  3. Connect to gateway using VB.NET
vb.netvisual basic
6 Posts 3 Posters 3.0k Views 1 Watching
    Sensorbuilder
    I am trying to develope my own controller SW using VB.NET 2012.
    Reading data from Gateway works perfect, using Sockets.NetworkStream and public function .GetStream(), but i do not suceed sending anything.
    When i try to send to gateway, i use function .Client.Send(<bytes>) where bytes are by command text string "20;1;1;1;2;0;\n" decoded to byte with the expression System.Text.Encoding.ASCII.GetBytes( "20;1;1;1;2;0;\n")
    When i connect to gateway using putty and a raw connection everything works fine.
    Does anyone have knowledge about VB.net and howto send command to gateway?
    • ch3b7C
      ch3b7C
      ch3b7
      You dont need send newline
      • ch3b7C
        ch3b7C
        ch3b7
        Use streamreader and streamwrite to read and send data over the networkstream
        • D
          Dirk_H
          I'm not 100% sure especially for Ethernet but shouldn't the string to send be:
          "20;1;1;1;2;0\n" (no trailing semicolon at the last argument).
          You can also check if the output of ASCII.GetBytes is ok. \n should get a 10 (dec). But this should work I think.
          • ch3b7C
            ch3b7C
            ch3b7
            im make a vb.net controller im try to help you with some code
            declare
            Public Swriter As StreamWriter
            Public Client As New TcpClient
            Public ClientStream As NetworkStream
            to send data use
            ClientStream = Client.GetStream()
            ClientStream.Flush()
            Swriter = New StreamWriter(ClientStream)
            Swriter.WriteLine(deviceid & ";" & sensorchildid & ";" & msgType & ";" & ack & ";" & subType & ";" & payload)
            Swriter.Flush()
            if you need more help tell me im try to help ^^
              Sensorbuilder
              Thank you very mouch for your quick support!!
              Now it works perfect as expected :-)
