Activate internal pull-up
          digitalWrite(BUTTON_PIN1,HIGH);
          digitalWrite(BUTTON_PIN2,HIGH);
          digitalWrite(BUTTON_PIN3,HIGH);
          debouncerB1.attach(BUTTON_PIN1);
          debouncerB2.attach(BUTTON_PIN2);
          debouncerB3.attach(BUTTON_PIN3);
          debouncerB1.interval(5);
          debouncerB2.interval(5);
          debouncerB3.interval(5);
          sendSketchInfo("Mysensors Garage", "1");
             present(i, S_TEMP);
                present(sensor+20, S_BINARY);
          present(CHILD_ID_B1, S_LIGHT);
          present(CHILD_ID_B2, S_LIGHT);
          present(CHILD_ID_B3, S_LIGHT);
         debouncerB1.update();
          // Get the update value
          int valueB1 = debouncerB1.read();
          if (valueB1 != oldValueB1) {
             // Send in the new value
             send(msgBUTTON1.set(valueB1==HIGH ? 1 : 0));
             oldValueB1 = valueB1;
          debouncerB2.update();
          int valueB2 = debouncerB2.read();
          if (valueB2 != oldValueB2) {
             send(msgBUTTON2.set(valueB2==HIGH ? 1 : 0));
             oldValueB2 = valueB2;
          debouncerB3.update();
          int valueB3 = debouncerB3.read();
          if (valueB3 != oldValueB3) {
             send(msgBUTTON3.set(valueB3==HIGH ? 1 : 0));
             oldValueB3 = valueB3;
        CURRENT_MILLIS = millis(); // The time since the sensor started, counted in milliseconds. This script tries to avoid using the Sleep function, so that it could at the same time be a MySensors repeater.
        // Let's measure the temperature
          if(CURRENTLY_MEASURING == true && CURRENT_MILLIS - PREVIOUS_MEASUREMENT_MILLIS >= MEASUREMENT_INTERVAL){ // If we'e not calculating, and enough time has passed, we'll start again.
            CURRENTLY_MEASURING == false; // We're measuring, so let's take it off our to-do list.
            Serial.print("Starting new measurement(s)\n");
            PREVIOUS_MEASUREMENT_MILLIS = CURRENT_MILLIS; // Mark the time of the initialiation of this measurement.
           // query conversion time. Apparently it takes a while to calculate?
            CONVERSION_TIME = sensors.millisToWaitForConversion(sensors.getResolution());
            CURRENTLY_CALCULATING = true; //Next step is to re-calculate the temperature again.
          // Let's calculate and send the temperature
          if(CURRENTLY_CALCULATING == true && CURRENT_MILLIS > PREVIOUS_MEASUREMENT_MILLIS + CONVERSION_TIME ){
            CURRENTLY_CALCULATING = false; // check calculating off the to-do list too.
            for (int i=0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) {    // Loop through all the attached temperatur sensors.
              float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;   // Fetch and round temperature to one decimal
              Serial.print("Sensor #");
              Serial.print(i);
              Serial.print(" says it is ");
              Serial.print(temperature);
              Serial.print(" degrees\n");
              if(temperature != -127.00 && temperature != 85.00){ // avoid working with measurement errors.
                if (COMPARE_TEMP == 1 && lastTemperature[i] == temperature){
                  Serial.print("Not sending it though, because it's the same temperature as before.\n");
                  Serial.print("Sending the temperature to the gateway.\n");
                  send(msgTEMP.setSensor(i).set(temperature,1));
                  lastTemperature[i] = temperature; // Save new temperatures to be able to compare in the next round.
            CURRENTLY_MEASURING = true; // Both tasks are done. Now we'll just wait for the measurement interval to be over.
            if (message.type==V_STATUS) {
                // Change relay state
                digitalWrite(message.sensor-21+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
                // Store state in eeprom
        All the relays are wired directly to the arduino uno which also has the ethernet shield installed on top of it. Both arduino, ethernet board and relay board are powered through an external DIN rail power supply providing 5V at 0.88A. I also have another ethernet gateway showing the same issues that is powered by a 12V psu feeding into a buck boost converter that supplies everything with 5V at 3A. Would you recommend setting this up differently?
        Both gateways are interfaced over ethernet where one has a 3m long cable and the other around 20m of cables. So cable length didn't seem like the issue to me.
        The issue only occurs on the ethernet gateways and not on the usb... i have had the gateway connected to the pc to view the changes coming in live from the serial monitor and there i also see nothing coming in when domotics displays the error and after a few seconds to minutes when the relay does switch i see the command arrive. So i don't think the gateway itself or the code is doing something wrong but for some reason between the command being sent from domoticz to it arriving at the gateway it gets lost?? and when domoticz repeats the command then sometimes it does come through???
        Ethernet lines are connected through a gigabit ethernet switch...
        Thank you already for all the help!
        • A AterMentis
          Hi mfalkvidd!
          //#endif
          /*STUFF FOR TEMP */
          int numSensors=0;
          bool metric = true;
          /*RELAY CODE*/
          //BUTTON CODE
          int oldValueB1=-1;
          int oldValueB2=-1;
          int oldValueB3=-1;
          void before()
            sensors.begin();
           // Setup the button
               present(i, S_TEMP);
                Serial.print(i);
          @atermentis I noticed the sketch has the ”demo” DEADBEEFFEED mac address. Do all sketches have the same address?
          All mac addresses on a ethernet network must be unique. If they are not unique, strange communication problems will occur.
