  3. [Solved] Arduino Nanos don't work as nodes
37 Posts 6 Posters 3.6k Views 5 Watching
  • alowhumA
    alowhumA
    alowhum
    Also, your code never loads MySensors? It's commented out?
    Your node code is very strange.
    A 1 Reply Last reply
    • A
      Avamander
      @alowhum said in Arduino Nanos don't work as nodes:
      How are you powering them?
      USB, tried a wall-wart and two different PCs.
      Are you sure there's nothing like encrpytion on the gateway?
      Yes, it's the default gateway sketch, except configured to use the right channel, data rate and nRF24.
      Have you tried replacing all the wires between the nano and the radio module?
      Yeah, I have multiple boards, some years old and have worked with other nRF24 projects. Plus, any wiring changes actually break it for things such as RF24.
      Have you tried enabling the advanced radio debug option? (I forget it's name).
      I'll look into that.
      Maybe you have some of those fake Atmel chips?
      Three of them bought at different times, and the only issues are with MySensor? :P Seems unlikely.
      • alowhumA alowhum
        Avamander
        Um, line 22 #include <MySensors.h>
        It was of the examples, barely modified.
        • alowhumA
          alowhumA
          alowhum
          @Avamander said in Arduino Nanos don't work as nodes:
          Ah, you're right. Have been programming in other languages lately, where that indicates a comment.
          • alowhumA
            alowhumA
            alowhum
            Is there a reason you're swapping your CE and CS pins?
            • alowhumA alowhum
              Avamander
              Because they're wired that way and it doesn't/shouldn't matter.
              • alowhumA
                alowhumA
                alowhum
                What happens if you remove everything but the essentials for your network here?
                #define MY_REPEATER_FEATURE
                #define MY_TRANSPORT_SANITY_CHECK
                #define MY_SIGNAL_REPORT_ENABLED
                #define MY_RF24_CE_PIN     9
                #define MY_RF24_CS_PIN     10
                #define MY_RF24_CHANNEL   29
                #define RF24_DATARATE      RF24_2MBPS
                #define RF24_PA_LEVEL      RF24_PA_MIN
                #define RF24_PA_LEVEL_GW   RF24_PA_MIN
                #define MY_NODE_ID         1
                #define MY_PARENT_NODE_ID  0
                #define MY_TRANSPORT_WAIT_READY_MS 1
                Maybe only leave #define MY_RF24_CHANNEL 29?
                • alowhumA
                  alowhumA
                  alowhum
                  Look for something like MY_DEBUG_VERBOSE_NRF24 - something along those lines, for that debug option I mentioned.
                  • alowhumA alowhum
                    Avamander
                    @alowhum
                    #define MY_DEBUG_VERBOSE_RF24
                    16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=16,REL=255,VER=2.3.2
                    26 TSM:INIT
                    28 TSF:WUR:MS=0
                    29 RF24:INIT:PIN,CE=9,CS=10
                    31 RF24:SBY
                    32 RF24:WBR:REG=0,VAL=14
                    39 RF24:WBR:REG=3,VAL=3
                    41 RF24:WBR:REG=4,VAL=95
                    44 RF24:WBR:REG=5,VAL=29
                    47 RF24:WBR:REG=6,VAL=37
                    49 RF24:WBR:REG=29,VAL=4
                    51 RF24:RBR:REG=29,VAL=4
                    53 RF24:RBR:REG=6,VAL=37
                    55 RF24:RBR:REG=5,VAL=29
                    58 RF24:WBR:REG=2,VAL=2
                    60 RF24:WBR:REG=1,VAL=0
                    62 RF24:WBR:REG=28,VAL=3
                    64 RF24:FRX
                    65 RF24:FTX
                    66 RF24:WBR:REG=7,VAL=112
                    69 TSM:INIT:TSP OK
                    70 TSM:INIT:STATID=1
                    72 RF24:WBR:REG=2,VAL=3
                    74 RF24:WBR:REG=1,VAL=1
                    76 RF24:STL
                    78 RF24:WBR:REG=0,VAL=15
                    80 RF24:WBR:REG=10,VAL=1
                    82 TSF:SID:OK,ID=1
                    84 TSM:FPAR
                    86 RF24:SPL
                    87 RF24:WBR:REG=0,VAL=14
                    89 RF24:OWP:RCPT=255
                    91 RF24:WBR:REG=10,VAL=255
                    93 RF24:WBR:REG=16,VAL=255
                    96 RF24:TXM:TO=255,LEN=7
                    98 RF24:FTX
                    99 RF24:WBR:REG=4,VAL=80
                    103 RF24:WBR:REG=7,VAL=112
                    106 ?RF24:TXM:MAX_RT
                    108 RF24:FTX
                    109 RF24:WBR:REG=4,VAL=95
                    111 RF24:STL
                    113 RF24:WBR:REG=0,VAL=15
                    115 RF24:WBR:REG=10,VAL=1
                    117 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    2125 !TSM:FPAR:NO REPLY
                    2127 TSM:FPAR
                    2128 RF24:SPL
                    2130 RF24:WBR:REG=0,VAL=14
                    2132 RF24:OWP:RCPT=255
                    2135 RF24:WBR:REG=10,VAL=255
                    2138 RF24:WBR:REG=16,VAL=255
                    2140 RF24:TXM:TO=255,LEN=7
                    2143 RF24:FTX
                    2144 RF24:WBR:REG=4,VAL=80
                    2149 RF24:WBR:REG=7,VAL=112
                    2151 ?RF24:TXM:MAX_RT
                    2153 RF24:FTX
                    2155 RF24:WBR:REG=4,VAL=95
                    2157 RF24:STL
                    2158 RF24:WBR:REG=0,VAL=15
                    2161 RF24:WBR:REG=10,VAL=1
                    2163 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    4171 !TSM:FPAR:NO REPLY
                    4173 TSM:FPAR
                    4174 RF24:SPL
                    4175 RF24:WBR:REG=0,VAL=14
                    4178 RF24:OWP:RCPT=255
                    4180 RF24:WBR:REG=10,VAL=255
                    4184 RF24:WBR:REG=16,VAL=255
                    4186 RF24:TXM:TO=255,LEN=7
                    4189 RF24:FTX
                    4190 RF24:WBR:REG=4,VAL=80
                    4195 RF24:WBR:REG=7,VAL=112
                    4197 ?RF24:TXM:MAX_RT
                    4199 RF24:FTX
                    4201 RF24:WBR:REG=4,VAL=95
                    4203 RF24:STL
                    4204 RF24:WBR:REG=0,VAL=15
                    4207 RF24:WBR:REG=10,VAL=1
                    4209 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    6217 !TSM:FPAR:NO REPLY
                    Still no reply.
