  3. Remote controlled switches (433MHz) and temperature sensors
17 Posts 5 Posters 12.1k Views 1 Watching
  • C Offline
    C Offline
    CaptainZap
    wrote on last edited by CaptainZap
    Hi guys,
    I've been trying to build a 433MHz transmitter and temperature sensor for two Dallas sensors. The goal is to monitor my heating system and turn on/off the recirculating pumps using the 433MHz switches. Up until now this has been done manually (through remote), but I would really love to automate this.
    The problem is that I suck badly at coding, everything goes over my head (sorry), so I've been trying to adapt the currently available code into a single sketch that would help me do this.
    Using the RC Switch library I was able to find out the codes I need to be sending to control my 3 RF switches. Now here comes the funny part, I've used @Dwalt sketch and modified to something I think should work(I am very bad at coding :(). I've also included bits from a multi-sensor sketch I had from @gregl to get at least one temperature sensor added (no idea how to add two).
    I've flashed it on my nano, but when included on the Vera lite (UI5), only the 3 switch devices show up on the interface but no temperature device is created. Using serial monitor I can see that temperature is sent back, but unfortunately the switches from the interface do not seem to control my RF switches.
    I would appreciate any hints on my current issues :
    • how to get two temperature sensors to show up on interface (including the current one)
    • how to correct the RF transmission
    The code is the one below :
    //  Include related libraries
    #include <RF24.h>
    #include <RCSwitch.h>
    #include <OneWire.h>
    //  Define Constants
    #define RF433_CHILD_ID 0
    #define NUMBER_OF_OUTLETS 3 // Each outlet will have 2 OOK codes
    #define SEND_DATA 3 // pin used to send 433MHz data
    #define CLIENT_ID AUTO  // Sets MYSensors client id
    #define RADIO_CH 76  // Sets MYSensors to use Radio Channel
    //Temp Sensor bits
    #define ONE_WIRE_BUS 4 // Pin where dallas sensor is connected - on Rboard this is (D4)
    DallasTemperature DallasSensors(&oneWire);
    float lastTemperature ;
    float tempC = DallasSensors.getTempCByIndex(1);
    RCSwitch mySwitch = RCSwitch();
    #define CHILD_ID_T1 4 //CHILD ID for temperature
    MyMessage tempMsg(CHILD_ID_T1,V_TEMP);
     Serial.begin(115200); // Not sure why this was included
     //  The node is mains powered, so why not make it a repeater.
     gw.begin(incomingMessage, CLIENT_ID , false,AUTO,RF24_PA_MAX,RADIO_CH,RF24_250KBPS);
      // Send the sketch version information to gateway
     gw.sendSketchInfo("RF433_Temp", "1.0");
      //enable RF 433MHz transmitter
     mySwitch.enableTransmit(SEND_DATA);
     // Register outlets to gw (they will be created as child devices)
     for(int i=0; i<NUMBER_OF_OUTLETS;i++) {
       gw.present(i+1, S_LIGHT);
    DallasSensors.requestTemperatures();
      if (lastTemperature != tempC && tempC != -127.00) {
      gw.send(tempMsg.set(tempC,1));
    lastTemperature=tempC;
      if (message.type==V_LIGHT) {
      int incomingLightState =  message.getBool();
      int incomingOutlet = message.sensor;
      Serial.print("Outlet #: ");
