  3. Which pins should I use for status led on a wemos d1 mini gateway
17 Posts 4 Posters 2.5k Views 4 Watching
  • Danielo RodríguezD Offline
    Danielo Rodríguez
    Sorry if this has been answered before, but I could not find any answer to this particular thing.
    I have a wifi gateway built using a d1 mini. It is working great, but I want to have some feedback about what is going on, so I decided to add some status leds. I already wired all the leds to 5v, and when I was about to check wich other pins to use I realized that the information is for an arduino gateway, so, what are the pins that ai can use on the D1 mini for this?
    mfalkviddM pw44P BearWithBeardB 3 Replies Last reply
    • Danielo RodríguezD Danielo Rodríguez
      @Danielo-Rodríguez D4 should be usable. See https://forum.mysensors.org/post/86619 dor an earlier discussion on a similar topic. Kolban’s book is great for checking which pins do what.
        pw44P Offline
        pw44P Offline
        pw44
        @Danielo-Rodríguez good question, i'm also looking for it.
        I used D1 for include button.
        #define MY_INCLUSION_MODE_BUTTON_PIN D1
        Tried
        #define MY_DEFAULT_ERR_LED_PIN D0 // 3 // Error led pin
        #define MY_DEFAULT_RX_LED_PIN D3 // 5 // Receive led pin
        #define MY_DEFAULT_TX_LED_PIN D4 // 4 // Transmit led pin
        But did not succeed.
          BearWithBeardB Offline
          BearWithBeard
          @Danielo-Rodríguez I used D0 (GPIO16), D3 (GPIO2) and D4 (GPIO4) on my NodeMCU-based GW for status LEDs. Since the pin definitions of the NodeMCU and D1 mini are the same, this should work on the D1 mini as well. Just make sure to connect them to VCC, not GND. If either D3 or D4 are pulled low, the ESP won't boot.
          pw44P 1 Reply Last reply
          • BearWithBeardB BearWithBeard
            pw44P Offline
            pw44P Offline
            pw44
            @BearWithBeard
            So, D0 to led anode and led cathode to resistor to gnd, correct?
            BearWithBeardB 1 Reply Last reply
            • pw44P pw44
              @BearWithBeard
              BearWithBeard
              wrote on last edited by BearWithBeard
              @pw44 No, this isn't a good idea. You should have all status LEDs in either source or sink configuration, or some LEDs will be inverted (lit by default, off when there is activity).
              D3 and D4 must to be connected like this to not prevent the ESP from booting: GPIO - Resistor - LED cathode - LED anode - VCC. D0 should be connected equally, even if it doesn't matter for the ESP's functionality.
              Besides that, if you don't use I2C, you should also be able to use D1 (GPIO5) and D2 (GPIO4) for status LEDs, inclusion mode button, etc.
              pw44P 2 Replies Last reply
                Danielo Rodríguez
                wrote on last edited by Danielo Rodríguez
                Wow, thank you everyone! I have all the leds sink to 5v (long leg) and I was going to put a resistor on the other leg to connect them to the gpio because that is what it says on the docs, but docs are for arduino. I'm very happy that it's the same for the D1 mini. When I define the pins on the sketch should I use the same label (without the D) or should I use a different value?
                By the way, what can be the i2c used on the gateway?
                OH, and which resistor should I use? Does it need to be of an specific value or is it enough if it is within certain range?
                  pw44P Offline
                  pw44P Offline
                  pw44
                  @BearWithBeard said in Which pins should I use for status led on a wemos d1 mini gateway:
                  Thank you so much for your answer. Helped me a lot.
                    BearWithBeard
                    @pw44 I'm glad I could help!
                    @Danielo-Rodríguez said in Which pins should I use for status led on a wemos d1 mini gateway:
                    You could add any kind of I2C device to it, like a temperature sensor. A gateway is basically a regular node with some (important) extra functionality. Just be mindful to not overburden the gateway with too many secondary tasks. If it spends too much time dealing with sensors and other stuff blocking the loop, you may risk that it misses incoming messages.
                    You can sink up to 20mA into a pin on the ESP8266. As long as you stay below that (and the current limit of the LEDs), you should be fine [R = (VCC - Vforward) / Iforward].
