  3. Output voltage problem with StepUp Booster 3.3V
19 Posts 8 Posters 6.3k Views 7 Watching
  • warmaniacW
    warmaniacW
    warmaniac
    @pansen
    PIN Configuration :
    SOT-89-3
    • warmaniacW warmaniac
      If I understand correctly, It was measured under load , arduino mini pro 3.3V with nrf24l01+ as door sensor.
      @pansen
      on the chip is written
      LA 3.3
      17B3S
      B
      B
      boozz
      @warmaniac
      You mean both the pro-mini and nrf24l01+ are fed via this module? In that case you could say that there should be enough load for the power module to get into the 3.3V modus...
      • warmaniacW
        warmaniacW
        warmaniac
        yep , it works well without step up booster , but when I added it, voltage is too high for radio :(
        B 1 Reply Last reply
          B
          B
          boozz
          @warmaniac
          Strange...
          Have you considered using a zener (3.3V) as a protection device next to the step-up booster module?
          BR,
          Boozz
          warmaniacW 1 Reply Last reply
          • B boozz
            @warmaniac
            Strange...
            BR,
            Boozz
            warmaniacW
            warmaniacW
            warmaniac
            @boozz
            Could you please send me what you mean ?
            Something like this ?
            http://www.ebay.com/itm/New-Zener-Diode-DIP-1-2W-0-5W-2-4V-8-2V-14-Values-Choice-Free-P-P-/262770408086?var=&hash=item3d2e563a96:m:mHD19Qu_1sjnfaWnrsCUbPQ
            Will not be generating additional energy consumption?
              @boozz
              B
              B
              boozz
              @warmaniac
              The zener crossed my mind as a simple but effective way to create a stable 3.3V. It might cost some 'bleeding' amps, maybe you could limit it by using a proper series resistor.
              See this article for some more details.
              BR,
              Boozz
                Hi ,
                I ordered 5 pcs step up boosters from different sellers on ebay.com
                like here http://www.ebay.com/itm/222350595744?_trksid=p2057872.m2749.l2648&ssPageName=STRK%3AMEBIDX%3AIT
                and the problem is my output voltage which is from 3,75 - 3,83 Volts, tried many types of new batteries 2xAA input voltage was about 3,10 - 3,20 Volts . How can I solve it to have stable about 3.3 Volts .
                Thanks much.
                E
                E
                emre299
                @warmaniac
                hello, i am having the same problem. If there is no booster, the mysensors works(full 2xAA), but if there is a booster, it doesn't connect to the network.
                I connected a capacitor to the bosteer input or output and I used 2 different booster and 2 different nrf but it didn't work.
                Did you find a way to run mysesors with booster?
                caniqueC 1 Reply Last reply
                • E emre299
                  @warmaniac
                  caniqueC
                  caniqueC
                  canique
                  wrote on last edited by canique
                  @emre299 must be something wrong with the booster. Canique Boost module (I run the site selling it) outputs 3.3V no matter if no load is attached or if 50mA or more are drawn from it. It's based on the MCP16251 chip.
                  I guess the ebay modules are based on chinese chips having minimum price as the one and only design goal. Years ago I've bought 2 different ebay modules myself to test them, but they were crap (unnecessary LEDs and even if they were unsoldered the modules had bad efficiency).
                  • E
                    E
                    emre299
                    I bought 5 new ones, they didn't work either. I don't understand why it doesn't work Nrf24l01
                    YveauxY skywatchS 2 Replies Last reply
                    • E emre299
                      @emre299 the booster likely adds noise to the power line, and it is a known fact that the nrf24 is very sensitive to this.
                      Either filter the noise, or better, get a decent booster.
                      • E emre299
                        skywatchS
                        skywatchS
                        skywatch
                        @emre299 @Yveaux Is right. You could try adding a 47uF or 100uF capacitor across the 3.3V and gnd on the radio module. it is known to help in some cases.
                        If you have access to an oscilliscope you might be able to see the noise. If it is sharp spikes then a 100nF capacitor can help as before. You may need both in parallel on the radio power connections.
                        • Y
                          Y
                          yetifor
                          Banned
                          I would like to step up 3.3V from my power supply with the help of a dc-dc-boost converter to 5V and then I want to draw 500mA by placing a 10 Ohm resistor between the output-pin of the boost-converter and ground.
