  3. NodeManager
  4. NodeManager sensors with multiple interrupt pins
14 Posts 5 Posters 2.5k Views 4 Watching
  • j54n1nJ
    j54n1nJ
    j54n1n
    wrote on last edited by j54n1n
    https://forum.mysensors.org/topic/8936/6-8-buttons-battery-remote-node/6: These are valid and nice hardware solutions for multiple interrupts. Since I am building my node as a replacement for an old weather station I have allocated already all the analog pins of the Moteino for the other sensors. So for that reason I have still some free digital pins and I will go for the wired or solution with the diodes.
    I was more interested in a solution on the software side. For example if the team of the NodeManager library had thought of supporting more than one pulse type sensor per interrupt pin. In my case it would be the rain sensor and the wind speed sensor.
    I hope it is now more clear what I meant.
    • j54n1nJ j54n1n
      @j54n1n So, you're wanting to tie all your pulse sources to one interrupt pin and use only software to somehow differentiate among them? If the pulse durations were different you might have a chance if the pulses were guaranteed not to overlap, but what if the pulses sometimes do overlap? How would you distinguish them?
      • j54n1nJ
        j54n1nJ
        j54n1n
        Hello @NeverDie,
        Yes that is it what I want to try. Both the rain sensor and the wind sensor are reed switches and it is clear to me that I could miss a pulse since it could be masked by one of the sensors. I am trying to fiddle arround in the code of the NodeManager template without changing to much of its interrupt (INT0 & INT1) handling. And since on my Moteino board INT0 is already occupied by the RFM69 radio I have to work arround pin D3 (INT1).
        Or is it possible also to use pin change interrupts with the NodeManager sketch on batteries? A.k.a.: Can I use PCINT2_vect for port D pins (for ex.: PD4 on pin D4) that wakes up my sleeping NodeManager sketch?
          That sounds more promising than overloading a single pin.
          • j54n1nJ
            j54n1nJ
            j54n1n
            So can somebody confirm that pin change interrupts can wake up a sleeping node loaded with a NodeManager template sketch?
            I have got the impression by reading here in the forum that the ATmega328p microcontroller has problems waking up from pin change interrupts. Maybe I am wrong?
            zboblamontZ U 2 Replies Last reply
            • j54n1nJ j54n1n
              zboblamontZ
              zboblamontZ
              zboblamont
              @j54n1n If not, would a second low power non-radio board handling the two Ints (and any other expansion) be a viable option ?
                I can't think of any reason it wouldn't work. It sounds as though he has enough spare digital pins to differentiate the pulse signals. That's different from where he originally said it all needed to be processed using just a single pin without any extra hardware. The tricky part would be when a different pulse arrives on the same port just immediately prior to his clearing the interrupt. I think he could cover that case in software though by simply re-checking the digital pins after clearing the interrupt and before going to sleep.
                Of course, using pin change he'll get twice as many interrupts as compared to just using a falling/rising edge interrupt, but that's easily handled in software as well. It's not as energy efficient, so that becomes part of the trade-off. If he were willing to use diodes, then he could OR all his pulses together onto a standard interrupt pin with a pulldown resistor on it but differentiate them using the spare digital pins that he now says are available. Then you could look for interrupts on a rising edge, and you wouldn't get twice the interrupts. Given the choice, I think I would do it this way, as it would make things easy. Diodes are cheap. It's personal preference as to which approach you take, but either way should work.
                  Sasquatch
                  wrote on last edited by Sasquatch
                  @j54n1n said in NodeManager sensors with multiple interrupt pins:
                  You are wrong, i have one sitting on my bench right now sleeping and waking up on A5 pin change.
                  it's bare 328p test bead drawing mere 1uA in sleep...
                  Use sleep(0);
                  All the code you need to set things up:(tested on nano and mini boards)
                  void pciSetup(byte pin)// enables pin change for given pin
                  	*digitalPinToPCMSK(pin) |= bit (digitalPinToPCMSKbit(pin));  // enable pin
                  	PCIFR  |= bit (digitalPinToPCICRbit(pin)); // clear any outstanding interrupt
                  	PCICR  |= bit (digitalPinToPCICRbit(pin)); // enable interrupt for the group
                  void pciClear(byte pin)// disables pin change for given pin
                  	*digitalPinToPCMSK(pin) &= ~(bit (digitalPinToPCMSKbit(pin)));  // disable pin
                  	PCICR  &= ~(bit (digitalPinToPCICRbit(pin))); // disable interrupt for the group
                  ISR (PCINT0_vect)//pins d8-d13
                  ISR (PCINT1_vect)// pins a0-a7
                  ISR (PCINT2_vect)//pins d0-d7
                  If you want to get several readings and then send them to gateway(power meter pulse counting) it's better to write your own sleep function. Built in sleep(); wakes radio on every wake up.
                  :work in progress:
                  void PowerDown(void)
                    ADCSRA &= ~(1<<ADEN);//disable ADC - 120uA
                    sleep_bod_disable();//disable bod  - 15uA
                    set_sleep_mode(SLEEP_MODE_PWR_DOWN);
                    wdt_disable();
                    sleep_enable();
                    sleep_cpu();
                    sleep_disable();
                   ADCSRA |= (1<<ADEN);//enable ADC
                  then call transportDisable(); before powering down
                  and transportReInitialise(); before sending your data.
                  • j54n1nJ
                    j54n1nJ
                    j54n1n
                    Ah ok, thanks @Sasquatch
                    • j54n1nJ j54n1n
                      U
                      U
                      user2684
                      @j54n1n at this time NodeManager can only handle interrupts through the designated pins and only one type of interrupt per pin. But feel free to submit a feature request on https://github.com/mysensors/NodeManager/issues and, if you have, any piece of code which may help in the implementation. Thanks
