  3. [Newbie] Little push in right direction (24nrf to MQTT Broker)
13 Posts 3 Posters 963 Views 3 Watching
  • M Offline
    M Offline
    myrandow
    Hi everyone,
    the recent situation gave me some time to go for mysensors. My plan was to hook up my Arduino Uno to the 2,4GHz 24nrf device and push sensor information to a MQTT Broker with same host as my Home-Assistant configuration.
    The ensemble:
    • Arduino Uni: 24nrf + PIR Sensor AM312
    • ESP8266: MQTT Broker Client
    • Host: MQTT Eclipse (Docker)
    I started with the ESP8266 and hooked up the 24nrf radio according to this site (https://www.mysensors.org/build/connect_radio). Once done I prepared my Arduino IDE according here (https://www.mysensors.org/build/esp8266_gateway). Then I fired up the MQTT Broker with docker via eclipse-mosquitto. Changing the mysensor example sketch "GatewayESP8266MQTTClient" to point to the right MQTT Broker. I am using the original MQTT Client sketch except change Wifi password and #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 52. The log of the MQTT Broker seems to accept the wifi connection of the ESP8266:
    1586628140: New client connected from 192.168.1.227 as mysensors-1 (p2, c1, k15).
    1586628567: Client mysensors-1 has exceeded timeout, disconnecting.
    1586628576: New connection from 192.168.1.227 on port 1883.
    1586628576: New client connected from 192.168.1.227 as mysensors-1 (p2, c1, k15).
    1586628703: Client mysensors-1 has exceeded timeout, disconnecting.
    1586628776: New connection from 192.168.1.227 on port 1883.
    1586628776: New client connected from 192.168.1.227 as mysensors-1 (p2, c1, k15).
    1586628904: Client mysensors-1 has exceeded timeout, disconnecting.
    The Problem - 2,4 radio not working?
    Since the MQTT "Bridge" seems to work I wanted to hook up the Arduino Uni with radio and a simple PIR sensor. I followed those instructions here (https://www.mysensors.org/build/motion) as well as for the radio above. At this stage it looked like this: IMG_0144.jpg
    I used for the PIR sketch the example library again and used PIN3 as digital input. Running the Serial Monitor on the Arduino I got some hints only in debug mode (commenting out #define MY_DEBUG):
     __  __       ____
            |___/                      2.3.2
    16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=16,REL=255,VER=2.3.2
    26 TSM:INIT
    28 TSF:WUR:MS=0
    34 TSM:INIT:TSP OK
    36 TSM:FPAR
    38 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    739 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    744 TSF:MSG:FPAR OK,ID=0,D=1
    2048 TSM:FPAR:OK
    2049 TSM:ID
    2050 TSM:ID:REQ
    2053 TSF:MSG:SEND,255-255-0-0,s=2,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    4060 TSM:ID
    4061 TSM:ID:REQ
    4063 TSF:MSG:SEND,255-255-0-0,s=221,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    6071 TSM:ID
    6072 TSM:ID:REQ
    6074 TSF:MSG:SEND,255-255-0-0,s=184,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    It looks like it is sending something to the radio gateway. So then I checked on the MQTTBroker/Client on the ESP8266 what was received.
    connected with Rally-O, channel 6
    dhcp client start...
    ip:192.168.1.227,mask:255.255.255.0,gw:192.168.1.1
    8077 GWT:TPC:IP=192.168.1.227
    8161 GWT:RMQ:CONNECTING...
    8202 GWT:RMQ:OK
    8220 GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
    pm open,type:2 0
    31149 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    31211 TSF:MSG:BC
    31229 TSF:MSG:FPAR REQ,ID=255
    31260 TSF:PNG:SEND,TO=0
    31285 TSF:CKU:OK
    31303 TSF:MSG:GWL OK
    31933 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    33162 TSF:MSG:READ,255-255-0,s=97,c=3,t=3,pt=0,l=0,sg=0:
    33222 GWT:TPS:TOPIC=mygateway1-out/255/97/3/0/3,MSG SENT
    35173 TSF:MSG:READ,255-255-0,s=60,c=3,t=3,pt=0,l=0,sg=0:
    35233 GWT:TPS:TOPIC=mygateway1-out/255/60/3/0/3,MSG SENT
    37184 TSF:MSG:READ,255-255-0,s=23,c=3,t=3,pt=0,l=0,sg=0:
    37244 GWT:TPS:TOPIC=mygateway1-out/255/23/3/0/3,MSG SENT
    39195 TSF:MSG:READ,255-255-0,s=242,c=3,t=3,pt=0,l=0,sg=0:
    39256 GWT:TPS:TOPIC=mygateway1-out/255/242/3/0/3,MSG SENT
    Okay looks like something was sent to mygateway1. Looking into the MQTT Server there is simply one log entry:
    1586634694: New connection from 192.168.1.227 on port 1883.
