  3. Pro Mini + RFM95 and two ISR-watched buttons possible?
16 Posts 4 Posters 1.8k Views 4 Watching
  • J
    J
    Joost
    Thanks very much! Will start looking into this now!
    • J
      J
      Joost
      Hi everybody,
      thanks for you help, I got as far as this:
      #include <Arduino.h>
      #include <avr/interrupt.h>
      #define MY_RADIO_RFM95
      volatile int value = 1000;
      volatile char PinRegLast, ChangedPin, PinRegister;
      volatile unsigned long last_debounce_time=0;
      noInterrupts();
      PCICR |= 0b00000011; // Enables Ports B and C Pin Change Interrupts
      PCMSK1 |= 0b00000110; //PCINT9 & PCINT10 = A1 & A2
      PCMSK1 |= 0b00001000; // PCINT11
      PCIFR  = B00000001; // Reset Interruptflag
      interrupts();
      pinMode(A1, INPUT_PULLUP); pinMode(A2, INPUT_PULLUP);
      Serial.begin(38400);
      void presentation() {}
        //_wokeUpByInterrupt = INVALID_INTERRUPT_NUM;
        Serial.print(value); Serial.print(" : ");Serial.println(PinRegister, BIN);
        sleep(160000);
      ISR(PCINT1_vect)
        if ( (long) millis() - last_debounce_time > 30)
          //_wokeUpByInterrupt = 0xFE;
          PinRegister = PINC;
          ChangedPin = PinRegister ^ PinRegLast;
          PinRegLast = PinRegister;
          switch (ChangedPin){
          case (1 << PINC1):
            if (~PinRegister & (1 << PINC1)) value++;
          case (1 << PINC2):
            if (~PinRegister & (1 << PINC2)) value--;
          default:
          last_debounce_time = millis();
      When I have this code without the MySensors parts (e.g. #inclue MySensors.h & sleep(..)) in it running, it kind of works plus/minus some debouncing issues. But when including MySensors and sleeping in loop(), there is rarely a reaction to pin changes and at no time a change of the variable "value", which is working without the MySensors bits in there.
      Is there something special to deal with when using sleep() together with PinChangeInterrupts?
      • J Joost
        Hi everybody,
        noInterrupts();
        interrupts();
          sleep(160000);
        ISR(PCINT1_vect)
            PinRegister = PINC;
            case (1 << PINC1):
            case (1 << PINC2):
            default:
        @Joost I think you need to use a custom sleep command, like at https://github.com/rikki78/MySensors/blob/master/WallRemote/WallRemote.ino#L142
        J 1 Reply Last reply
          J
          J
          Joost
          @mfalkvidd Thanks, will try that.
          TBH I had seen that already in there, but hoped it would not be needed anymore (since that sketch is from 2016).
          Would I need to power down my RFM95 radio like it is done with the NRF24?
          Don't want to loose my 9microAmp sleeping current :-)
          Will get back with results tomorrow,
          Joost
          • J Joost
            Joost
            @Joost yes you would need to power down the rfm95 to get low sleeping current. I think the radio will need to be reinitialized when it is powered on again but I have no experience working on this low level.
            • BearWithBeardB
              BearWithBeardB
              BearWithBeard
              A good while ago I have experimented with a multi (touch) button node which used both external and pin change interrupts and did not need to use a custom sleep function. Here is the relevant excerpt of the latest sketch which I used. As far as I remember, it was working fine.
              Note that I was using a NRF24 radio. I'm not familiar with the RFM95, but I don't think that should be a problem. (Is the IRQ pin even needed for a regular sensor node?)
              #define MY_RADIO_RF24
              [ other MySensors stuff ]
              void sense()
                  // Handle interrupt
              ISR(PCINT2_vect)
                  // Handle interrupt
              setup ()
                  pinMode(2, INPUT);
                  pinMode(3, INPUT);
                  pinMode(4, INPUT);
                  cli();
                  PCICR |= 0b00000100; // Port D
                  PCMSK2 |= 0b00010000; // PCINT20 (D4)
                  sei();
                  attachInterrupt(0, sense, RISING); // (D2)
                  attachInterrupt(1, sense, RISING); // (D3)
                  // Do stuff, send messages
                  sleep(0);
                J
                J
                Joost
                @mfalkvidd Will look into this tonight or tomorrow; just as a quick note for me and potentially others:
                Just found this thread with a very professional looking sketch by the author which seems a solid base to start upon:
                https://forum.mysensors.org/topic/5704/rfm95-sleep-mode/6
                Seemingly important parts from the sketch ( https://github.com/trlafleur/Soil_Moisture_Sensor_MS_R1.1-RFM95/blob/master/Soil_Moisture_Sensor_MS_R1.1-RFM95.ino ) :
                void systemSleep()
                    debug1(PSTR("\n*** Going to Sleep ***\n"));
                    wait (100);
                    // put led's, radio and flash to sleep
                    // Turn off LED's
                    pinMode (MY_DEFAULT_TX_LED_PIN, INPUT);
                    pinMode (MY_DEFAULT_RX_LED_PIN, INPUT);
                    pinMode (MY_DEFAULT_ERR_LED_PIN, INPUT);
                    pinMode (OnBoardLed, INPUT);
                    // Put Flash to sleep
                    // Put Radio and transport to Sleep
                    transportPowerDown();               // Shut down radio and MySensor transport
                    interrupts();                       // make sure interrupts are on...
