  3. 💬 MySensors Linky
💬 MySensors Linky
mysensorslinkyedfenedismysensorarduinoarduino pro mini
12 Posts 6 Posters 2.7k Views 4 Watching
  • jeremushkaJ
    jeremushkaJ
    jeremushka
    Nice project. I have done something with jeedom plugin through USB connection in a raspberry pi. However, how do you auto power supply your system?
    On my linky i just use the 2 pins I1 and I2 to get the information and then i have 4m of cables until my raspberry pi to power on all the system. With NRF will be more usefull.
    • Fumée BleueF
      Fumée BleueF
      Fumée Bleue
      jeremushka,
      I updated the project description and added arduino sources. The pins I1 and A are used for power supply, and I2 for the datas.
        secator
        hello,
        well done for your project. I am interested but I have an error during the compilation. I'm bad at programming. can you help me.
        C:\Users\Maison\Downloads\TeleinfoMySensors\TeleinfoMySensorsDecode.ino: In function 'void traitement_trame(char*, int)':
        C:\Users\Maison\Downloads\TeleinfoMySensors\TeleinfoMySensorsDecode.ino:69:7: warning: unused variable 'i' [-Wunused-variable]
        int i;
        C:\Users\Maison\Downloads\TeleinfoMySensors\TeleinfoMySensorsDecode.ino:65:39: warning: unused parameter 'len' [-Wunused-parameter]
        void traitement_trame(char *buff, int len)
        Le croquis utilise 9328 octets (30%) de l'espace de stockage de programmes. Le maximum est de 30720 octets.
        Les variables globales utilisent 921 octets (44%) de mémoire dynamique, ce qui laisse 1127 octets pour les variables locales. Le maximum est de 2048 octets.
        thank you
        • S secator
          hello,
          int i;
          thank you
          @secator are you getting any errors? Doesn’t look like any problems in the part that you posted.
            secator
            @secator said in 💬 MySensors Linky:
            int i;
            this messages are normal ?????
            • S secator
              int i;
              @secator maybe not normal, but definitely labelled as warnings and not errors.
                secator
                Do you use an Arduino Pro Mini 5v or 3.3V ?
                • Fumée BleueF
                  Fumée BleueF
                  Fumée Bleue
                  wrote on last edited by Fumée Bleue
                  @Secator,
                  I use an Arduino pro mini 3.3 V in order to voltage compatible with the NRF24L01
                  • Fumée BleueF
                    Fumée BleueF
                    Fumée Bleue
                    I created an 1.0.4 version without warning compilation. I removed "i" and "len" unnecessary variables.
                      secator
                      thanks for you reply Fumée Bleue.