    1586634694: New client connected from 192.168.1.227 as mysensors-1 (p2, c1, k15)%
    Is there any problem with my radio? What am I missing to get PIR sensor state to the MQTT publish? I will buy you a coffee for a successfull hand for help.
    Thank you all for keeping up this great work.
    Cheers !
    • M myrandow
      Hi everyone,
      The ensemble:
       __  __       ____
              |___/                      2.3.2
      26 TSM:INIT
      28 TSF:WUR:MS=0
      34 TSM:INIT:TSP OK
      36 TSM:FPAR
      2048 TSM:FPAR:OK
      2049 TSM:ID
      2050 TSM:ID:REQ
      4060 TSM:ID
      4061 TSM:ID:REQ
      6071 TSM:ID
      6072 TSM:ID:REQ
      8202 GWT:RMQ:OK
      pm open,type:2 0
      31211 TSF:MSG:BC
      31285 TSF:CKU:OK
      Cheers !
      Welcome to the forum @myrandow
      The log parser can be useful when looking at the logs.
      tsm:ID:REQ
      and
      mean that the node is requesting an Id from the controller (similar to dhcp if you are familiar with that). You don't seem to have a controller yet?
      Either install and configure a controller (that supports giving out ids over mqtt), or use
      #define MY_NODE_ID 42
      in the node sketch, before including MySensors.h. 42 can be any unique number between 1 and 254.
      I am not familiar with eclipse mqtt broker, but most mqtt brokers do not log all messages by default. You'll need to subscribe (using mqtt.fx or similar) to see the messages, or reconfigure the log level.
        tsm:ID:REQ
        and
        M Offline
        M Offline
        myrandow
        @mfalkvidd Great that was a fast forward! Now it seems that the ESP8266 holds a connection to the Mosquitto Gateway. For the curious reader it added to the sketch ESP8266GatewayClient as mfalkvidd said #define MY_NODE_ID 42.
        Logs of ESP8266 (irrtitating "sent without radio messages"
        5510 GWT:TPC:IP=192.168.1.227
        5594 GWT:RMQ:CONNECTING...
        5637 GWT:RMQ:OK
        5654 GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
        pm open,type:2 0
        111055 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        111118 TSF:MSG:BC
        111137 TSF:MSG:FPAR REQ,ID=255
        111170 TSF:PNG:SEND,TO=0
        111196 TSF:CKU:OK
        111214 TSF:MSG:GWL OK
        111887 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        113069 TSF:MSG:READ,255-255-0,s=2,c=3,t=3,pt=0,l=0,sg=0:
        113128 GWT:TPS:TOPIC=mygateway1-out/255/2/3/0/3,MSG SENT
        115079 TSF:MSG:READ,255-255-0,s=221,c=3,t=3,pt=0,l=0,sg=0:
        115141 GWT:TPS:TOPIC=mygateway1-out/255/221/3/0/3,MSG SENT
        117090 TSF:MSG:READ,255-255-0,s=184,c=3,t=3,pt=0,l=0,sg=0:
        117152 GWT:TPS:TOPIC=mygateway1-out/255/184/3/0/3,MSG SENT
        119101 TSF:MSG:READ,255-255-0,s=147,c=3,t=3,pt=0,l=0,sg=0:
        119162 GWT:TPS:TOPIC=mygateway1-out/255/147/3/0/3,MSG SENT
        131127 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        131191 TSF:MSG:BC
        131210 TSF:MSG:FPAR REQ,ID=255
        131242 TSF:PNG:SEND,TO=0
        131268 TSF:CKU:OK
        131287 TSF:MSG:GWL OK
