  3. OpenHAB
  4. OH3 - MySensors Binding
135 Posts 34 Posters 36.0k Views 40 Watching
  • N ncollins
    @haloway13 you have any logs or screenshots of errors you're seeing?
    H
    H
    haloway13
    @ncollins best I can do is say that it was a java io exception of some sort associated with the bridge or broker. I have since started from scratch several times and have not taken any screenshots.
    I have faithfully followed directions from: https://github.com/tobof/openhab2-addons/wiki/Installation
    Then it is a bit of a mystery to me how to finish up the configuration through the web pages.
    Any help would be greatly appreciated!
    • N
      N
      ncollins
      Hmm, I don't use openhabian, but it looks like there is a log viewer built in: http://openhabian:9001 (maybe change openhabian to the IP of your pi).
      Without logs or screenshots, it'll be impossible to help.
      H 1 Reply Last reply
      • N ncollins
        H
        H
        haloway13
        @ncollins
        openhab log:tail output
        log:set DEBUG org.openhab.binding.mysensors
        openhab> log:tail
        20:17:49.861 [INFO ] [b.core.internal.i18n.I18nProviderImpl] - Time zone set to 'America/Denver'.
        20:17:49.924 [INFO ] [b.core.internal.i18n.I18nProviderImpl] - Location set to '39.82834020908714,-105.06875216960907'.
        20:17:49.929 [INFO ] [b.core.internal.i18n.I18nProviderImpl] - Locale set to 'en_US'.
        20:18:27.583 [INFO ] [b.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
        20:18:33.947 [INFO ] [org.openhab.ui.internal.UIService    ] - Started UI on port 8080
        20:18:35.072 [INFO ] [re.automation.internal.RuleEngineImpl] - Rule engine started.
        20:18:36.112 [INFO ] [hab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
        20:25:15.958 [INFO ] [ig.discovery.internal.PersistentInbox] - Added new thing 'mqtt:systemBroker:mosquitto' to inbox.
        20:25:15.959 [INFO ] [openhab.event.InboxAddedEvent        ] - Discovery Result with UID 'mqtt:systemBroker:mosquitto' has been added.
        20:25:17.970 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid 86f6e016-3847-404f-80dc-a5abb81f6b2d
        20:25:28.579 [INFO ] [t.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.151'. Next attempt in 60000ms
        20:25:28.673 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid 86f6e016-3847-404f-80dc-a5abb81f6b2d
        20:26:28.685 [INFO ] [t.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.151'. Next attempt in 60000ms
        20:26:28.694 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid 86f6e016-3847-404f-80dc-a5abb81f6b2d
        Broker config screen:
        Addition to the Inbox:
        Clicking the inbox. This is where I have no clue as to how to proceed...
        • H
          H
          haloway13
          so to follow up:
          Here is the log after adding the thing systembroker:
          21:28:27.906 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid bd9a756d-5cf7-46b0-adaa-856d29f8b587
          21:29:27.913 [INFO ] [t.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.151'. Next attempt in 60000ms
          21:29:27.920 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid bd9a756d-5cf7-46b0-adaa-856d29f8b587
          21:30:27.925 [INFO ] [t.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.151'. Next attempt in 60000ms
          21:30:27.933 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid bd9a756d-5cf7-46b0-adaa-856d29f8b587
          21:31:05.860 [INFO ] [openhab.event.InboxRemovedEvent      ] - Discovery Result with UID 'mqtt:systemBroker:mosquitto' has been removed.
