  3. watchdog 2021
watchdog 2021
5 Posts 3 Posters 802 Views 4 Watching
  • skywatchS
    skywatchS
    skywatch
    I have been reading through the posts on watchdogging and still not sure about it, so here is a question that perhaps someone can answer.......
    Is the below code snippet the right way to use watchdog in 2.3.2? Do I need the #include <avr/wdt.h> is it already in the mysensors package?
      wdt_disable();
      wait(250);
      wdt_enable(WDTO_8S);
      wdt_reset();
    This is to use on a gateway but is the same method implemented on sleeping nodes?
    I will be using the minicore bootloaders which I believe are optiboot forks.
    • Melih KuligM
      Melih KuligM
      Melih Kulig
      @skywatch, I don't know if you're still looking for the answer, but in case you are, or anyone else who hits through google search, from what I understand reading this page: https://www.nongnu.org/avr-libc/user-manual/group__avr__watchdog.html , you can set your watchdog timer with wdt_enable(time constant), time constant is typically in WDTO_XS format, where X is the seconds, however not all values are available for all processors, please see the link to check which values are supported.
      Next thing to do is including wdt_reset() on your loop. This will reset the timer. If the timer isn't reset by the time your counter expires, watchdog will trigger.
      skywatchS 1 Reply Last reply
      • Melih KuligM Melih Kulig
        skywatchS
        skywatchS
        skywatch
        @Melih-Kulig Thanks - #i actually used the code above and it has been working OK for the last 10 days, so no bad effect. I don't know if the watchdog has had to kick in yet but it seems not.
        • V
          V
          virtualmkr
          Hi all,
          I'd like to add, there is no need to call wdt_reset() explicitly in loop().
          This already takes place before each loop() call in the MySensors library code behind function doYield():
          see: MySensorsCore.cpp#L619
          And hwWatchdogReset() is an HW abstraction of wdt_reset() for AVR architecture:
          /hal/architecture/AVR/MyHwAVR.h#L71
          My call stack from main() to doYield() is:
          >	MySensorsProject2.exe!doYield() Line 650	C++
           	MySensorsProject2.exe!_processInternal() Line 74	C++
           	MySensorsProject2.exe!_process() Line 91	C++
           	MySensorsProject2.exe!main(int argc, char * * argv) Line 343	C++
          • V virtualmkr
            Hi all,
            skywatchS
            skywatchS
            skywatch
            @virtualmkr That is useflul to know - thanks! - As it happens I think I had my first wdt 'kick' early this morning as the Gateway with the wdt on was showing as up for 3 hours instead of the 4 days I was expecting, so it restarted and all is still working ;)
