  3. Sending custom messages from a Raspberry Pi Gateway to Arduino node
3 Posts 3 Posters 552 Views 3 Watching
  • J Offline
    J Offline
    Jurg
    For my school project I have a Raspberry Pi and a Arduino Uno both connected with a NRF24 module. The Raspberry Pi is used as a Gateway. I am able to send signed and encrypted messages from the Arduino to the Raspberry Pi, but how can I send a custom message from my Raspberry Pi to my Arduino?
    • J Jurg
      Hi @jurg, welcome to the forum!
      Easiest way is to issue the messages from your controller. If you don't have a controller, look at https://www.mysensors.org/controller
      An alternative is to modify the raspberry pi gateway sketch and add a call to send(). Documentation: https://www.mysensors.org/download/sensor_api_20#sending-data
      • monteM Offline
        monteM Offline
        monte
        If you compile Mysensors for Raspberry Pi as an ethernet gateway, you will be able to send commands to a socket on an IP of your Raspberry. You can use netcat command, or a python script, as described here: https://forum.mysensors.org/post/88439
        This way, you won't need any controller software, if you are not planning anything big.