          21:31:06.015 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:systemBroker:mosquitto' changed from UNINITIALIZED to INITIALIZING
          21:31:06.072 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:systemBroker:mosquitto' changed from INITIALIZING to OFFLINE
          21:31:06.079 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid bd9a756d-5cf7-46b0-adaa-856d29f8b587
          21:31:06.130 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:systemBroker:mosquitto' changed from OFFLINE to OFFLINE (COMMUNICATION_ERROR): Timeout
          21:31:06.135 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:systemBroker:mosquitto' changed from OFFLINE (COMMUNICATION_ERROR): Timeout to OFFLINE (COMMUNICATION_ERROR): java.io.IOException: Connection reset by peer
          21:31:27.938 [INFO ] [t.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.151'. Next attempt in 60000ms
          21:31:27.943 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:systemBroker:mosquitto' changed from OFFLINE (COMMUNICATION_ERROR): java.io.IOException: Connection reset by peer to OFFLINE
          21:31:27.951 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid bd9a756d-5cf7-46b0-adaa-856d29f8b587
          21:31:27.986 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:systemBroker:mosquitto' changed from OFFLINE to OFFLINE (COMMUNICATION_ERROR): java.io.IOException: Connection reset by peer
          21:32:27.956 [INFO ] [t.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.151'. Next attempt in 60000ms
          21:32:27.967 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid bd9a756d-5cf7-46b0-adaa-856d29f8b587
          21:32:27.968 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:systemBroker:mosquitto' changed from OFFLINE (COMMUNICATION_ERROR): java.io.IOException: Connection reset by peer to OFFLINE
          21:32:28.014 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:systemBroker:mosquitto' changed from OFFLINE to OFFLINE (COMMUNICATION_ERROR): java.io.IOException: Connection reset by peer
          Here is how I configured the thing:
          • fabyteF fabyte
            After reinstalling the mqtt bindung the MQTT System Broker connection now could be established - strange, that a reinstall was required since I did several OpenHAB system restarts and those didn't fix it.
            Well, now the MySensors binding is working with the system broker:
            Here's a MySensors temperature item:
            To sum up, here's what I did
            1. (manually) installed MySensors binding
            2. uninstalled mqtt binding
            3. installed mqtt binding
            4. set up the MQTT system broker connection
              4.1 set Connection Name to systembroker
              4.2 set Broker Host to localhost (it's running on the same device)
              4.3 Show advanced -> set Broker Port to 1883 since it was always using 8883 but I don't use a secure connection
              (4.4 I didn't set a clientid, no user and no password)
            5. set up the MySensors MQTT Gateway thing
              5.1 set Broker Name to systembroker
            H
            H
            haloway13
            @fabyte
            Could you post config screens for each of the things above for me?
            • N
              N
              ncollins
              One thing I had to do was explicitly set secure="false" into /opt/openhab/userdata/config/org/openhab/mqttbroker.config.
              Please try that, then restart.
              D 1 Reply Last reply
              • N
                N
                ncollins
                also, is your MQTT broker password protected? if not, remove the username and password from your system broker configuration.
                • N ncollins
                  H
                  H
                  haloway13
                  @ncollins
                  I will check tonight.
                  I really appreciate all help so far.
                  When you refer to the broker password: do you mean when you install the mqtt using the openhabian-config utility from the command line while being logged in with ssh to the Pi?
                  N 1 Reply Last reply
                  • fabyteF
                    fabyteF
                    fabyte
                    wrote on last edited by fabyte
                    #60
                    @haloway13 I had exactly the same problem.
                    Here is what I did to fix it:
                    1. uninstalled the mqtt binding
                      1.1 make sure the /opt/openhab/userdata/config/org/openhab/mqttbroker.config is removed
                    2. installed the mqtt binding
                    3. setup the system broker
                    After that, the system broker connection could be established and the Try to restore connection to '192.168.1.151'. Next attempt in 60000ms messaged disappeared.
                    Then you can proceed and set up the MySensors MQTT Bridge.
                    • H haloway13
                      @ncollins
                      N
                      N
                      ncollins
                      @haloway13 yeah, when you did the initial mqtt setup, did you protect it with a password? If not, make sure you clear out the username and password from the OpenHAB broker settings. (I’m not sure if it will fail if you provide credentials to an instance that is not password protected)
                      • fabyteF fabyte
                        H
                        H
                        haloway13
                        @fabyte
                        I am not showing such a file as mentioned in 1.1
                        2 & 3 refer to using the web interface?
                        fabyteF N 2 Replies Last reply
                        • H haloway13
                          @fabyte
                          fabyteF
                          fabyteF
                          fabyte
                          @haloway13 Yes, everything via the web interface
                          • H haloway13
                            @fabyte
                            N
                            N
                            ncollins
                            wrote on last edited by ncollins
                            #64
                            @haloway13 Here are all of my settings in my sandbox environment.
                            A couple things to note, NO MQTT BINDING INSTALLED, no special MQTT thing configured, my mqtt install is not password protected.