                    220R or 330R is fine for a bright light. Use 1K or even more if you prefer a rather dim light. Or anything in between. If you connect the LEDs to 3.3V instead of 5V, you need smaller resistors for the same brightness.
                    Danielo RodríguezD 1 Reply Last reply
                      Danielo Rodríguez
                      @BearWithBeard Thank you very much!
                      I'll do that
                        Danielo Rodríguez
                        At the end I was able to use D0,D1 and D4 for status leds. Something interesting is that I can use the actual DN nomenclature because there is a header file that maps them properly. The weird thing is that such file is arduino.h (I'm using platformio) so I'm not sure if it is specific for the D1 mini or if D1 is compatible with arduino pinout.
                        I used a 220 ohm resistor and, dam it, the leds are bright as hell, haha.
                        Everything is working now, it's very pleasant to see the leds blink when I turn on other node. Thanks to all the people on this forum for the great support.
                          pw44P Offline
                          pw44P Offline
                          pw44
                          @BearWithBeard could you please confirm the correct definitions for the pins?
                          #define MY_DEFAULT_ERR_LED_PIN 3 // D0 Error led pin
                          #define MY_DEFAULT_RX_LED_PIN 5 // D3 Receive led pin
                          #define MY_DEFAULT_TX_LED_PIN 4 // D4 Transmit led pin
                          D1 = pin 1
                          D3 = pin 5
                          D4 = pin 4
                          D0 = pin 3
                          is this correct?
                          thx in advance.
                          mfalkviddM BearWithBeardB 2 Replies Last reply
                          • pw44P pw44
                            D1 = pin 1
                            D3 = pin 5
                            D4 = pin 4
                            D0 = pin 3
                            is this correct?
                            thx in advance.
                            @pw44 could you clarify what pin numbers you are referring to, perhaps with a picture?
                            The mapping used by the Arduino IDE can be seen at https://github.com/esp8266/Arduino/blob/master/variants/d1_mini/pins_arduino.h#L37
                              pw44P Offline
                              pw44P Offline
                              pw44
                              @mfalkvidd thx for answering.
                              i was looking for the correct mapping for:
                              #define MY_DEFAULT_ERR_LED_PIN D0 // Error led pin
                              #define MY_DEFAULT_RX_LED_PIN D3 // Receive led pin
                              #define MY_DEFAULT_TX_LED_PIN D4 // Transmit led pin
                              thx to your hint, D0 =16, D3 = 0, D4 = 2.
                              So, i shall change to:
                              #define MY_DEFAULT_ERR_LED_PIN 16 // Error led pin
                              #define MY_DEFAULT_RX_LED_PIN 0 // Receive led pin
                              #define MY_DEFAULT_TX_LED_PIN 2 // Transmit led pin
                              • pw44P pw44
                                D1 = pin 1
                                D3 = pin 5
                                D4 = pin 4
                                D0 = pin 3
                                is this correct?
                                thx in advance.
                                BearWithBeard
                                @pw44 If you are using the "big" WeMos D1 - the one in the shape of an Arduino Uno - then yes, that looks right to me. This file contains the pin definitions used for this board. But you may have to wire the LEDs to different pins in this case, because D4 / GPIO4 conflicts with the default assignment for CE when using an NRF24 transceiver and D3 / GPIO5 conflicts with DIO0 when using an RFM radio according to the Connecting the Radio guide.
                                If you want to try using the same GPIOs that worked for me on the NodeMCU (2, 4 and 16), you may connect the LEDs to D9, D14 and D2.
                                You may also want to read the book that @mfalkvidd recommended or take a look at this ESP8266 pinout reference to see what pin does what.
                                The D1 mini - the board that the OP uses - has different pin definitions, which are listed here and are similar to the NodeMCU I was using.
                                In general, I think it should be fine to use the alias D1, D2, etc for the pins. No need to use the GPIO number here.
                                  pw44P Offline
                                  pw44P Offline
                                  pw44
                                  @BearWithBeard exactly what i was looking for, the pin mapping for D1 MINI.
                                  Thx!
                                  • pw44P pw44
                                    Thx!
                                    pw44P Offline
                                    pw44P Offline
                                    pw44
                                    @pw44 and so, my first assbled gateway looks like:
                                    Now i will try a more robust version, with external antenna.