      Serial.print("Command: ");
     if (incomingOutlet==1) {
     if (incomingLightState==1) {
    // Turn on  socket 1
     Serial.println("Turn on Socket 1");
     mySwitch.switchOn("10101", "10000"); // These codes are unique to each outlet
     delay(50);
     if (incomingLightState==0)  {
    // Turn off socket 1
    Serial.println("Turn off Socket 1");
    mySwitch.switchOff("10101", "10000");
    delay(50);
     if (incomingOutlet==2) {
    // Turn on  socket 2
    Serial.println("Turn on Socket 2");
    mySwitch.switchOn("10101", "01000");
     delay(50);
    // Turn off socket 2
     Serial.println("Turn off Socket 2");
     mySwitch.switchOff("10101", "01000");
    delay(50);
     if (incomingOutlet==3) {
    // Turn on  socket 3
    Serial.println("Turn on Socket 3");
     mySwitch.switchOn("10101", "00100");
     delay(50);
    // Turn off socket 3
     Serial.println("Turn off Socket 3");
    mySwitch.switchOff("10101", "00100");
    delay(50);
     delay(50);
    D 1 Reply Last reply
    • C Offline
      C Offline
      CaptainZap
      Looking in the Vera logs this is what I actually see when I try to control one switch from the interface :
      08      02/26/15 18:23:50.791   JobHandler_LuaUPnP::HandleActionRequest device: 57 service: urn:upnp-org:serviceId:SwitchPower1 action: SetTarget <0x2f6a5680>
      08      02/26/15 18:23:50.791   JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=57 <0x2f6a5680>
      08      02/26/15 18:23:50.791   JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:upnp-org:serviceId:SwitchPower1 <0x2f6a5680>
      08      02/26/15 18:23:50.792   JobHandler_LuaUPnP::HandleActionRequest argument action=SetTarget <0x2f6a5680>
      08      02/26/15 18:23:50.792   JobHandler_LuaUPnP::HandleActionRequest argument newTargetValue=0 <0x2f6a5680>
      08      02/26/15 18:23:50.792   JobHandler_LuaUPnP::HandleActionRequest argument rand=0.6773929147942098 <0x2f6a5680>
      50      02/26/15 18:23:50.795   luup_log:34: Arduino: Sending: 19;1;1;1;2;0 <0x2b772000>
      51      02/26/15 18:23:50.796   0x31 0x39 0x3b 0x31 0x3b 0x31 0x3b 0x31 0x3b 0x32 0x3b 0x30 0xd 0xa (19;1;1;1;2;0\r\n) <0x2b772000>
      52      02/26/15 18:23:50.852   0x30 0x3b 0x30 0x3b 0x33 0x3b 0x30 0x3b 0x39 0x3b 0x73 0x65 0x6e 0x64 0x3a 0x20 0x30 0x2d 0x30 0x2d 0x31 0x39 0x2d 0x31 0x39 0x20 0x73 0x3d 0x31 0x2c 0x63 0x3d 0x31 0x2c 0x74 0x3d 0x32 0x2c 0x70 0x74 0x3d 0x30 0x2c 0x6c 0x3d 0x31 0x2c 0x73 0x74 0x3d 0x66 0x61 0x69 0x6c 0x3a 0x30 (0;0;3;0;9;send: 0-0-19-19 s=1,c=1,t=2,pt=0,l=1,st=fail:0) <0x2f8e8680>
      50      02/26/15 18:23:50.853   luup_log:34: Arduino: Log: send: 0-0-19-19 s=1,c=1,t=2,pt=0,l=1,st=fail:0 <0x2f8e8680>
      08      02/26/15 18:23:51.815   JobHandler_LuaUPnP::HandleActionRequest device: 57 service: urn:upnp-org:serviceId:SwitchPower1 action: SetTarget <0x2f6a5680>
      08      02/26/15 18:23:51.815   JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=57 <0x2f6a5680>
      08      02/26/15 18:23:51.816   JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:upnp-org:serviceId:SwitchPower1 <0x2f6a5680>
      08      02/26/15 18:23:51.816   JobHandler_LuaUPnP::HandleActionRequest argument action=SetTarget <0x2f6a5680>
      08      02/26/15 18:23:51.816   JobHandler_LuaUPnP::HandleActionRequest argument newTargetValue=1 <0x2f6a5680>
