  3. Messages list without ack
11 Posts 2 Posters 1.5k Views 2 Watching
  • T Offline
    T Offline
    tropicaxarquia
    how can reset the list of messages pending receive ack in the gateway from the node?
    regards
    • T tropicaxarquia
      regards
      @tropicaxarquia there is no such list
      • T Offline
        T Offline
        tropicaxarquia
        @mfalkvidd it's very strange. Some messages that I had sent from a Domoticz python sketch sent V_VAR24-25-26 and they have worked, but in the sending I put 1 in ack instead of 0 and the arduino sckets did not manage the ack and therefore they have stayed in some queue and sends them constantly (every so often the same message over and over again from the gateway). If I send another message modifying V_VAR26 to the same node, it works, but after a short time the gateway sends the original message again (the one that had ack in its format).
        this has me crazy!!!!
        • T tropicaxarquia
          @tropicaxarquia the list must be in Domoticz. The gateway has no list.
          • mfalkviddM Offline
            Maybe restarting Domoticz helps? I have never tried sending messages from Domoticz.
            • T Offline
              T Offline
              tropicaxarquia
              @mfalkvidd I have stopped the domoticz service and the mysensors log sends these messages every minute: DEBUG TSF: MSG: READ, 10-10-0, s = 3, c = 2, t = 26, pt = 0, l = 0, sg = 0.
              It is MySensors who sends a READ request to the nodes and when domoticz is up, they respond but if it is not up, the nodes do not respond???
              • T Offline
                T Offline
                tropicaxarquia
                I am using in node 10 the sketch of the irrigation example
                • T Offline
                  T Offline
                  tropicaxarquia
                  This occurs when from python: s.sendall(b"" + nodoID + ";" + childID + ";1;1;26;" + timeAllZones + b"\n").
                  When i changed the ACK from 1 to 0 in the message structure this has stopped happening. but all messages sent with ack to 1 are automatically forwarded again and again...
                  • T Offline
                    T Offline
                    tropicaxarquia
                    Resuelto.
                    Tanks
                    • T tropicaxarquia
                      Resuelto.
                      Tanks
                      Nice work @tropicaxarquia
                      Could you share how you resolved it, in case someone else finds themselves in a similar situation?
                      • T Offline
                        T Offline
                        tropicaxarquia
                        In sketch definitions:
                        MyMessage msg1valve(CHILD_ID_IRRIGATION_SYSTEM, V_LIGHT);
                        MyMessage var1valve(CHILD_ID_IRRIGATION_SYSTEM, V_VAR1);
                        MyMessage var2valve(CHILD_ID_IRRIGATION_SYSTEM, V_VAR2);
                        MyMessage var3valve(CHILD_ID_IRRIGATION_SYSTEM, V_TEXT);
                        in sketch receive function:
                        if (message.type == V_LIGHT)
                        DEBUG_PRINT(F("Recibida V_VAR1 de la válvula:"));
                        DEBUG_PRINT(i);
                        DEBUG_PRINT(F(" = "));
                        DEBUG_PRINTLN(variable1);
                        if (variable1 != allZoneTime[i]) // es un valor diferente del que había anteriormente
                        allZoneTime[i] = variable1;
                        zoneTimeUpdate = true;
                              //enviar valor al contrtolador
                              send(var1valve.setSensor(i).set(variable1), false);
                            receivedInitialValue = true;
                            DEBUG_PRINT(F("Recibida V_VAR2 de la válvula:"));
                            DEBUG_PRINT(i);
                            DEBUG_PRINTLN(variable2);
                            if (variable2 != valveSoloTime[i]) // es un valor diferente del que había anteriormente
                              valveSoloTime[i] = variable2;
                              send(var2valve.setSensor(i).set(variable2), false);
                          else if (message.type == V_TEXT)
                            if (newMessage.length() == 0)
                              DEBUG_PRINT(F("No se ha recibido NOMBRE (V_TEXT) para la zona "));
                              DEBUG_PRINTLN(i);
                            if (newMessage.length() > 16)
                              newMessage.substring(0, 16);
                            valveNickName[i] = "";
                            String val = String(valveNickName[i]);
                            DEBUG_PRINT(F("Recibida V_TEXT de la válvula: "));
                            DEBUG_PRINT(i);
                        In domoticz:
                        each scene for each valve who on action:
                        script://exec.sh irrigation_single_zone 10 1 0 5 "Zona 1"
                        in /domoticz/scripts/exec.sh:
                        #!/bin/sh
                        case $1 in
                        irrigation_single_zone)
                        python /home/pi/domoticz/scripts/python/send_vars_to_irrigation_system.py --nodo_id=$2 --child_id=$3 --time_all_zones=$4 --time_single_zone=$5 --n$
