  3. Help: Some explanation requested regarding NACK
26 Posts 5 Posters 7.0k Views 4 Watching
    Of course not. What version of rfm69 and frequency are you using? Are you sure you got the antenna of the right size?
    • O
      O
      Omemanti
      wrote on last edited by Omemanti
      Rfm69w 868mhz , springcoil antenna from ebay.
      will test a long single wire right away.
      • O
        O
        Omemanti
        Springcoil on the gw, straight line on the node, still the same
        • O
          O
          Omemanti
          Thnx for the help so far, Ill let it rest for a while, Im thinking of rebuilding the whole thing..
          K 1 Reply Last reply
          • O Omemanti
            K
            K
            kiesel
            @Omemanti
            Where you able to solve this? I am also experiencing a lot of NACKs in my rfm69 network (868mhz)
            O 1 Reply Last reply
            • K kiesel
              @Omemanti
              O
              O
              Omemanti
              @kiesel said in Help: Some explanation requested regarding NACK:
              Nope, not that I can remember.
              BTW: I ditched the rfm69 and moved over to the NRF52.
              R 1 Reply Last reply
              • O Omemanti
                R
                R
                ricmail85
                @Omemanti
                I had exactly the same issue with Rfm69 and latest version of mysensors. The only solution I found is to use the 2.2.0 version. With this everything works perfectly.
                I don't know why with latest releases the messages are NACK even if they actually reach the gateway.
                • R ricmail85
                  @Omemanti
                  K
                  K
                  kiesel
                  @ricmail85 I solved my problem by soldering a cable to the reset pin of the chip and the (in my case) raspberry pi. This or the dupont wires I used were glitchy :D
                  • K kiesel
                    R
                    R
                    ricmail85
                    @kiesel thanks for reporting! I've also a Raspberry gateway but I left the Rfm69 reset pin unconnected. How did you connect it?
                    • R ricmail85
                      K
                      K
                      kiesel
                      wrote on last edited by kiesel
                      #26
                      @ricmail85 sorry for the late reply. I soldered it to a free pin on the pi and reconfigured the gateway.
                      Use this as part of your configure
                      --extra-cxxflags="-DMY_RFM69_RST_PIN=29"
                      If you connected to pi pin 29.