                            Screen Shot 2021-03-05 at 12.49.22 PM.png Screen Shot 2021-03-05 at 12.53.23 PM.png Screen Shot 2021-03-05 at 12.54.34 PM.png Screen Shot 2021-03-05 at 12.55.27 PM.png Screen Shot 2021-03-05 at 12.55.50 PM.png Screen Shot 2021-03-05 at 1.01.14 PM.png
                            My Gateway code:
                            //#define MY_RADIO_RF24
                            //#define MY_RADIO_RFM95
                            #define MY_GATEWAY_ESP8266
                            #define MY_BAUD_RATE 9600
                            #define MY_MQTT_CLIENT_ID "MYSGW01"
                            #define MY_MQTT_PUBLISH_TOPIC_PREFIX "tele/mysgw01-out"
                            #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX  "cmnd/mysgw01-in"
                            // Set MQTT client id
                            // Enable these if your MQTT broker requires username/password
                            // Set WIFI SSID and password
                            #define MY_WIFI_SSID "--------"
                            #define MY_WIFI_PASSWORD "*********"
                            // passed to the DHCP server if not static.
                            #define MY_HOSTNAME MY_MQTT_CLIENT_ID
                            // MQTT broker ip address.
                            #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 62
                            //MQTT broker if using URL instead of ip address.
                            // #define MY_CONTROLLER_URL_ADDRESS "test.mosquitto.org"
                            #define MY_PORT 1883
                            // Enable inclusion mode
                            //#define MY_INCLUSION_MODE_BUTTON_PIN D1
                            // Set blinking period
                            // Flash leds on rx/tx/err
                            //#define MY_DEFAULT_TX_LED_PIN  2  // the PCB, on board LED
                            #include <ArduinoOTA.h>
                              pinMode(LED_BUILTIN, OUTPUT);
                             ArduinoOTA.setHostname(MY_HOSTNAME);
                              ArduinoOTA.onStart([]() {
                                Serial.println("ArduinoOTA start");
                              ArduinoOTA.onEnd([]() {
                                Serial.println("\nArduinoOTA end");
                              ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
                                Serial.printf("OTA Progress: %u%%\r", (progress / (total / 100)));
                              ArduinoOTA.onError([](ota_error_t error) {
                                Serial.printf("Error[%u]: ", error);
                                if (error == OTA_AUTH_ERROR) {
                                  Serial.println("Auth Failed");
                                } else if (error == OTA_BEGIN_ERROR) {
                                  Serial.println("Begin Failed");
                                } else if (error == OTA_CONNECT_ERROR) {
                                  Serial.println("Connect Failed");
                                } else if (error == OTA_RECEIVE_ERROR) {
                                  Serial.println("Receive Failed");
                                } else if (error == OTA_END_ERROR) {
                                  Serial.println("End Failed");
                              ArduinoOTA.begin();
                              sendSketchInfo("MYSGW01-TEST Gateway","1.0");
                              present(0, S_BINARY);
                               ArduinoOTA.handle();
                                if (message.type==V_STATUS) {
                                    // Change relay state
                                    digitalWrite(LED_BUILTIN, message.getBool() ? LOW:HIGH);
                                    // Store state in eeprom
                            • N ncollins
                              My Gateway code:
                                ArduinoOTA.begin();
                              H
                              H
                              haloway13
                              wrote on last edited by haloway13
                              #65
                              @ncollins
                              Thank you so much. This has gotten me so much closer to actually getting the test temp and humidity arduino thing working.
                              I am seeing this output from the mysensors gateway:
                              Mar 05 22:55:07 DEBUG GWT:RMQ:OK
                              Mar 05 22:55:07 DEBUG GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
                              Mar 05 22:55:07 DEBUG TSM:READY:NWD REQ
                              Mar 05 22:55:07 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                              Mar 05 22:55:07 DEBUG TSF:MSG:READ,1-1-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
                              Mar 05 22:55:07 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/255/3/0/21,MSG SENT
                              Mar 05 22:55:41 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:34.0
                              Mar 05 22:55:41 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
                              Mar 05 22:55:51 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.8
                              Mar 05 22:55:51 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
                              Mar 05 22:57:01 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:34.1
                              Mar 05 22:57:01 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
                              Mar 05 22:57:11 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:34.0
                              Mar 05 22:57:11 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
                              Mar 05 22:57:41 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.8
                              Mar 05 22:57:41 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
                              Mar 05 22:59:01 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:34.0
                              Mar 05 22:59:01 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
                              Mar 05 22:59:21 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.9
                              Mar 05 22:59:21 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
                              Mar 05 22:59:41 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.8
                              Mar 05 22:59:41 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
                              Mar 05 23:00:51 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:34.0
                              Mar 05 23:00:51 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
                              Mar 05 23:01:11 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.7
                              Mar 05 23:01:11 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
                              Mar 05 23:01:21 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.8
                              My Sensors Gateway configuration: not letting me upload the image/screenshot, getting an error.
