  3. ESP8266 Gateway
ESP8266 Gateway
gatewayesp8266 nrf24l01+ gateway
2 Posts 2 Posters 438 Views 2 Watching
    sash.sc
    Hi Guys.
    I want do compile the .ino for the esp8266 wifi gateway. i used the normal script, put my wland access data into the script with pwassword. I have left everything as it was.
    I selected the "node MCU 1.0" Board and started to compile.
    I´m using the arduino ide 1.8.5 and mysensor 2.2
    Now i´ve the following errors
    In file included from D:\Users\Sascha\Documents\Arduino\libraries\MySensors/MySensors.h:405:0,
                     from C:\Users\Sascha\AppData\Local\Temp\arduino_modified_sketch_127728\GatewayESP8266.ino:120:
    D:\Users\Sascha\Documents\Arduino\libraries\MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp:57:53: error: declaration of C function 'void ets_update_cpu_frequency(int)' conflicts with
     extern "C" void ets_update_cpu_frequency(int freqmhz);
    In file included from C:\Users\Sascha\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.1\cores\esp8266/pgmspace.h:11:0,
                     from C:\Users\Sascha\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.1\cores\esp8266/Arduino.h:258,
                     from sketch\GatewayESP8266.ino.cpp:1:
    C:\Users\Sascha\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.1/tools/sdk/include/ets_sys.h:218:6: error: previous declaration 'void ets_update_cpu_frequency(uint32_t)' here
     void ets_update_cpu_frequency(uint32_t ticks_per_us);
    exit status 1
    Fehler beim Kompilieren für das Board Generic ESP8266 Module.
    Can someone help ?
    greetings
    Sascha
    • S sash.sc
      Hi Guys.
      exit status 1
      Can someone help ?
      greetings
      Sascha
      @sash-sc upgrade MySensors to 2.3.2 or downgrade the esp board definition.
      More info: https://github.com/mysensors/MySensors/releases/tag/2.3.2