        131551 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        133141 TSF:MSG:READ,255-255-0,s=108,c=3,t=3,pt=0,l=0,sg=0:
        133202 GWT:TPS:TOPIC=mygateway1-out/255/108/3/0/3,MSG SENT
        135152 TSF:MSG:READ,255-255-0,s=72,c=3,t=3,pt=0,l=0,sg=0:
        135213 GWT:TPS:TOPIC=mygateway1-out/255/72/3/0/3,MSG SENT
        137163 TSF:MSG:READ,255-255-0,s=35,c=3,t=3,pt=0,l=0,sg=0:
        137223 GWT:TPS:TOPIC=mygateway1-out/255/35/3/0/3,MSG SENT
        139174 TSF:MSG:READ,255-255-0,s=0,c=3,t=3,pt=0,l=0,sg=0:
        139234 GWT:TPS:TOPIC=mygateway1-out/255/0/3/0/3,MSG SENT
        151202 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        151266 TSF:MSG:BC
        151284 TSF:MSG:FPAR REQ,ID=255
        151317 TSF:PNG:SEND,TO=0
        151343 TSF:CKU:OK
        151362 TSF:MSG:GWL OK
        152245 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        153215 TSF:MSG:READ,255-255-0,s=219,c=3,t=3,pt=0,l=0,sg=0:
        153277 GWT:TPS:TOPIC=mygateway1-out/255/219/3/0/3,MSG SENT
        155226 TSF:MSG:READ,255-255-0,s=182,c=3,t=3,pt=0,l=0,sg=0:
        155288 GWT:TPS:TOPIC=mygateway1-out/255/182/3/0/3,MSG SENT
        157237 TSF:MSG:READ,255-255-0,s=145,c=3,t=3,pt=0,l=0,sg=0:
        157299 GWT:TPS:TOPIC=mygateway1-out/255/145/3/0/3,MSG SENT
        159248 TSF:MSG:READ,255-255-0,s=108,c=3,t=3,pt=0,l=0,sg=0:
        159310 GWT:TPS:TOPIC=mygateway1-out/255/108/3/0/3,MSG SENT
        171275 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        171338 TSF:MSG:BC
        171357 TSF:MSG:FPAR REQ,ID=255
        171389 TSF:PNG:SEND,TO=0
        171416 TSF:CKU:OK
        171434 TSF:MSG:GWL OK
        171910 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        173288 TSF:MSG:READ,255-255-0,s=70,c=3,t=3,pt=0,l=0,sg=0:
        173349 GWT:TPS:TOPIC=mygateway1-out/255/70/3/0/3,MSG SENT
        175299 TSF:MSG:READ,255-255-0,s=33,c=3,t=3,pt=0,l=0,sg=0:
        175360 GWT:TPS:TOPIC=mygateway1-out/255/33/3/0/3,MSG SENT
        177311 TSF:MSG:READ,255-255-0,s=253,c=3,t=3,pt=0,l=0,sg=0:
        177373 GWT:TPS:TOPIC=mygateway1-out/255/253/3/0/3,MSG SENT
        179322 TSF:MSG:READ,255-255-0,s=217,c=3,t=3,pt=0,l=0,sg=0:
        179384 GWT:TPS:TOPIC=mygateway1-out/255/217/3/0/3,MSG SENT
        191349 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        191413 TSF:MSG:BC
        191432 TSF:MSG:FPAR REQ,ID=255
        191464 TSF:PNG:SEND,TO=0
        191490 TSF:CKU:OK
        191509 TSF:MSG:GWL OK
        191580 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        193363 TSF:MSG:READ,255-255-0,s=179,c=3,t=3,pt=0,l=0,sg=0:
        193425 GWT:TPS:TOPIC=mygateway1-out/255/179/3/0/3,MSG SENT
        195374 TSF:MSG:READ,255-255-0,s=143,c=3,t=3,pt=0,l=0,sg=0:
        195436 GWT:TPS:TOPIC=mygateway1-out/255/143/3/0/3,MSG SENT
        197385 TSF:MSG:READ,255-255-0,s=106,c=3,t=3,pt=0,l=0,sg=0:
        197447 GWT:TPS:TOPIC=mygateway1-out/255/106/3/0/3,MSG SENT
        199396 TSF:MSG:READ,255-255-0,s=69,c=3,t=3,pt=0,l=0,sg=0:
        199457 GWT:TPS:TOPIC=mygateway1-out/255/69/3/0/3,MSG SENT
        211423 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        211486 TSF:MSG:BC