                    LowPower.standby();                 // SAMD sleep from LowPower systems
                       //  .... we will wake up from sleeping here if triggered from an interrupt
                /* **************** System Wake-up from Sleep ******************* */
                void systemWakeUp()
                //  re enable LED's if needed
                //    pinMode (MY_DEFAULT_TX_LED_PIN, OUTPUT);
                //    pinMode (MY_DEFAULT_RX_LED_PIN, OUTPUT);
                //    pinMode (MY_DEFAULT_ERR_LED_PIN, OUTPUT);
                //    pinMode (OnBoardLed, OUTPUT);
                    // wake up Flash if needed
                    // wake up MySensor transport and Radio from Sleep
                    //transportInit();
                    hwSleep(1);                         // as MySensor had NO sleep or Watch Dog for SAMD, this will
                                                        // wake us up so that we can send and receive messages
                    while (!isTransportReady()) {       // Make sure transport is ready
                    _process(); }
                • BearWithBeardB BearWithBeard
                  void sense()
                      // Handle interrupt
                  ISR(PCINT2_vect)
                      // Handle interrupt
                  setup ()
                      pinMode(2, INPUT);
                      pinMode(3, INPUT);
                      pinMode(4, INPUT);
                      cli();
                      sei();
                      sleep(0);
                  J
                  J
                  Joost
                  @BearWithBeard Thanks; will look into this as well.
                  Seems to me that the main difference is your sleep(0) vs. my sleep(16000), but who knows, perhaps that makes a difference. Btw, I believe Pin2 with the attached IRQ is obligatory for RFM95 radios (at least it's the default in MySensors, and I designed my PCB according to this).
                  • J
                    J
                    Joost
                    Well, seems MySensors and the Low-Power lib in its latest revisions don't play nice together, bummer...
                    Getting
                    Compiling .pio/build/pro8MHzatmega328/src/main.cpp.o
                    Linking .pio/build/pro8MHzatmega328/firmware.elf
                    LowPower.cpp.o (symbol from plugin): In function `LowPowerClass::idle(period_t, adc_t, timer2_t, timer1_t, timer0_t, spi_t, usart0_t, twi_t)':
                    (.text+0x0): multiple definition of `__vector_6'
                    .pio/build/pro8MHzatmega328/src/main.cpp.o (symbol from plugin):(.text+0x0): first defined here
                    collect2: error: ld returned 1 exit status
                    *** [.pio/build/pro8MHzatmega328/firmware.elf] Error 1
                    and it looks like I'm not the only one: :confused:
                    Github issue
                    electrikE 1 Reply Last reply
                    • J Joost
                      Getting
                      Github issue
                      electrikE
                      electrikE
                      electrik
                      @Joost I've used mysensors V2 I believe...
                      • J
                        J
                        Joost
                        wrote on last edited by Joost
                        *** Edit: sorry, all below seems to be wrong / misuse of sleep(); see end of linked thread from 2017
                        Some news: I found this comment https://forum.mysensors.org/post/56372 by @DavidZH who possibly described what I seem to be seeing as well (no wakeups via PinChangeInterrupt when using MySensors sleep() function as posted above) and who also posted a workaround (thanks David for posting this in 2017!!):
                        sleep(0xff,0x00, 0xff, 0x00, 0);
                        Quote: "...As soon as I change any of the parameters, the node will not wake up anymore...."
                        Now indeed my node can be woken via PinChangeInterrupts on Pin A1 and A2 and is down to some unbelievable 1microAmp in between (by means of a cheap Multimeter) with no radio/transport initialization so far.
                        So, with just preliminary testing so far this might be the solution (did not check radio transmission after interrupts for now).
                        Could someone shed some light on what these parameters do to the sleep function? Looked here of course https://www.mysensors.org/download/sensor_api_20#sleeping but couldn't make sense out of 0xFF, 0x00 .
                        Thanks everyone,
                        Joost
                        ********************** End of edit
                        • J
                          J
                          Joost
                          PS: one downside will probably be not being able to wake up programmatically and double the node as a e.g. temperature / climate sensor, as I had in mind.
                          Sorry for the confusion above, too little sleep in the last days (at least I hope that explains it :-) )
                          Perhaps @Yveaux can help here on how to combine pin change interrupts and timer wake into a successful sleep() command? So far it looks like that would be possible with Low-Power lib, but this is not compiling in conjunction with MySensors 2.3.2.
