  2. Feature Requests
  3. Filter node
Filter node
Scheduled Pinned Locked Moved Feature Requests
17 Posts 6 Posters 2.9k Views 6 Watching
  • SnyfirS Snyfir
    I want to have a network (A) which will not stop working when the power of the house is down. Because I have door sensor for the alarm of the house.
    And I want another network (B) which can be down when the power is off because it is not for security (temperature, humidity sensor…). This network needs to used the repeater of the network A also.
    That’s why I want nodes of network (A) use only repeaters of network (A), and nodes of network (B) use repeaters of networks (A) and (B)
    E
    E
    evb
    wrote on last edited by evb
    @Snyfir another approach is to use another radio channel for your B network? That includes of course another gateway also...
    An advantage is that you can stick with the standard MySensors library.
    More information on : https://www.mysensors.org/download/sensor_api_20 : search channel
    of course:
    This will not be possible....
    • TheoLT
      TheoLT
      TheoL
      In all honesty mixing rfm69 and nrf24L01+, as @evb, suggests seems to me to be a way that isn't complicated and doesn't acquire any additional coding. I think I'd go that route
      E 1 Reply Last reply
      • TheoLT TheoL
        E
        E
        evb
        @TheoL sorry, I didn't have that in mind, but of course that is also a possibility. :-)
        With the RF24, we can configure another channel
         * @def MY_RF24_CHANNEL
         * Frequencies: 2400 Mhz - 2525 Mhz
         * Channels: 126
         * @see https://www.nordicsemi.com/eng/nordic/download_resource/8765/2/42877161/2726
         * - 0 => 2400 Mhz (RF24 channel 1)
         * - 1 => 2401 Mhz (RF24 channel 2)
         * - 76 => 2476 Mhz (RF24 channel 77)
         * - 83 => 2483 Mhz (RF24 channel 84)
         * - 124 => 2524 Mhz (RF24 channel 125)
         * - 125 => 2525 Mhz (RF24 channel 126)
         * In some countries there might be limitations, in Germany for example only the range
         * 2400,0 - 2483,5 Mhz is allowed.
         * @see http://www.bundesnetzagentur.de/SharedDocs/Downloads/DE/Sachgebiete/Telekommunikation/Unternehmen_Institutionen/Frequenzen/Allgemeinzuteilungen/2013_10_WLAN_2,4GHz_pdf.pdf
        #ifndef MY_RF24_CHANNEL
        #define MY_RF24_CHANNEL (76)
        If we use RFM69 radio, we can define the network ID
        #define 	MY_RFM69_NETWORKID   (100)
         	RFM69 Network ID. Use the same for all nodes that will talk to each other.
        • SnyfirS
          SnyfirS
          Snyfir
          I understand what you said. For further project I wild I think used two channels.
          But right now, I don’t want to change the hardware. If nobody can tell me if the solution i propose in post 2 works, I will try it.
          • SnyfirS Snyfir
            @Snyfir thanks for explaining. How come you want the B sensors to be disabled when the power is off? Why can’t they be allowed to continue working?
            SnyfirS 1 Reply Last reply
              SnyfirS
              SnyfirS
              Snyfir
              @mfalkvidd said in Filter node:
              I don't want the B sensors to be disable when the power is off. It's juste because sensors B is not on battery and if the power of the house is off, sensors B can't works
              • SnyfirS Snyfir
                @Snyfir if they can't work anyway, why do you want to filter them?
                  SnyfirS
                  SnyfirS
                  Snyfir
                  wrote on last edited by Snyfir
                  I don't want that repeaters without battery are used by security nodes (door status, PIR...). Because if the power of the house is down, security nodes while not works during a moment.
                  That's why i want repeaters without battery to reject security nodes
                  alexeliteA 1 Reply Last reply
                  • SnyfirS Snyfir
                    alexeliteA
                    alexeliteA
                    alexelite
                    @Snyfir In your first post you say that only one node is mains powered. Instead of modifying the library, why not provide a UPS type power supply for that node. Something with an old phone battery or 1-2 18650 cells.
                    But I guess the other two already have something like this, they are not battery only.
                    That way if the power goes down all your repeaters are up.
                    • TheoLT
                      TheoLT
                      TheoL
                      In all honesty, I'm not quite convinced you'd need two separate networks. Just provide the security sensors, the repeaters, the gateway and your controller - that form the security system - with some sort of ups and they will keep running until the UPS has no more power left.
                      The none security devices will stop working when the power goes out and, unless I don't really understand your problem well. That does what I think you want to achieve? Unless you have combined a lot of sensors within a repeater it would really be my way to go. It wouldn't mean any modifications to your security hardware, because they need to be battery powered or have some sort of UPS anyway, to keep working when the power goes down.
                      But again it's hard to judge when you don't really understand the problem some one is trying to solve.
