  3. RFM69/95 won't run
RFM69/95 won't run
22 Posts 5 Posters 2.3k Views 4 Watching
  • J
    J
    Joost
    wrote on last edited by Joost
    Is the SX1278 working with the RFM95 driver as well? All my boards are SX1276 and have a different pinout/PCB formfactor...
    • N
      N
      niclas
      Have you set it up for 434mhz? I think the standard is 866 mhz if not redefined. Also delay is important for certain settings.
      I have the same chip working at home, I'll post code tomorrow.
      • N
        N
        niclas
        #define MY_RADIO_RFM95
        #define MY_DEBUG_VERBOSE_RFM95
        #define MY_RFM95_FREQUENCY (RFM95_434MHZ)
        #define MY_RFM95_MODEM_CONFIGRUATION RFM95_BW125CR48SF4096
        #define RFM95_RETRY_TIMEOUT_MS (3000ul)
        #define MY_TRANSPORT_STATE_TIMEOUT_MS (3000ul)
        These are the defines I'm using. All done before including the MySensors.h.
        What do you get if you try the above?
        • N
          N
          niclas
          And also:
          The fourth line (configuration) needs to be the same on both the node and the gateway in order to work.
          Be sure to set the frequncy to 434Mhz on both devices as well.
          • C
            C
            cYnd
            @niclas said in RFM69/95 won't run:
            Hi Nicals,
            thanks for the hints with the defines. Currently I am using this sketch:
            #define MY_BAUD_RATE 9600
            #define CHILD_ID 1
              present(CHILD_ID, S_MOISTURE);
              send(msg.set(12));
              sleep(10000);
            So pretty basic I think. However I still get with your defines the error:
            208 RFM95:INIT
            292 RFM95:INIT:PIN,CS=10,IQP=2,IQN=0
            342 RFM95:PTX:LEVEL=13
            364 !RFM95:INIT:SANCHK FAIL
            395 RFM95:RSL
            Unfortunalety my replacement still didn't arrive (i guess due to the COVID-19 crisis....) so I can just work with the breakouts I got.
            What exactly do you mean with:
            And also:
            I can't get is running on one devices (Pro Mini) due to the above mentioned errors, so I didn't even tried it with a second device. What exactly do you mean with fourth line? And which are the "both devices"?
            N 1 Reply Last reply
            • C cYnd
              Hi Nicals,
              #define CHILD_ID 1
                send(msg.set(12));
                sleep(10000);
              208 RFM95:INIT
              395 RFM95:RSL
              And also:
              N
              N
              niclas
              @cYnd Hi! Sorry for really late answer. I must have missed the e-mail notification. Have you solved the issue yet?
              I just read your first post and it says: MISO (D11), MOSI (D12). This is swapped according to for instance https://www.circuito.io/blog/arduino-uno-pinout/
              MOSI->MOSI and MISO->MISO is correct but the pin number on the pro mini seems wrong?
              • C
                C
                cYnd
                Hey niclas,
                no worries :-)
                Got still no solution for this issue. On my first post I linked to the shop where i bought it and on the shops spec sheet, I find MOSI on D12. However on the official documentation I also find MOSI on D11. I switched these pins but still get the error:
                208 RFM95:INIT
                395 RFM95:RSL
                I also found this tool for testing LoRa devices. With MOSI on D12 I just got FF on all addresses but with the switched pins I got:
                Reg    0  1  2  3  4  5  6  7  8  9  A  B  C  D  E  F
                0x00  00 08 00 08 00 08 00 08 00 08 00 08 00 08 00 08
                0x10  00 08 00 08 00 08 00 08 00 08 00 08 00 08 00 08
                0x20  00 08 00 08 00 08 00 08 00 08 00 08 00 08 00 08
                0x30  00 08 00 08 00 08 00 08 00 08 00 08 00 08 00 08
                0x40  00 08 00 08 00 08 00 08 00 08 00 08 00 08 00 08
                0x50  00 08 00 08 00 08 00 08 00 08 00 08 00 08 00 08
                0x60  00 08 00 08 00 08 00 08 00 08 00 08 00 08 00 08
                0x70  00 08 00 08 00 08 00 08 00 08 00 08 00 08 00 08
                I don't know if it is a good sign that I see some other values with the test programm or not.