        211505 TSF:MSG:FPAR REQ,ID=255
        211538 TSF:PNG:SEND,TO=0
        211564 TSF:CKU:OK
        211583 TSF:MSG:GWL OK
        212270 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        213436 TSF:MSG:READ,255-255-0,s=31,c=3,t=3,pt=0,l=0,sg=0:
        213497 GWT:TPS:TOPIC=mygateway1-out/255/31/3/0/3,MSG SENT
        215447 TSF:MSG:READ,255-255-0,s=250,c=3,t=3,pt=0,l=0,sg=0:
        215509 GWT:TPS:TOPIC=mygateway1-out/255/250/3/0/3,MSG SENT
        217459 TSF:MSG:READ,255-255-0,s=215,c=3,t=3,pt=0,l=0,sg=0:
        217521 GWT:TPS:TOPIC=mygateway1-out/255/215/3/0/3,MSG SENT
        219470 TSF:MSG:READ,255-255-0,s=178,c=3,t=3,pt=0,l=0,sg=0:
        219532 GWT:TPS:TOPIC=mygateway1-out/255/178/3/0/3,MSG SENT
        231498 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        231561 TSF:MSG:BC
        231580 TSF:MSG:FPAR REQ,ID=255
        231613 TSF:PNG:SEND,TO=0
        231639 TSF:CKU:OK
        231657 TSF:MSG:GWL OK
        231940 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        233511 TSF:MSG:READ,255-255-0,s=141,c=3,t=3,pt=0,l=0,sg=0:
        233573 GWT:TPS:TOPIC=mygateway1-out/255/141/3/0/3,MSG SENT
        235522 TSF:MSG:READ,255-255-0,s=104,c=3,t=3,pt=0,l=0,sg=0:
        235584 GWT:TPS:TOPIC=mygateway1-out/255/104/3/0/3,MSG SENT
        237533 TSF:MSG:READ,255-255-0,s=67,c=3,t=3,pt=0,l=0,sg=0:
        237594 GWT:TPS:TOPIC=mygateway1-out/255/67/3/0/3,MSG SENT
        239544 TSF:MSG:READ,255-255-0,s=30,c=3,t=3,pt=0,l=0,sg=0:
        239605 GWT:TPS:TOPIC=mygateway1-out/255/30/3/0/3,MSG SENT
        On the Mosquitto MQTT Gateway it seems something arrives:
        │   1586673064: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/255/141/3/0/3', ... (0 bytes))                │
        │   1586673066: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/255/104/3/0/3', ... (0 bytes))                │
        │   1586673068: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/255/67/3/0/3', ... (0 bytes))                 │
        │   1586673070: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/255/30/3/0/3', ... (0 bytes))                 │
        │   1586673076: Received PINGREQ from mysensors-1        │
        │   1586673076: Sending PINGRESP to mysensors-1
        For the side note I had edited the mosquitto.conf to debug logging with log_type all and log_dest stdout.
        Is now the PIR sesnors already sucessfully pushing the sensor state to the Mosquitto Gateway or am I missing here something still?
        Thank you very much in advance for your ideas/direction.
        mfalkviddM BearWithBeardB 2 Replies Last reply
        • M myrandow
          5637 GWT:RMQ:OK
          pm open,type:2 0
          111118 TSF:MSG:BC
          111196 TSF:CKU:OK
          131191 TSF:MSG:BC
          131268 TSF:CKU:OK
          151266 TSF:MSG:BC
          151343 TSF:CKU:OK
          171338 TSF:MSG:BC
          171416 TSF:CKU:OK
          191413 TSF:MSG:BC
          191490 TSF:CKU:OK
          211486 TSF:MSG:BC
          211564 TSF:CKU:OK
          231561 TSF:MSG:BC
          231639 TSF:CKU:OK
          What does the node log say?
