  3. MQTT RETAIN messages work a little strangely
5 Posts 2 Posters 731 Views 2 Watching
  • C
    C
    Clone Tv
    MQTT RETAIN messages work a little strangely. The first ones always come and are recorded by the mosquito server, but all subsequent messages do not reach and are not recorded by the server .. The RETAIN flag is naturally set.
    • C Clone Tv
      @Clone-Tv what exactly is your issue? Is it with the mosquitto MQTT broker, the MQTT mysensors gateway, or...?
      • C
        C
        Clone Tv
        Yes, I am using the mosquitto MQTT broker, but the problem is most likely with the mysensors MQTT gateway. On Mosquito, I am able to write a packet with the retained flag from the console, and it works.
        • C Clone Tv
          @Clone-Tv Could you post your sketch, gateway log and which hardware you're using?
          E.g. the default MQTT gateways don't set MY_MQTT_CLIENT_PUBLISH_RETAIN, so the stack behaves differently when set (https://github.com/mysensors/MySensors/blob/6c4b8055f729d1582b52068e3e858b77803a18b3/core/MyGatewayTransportMQTTClient.cpp#L129)
          • C
            C
            Clone Tv
            wrote on last edited by Clone Tv
            I do not use signed messages, so I used the Signed flag in the MySensors packet header to implement selective MQTT retain state.
            Gateway is ESP2866 - no specific code.
            Code send from client:
            template<typename T>
            void reportMsg(const uint8_t & id, const mysensors_data_t & tag, const T & val, const bool retain) {
                MyMessage msg(id, tag);
                msg.setSigned(retain);
                send(msg.set(val), true);
            Lite patch MyGatewayTransportMQTTClient.cpp:
            bool gatewayTransportSend(MyMessage &message) {
               bool retain = message.getSigned();
               message.setSigned(false);
