  3. [Solved] Arduino Nanos don't work as nodes
37 Posts 6 Posters 2.8k Views 5 Watching
  • A Offline
    A Offline
    Avamander
    wrote on last edited by tekka
    My issue is rather simple, no matter what I do, Arduino Nano nodes are unable to act as nodes.
    I have a working pair of an Arduino Nano based GW and an Arduino Mega 2560 based node.
    I have:
    • Switched the radios between the nodes, the same radios that work on the GW and the Mega work on each other.
    • Tried PA+LNA and two different regular nRF24 boards (no, not the COB ones)
    • Built three new boards to plug the radio and the Nano into -
    • Tried 1uF, 10uF and 470uF decoupling all separately
    • Tried both with and without MY_PARENT_NODE_ID and MY_PARENT_NODE_IS_STATIC
    • Tried with and without MY_TRANSPORT_WAIT_READY_MS
    • I wiped the EEPROM of all the devices
    • Tried an external 3.3V regulator
    • With both the old and new Nano bootloader
    • Multiple Nano boards
    • Downloaded newer Arduino IDE and newest MySensors
    • Switched channel and tried different power levels
    But the node still either outputs:
    16 MCO:BGN:INIT REPEATER,CP=RNNRA---,FQ=16,REL=255,VER=2.3.2
    27 TSM:INIT
    28 TSF:WUR:MS=0
    34 TSM:INIT:TSP OK
    36 TSM:INIT:STATID=1
    38 TSF:SID:OK,ID=1
    40 TSM:FPAR
    45 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2052 !TSM:FPAR:NO REPLY
    2054 TSM:FPAR
    2058 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4065 !TSM:FPAR:NO REPLY
    4067 TSM:FPAR
    4071 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6078 !TSM:FPAR:NO REPLY
    6080 TSM:FPAR
    6084 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8091 !TSM:FPAR:FAIL
    8092 TSM:FAIL:CNT=1
    8094 TSM:FAIL:DIS
    8096 TSF:TDI:TSL
    18098 TSM:FAIL:RE-INIT
    18100 TSM:INIT
    18106 TSM:INIT:TSP OK
    18108 TSM:INIT:STATID=1
    18111 TSF:SID:OK,ID=1
    18113 TSM:FPAR
    18117 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20124 !TSM:FPAR:NO REPLY
    20126 TSM:FPAR
    or with MY_TRANSPORT_WAIT_READY_MS:
    16 MCO:BGN:INIT REPEATER,CP=RNNRAS--,FQ=16,REL=255,VER=2.3.2
    54 TSM:INIT
    58 TSF:WUR:MS=1
    64 TSM:INIT:TSP OK
    66 TSM:INIT:STATID=1
    68 TSF:SID:OK,ID=1
    69 TSM:FPAR
    70 TSM:FPAR:STATP=0
    72 MCO:BGN:INIT OK,TSP=0
    74 TSM:ID
    Sensor: 17
    76 !MCO:SND:NODE NOT REG
    79 MCO:SLP:MS=500,SMS=0,I1=255,M1=255,I2=255,M2=255
    84 !MCO:SLP:REP
    86 TSM:ID:OK
    87 TSM:UPL
    123 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    Sensor: 34
    586 !MCO:SND:NODE NOT REG
    589 MCO:SLP:MS=500,SMS=0,I1=255,M1=255,I2=255,M2=255
    594 !MCO:SLP:REP
    Node code:
    #define MY_REPEATER_FEATURE
    #define MY_TRANSPORT_SANITY_CHECK
    #define MY_SIGNAL_REPORT_ENABLED
    #define MY_RF24_CE_PIN     9
    #define MY_RF24_CS_PIN     10
    #define MY_RF24_CHANNEL   29
    #define RF24_DATARATE      RF24_2MBPS
    #define RF24_PA_LEVEL      RF24_PA_MIN
    #define RF24_PA_LEVEL_GW   RF24_PA_MIN
    #define MY_NODE_ID         1
    #define MY_PARENT_NODE_ID  0
    #define MY_TRANSPORT_WAIT_READY_MS 1
    uint32_t SLEEP_TIME = 500; // Sleep time between reads (in milliseconds)
    MyMessage msg(0, V_LIGHT_LEVEL);
      pinMode(A7, INPUT);
      sendSketchInfo("Basicsensor 1", "0.1");
      delay(10);
      present(0, S_LIGHT_LEVEL, F("Light level sensor"), true);
    uint16_t lightLevel = 0;
    uint16_t lastLightLevel = 0;
      lightLevel = analogRead(A7);
        Serial.print("Sensor: ");
        Serial.println(lightLevel);
        send(msg.setSensor(0).setType(V_LIGHT_LEVEL).set(lightLevel));
        lastLightLevel = lightLevel;
      sleep(SLEEP_TIME);
    I now suspect there's a bug somewhere in MySensors introduced by some newer version affecting Arduino Nanos. Because I remember MySensors working on Nanos a while ago.
