  3. RFM69/95 won't run
RFM69/95 won't run
22 Posts 5 Posters 2.3k Views 4 Watching
  • C
    C
    cYnd
    @niclas said in RFM69/95 won't run:
    #define MY_RFM95_FREQUENCY (RFM95_434MHZ)
    #define MY_RFM95_MODEM_CONFIGRUATION RFM95_BW125CR48SF4096
    #define RFM95_RETRY_TIMEOUT_MS (3000ul)
    #define MY_TRANSPORT_STATE_TIMEOUT_MS (3000ul)
    Hi Nicals,
    thanks for the hints with the defines. Currently I am using this sketch:
    #define MY_RADIO_RFM95
    #define MY_DEBUG_VERBOSE_RFM95
    #define MY_BAUD_RATE 9600
    #define CHILD_ID 1
      present(CHILD_ID, S_MOISTURE);
      send(msg.set(12));
      sleep(10000);
    So pretty basic I think. However I still get with your defines the error:
    208 RFM95:INIT
    292 RFM95:INIT:PIN,CS=10,IQP=2,IQN=0
    342 RFM95:PTX:LEVEL=13
    364 !RFM95:INIT:SANCHK FAIL
    395 RFM95:RSL
    Unfortunalety my replacement still didn't arrive (i guess due to the COVID-19 crisis....) so I can just work with the breakouts I got.
    What exactly do you mean with:
    And also:
    The fourth line (configuration) needs to be the same on both the node and the gateway in order to work.
    Be sure to set the frequncy to 434Mhz on both devices as well.
    I can't get is running on one devices (Pro Mini) due to the above mentioned errors, so I didn't even tried it with a second device. What exactly do you mean with fourth line? And which are the "both devices"?
    N 1 Reply Last reply
    • C cYnd
      Hi Nicals,
      #define CHILD_ID 1
        send(msg.set(12));
        sleep(10000);
      208 RFM95:INIT
      395 RFM95:RSL
      And also:
      N
      N
      niclas
      @cYnd Hi! Sorry for really late answer. I must have missed the e-mail notification. Have you solved the issue yet?
      I just read your first post and it says: MISO (D11), MOSI (D12). This is swapped according to for instance https://www.circuito.io/blog/arduino-uno-pinout/
      MOSI->MOSI and MISO->MISO is correct but the pin number on the pro mini seems wrong?
      • C
        C
        cYnd
        Hey niclas,
        no worries :-)
        Got still no solution for this issue. On my first post I linked to the shop where i bought it and on the shops spec sheet, I find MOSI on D12. However on the official documentation I also find MOSI on D11. I switched these pins but still get the error:
        208 RFM95:INIT
        395 RFM95:RSL
        I also found this tool for testing LoRa devices. With MOSI on D12 I just got FF on all addresses but with the switched pins I got:
        Reg    0  1  2  3  4  5  6  7  8  9  A  B  C  D  E  F
        0x00  00 08 00 08 00 08 00 08 00 08 00 08 00 08 00 08
        0x10  00 08 00 08 00 08 00 08 00 08 00 08 00 08 00 08
        0x20  00 08 00 08 00 08 00 08 00 08 00 08 00 08 00 08
        0x30  00 08 00 08 00 08 00 08 00 08 00 08 00 08 00 08
        0x40  00 08 00 08 00 08 00 08 00 08 00 08 00 08 00 08
        0x50  00 08 00 08 00 08 00 08 00 08 00 08 00 08 00 08
        0x60  00 08 00 08 00 08 00 08 00 08 00 08 00 08 00 08
        0x70  00 08 00 08 00 08 00 08 00 08 00 08 00 08 00 08
        I don't know if it is a good sign that I see some other values with the test programm or not.
        Still any ideas how to get this working?
        • C cYnd
          Hey niclas,
          no worries :-)
          208 RFM95:INIT
          395 RFM95:RSL
          N
          N
          niclas
          wrote on last edited by niclas
          @cYnd hmm.. too bad..
          I guess I would start by downloading the Lora library by Sandeep Mistry in Arduino IDE and just run the example provided, I think one is called dump_registers. If that doesn't work I would start to suspect hardware failure or some problem with the wires.
          And also, check that all the gnd pads of the module are connected to each other. I used a Bluetooth module once that needed all the gnd pins connected.
          • N niclas
            N
            N
            niclas
            Found a picture of my node. I hooked up both the GND pads. Can't remember if it was necessary.
            Still no luck with your module?
            C 1 Reply Last reply
            • N niclas
              C
              C
              cYnd
              @niclas Still no luck when connection both grounds. Also measured them and they are both connected, even without soldering an cable to it.
              I just ordered the RA AI02 modules so let's hope that these will arrive soon and will work (still didn't receive my replacements).
              A real pity that I can't get these to work :(
              • C cYnd
                N
                N
                niclas
                @cYnd Well I'm out of ideas. Could be a hardware issue, perhaps you shorted something when handling the module or you exposed it to 5V?
                Is the VCC output from the Mini 5V or 3.3V? If you supply the mini board with 3.3V you should connect the module VCC to 'raw' if i remember correctly.
                I use the RA-01 and RA-02 all the time so hopefully you will be very pleased with them. Good luck!
                • A
                  Avamander
                  Looking at the images, the wires might not be properly connected, a few wires look like they're just plugged in. In that case even the slightest movement could cause issues.
                  • A Avamander
                    C
                    C
                    cYnd
                    @Avamander The cables are solder from the other side and I just took a picture of the side with the writing so you can trace if it's correctly wired.
                    A 1 Reply Last reply
                    • C cYnd
                      Avamander
                      @cYnd I know, but the lack of proper solder flow (on at least two pins) and a cold joint should not happen even if soldered from the other side. I'd fix it just to be sure it doesn't cause any erratic issues.
                      • C
                        C
                        cYnd
                        FINALLY!
                        My replacement arrived and I soldered it to my pro mini. This time I used a level converter for powering it directly from VCC and not the arduino's VCC. First no luck, but after switching MISO and MOSI it finally worked:
                        LED Flash
                        Checking LoRa Device
                        LoRa Device Present
                        LoRa device version 0x12
                        LoRa Registers
                        0x00  00 09 1A 0B 00 52 6C AA 99 4F 09 2B 20 08 02 0A
                        0x10  FF 70 15 0B 28 0C 12 47 32 3E 00 00 00 00 00 40
                        0x20  00 00 00 00 05 00 03 93 55 55 55 55 55 55 55 55
                        0x30  90 40 40 00 00 0F 00 00 00 F5 20 82 EF 02 80 40
                        0x40  00 00 12 24 2D 00 03 00 04 23 00 09 05 84 32 2B
                        0x50  14 00 00 11 00 00 00 0F E0 00 0C F0 07 00 5C 78
                        0x60  00 19 0C 4B CC 0E 7F 20 04 47 AF 3F 7A 00 3B 0B
                        0x70  D0 01 10 00 00 00 00 00 00 00 00 00 00 00 00 00
                        Current frequency 434.666MHz
                        Write new frequency 434.400MHz
                        Changed frequency 434.400MHz
                        Seems like the diagram of the shop where I bought the arduino is switched. However I can now try to read the sensor and send the data via LoRa! Awesome!
                        One final question (not related to this issue but maybe you can still answer that in this topic :innocent: ) : I got a RXB6 runnign to read a radio rain sensor at 433MHz. Is this received able to recive also LoRa signals or do I need a dedicated LoRa chip to receive LoRa radio signals?