            M Offline
            M Offline
            myrandow
            @mfalkvidd Sorry I forget this one:
             __  __       ____
                    |___/                      2.3.2
            26 TSM:INIT
            28 TSF:WUR:MS=0
            34 TSM:INIT:TSP OK
            36 TSM:FPAR
            2048 !TSM:FPAR:NO REPLY
            2050 TSM:FPAR
            2052 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            3018 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            3023 TSF:MSG:FPAR OK,ID=0,D=1
            4060 TSM:FPAR:OK
            4061 TSM:ID
            4062 TSM:ID:REQ
            4065 TSF:MSG:SEND,255-255-0-0,s=222,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            6072 TSM:ID
            6073 TSM:ID:REQ
            6075 TSF:MSG:SEND,255-255-0-0,s=185,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            8083 TSM:ID
            8084 TSM:ID:REQ
            8086 TSF:MSG:SEND,255-255-0-0,s=148,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            10094 TSM:ID
            10095 TSM:ID:REQ
            10098 TSF:MSG:SEND,255-255-0-0,s=111,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            12105 !TSM:ID:FAIL
            12106 TSM:FAIL:CNT=1
            12108 TSM:FAIL:DIS
            12110 TSF:TDI:TSL
            22113 TSM:FAIL:RE-INIT
            22115 TSM:INIT
            22121 TSM:INIT:TSP OK
            22123 TSM:FPAR
            22126 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            22723 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            22728 TSF:MSG:FPAR OK,ID=0,D=1
            I used the following sketch https://hastebin.com/ulusefigod.cpp
            • M myrandow
              5637 GWT:RMQ:OK
              pm open,type:2 0
              111118 TSF:MSG:BC
              111196 TSF:CKU:OK
              131191 TSF:MSG:BC
              131268 TSF:CKU:OK
              151266 TSF:MSG:BC
              151343 TSF:CKU:OK
              171338 TSF:MSG:BC
              171416 TSF:CKU:OK
              191413 TSF:MSG:BC
              191490 TSF:CKU:OK
              211486 TSF:MSG:BC
              211564 TSF:CKU:OK
              231561 TSF:MSG:BC
              231639 TSF:CKU:OK
              BearWithBeardB Offline
              BearWithBeard
              wrote on last edited by BearWithBeard
              @myrandow said in [Newbie] Little push in right direction (24nrf to MQTT Broker):
              ESP8266GatewayClient is a sketch for a gateway. A gateway is unique in every MySensors network and has the ID 0. You can assign static IDs to any node but the gateway.
              When @mfalkvidd suggested to add the static node ID, he meant your sensor node on the Arduino UNO, not the ESP-Gateway. Using static IDs allows your nodes to connect to each other and the gateway even if you have no controller set up (like Home Assistant, Domoticz, WebThings,..).
              If you want the IDs to be assigned dynamically, you need a controller. Since you mentioned Home Assistant, I assume you intent to use it as a controller. Did you follow the integration guide and setup the configuration for MySensors and MQTT?
              A MQTT broker alone can't assign IDs, nor can a Home Assistant instance which is not properly configured. Think of the MQTT broker as a mailman who delivers messages from the gateway to the controller and vice versa. If the controller doesn't know where its mailbox is (it doesn't subscribe to the MQTT topics), it can't read the messages and return an answer (the ID for the new sensor node), which means that the gateway will continue to send out the sensor node's request for an ID forever and ever.
              • M Offline
                M Offline
                myrandow
                thanks for this fundamental clarification. I got it wrong. So now I changed it as mentioned:
                • Gateway/ESP8266 - no ID (as already set to 0)
                • Node/Arduino - Id set to 41 before setup() loop
                My understanding from reading the introduction is that ESP8266 is capable of working as WifiGateway to MQTT Broker. In Home-Assistant I want to use the mqtt-integration (https://www.home-assistant.io/integrations/mqtt).
                @BearWithBeard that means I got the architecture wrong? Is this setup only workable if the Gateway/ESP8266 is attached via USB to Home-Assistant?
                Just for the record I have attached the current sketch codes of the devices:
                Sketches:
                • Gateway/ESP8266: https://hastebin.com/axiralaviq.cpp
                • Node/ArduinoUno: https://hastebin.com/yexafimiqe.cpp
                Thank you very much for clarification. When dealing with it at first time it is very detailed documented but in a whole hard to get the detailed parts into living things.
                • M Offline
                  M Offline
                  myrandow
                  @BearWithBeard AWESOME ! I understood changed the sketch and it WORKS ! THANK YOU so much! I love it. I cannot express how grateful I am. I donated a coffee for you all https://imgur.com/mIAtYc9.png.
                  For others interested: I used the exact original examples without any modification. I just missed the part, that home-assistant controller is required to hand out IDs. So as BearWithBeard's graphic perfectly illustrates the approach is:
                  1. Create MQTT Broker (aka Mailman with i.e. Mosquitto)
                  2. Add (A) mysensor integration and (B) mqtt integration in Home-Assistant
                  3. Flash mysensors examples to MQTTGateway and Node
                  Done.
                  Thank you all for your help!
                  • M myrandow
                    Done.
                    Great work @myrandow Thanks for reporting back!
                    • M Offline
                      M Offline
                      myrandow
                      Hey again,
                      May I come back to my Newbie topic? I tried to creating a repeating node and wanted to attach the PIR AM312 sensor.
