  3. I need some help regarding repeaters SOLVED!
4 Posts 1 Posters 1.9k Views 1 Watching
  • 5546dug5
    5546dug5
    5546dug
    wrote on last edited by 5546dug
    So the question is , I have my minipro o/s with a humidity sensor and using the standard radio, but cannot receive signal i/s home. I have enough parts to build a repeater and install it adjacent to the o/s sensor in hopes of bouncing the signal. I have not found the required info on the learning pages of My Sensors, and so need to ask the form once again what needs to be done . Guessing it needs a sketch and anything else. what would this sketch be called ?
    • 5546dug5
      5546dug5
      5546dug
      Think I found the answer in the ardunio library , once again under my sensors must have bad eyes.
      • 5546dug5
        5546dug5
        5546dug
        I have set up the repeater node called repeater 2
        I wish to have o/s humidity sensor 3 which cant see the gw to report to repeater 2.
        Using the my sensors repeater sketch on lib 1.4 ver 1.4
        Not getting any action from anything.
        If I look in the work area of repeater it indicates it is clearing childs is there a step or steps missing do I need to input more info into repeater on humidity sensor here are sceenshotsScreenshot (28).png Screenshot (27).png Screenshot (29).png
        • 5546dug5
          5546dug5
          5546dug
          just needed to make the repeater node the mother( or reporting to node ) in the humidity parmeters . In my case, change the node from a 0 to a 2. simple!
