  3. My Sensors with Heltec V2
6 Posts 4 Posters 1.2k Views 4 Watching
  • D
    dimoia
    Hello MySensors,
    I have a problem.
    I buy two Heltec Lora V2 and I wanto to use the first as Gateway and the second as node.
    The gateway and relative node start (No FAIL detect) but, when the node try to send a msg the log print NO_REPY.
    Ho I can find an example?.
    Is possible to use Heltec as node and raspberry gateway with RFM95 ?.
    thanks to all
    Heltec V2 GATEWAY LOG
    1176 GWT:TIN:CONNECTING...
    1178 GWT:TIN:IP: 192.168.1.50
    1184 MCO:BGN:STP
    1187 MCO:BGN:INIT OK,TSP=1
    1191 TSM:READY:NWD REQ
    1195 RFM95:SWR:SEND,TO=255,SEQ=0,RETRY=0
    8201 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=NACK:
    900050 TSF:SAN:OK
    Heltec V2 Node
    17 MCO:BGN:INIT NODE,CP=RLNNA---,FQ=16,REL=7,VER=2.3.2-beta
    27 TSM:INIT
    28 TSF:WUR:MS=0
    40 TSM:INIT:TSP OK
    41 TSM:INIT:STATID=1
    44 TSF:SID:OK,ID=1
    46 TSM:FPAR
    71 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2078 !TSM:FPAR:NO REPLY
    2080 TSM:FPAR
    2106 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4113 !TSM:FPAR:NO REPLY
    4115 TSM:FPAR
    4141 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    • D dimoia
      Hello MySensors,
      I have a problem.
      thanks to all
      1184 MCO:BGN:STP
      900050 TSF:SAN:OK
      Heltec V2 Node
      27 TSM:INIT
      28 TSF:WUR:MS=0
      40 TSM:INIT:TSP OK
      44 TSF:SID:OK,ID=1
      46 TSM:FPAR
      2080 TSM:FPAR
      4115 TSM:FPAR
      Welcome to the forum @dimoia
      I'm not sure if anyone has tried it, but the setup you are describing should work.
      What spreading factor setting are you using for the lora modem? If you use the slow factors, you might need to adjust some timeouts. See https://github.com/mysensors/MySensors/issues/742
      Are the devices withn range from eachother? ( at least 5m, but not many hundred meters away?)
      Are you using the antenna that seems to be included in the kit? If not, what atenna are you using?
      • D
        dimoia
        Hi Mikael,
        I executed the instructions you posted and I solved the problem.
        • D dimoia
          Hi Mikael,
          Great work @dimoia, thanks for reporting back
            mrussi
            Hello @dimoia ,
            Trying to make a gateway and a node using the Heltec Lora Oled board, can you please post the settings you used to make it work with mysensors?
            Thank you
            FarmerEdF 1 Reply Last reply
            • M mrussi
              Hello @dimoia ,
              Thank you
              FarmerEdF
              FarmerEdF
              FarmerEd
              @mrussi
              Not sure if you still need this info, but I'll leave it here in case anyone else needs it. I couldn't find this either so i had to look at the heltec pinout diagram and compared to the ESP32 Library
               * Copyright (C) 2013-2018 Sensnology AB
               * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
               * Version 1.0 - tekka
               * The ESP32 gateway sends data received from sensors to the WiFi link.
               * Make sure to fill in your ssid and WiFi password below.
              //#define MY_RADIO_RF24
              #define MY_RADIO_RFM95
              #define MY_DEBUG_VERBOSE_RFM95
              #define MY_RFM95_RST_PIN 14
              #define MY_RFM95_CS_PIN 18
              #define MY_RFM95_IRQ_PIN 26
              #define MY_RFM95_IRQ_NUM MY_RFM95_IRQ_PIN
              #define MY_SOFT_SPI_MOSI_PIN 27
              #define MY_SOFT_SPI_SCK_PIN 5
              #define MY_RFM95_FREQUENCY (RFM95_868MHZ)
              #define MY_RFM95_MODEM_CONFIGRUATION RFM95_BW125CR45SF128
              #define MY_GATEWAY_ESP32
              #define MY_WIFI_SSID "WiFi_SSID"
              #define MY_WIFI_PASSWORD "password"
              #define MY_HOSTNAME "ESP32_GW_LoRa"
              //#define MY_IP_ADDRESS 192,168,1,100
              //#define MY_IP_GATEWAY_ADDRESS 192,168,1,1
              #define MY_PORT 5003
