  3. Message Payload type
7 Posts 3 Posters 895 Views 3 Watching
  • R Offline
    R Offline
    r-nox
    wrote on last edited by r-nox
    I'm sending a message from node to node but when the message gets there it's the wrong type.
    I need to send as P_STRING but it's showing as P_INT16
    This is my send
    void sendToReceiver(boolean reed_tripped)
     char percent;
     Serial.print(" Light Status ");
     Serial.println(reed_tripped);
    switch (reed_tripped) {
     case 0:
     percent = "0";
     send(msgDimmer_to_5.setDestination(5).setSensor(0).set(percent).setType(V_PERCENTAGE));
     //send(msgDimmer_to_5.setDestination(5).setSensor(0).set(percent));
     //send(msgDimmer_to_5.set(percent, 0));
     case 1:
     percent = "30";
    and the message
    2836 !TSF:MSG:SEND,8-8-5-5,s=0,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=NACK:4
    2842 !TSF:RTE:N2N FAIL
    2846 TSF:MSG:SEND,8-8-0-5,s=0,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:4
    2854 MCO:SLP:MS=360000,SMS=0,I1=0,M1=1,I2=255,M2=255
    2861 TSF:TDI:TSL
    What the heck am I doing wrong?
    • R r-nox
      This is my send
       char percent;
       case 0:
       percent = "0";
       case 1:
       percent = "30";
      and the message
      2861 TSF:TDI:TSL
      @r-nox you are setting the message type to V_PERCENTAGE. You probably want to use V_TEXT.
      R 1 Reply Last reply
      • fritsF Offline
        fritsF Offline
        frits
        @r-nox said in Message Payload type:
        char percent;
        Your data is of type char. Make it char *. Something like
        char buf[MAX_PAYLOAD_SIZE+1];
        strcpy ( buf, "30" );
        send(msgDimmer_to_5.setDestination(5).setSensor(0).set(buf).setType(V_TEXT));
        • fritsF frits
          char percent;
          R Offline
          R Offline
          r-nox
          @frits
          I tried this. Here's the results. They are close but payload looks corrupted.
          strcpy ( buf, percent );
            char percent;
            case 0:
            percent = "0";
            Serial.print(" Select case is ");
            Serial.println("0");
            case 1:
            percent = "30";
            Serial.println("30");
          char buf2[MAX_PAYLOAD_SIZE+1];
          send(msgDimmer_to_5.setDestination(5).setSensor(0).set(buf2).setType(V_TEXT));
          My results have had their molecules mixed during transport. I expected "30" but received :⸮
          4870 TSF:MSG:SEND,8-8-0-5,s=0,c=1,t=47,pt=0,l=3,sg=0,ft=0,st=OK:⸮
          Any further advice?
            R Offline
            R Offline
            r-nox
            @mfalkvidd
            Sending as V_TEXT did not have the effect needed.
              char percent;
              case 0:
              percent = "0";
              send(msgDimmer_to_5.setDestination(5).setSensor(0).set(percent).setType(V_TEXT));
              case 1:
              percent = "30";
            and the results
            3201 TSF:MSG:SEND,8-8-0-5,s=0,c=1,t=47,pt=2,l=2,sg=0,ft=0,st=OK:4
            Payload still shows as P_INT16 and payload is 4 but in fact should be 30
            This should be simple. I don't understand what's going wrong.
            • fritsF Offline
              fritsF Offline
              frits
              You copied to buf, but sent buf2 ;-)
              • fritsF frits
                R Offline
                R Offline
                r-nox
                @frits Thank you for catching that. I was just reworking and now it's sending proper values. :)
