  3. Cross compile mysensors gateway
gatewayraspberry pi
6 Posts 4 Posters 1.3k Views 4 Watching
  • Jasper van ZuijlenJ Offline
    Jasper van Zuijlen
    Hi!
    I'm about to attempt to cross compile a gateway for Arm (raspi 1 b+) on Ubuntu. Has anymore tried that before (I could't find any posts related)? Would it be interesting to document this here as well?
    monteM 1 Reply Last reply
    • Jasper van ZuijlenJ Jasper van Zuijlen
      Hi!
      monteM Offline
      monteM Offline
      monte
      wrote on last edited by monte
      @Jasper-van-Zuijlen well, it took 6 minutes to compile on my Raspberry 1 B+, so no big deal, but if you will achieve cross compiling, I think documenting it here will be much appreciated :)
      • J Offline
        J Offline
        Jens Jensen
        maybe a good knowledge resource for cross-compilation against rpi targets:
        https://tttapa.github.io/Pages/Raspberry-Pi/C++-Development/Building-The-Toolchain.html
        • mfalkviddM Offline
          I use ccache, so recompiling (which I do occasionally when I try to help forum members troubleshooting) doesn't take much time.
            Jasper van Zuijlen
            @monte yeah, it does only take that long. I think I got sidetracked a bit 😅 I usually set up my pi by Ansible, but it's very slow. I was thinking about ways to speed that up.
            Maybe get my project working first before I dive into this. I'll post what I have so far shortly should anyone be interesed.
            Thanks for screwing my head on straight again 😁
              Jasper van Zuijlen
              wrote on last edited by Jasper van Zuijlen
              As promised, what I found so far: the following dockerfile yeilds a usable cross-compile environment, provided you use it with a Makefile.
              FROM ubuntu:xenial
              RUN apt-get update \
                  && apt-get install --yes \
                    vim \
                    build-essential \
                    git
              RUN git clone https://github.com/raspberrypi/tools
              RUN git clone https://gist.github.com/3873805.git /build
              WORKDIR "/build"
              CMD ["/usr/bin/make", "CC=/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian-x64/bin/arm-linux-gnueabihf-gcc"
              , "HelloWorld"]
              # Seems I need a real makefile for the above to work.
              For cross compiling mysensors to work, hoever, you also need to properly seed the variable in configure, for it to work correctly. This is where I left off.
              Sources:
              https://stackoverflow.com/questions/18007326/how-to-change-default-values-of-variables-like-cc-in-makefile
              https://bitbucket.org/mitchallen/pi-hello-cross-compile/src/master/
              https://desertbot.io/blog/how-to-cross-compile-for-raspberry-pi
              https://github.com/mitchallen/pi-cross-compile/blob/master/Dockerfile
              https://github.com/mysensors/MySensors/blob/development/configure
              https://github.com/raspberrypi/tools/tree/master/arm-bcm2708/arm-bcm2708-linux-gnueabi/bin
              https://www.raspberrypi.org/documentation/linux/kernel/building.md
              https://www.mysensors.org/build/raspberry
              12.1k
