  3. Measuring battery voltage, which way is best?
24 Posts 6 Posters 3.3k Views 5 Watching
  • BearWithBeardB
    BearWithBeardB
    BearWithBeard
    wrote on last edited by BearWithBeard
    The URL is in an inline code HTML element and the CSS rule #article code {white-space: nowrap;} prevents long lines from breaking the layout, causing the (visual) truncation depending on the window size. Double-clicking or marking the whole line with the cursor gives you the full link, but you can't simply click on it to open the URL. A hyperlink would wrap (and be clickable).
    I assume this is only a temporary solution. It might be better though to replace it with a hyperlink tag or better, embed it like the external measurement example in the section below it (once it's added to the examples repo).
    @mfalkvidd Okay, understood. Managing external libraries in ArduinoIDE projects can be cumbersome and confusing. Just brainstorming here - two ways of clarifying that external libraries are required in a provided example sketch:
    • After including an external library, add a conditional #error preprocessor directive that checks if the library-specific header guard is defined. This doesn't address backwards compatibility issues though:
    #include <Vcc.h>
    #ifndef VCC_H
    #error You need to install Arduino_VCC version 1.x (URL)
    #error How to install libraries in ArduinoIDE: (URL)
    • Provide a "Notice" box or something like that above the embedded sketch on the website: (quickly hacked together):
    • BearWithBeardB BearWithBeard
      #include <Vcc.h>
      #ifndef VCC_H
      @BearWithBeard said in Measuring battery voltage, which way is best?:
      Nor forward compatibility, as "#pragma once" is much more common these days than using an include guard
      • V
        V
        virtualmkr
        Hello all, may be I did not get the point of this thread, but a very similar code to measure the AVR CPU voltage is already part of the MySensors library: MyHwAVR.cpp#L289
        I use it in some of my PIR sensors and it works fine. Simply call hwCPUVoltage() to get it.
        This is from my code:
        void sendBatteryLevel()
          // This calls the internal voltage measurement
          uint16_t voltage = hwCPUVoltage();
          // Li AAA Cell Voltage range: discharged - full 2.6V - 3.0V
          uint16_t batteryPcnt = map(voltage, 2600, 3000, 0, 100);
          batteryPcnt = constrain(batteryPcnt, 0, 100);
          // This MySensors function sends the "internal battery info" to the gateway
        BR Immo
        skywatchS 1 Reply Last reply
        • V virtualmkr
          BR Immo
          skywatchS
          skywatchS
          skywatch
          @virtualmkr Thanks - I did not know that - it is really helpful! :)
          The original purpose was that the 'build' section on 'battery power' was missing anything about the 'internal voltmeter' and only mentioned the external components method.
          V 1 Reply Last reply
          • skywatchS skywatch
            V
            V
            virtualmkr
            @skywatch Thank you for clarifying. And nice that you like my implementation :-)
            I also find it very good and helpful for beginners to show the internal battery measurement method on the "Battery Power" page from MySensors. When I started with MySensors I followed the instructions for measuring via analog pin and 2 resistors. The more simple internal measurement I discovered way much later.
            BTW there are some more built in functions, e.g. for the current CPU frequency and the current free heap size. With the MYSController you can query these values from the individual nodes:
            You need only to add the #define for this functionality in your Node sketch:
            // Enable support for I_DEBUG messages.
            #define MY_SPECIAL_DEBUG
            • V virtualmkr
              skywatchS
              skywatchS
              skywatch
              @virtualmkr Thanks - this is really useful stuff which is 'hidden away' and should really be seen by all coming to mysensors for the first time. I hope @mfalkvidd will find a way to get this into the battery section.
              I modified your implementation a little to better suit my needs, as follows....
                // This calls the internal voltage measurement and converts to Volts.
                 wait(250);                                        //Allow power lines to settle.
                 float voltage = hwCPUVoltage()/1000;
                 wdt_reset();
                 batteryPcnt = map(voltage, brown_out_voltage, BattMax, 0, 100);
                //batteryPcnt = constrain(batteryPcnt, 0, 100);
                if(batteryPcnt != oldBatteryPcnt){
                oldBatteryPcnt = batteryPcnt;
              I wanted it all in volts and not mV and also not send unless there is a change in % level to further reduce battery usage. For some reason the 'constrain' function gives a warning in minicore so I leave it out for now.
              The image you posted shows frequency as "cHz". I am not familiar with that term, do you know what it is?
                   wdt_reset();
                V
                V
                virtualmkr
                @skywatch Thank you for the minicore tip. I was not aware of this project.
                Implementation of constrain() in minicore differs from constrain() implementation in the original Arduino core.
                So maybe it is a minicore issue. Or may be your batteryPcnt type is float?
                Neverless one should prevent battery percentage below 0% or above 100% because it makes no much sense.
                "cHz" is actually strange but it means 0.1 x MHz, so for my ESP8266 I get 1600 x 0.1 MHz = 160 MHz:
                This way the frequency value fits well into uint16_t type.
                • V virtualmkr
                  skywatchS
                  skywatchS
                  skywatch
                  @virtualmkr Thanks for the information, very interesting.
                  My batteryPcnt is an int. The voltage is defined as a float but as I understand it any math between a float and an int will always result in an int, expecially if the variable it is being stored in is an int.
                  cHz! Well I learn something new, so that is good! ;)
                  As for minicore, it does get a mention in the bootloader page on this site and I like it as it is easy to use and I don't need to keep going to the command line or avrdudess all the time, it all works within arduino ide. As a big plus it was upgraded to version 2.1.0 today and the constrain issue has been fixed!
                  • mfalkviddM
                    My pull request has now been merged to the MySensors development branch. I have updated the battery page to show the example sketch for internal measurement. Note that the internal measurement method does not work on all supported mcus (not esp8266 for example) but I don't think it matter much since the battery page recommends a Pro Mini which works.
                    Special thanks to @hek for tracking down a tricky display problem with the sketch inclusion, and to @Yveaux, @user2684 and @tekka for feedback on the pull request.
                      skywatchS
                      skywatchS
                      skywatch
                      @mfalkvidd Good News! :)
                      But I am curious where the "+ 0.5" vomes from in this line.....
                      int batteryPcnt = batteryMillivolts / FULL_BATTERY / 1000.0 * 100 + 0.5;
                      zboblamontZ mfalkviddM 2 Replies Last reply
                        zboblamontZ
                        zboblamontZ
                        zboblamont
                        @skywatch Rounding up to the nearest int ?
                          #23
                          @skywatch as @zboblamont said, it makes sure we have ”proper” rounding. In C, floating point numbers are always rounded down Ehrn converted to an integer. So 42.8 becomes 42. By adding 0.5, we get the rounding expected by most humans in most cases.
                          To read about different rounding methods, see https://en.wikipedia.org/wiki/Rounding#Rounding_to_the_nearest_integer
                          My personal favorite is called ”banker’s rounding” but I did not use it in this sketch.
                          • skywatchS
                            skywatchS
                            skywatch
                            #24
                            @zboblamont & @mfalkvidd - Thank you for that. It never occured to me that rounding might need some help. But now it makes logical sense.
                            @mfalkvidd I guess if you used 'bankers rounding' you would always end up with 0.