                      Hooked up according instructions with the following sketch I always get motion detected (v_tripped=1). Can someone help? Is the ESP8266 not suported for mysensors except as gateway?
                      Log from ESP8266 Repeater
                      31217 TSF:MSG:SEND,2-2-0-0,s=6,c=1,t=16,pt=0,l=1,sg=0,ft=1,st=OK:1
                      31223 MCO:SLP:MS=120000,SMS=0,I1=3,M1=3,I2=255,M2=255
                      31228 TSF:TDI:TSL
                      31229 MCO:SLP:WUP=-2
                      31231 TSF:TRI:TSB
                      31273 !TSF:MSG:SEND,2-2-0-0,s=6,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=NACK:1
                      31279 MCO:SLP:MS=120000,SMS=0,I1=3,M1=3,I2=255,M2=255
                      31284 TSF:TDI:TSL
                      31286 MCO:SLP:WUP=-2
                      31288 TSF:TRI:TSB
                      31330 !TSF:MSG:SEND,2-2-0-0,s=6,c=1,t=16,pt=0,l=1,sg=0,ft=1,st=NACK:1
                      31336 MCO:SLP:MS=120000,SMS=0,I1=3,M1=3,I2=255,M2=255
                      31341 TSF:TDI:TSL
                      31342 MCO:SLP:WUP=-2
                      31344 TSF:TRI:TSB
                      31352 TSF:MSG:SEND,2-2-0-0,s=6,c=1,t=16,pt=0,l=1,sg=0,ft=2,st=OK:1
                      31358 MCO:SLP:MS=120000,SMS=0,I1=3,M1=3,I2=255,M2=255
                      31363 TSF:TDI:TSL
                      31364 MCO:SLP:WUP=-2
                      31366 TSF:TRI:TSB
                      31408 !TSF:MSG:SEND,2-2-0-0,s=6,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=NACK:1
                      31414 MCO:SLP:MS=120000,SMS=0,I1=3,M1=3,I2=255,M2=255
                      31419 TSF:TDI:TSL
                      31421 MCO:SLP:WUP=-2
                      31422 TSF:TRI:TSB
                      Sketch
                       * Copyright (C) 2013-2019 Sensnology AB
                       * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
                       * Version 1.0 - Henrik Ekblad
                      // Enable Repeating Feature
                      //#define MY_REPEATER_FEATURE
                      // Enable debug prints
                      #define MY_RADIO_RF24
                      //#define MY_RADIO_NRF5_ESB
                      //#define MY_RADIO_RFM95
                      uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
                      #define CHILD_ID 6   // Id of the sensor child
                      // Initialize motion message
                      	present(CHILD_ID, S_MOTION);
                      	// Read digital motion value
                      	bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
                      	Serial.println(tripped);
                      • M myrandow
                        Hey again,
                        31228 TSF:TDI:TSL
                        31231 TSF:TRI:TSB
                        31284 TSF:TDI:TSL
                        31288 TSF:TRI:TSB
                        31341 TSF:TDI:TSL
                        31344 TSF:TRI:TSB
                        31363 TSF:TDI:TSL
                        31366 TSF:TRI:TSB
                        31419 TSF:TDI:TSL
                        31422 TSF:TRI:TSB
                        Sketch
                        @myrandow there are (at least) two things happening:
                        1. A repeater should never sleep. Because if it sleeps, it can not receive messages and therefore ceases to be a useful repeater.
                        2. esp8266 can not sleep, so all calls to sleep() will return immediately with the return value MY_SLEEP_NOT_POSSIBLE. Documentation: https://www.mysensors.org/apidocs/group__MySensorsCoregrp.html#ga4dcfb8da9716960a85d4b64b8198ecbb
                          M Offline
                          M Offline
                          myrandow
                          @mfalkvidd thank you very much for clarification. Got it. ESP82 should not sleep. How to change the code that the ESP82 can work as motion sensor and repeater at the same time? Cut out all sleep commands? Does this fix the Problem That v_tripped Is always 1? Thank you very much !
                          • M myrandow
                            @myrandow you can change the loop to something like this:
                                    static bool sentValue = false;
                                    if(tripped != sentValue){
                                        // The state of the motion sensor has changed
                                        sentValue=tripped;
                                        send(msg.set(sentValue?"1":"0"));  // Send tripped value to gw
                            If you want the sensor to send updates every 2 minutes even if the state has not changed, you'll need to add some additional logic.