                        exit 0
                        irrigation_all_zones)
                        python /home/pi/domoticz/scripts/python/send_vars_to_irrigation_system.py --nodo_id=$2 --child_id=1 --time_all_zones=$3 >/dev/null 2>&1 &
                        python /home/pi/domoticz/scripts/python/send_vars_to_irrigation_system.py --nodo_id=$2 --child_id=2 --time_all_zones=$3 >/dev/null 2>&1 &
                        python /home/pi/domoticz/scripts/python/send_vars_to_irrigation_system.py --nodo_id=$2 --child_id=3 --time_all_zones=$3 >/dev/null 2>&1 &
                        python /home/pi/domoticz/scripts/python/send_vars_to_irrigation_system.py --nodo_id=$2 --child_id=4 --time_all_zones=$3 >/dev/null 2>&1 &
                        python /home/pi/domoticz/scripts/python/send_vars_to_irrigation_system.py --nodo_id=$2 --child_id=5 --time_all_zones=$3 >/dev/null 2>&1 &
                        python /home/pi/domoticz/scripts/python/send_vars_to_irrigation_system.py --nodo_id=$2 --child_id=6 --time_all_zones=$3 >/dev/null 2>&1 &
                        python /home/pi/domoticz/scripts/python/send_vars_to_irrigation_system.py --nodo_id=$2 --child_id=7 --time_all_zones=$3 >/dev/null 2>&1 &
                        python /home/pi/domoticz/scripts/python/send_vars_to_irrigation_system.py --nodo_id=$2 --child_id=8 --time_all_zones=$3 >/dev/null 2>&1 &
                        exit 0
                        esac
                        /domoticz/scripts/python/send_vars_to_irrigation_system.py:
                        #!/usr/bin/python3
                        import socket
                        from time import sleep
                        import sys
                        import argparse
                        #import DomoticzEvents as DE
                        def gwsend(args):
                        nodoID = str.encode(str(args.nodo_id))
                        childID = str.encode(str(args.child_id))
                        timeAllZones = str.encode(str(args.time_all_zones))
                        timeSingleZone = str.encode(str(args.time_single_zone))
                        nameZone = args.name_zone
                        s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
                        s.connect(("127.0.0.1", 5003))
                        sleep(3)
                        #estructura del mensaje
                        #99: Node ID
                        #1: ChildId
                        #1: command (Set in this case)
                        #0: ACK (None in this case)
                        #47: V_TYPE (V_TEXT in this case), 24-25-26 V_VAR1-2-3
                        #enviar tiempo duracion en modo All Zones (V_VAR1 -> value 24)
                        if timeAllZones != "None":
                        s.sendall(b"" + nodoID + ";" + childID + ";1;0;24;" + timeAllZones + b"\n")
                        sleep(3)
                        #enviar tiempo de duracion en modo Single zone(V_VAR2 -> value 25)
                        if timeSingleZone != "None":
                        s.sendall(b"" + nodoID + ";" + childID + ";1;0;25;" + timeSingleZone + b"\n")
                        sleep(3)
                        #enviar nombre de zona (V_VAR3 -> value 26)
                        if nameZone is not None:
                        s.sendall(b"" + nodoID + ";" + childID + ";1;0;47;" + nameZone + b"\n")
                        sleep(3)
                        s.shutdown(socket.SHUT_WR)
                        s.close()
                        def main():
                        my_parser = argparse.ArgumentParser(prog='send_vars_to_irrigation_system',
                        usage='%(prog)s --nodo_id=NODO_ID --child_id=VALVULA_ID, [--time_all_zones=TIME_EN_MODO_TODAS] [--time_single_zone$
                        description='Envio de parametros de cada zona al sistema de riego')
                        my_parser.version = '1.0'
                        my_parser.add_argument('--nodo_id',
                        type=int,
                        action='store',
                        required=True,
                        help='ID del nodo Sistema de Riego')
                        my_parser.add_argument('--child_id',
                        type=int,
                        action='store',
                        required=True,
                        help='ID de la valvula')
                        my_parser.add_argument('--time_all_zones',
                        type=int,
                        action='store',
                        required=False,
                        help='Duracion en modo Todas las zonas')
                        my_parser.add_argument('--time_single_zone',
                        type=int,
                        action='store',
                        required=False,
                        help='Duracion en modo Solo esta zona')
                        my_parser.add_argument('--name_zone',
                        type=str,
                        action='store',
                        required=False,
                        help='Nombre de la zona')
                        args = my_parser.parse_args()
                        gwsend(args)
                        if name == 'main':
                        main()