                Still any ideas how to get this working?
                • C cYnd
                  Hey niclas,
                  no worries :-)
                  208 RFM95:INIT
                  395 RFM95:RSL
                  N
                  N
                  niclas
                  wrote on last edited by niclas
                  @cYnd hmm.. too bad..
                  I guess I would start by downloading the Lora library by Sandeep Mistry in Arduino IDE and just run the example provided, I think one is called dump_registers. If that doesn't work I would start to suspect hardware failure or some problem with the wires.
                  And also, check that all the gnd pads of the module are connected to each other. I used a Bluetooth module once that needed all the gnd pins connected.
                  • N niclas
                    N
                    N
                    niclas
                    Found a picture of my node. I hooked up both the GND pads. Can't remember if it was necessary.
                    Still no luck with your module?
                    C 1 Reply Last reply
                    • N niclas
                      C
                      C
                      cYnd
                      @niclas Still no luck when connection both grounds. Also measured them and they are both connected, even without soldering an cable to it.
                      I just ordered the RA AI02 modules so let's hope that these will arrive soon and will work (still didn't receive my replacements).
                      A real pity that I can't get these to work :(
                      • C cYnd
                        N
                        N
                        niclas
                        @cYnd Well I'm out of ideas. Could be a hardware issue, perhaps you shorted something when handling the module or you exposed it to 5V?
                        Is the VCC output from the Mini 5V or 3.3V? If you supply the mini board with 3.3V you should connect the module VCC to 'raw' if i remember correctly.
                        I use the RA-01 and RA-02 all the time so hopefully you will be very pleased with them. Good luck!
                        • A
                          Avamander
                          Looking at the images, the wires might not be properly connected, a few wires look like they're just plugged in. In that case even the slightest movement could cause issues.
                          • A Avamander
                            C
                            C
                            cYnd
                            @Avamander The cables are solder from the other side and I just took a picture of the side with the writing so you can trace if it's correctly wired.
                            A 1 Reply Last reply
                            • C cYnd
                              Avamander
                              @cYnd I know, but the lack of proper solder flow (on at least two pins) and a cold joint should not happen even if soldered from the other side. I'd fix it just to be sure it doesn't cause any erratic issues.
                              • C
                                C
                                cYnd
                                FINALLY!
                                My replacement arrived and I soldered it to my pro mini. This time I used a level converter for powering it directly from VCC and not the arduino's VCC. First no luck, but after switching MISO and MOSI it finally worked:
                                LED Flash
                                Checking LoRa Device
                                LoRa Device Present
                                LoRa device version 0x12
                                LoRa Registers
                                0x00  00 09 1A 0B 00 52 6C AA 99 4F 09 2B 20 08 02 0A
                                0x10  FF 70 15 0B 28 0C 12 47 32 3E 00 00 00 00 00 40
                                0x20  00 00 00 00 05 00 03 93 55 55 55 55 55 55 55 55
                                0x30  90 40 40 00 00 0F 00 00 00 F5 20 82 EF 02 80 40
                                0x40  00 00 12 24 2D 00 03 00 04 23 00 09 05 84 32 2B
                                0x50  14 00 00 11 00 00 00 0F E0 00 0C F0 07 00 5C 78
                                0x60  00 19 0C 4B CC 0E 7F 20 04 47 AF 3F 7A 00 3B 0B
                                0x70  D0 01 10 00 00 00 00 00 00 00 00 00 00 00 00 00
                                Current frequency 434.666MHz
                                Write new frequency 434.400MHz
                                Changed frequency 434.400MHz
                                Seems like the diagram of the shop where I bought the arduino is switched. However I can now try to read the sensor and send the data via LoRa! Awesome!
                                One final question (not related to this issue but maybe you can still answer that in this topic :innocent: ) : I got a RXB6 runnign to read a radio rain sensor at 433MHz. Is this received able to recive also LoRa signals or do I need a dedicated LoRa chip to receive LoRa radio signals?
