  3. Help: Some explanation requested regarding NACK
26 Posts 5 Posters 7.0k Views 4 Watching
  • O
    O
    Omemanti
    How can I change the channel? Can you point me in the right direction.?
      Go in myconfig.h and search for "channel", you should find it in the nrf24 section, change the default channel there and recompile all your nodes and gateway
      • O
        O
        Omemanti
        Stupid question.. because I use the rfm69. Will the also comply?
          Of course not. What version of rfm69 and frequency are you using? Are you sure you got the antenna of the right size?
          • O
            O
            Omemanti
            wrote on last edited by Omemanti
            Rfm69w 868mhz , springcoil antenna from ebay.
            will test a long single wire right away.
            • O
              O
              Omemanti
              Springcoil on the gw, straight line on the node, still the same
              • O
                O
                Omemanti
                Thnx for the help so far, Ill let it rest for a while, Im thinking of rebuilding the whole thing..
                K 1 Reply Last reply
                • O Omemanti
                  K
                  K
                  kiesel
                  @Omemanti
                  Where you able to solve this? I am also experiencing a lot of NACKs in my rfm69 network (868mhz)
                  O 1 Reply Last reply
                  • K kiesel
                    @Omemanti
                    O
                    O
                    Omemanti
                    @kiesel said in Help: Some explanation requested regarding NACK:
                    Nope, not that I can remember.
                    BTW: I ditched the rfm69 and moved over to the NRF52.
                    R 1 Reply Last reply
                    • O Omemanti
                      R
                      R
                      ricmail85
                      @Omemanti
                      I had exactly the same issue with Rfm69 and latest version of mysensors. The only solution I found is to use the 2.2.0 version. With this everything works perfectly.
                      I don't know why with latest releases the messages are NACK even if they actually reach the gateway.
                      • R ricmail85
                        @Omemanti
                        K
                        K
                        kiesel
                        @ricmail85 I solved my problem by soldering a cable to the reset pin of the chip and the (in my case) raspberry pi. This or the dupont wires I used were glitchy :D
                        • K kiesel
                          R
                          R
                          ricmail85
                          @kiesel thanks for reporting! I've also a Raspberry gateway but I left the Rfm69 reset pin unconnected. How did you connect it?
                          • R ricmail85
                            K
                            K
                            kiesel
                            wrote on last edited by kiesel
                            #26
                            @ricmail85 sorry for the late reply. I soldered it to a free pin on the pi and reconfigured the gateway.
                            Use this as part of your configure
                            --extra-cxxflags="-DMY_RFM69_RST_PIN=29"
                            If you connected to pi pin 29.