      08      02/26/15 18:23:51.816   JobHandler_LuaUPnP::HandleActionRequest argument rand=0.17616296711805424 <0x2f6a5680>
      50      02/26/15 18:23:51.832   luup_log:34: Arduino: Sending: 19;1;1;1;2;1 <0x2b772000>
      51      02/26/15 18:23:51.833   0x31 0x39 0x3b 0x31 0x3b 0x31 0x3b 0x31 0x3b 0x32 0x3b 0x31 0xd 0xa (19;1;1;1;2;1\r\n) <0x2b772000>
      52      02/26/15 18:23:51.883   0x30 0x3b 0x30 0x3b 0x33 0x3b 0x30 0x3b 0x39 0x3b 0x73 0x65 0x6e 0x64 0x3a 0x20 0x30 0x2d 0x30 0x2d 0x31 0x39 0x2d 0x31 0x39 0x20 0x73 0x3d 0x31 0x2c 0x63 0x3d 0x31 0x2c 0x74 0x3d 0x32 0x2c 0x70 0x74 0x3d 0x30 0x2c 0x6c 0x3d 0x31 0x2c 0x73 0x74 0x3d 0x66 0x61 0x69 0x6c 0x3a 0x31 (0;0;3;0;9;send: 0-0-19-19 s=1,c=1,t=2,pt=0,l=1,st=fail:1) <0x2f8e8680>
      50      02/26/15 18:23:51.884   luup_log:34: Arduino: Log: send: 0-0-19-19 s=1,c=1,t=2,pt=0,l=1,st=fail:1 <0x2f8e8680>
      From serial monitor I see this output:
      sensor started, id 19
      send: 19-19-0-0 s=255,c=0,t=17,pt=0,l=3,st=fail:1.4
      send: 19-19-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
      send: 19-19-0-0 s=255,c=3,t=11,pt=0,l=5,st=fail:RF433
      send: 19-19-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
      send: 19-19-0-0 s=1,c=0,t=3,pt=0,l=3,st=fail:1.4
      send: 19-19-0-0 s=2,c=0,t=3,pt=0,l=3,st=fail:1.4
      send: 19-19-0-0 s=3,c=0,t=3,pt=0,l=3,st=ok:1.4
      send: 19-19-0-0 s=4,c=1,t=0,pt=7,l=5,st=fail:21.1
      • C CaptainZap
        Hi guys,
        #include <RF24.h>
        //  Define Constants
        //Temp Sensor bits
        // Turn on  socket 1
         delay(50);
        delay(50);
        // Turn on  socket 2
         delay(50);
        delay(50);
        // Turn on  socket 3
         delay(50);
        delay(50);
         delay(50);
        Dwalt
        @CaptainZap Just a quick look at your sketch and I see that your temp fetching commands are in 'setup' and not 'loop'', that may explain the lack of temp data. As for the 433 commands, I am not familiar with the RCSwitch library and how it works. For my sketch, I spelled out the transmit process by defining a command (in my sketch it was "pt2262Send", which I borrowed from somewhere else but cant remember where off hand) and used that command within the loop when the V_Light message was received. I used the binary code I received from raw sniffing of the signal.
        • C Offline
          C Offline
          CaptainZap
          @Dwalt Thank you for pointing that out, I am that bad at coding. Anyway, I've done that and I've tried to rewrite the part for two temperature sensors but they still don't show up on the Vera interface.
          I've done some testing and said that I should ditch RCSwitch library and use instead a simple function they provide, so I've retested the switches, and made sure that the code send is correct but I still can't control any switches. Also the temperature sensors do not show up. I need help guys, I feel I am so close it's kind of frustrating :(
          Below is the revised code :
          #include <RF24.h>
          //  Define Constants
          #define MAX_ATTACHED_DS18B20 2
          //Temp Sensor bits
          int numSensors=0; // >> in original temp sketch this is 0 should it be changed to 2 ?
