  3. Home Assistant
  4. 2nd sensor in sketch not showing up in HA
5 Posts 4 Posters 621 Views 4 Watching
  • M Offline
    M Offline
    mrhutchinsonmn
    wrote on last edited by mrhutchinsonmn
    I am trying to modify my working moisture sensor sketch to present 2 child Ids instead of one. Arduino serial monitor shows the data from both sensors and HA sees it but the 2nd sensor does not show up in unused entities. I am confident I am erring in my sketch somehow but not sure where.
      AnalogReadSerial
      Reads an analog input on pin 0, prints the result to the Serial Monitor.
      Graphical representation is available using Serial Plotter (Tools > Serial Plotter menu).
      Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
      This example code is in the public domain.
      http://www.arduino.cc/en/Tutorial/AnalogReadSerial
    // Enable debug prints
    // #define MY_DEBUG
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define CHILD_ID_A0 0
    #define CHILD_ID_A1 1
    MyMessage msg(CHILD_ID_A0, V_LEVEL);
    MyMessage msg2(CHILD_ID_A1, V_LEVEL);
    // the setup routine runs once when you press reset:
      // initialize serial communication at 9600 bits per second:
      Serial.begin(9600);
      sendSketchInfo("Analog Soil Moisture Sensor", "1c.0");
      present(CHILD_ID_A0, S_MOISTURE);
      present(CHILD_ID_A1, S_MOISTURE);
    // the loop routine runs over and over again forever:
      // read the input on analog pin 0:
      int sensorValue = analogRead(A0);
      int sensorValueA1 = analogRead(A1);
      // print out the value you read:
      Serial.println(sensorValue);
      Serial.println(sensorValueA1);
      send(msg.set(sensorValue));
      send(msg.set(sensorValueA1));
      delay(10000);        // delay in between reads for stability
    HA logs:
    2020-03-16 15:56:04 WARNING (MainThread) [mysensors.sensor] child_id 0 already exists in children of node 105, cannot add child
    2020-03-16 15:56:04 WARNING (MainThread) [mysensors.sensor] child_id 1 already exists in children of node 105, cannot add child
    electrikE BearWithBeardB 2 Replies Last reply
    • M mrhutchinsonmn
        AnalogReadSerial
      // #define MY_DEBUG
        Serial.begin(9600);
      HA logs:
      electrikE Offline
      electrikE Offline
      electrik
      @mrhutchinsonmn I think the error indicates the child already exist, so you could try to change the node id, or modify the persistence file manually:
      https://forum.mysensors.org/topic/10901/manual-adjust-the-persistence-file-instead-of-adjust-the-node-s/3
      • M mrhutchinsonmn
          AnalogReadSerial
        // #define MY_DEBUG
          Serial.begin(9600);
        HA logs:
        BearWithBeardB Offline
        BearWithBeard
        @mrhutchinsonmn said in 2nd sensor in sketch not showing up in HA:
        You are sending both sensor values with the same message, so they both get reported to child ID 0 and child ID 1 will never show up.
        Change the second send function from
        to
        send(msg2.set(sensorValueA1));
        skywatchS M 2 Replies Last reply
        • BearWithBeardB BearWithBeard
          to
          skywatchS Offline
          skywatchS Offline
          skywatch
          @BearWithBeard You beat me to it by a minute! ;)
            to
            M Offline
            M Offline
            mrhutchinsonmn
            @BearWithBeard said in 2nd sensor in sketch not showing up in HA:
            Yes, that was it!! Thank you!!