    Maybe someone here has some ideas how to narrow the issue down?
    • alowhumA Offline
      alowhumA Offline
      alowhum
      I created a new gateway on an Arduino Nano today, and that worked. Not sure if that was using the very latest MySensors though. The rest of my network is all based on the RF-Nano, which I'm a big fan of. It shields me from exactly these types of issues :-)
      How are you powering them?
      The Nano itself runs on 5v, but I suspect you know that.
      Have you tried enabling the advanced radio debug option? (I forget it's name). That can magicaly enable things sometimes. At the very least it will tell you more about what's going on.
      Are you sure there's nothing like encrpytion on the gateway?
      Have you tried replacing all the wires between the nano and the radio module?
      I recommend just buying the Arduino Nano Wireless Expansion Board. They cost a dollar on Aliexpress.
      Maybe you have some of those fake Atmel chips?
      • alowhumA Offline
        alowhumA Offline
        alowhum
        pinMode(A7, INPUT); should not be in presentation. It should be in setup. Similarly, don't put Serial.begin(115200); in there. All that should be in presentation function is sendSketchInfo and present.
        Also, don't use "delay", use wait() instead.
        And where is your setup function in the first place?
        • alowhumA Offline
          alowhumA Offline
          alowhum
          Also, your code never loads MySensors? It's commented out?
          Your node code is very strange.
          A 1 Reply Last reply
          • A Offline
            A Offline
            Avamander
            @alowhum said in Arduino Nanos don't work as nodes:
            USB, tried a wall-wart and two different PCs.
            Yes, it's the default gateway sketch, except configured to use the right channel, data rate and nRF24.
            Yeah, I have multiple boards, some years old and have worked with other nRF24 projects. Plus, any wiring changes actually break it for things such as RF24.
            I'll look into that.
            Three of them bought at different times, and the only issues are with MySensor? :P Seems unlikely.
            • alowhumA alowhum
              A Offline
              A Offline
              Avamander
              Um, line 22 #include <MySensors.h>
              It was of the examples, barely modified.
              • alowhumA Offline
                alowhumA Offline
                alowhum
                @Avamander said in Arduino Nanos don't work as nodes:
                Ah, you're right. Have been programming in other languages lately, where that indicates a comment.
                • alowhumA Offline
                  alowhumA Offline
                  alowhum
                  Is there a reason you're swapping your CE and CS pins?
                  • alowhumA alowhum
                    A Offline
                    A Offline
                    Avamander
                    Because they're wired that way and it doesn't/shouldn't matter.
                    • alowhumA Offline
                      alowhumA Offline
                      alowhum
                      What happens if you remove everything but the essentials for your network here?
                      Maybe only leave #define MY_RF24_CHANNEL 29?