          int RCLpin = 3;
          MyMessage msg(0,V_TEMP);
           void RCLswitch(uint16_t code) {
          for (int nRepeat=0; nRepeat<6; nRepeat++) {
              for (int i=4; i<16; i++) {
                  RCLtransmit(1,3);
                  if (((code << (i-4)) & 2048) > 0) {
                      RCLtransmit(1,3);
                      RCLtransmit(3,1);
              RCLtransmit(1,31);
          void RCLtransmit(int nHighPulses, int nLowPulses) {
          digitalWrite(RCLpin, HIGH);
          delayMicroseconds( 350 * nHighPulses);
          digitalWrite(RCLpin, LOW);
          delayMicroseconds( 350 * nLowPulses);
           gw.sendSketchInfo("RF433&Temp", "1.0b");
           pinMode(RCLpin, OUTPUT);
               gw.present(i, S_TEMP);
          //DallasSensors.requestTemperatures();
          float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
          if (lastTemperature[i] != temperature && temperature != -127.00) {
            gw.send(msg.setSensor(i).set(temperature,1));
          // Turn on  socket 1
          RCLswitch(0b101011000001);// These codes are unique to each outlet
          RCLswitch(0b101011000010);
          // Turn on  socket 2
          RCLswitch(0b101010100001);
          RCLswitch(0b101010100010);
          // Turn on  socket 3
          RCLswitch(0b101010010001);
          RCLswitch(0b101010010010);
           gw.sleep(SLEEP_TIME);
          • HeinzH Offline
            HeinzH Offline
            Heinz
            To be sure that the sensor works, you should download myscontroller from here : goo.gl/9DCWNo
            (http://forum.mysensors.org/topic/838/windows-gui-controller-for-mysensors/33)
            Edit the ini file and enter the ip and port of your mysensors-gateway or com port which depends on the type of gateway you are using.
            Start MysController and click the connect button.
            Now power on your sensor and check if the sensor is sending values.
            If everything is ok then something is wrong with your vera integration. If the sensor does not show up then something is wrong with your sensor. You can also send messages to your sensor with myscontroller to check if your incomming function works.
            • HeinzH Offline
              HeinzH Offline
              Heinz
              Have a look at this lib
              https://code.google.com/p/rc-switch/
              C 1 Reply Last reply
              • HeinzH Heinz
                C Offline
                C Offline
                CaptainZap
                @Heinz I've used that lib in both my tries (it works with their sketch, but not with mine), but I will try the windows GUI and see how that goes.
                LE: While bringing the serial gateway near my computer, I broke off the mini USB port (on the nano I was testing this), something dropped on it and all hell broke loose. I'll check it out tomorrow, but I would really appreciate if someone could take a look at my code. It has to be something I used incorrectly.
                • B Offline
                  B Offline
                  blacey
                  @CaptainZap I would start by trying to eliminate the st=fail: issue in your logs first. That is indicative of a wireless comm problem, at times indicating a message size failure. The root cause in my case was not due to software, but due to the circuit state which I corrected by power cycling, not hard resetting, to stabilize the current/radio.
                  • B blacey
                    C Offline
                    C Offline
                    CaptainZap
                    @blacey
                    Thanks for the feedback, today I started from scratch with a brand spanking new arduino nano ready for flashing. I ditched the temperature sensor part because yesterday I was being a bit too cocky, and rewrote the the sketch based on @Dwalt example combined with the TypeA_lightweight example from RC Switch and I can successfully say that I was able to control my switches !!!
                    YAY! , now how do I add the temperature part as I need to monitor two temperature sensors from the device.