                    • N
                      N
                      niclas
                      wrote on last edited by niclas
                      I'm not super experienced using mysensors but I do have 3 nodes working and when first settings things up I had some problems with NODE IDs. It looks like you are setting a Static node Id? Is that ID "free" in the gateway? Have you tried powering of all the nodes you have running, wiping the EEPROM of the gateway, powering up the gateway and shortly after powering up the node?
                      Someone else perhaps knows this better but, if the gateway don't want to include the node, does that generate the FPAR:No reply?
                      And also, how is the interrupt pin connected?
                      A 2 Replies Last reply
                      • electrikE
                        electrikE
                        electrik
                        I use Arduinos all the time and have problem with them.
                        I suggest to start with one of the examples.
                        The RF channel is the same everywhere I guess?
                        What does the output on the gateway say?
                        • N niclas
                          Avamander
                          @niclas
                          Yes, there are no other nodes (other than the one with a different static node ID that works)
                          Yes.
                          Yes, I've wiped EEPROMs of all the nodes.
                          N 1 Reply Last reply
                          • A Avamander
                            @niclas
                            Yes.
                            N
                            N
                            niclas
                            @Avamander I meant, have you erased the EEPROM of the gateway?
                            • N niclas
                              Avamander
                              wrote on last edited by Avamander
                              @niclas
                              Yes, that too.
                              The radio's IRQ pin is not connected. (The IRQ pin is only required to be connected if the MY_RX_MESSAGE_BUFFER_FEATURE is defined in the sketch.)
                              • A Avamander
                                @niclas
                                Yes, that too.
                                N
                                N
                                niclas
                                @Avamander Regarding the interrupt pin, at least when using the RFM95 I need to have the pin connected to be able to receive anything. It doesnt poll the module to check for incoming messages. Maybe its different with nRF24.
                                I haven't tried messing with the MY_RX_MESSAGE_BUFFER_FEATURE so I wouldnt know about that.
                                • A
                                  Avamander
                                  @niclas
                                  Well, the documentation says I don't have to have it connected.
                                  @electrik
                                  The gateway and node both are examples with the minimal required changes.
                                  Yes.
                                  Nothing, totally silent. When I plug in the Mega node, then it starts outputting all the sensor and other data.
                                  Anyways, the weird thing here is that I remember this working a few years or so ago on the same boards and stuff, it just doesn't work now and I have 0 clue why. I'm thinking about downgrading MySensors to 1.something
                                  • A Avamander
                                    @niclas
                                    @electrik
                                    Yes.
                                    N
                                    N
                                    niclas
                                    @Avamander Found the documentation you were referring to and yes. Seems to be true for the RF24 which I haven't used in a long time.
                                    #define MY_RX_MESSAGE_BUFFER_FEATURE
                                    This enables the receiving buffer feature.
                                    This feature is currently not supported for anything but RF24. Require MY_RF24_IRQ_PIN to be set.
                                    Note: Not supported on ESP8266, ESP32, STM32, nRF5 and sketches that use SoftSPI. See below issue for details https://github.com/mysensors/MySensors/issues/1128
                                    Definition at line 2406 of file MyConfig.h.
                                    • electrikE
                                      electrikE
                                      electrik
                                      I don't think this is a software issue. More likely your NRF24 is failing.
                                      • electrikE electrik
                                        Avamander
                                        @electrik It's highly unlikely. I have more than one type of module and more than one module of each type, none of them work. I also swapped the modules between working GW and Mega node and it still works, I swap the module between working GW and the node, it doesn't work.
                                        • electrikE
                                          electrikE
                                          electrik
                                          Could you try version 2.2 of mysensors? I remember summer changes in 2.4 regarding nrf modules