                      • alowhumA Offline
                        alowhumA Offline
                        alowhum
                        Look for something like MY_DEBUG_VERBOSE_NRF24 - something along those lines, for that debug option I mentioned.
                        • alowhumA alowhum
                          A Offline
                          A Offline
                          Avamander
                          @alowhum
                          #define MY_DEBUG_VERBOSE_RF24
                          16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=16,REL=255,VER=2.3.2
                          26 TSM:INIT
                          28 TSF:WUR:MS=0
                          29 RF24:INIT:PIN,CE=9,CS=10
                          31 RF24:SBY
                          32 RF24:WBR:REG=0,VAL=14
                          39 RF24:WBR:REG=3,VAL=3
                          41 RF24:WBR:REG=4,VAL=95
                          44 RF24:WBR:REG=5,VAL=29
                          47 RF24:WBR:REG=6,VAL=37
                          49 RF24:WBR:REG=29,VAL=4
                          51 RF24:RBR:REG=29,VAL=4
                          53 RF24:RBR:REG=6,VAL=37
                          55 RF24:RBR:REG=5,VAL=29
                          58 RF24:WBR:REG=2,VAL=2
                          60 RF24:WBR:REG=1,VAL=0
                          62 RF24:WBR:REG=28,VAL=3
                          64 RF24:FRX
                          65 RF24:FTX
                          66 RF24:WBR:REG=7,VAL=112
                          69 TSM:INIT:TSP OK
                          70 TSM:INIT:STATID=1
                          72 RF24:WBR:REG=2,VAL=3
                          74 RF24:WBR:REG=1,VAL=1
                          76 RF24:STL
                          78 RF24:WBR:REG=0,VAL=15
                          80 RF24:WBR:REG=10,VAL=1
                          82 TSF:SID:OK,ID=1
                          84 TSM:FPAR
                          86 RF24:SPL
                          87 RF24:WBR:REG=0,VAL=14
                          89 RF24:OWP:RCPT=255
                          91 RF24:WBR:REG=10,VAL=255
                          93 RF24:WBR:REG=16,VAL=255
                          96 RF24:TXM:TO=255,LEN=7
                          98 RF24:FTX
                          99 RF24:WBR:REG=4,VAL=80
                          103 RF24:WBR:REG=7,VAL=112
                          106 ?RF24:TXM:MAX_RT
                          108 RF24:FTX
                          109 RF24:WBR:REG=4,VAL=95
                          111 RF24:STL
                          113 RF24:WBR:REG=0,VAL=15
                          115 RF24:WBR:REG=10,VAL=1
                          2125 !TSM:FPAR:NO REPLY
                          2127 TSM:FPAR
                          2128 RF24:SPL
                          2130 RF24:WBR:REG=0,VAL=14
                          2132 RF24:OWP:RCPT=255
                          2135 RF24:WBR:REG=10,VAL=255
                          2138 RF24:WBR:REG=16,VAL=255
                          2140 RF24:TXM:TO=255,LEN=7
                          2143 RF24:FTX
                          2144 RF24:WBR:REG=4,VAL=80
                          2149 RF24:WBR:REG=7,VAL=112
                          2151 ?RF24:TXM:MAX_RT
                          2153 RF24:FTX
                          2155 RF24:WBR:REG=4,VAL=95
                          2157 RF24:STL
                          2158 RF24:WBR:REG=0,VAL=15
                          2161 RF24:WBR:REG=10,VAL=1
                          2163 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          4171 !TSM:FPAR:NO REPLY
                          4173 TSM:FPAR
                          4174 RF24:SPL
                          4175 RF24:WBR:REG=0,VAL=14
                          4178 RF24:OWP:RCPT=255
                          4180 RF24:WBR:REG=10,VAL=255
                          4184 RF24:WBR:REG=16,VAL=255
                          4186 RF24:TXM:TO=255,LEN=7
                          4189 RF24:FTX
                          4190 RF24:WBR:REG=4,VAL=80
                          4195 RF24:WBR:REG=7,VAL=112
                          4197 ?RF24:TXM:MAX_RT
                          4199 RF24:FTX
                          4201 RF24:WBR:REG=4,VAL=95
                          4203 RF24:STL
                          4204 RF24:WBR:REG=0,VAL=15
                          4207 RF24:WBR:REG=10,VAL=1
                          4209 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          6217 !TSM:FPAR:NO REPLY
                          Still no reply.