                    FYI, this is the sketch I have that works :
                    #include <RF24.h>
                    #define SEND_DATA 3
                    int RCLpin = 3;
                            RCLtransmit(1,3);
                                RCLtransmit(1,3);
                                RCLtransmit(3,1);
                        RCLtransmit(1,31);
                     gw.sendSketchInfo("RF433", "0.1");
                    // Turn on  socket 1
                     delay(50);
                     delay(50);
                    // Turn on  socket 2
                     delay(50);
                     delay(50);
                    // Turn on  socket 3
                     delay(50);
                     delay(50);
                     delay(50);
                    • C Offline
                      C Offline
                      CaptainZap
                      Just an update on this, I've spent several hours today but I was able to get the sketch to show up 1 temperature sensor, and then two temperature sensors. Now the problem I have is that the two temperature sensors display the same value. They are connected to different pins on the arduino, 4 and 5, and are not wired in parallel. This is the temperature sensor part :
                      float lastTemperature1 ;
                      #define CHILD_ID_T1 4 //CHILD ID for temperature sensor1
                      #define CHILD_ID_T2 5 //CHILD ID for temperature sensor2
                      MyMessage tempMsg2(CHILD_ID_T2,V_TEMP);
                      {...} // the lights part
                       gw.present(CHILD_ID_T1, S_TEMP);
                       gw.present(CHILD_ID_T2, S_TEMP);
                                  float tempD = DallasSensors.getTempCByIndex(2);
                      	if (lastTemperature1 != tempD && tempD != -127.00) {
                      		gw.send(tempMsg2.set(tempD,1));
                      		lastTemperature1=tempD;
                      Anyone got any hints ? I'm so close on finalizing this ! I've learned a lot over the last couple of days :D
                      LE: After writing this here I realized I didn't declare the second pin in the code and thus was using the same one. I've corrected that and this WAS IT !
                      • T Offline
                        T Offline
                        tbowmo
                        @CaptainZap
                        Why did you connect the two sensors to two different pins on the arduino? Onewire bus is exactly what it says, only a single wire, and a bus (meaning that it supports multiple devices)
                        you have
                        OneWire onewire(ONE_WIRE_BUS)
                        ONE_WIRE_BUS is the pin that all your DS1820 sensors are connected to..
                        • T tbowmo
                          @CaptainZap
                          you have
                          C Offline
                          C Offline
                          CaptainZap
                          @tbowmo Because I don't know how to use the library correctly. I don't know how to display two sensors connected to the same port so I've done it how I knew. I am a beginner at coding and I know it can be simplified but this is as much as I know. I would like to see how you would do it :)
                          This is my last code for the temperature part:
                          #define ONE_WIRE_BUS 4 // Pin where dallas sensor is connected - on Rboard this is A0(D14)
                          #define ONE_WIRE_BUS2 5
                          OneWire oneWire2(ONE_WIRE_BUS2);
                          DallasTemperature DallasSensors2(&oneWire2);
                                      DallasSensors2.requestTemperatures();
                                      float tempD = DallasSensors2.getTempCByIndex(1);
                          • HeinzH Offline
                            HeinzH Offline
                            Heinz
                            wrote on last edited by Heinz
                            Indexes usually start at 0 not at 1
                            try getTempCByIndex(0);
                            • C Offline
                              C Offline
                              CaptainZap
                              As per @Heinz suggestion I was able to use only one pin to get both temperature values, now I'm looking at lowering the refresh rate interval, now happens very fast. He suggested using millis(), but didn't help much.
                              Also I have one other question, I've noticed that when the node is on my desk (about 5 meters and 1 wall) from the gateway the RF switches no longer work, but the sensors do keep updating without any issues. I don't understand exactly why would this be the case.
                              LE: Seems that the issue with the RF is related to the power output from my USB port, I changed to a different one and it works without issue. Weird anyway.
                              • C CaptainZap
                                T Offline
                                T Offline
                                tbowmo
                                Take a look at the dallas example that comes with the mysensors library it supports multiple ds1820s.
                                http://www.mysensors.org/build/temp
                                Think that everything you need is there.
                                • HeinzH Offline
                                  HeinzH Offline
                                  Heinz
                                  @CaptainZap I had the same problem with the range.
                                  The sensor is able to send data to the gateway but the gateway fails to send commands to the sensor.
                                  I found out that the maximum power level of the gateway sender is not set to maximum by default, but the
                                  level of the sensor is. I simply changed the value before compiling the gateway in
                                  MyConfig.h
                                  #define RF24_PA_LEVEL_GW RF24_PA_MAX
                                  • HeinzH Heinz
                                    MyConfig.h
                                    C Offline
                                    C Offline
                                    CaptainZap
                                    @Heinz Thanks for pointing that out, since I plan to have most if not all my sensors ac powered I'll change that.