                          • N Offline
                            N Offline
                            niclas
                            wrote on last edited by niclas
                            I'm not super experienced using mysensors but I do have 3 nodes working and when first settings things up I had some problems with NODE IDs. It looks like you are setting a Static node Id? Is that ID "free" in the gateway? Have you tried powering of all the nodes you have running, wiping the EEPROM of the gateway, powering up the gateway and shortly after powering up the node?
                            Someone else perhaps knows this better but, if the gateway don't want to include the node, does that generate the FPAR:No reply?
                            And also, how is the interrupt pin connected?
                            A 2 Replies Last reply
                            • electrikE Offline
                              electrikE Offline
                              electrik
                              I use Arduinos all the time and have problem with them.
                              I suggest to start with one of the examples.
                              The RF channel is the same everywhere I guess?
                              What does the output on the gateway say?
                              • N niclas
                                A Offline
                                A Offline
                                Avamander
                                @niclas
                                Yes, there are no other nodes (other than the one with a different static node ID that works)
                                Yes.
                                Yes, I've wiped EEPROMs of all the nodes.
                                N 1 Reply Last reply
                                • A Avamander
                                  @niclas
                                  Yes.
                                  N Offline
                                  N Offline
                                  niclas
                                  @Avamander I meant, have you erased the EEPROM of the gateway?
                                  • N niclas
                                    A Offline
                                    A Offline
                                    Avamander
                                    wrote on last edited by Avamander
                                    @niclas
                                    Yes, that too.
                                    The radio's IRQ pin is not connected. (The IRQ pin is only required to be connected if the MY_RX_MESSAGE_BUFFER_FEATURE is defined in the sketch.)
                                    • A Avamander
                                      @niclas
                                      Yes, that too.
                                      N Offline
                                      N Offline
                                      niclas
                                      @Avamander Regarding the interrupt pin, at least when using the RFM95 I need to have the pin connected to be able to receive anything. It doesnt poll the module to check for incoming messages. Maybe its different with nRF24.
                                      I haven't tried messing with the MY_RX_MESSAGE_BUFFER_FEATURE so I wouldnt know about that.
                                      • A Offline
                                        A Offline
                                        Avamander
                                        @niclas
                                        Well, the documentation says I don't have to have it connected.
                                        @electrik
                                        The gateway and node both are examples with the minimal required changes.
                                        Yes.
                                        Nothing, totally silent. When I plug in the Mega node, then it starts outputting all the sensor and other data.
                                        Anyways, the weird thing here is that I remember this working a few years or so ago on the same boards and stuff, it just doesn't work now and I have 0 clue why. I'm thinking about downgrading MySensors to 1.something
                                        • A Avamander
                                          @niclas
                                          @electrik
                                          Yes.
                                          N Offline
                                          N Offline
                                          niclas
                                          @Avamander Found the documentation you were referring to and yes. Seems to be true for the RF24 which I haven't used in a long time.
                                          #define MY_RX_MESSAGE_BUFFER_FEATURE
                                          This enables the receiving buffer feature.
                                          This feature is currently not supported for anything but RF24. Require MY_RF24_IRQ_PIN to be set.
                                          Note: Not supported on ESP8266, ESP32, STM32, nRF5 and sketches that use SoftSPI. See below issue for details https://github.com/mysensors/MySensors/issues/1128
                                          Definition at line 2406 of file MyConfig.h.
                                          12.2k