                              ![0_1615011411135_SS_2021-03-05_23-09-13.jpg](Uploading 100%)
                              Humidity Sensor thing: same problem here.
                              ![0_1615011449159_SS_2021-03-05_23-12-48.jpg](Uploading 100%)
                              I will try to edit this in the morning
                              The short of it is that I am not seeing the values I am expecting from the sensor. I am leaning towards just not identifying the id/node for each of the things/channel.
                              • H
                                H
                                haloway13
                                #66
                                Here is the humidity sensor thing page:
                                Here is the temperature:
                                Do I have the node and child id right? What should I check?
                                Or maybe I need to do a follow on configuration to see the values?
                                Thank you!
                                • H haloway13
                                  Thank you!
                                  N
                                  N
                                  ncollins
                                  @haloway13 progress!
                                  Check the channels tab of your temperature sensor thing:
                                  "Add link to item" then follow the directions to create a new item
                                  • N ncollins
                                    H
                                    H
                                    haloway13
                                    @ncollins
                                    I tried just as you describe. However I think something is failing before this should be expected to succeed.
                                    Thoughts?
                                    openhab> log:tail
                                    22:37:44.426 [DEBUG] [s.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
                                    22:37:44.428 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Adding consumer for topic: mygateway1-out/+/+/+/+/+
                                    22:37:44.434 [WARN ] [protocol.mqtt.MySensorsMqttConnection] - Skipping I_VERSION connection test, not recommended...
                                    22:37:44.438 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-mqtt:3976df7e54' changed from INITIALIZING to ONLINE
                                    22:37:44.446 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
                                    22:37:44.443 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
                                    22:37:44.451 [INFO ] [protocol.mqtt.MySensorsMqttConnection] - Successfully connected to MySensors Bridge.
                                    22:37:44.454 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
                                    22:37:44.460 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=1, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                                    22:37:44.464 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={1=MySensorsChild [childId=1, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]}]
                                    22:37:44.465 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=0, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                                    22:37:44.467 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-1 not registered yet, registering...
                                    22:37:44.469 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Merging child map: {1=MySensorsChild [childId=1, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]} with: {0=MySensorsChild [childId=0, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_ID=MySensorsVariableVId [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_TEMP=MySensorsVariableVTemp [value=null]}]}
                                    22:37:44.472 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from INITIALIZING to ONLINE
                                    22:37:44.474 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-0 not registered yet, registering...
                                    22:37:44.479 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from INITIALIZING to ONLINE
                                    22:41:47.918 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from ONLINE to UNINITIALIZED
                                    22:41:47.936 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
                                    22:41:49.778 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from UNINITIALIZED (DISABLED) to INITIALIZING
                                    22:41:49.786 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=1, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                                    22:41:49.788 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={1=MySensorsChild [childId=1, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]}]
                                    22:41:49.791 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-1 not registered yet, registering...
                                    22:41:49.795 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from INITIALIZING to ONLINE
                                    22:41:51.075 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from ONLINE to UNINITIALIZED
                                    22:41:51.090 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
                                    22:41:51.806 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from UNINITIALIZED (DISABLED) to INITIALIZING
                                    22:41:51.814 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=1, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                                    22:41:51.817 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={1=MySensorsChild [childId=1, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]}]
                                    22:41:51.819 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-1 not registered yet, registering...
                                    22:41:51.825 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from INITIALIZING to ONLINE
                                    22:42:06.748 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from ONLINE to UNINITIALIZED
                                    22:42:06.762 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
                                    22:42:07.739 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from UNINITIALIZED (DISABLED) to INITIALIZING
                                    22:42:07.749 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=0, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                                    22:42:07.751 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={0=MySensorsChild [childId=0, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_ID=MySensorsVariableVId [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_TEMP=MySensorsVariableVTemp [value=null]}]}]
                                    22:42:07.753 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-0 not registered yet, registering...
                                    22:42:07.756 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from INITIALIZING to ONLINE
                                    22:51:49.195 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuation update for thing 1-1: {nodeUpdateTimeout=-1, smartSleep=false, requestHeartbeatResponse=false, childUpdateTimeout=-1, childId=18, nodeId=1, revertState=true, requestAck=false}
                                    22:51:49.214 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=18, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                                    22:51:49.217 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={18=MySensorsChild [childId=18, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]}]
                                    22:51:49.218 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-18 not registered yet, registering...
                                    23:01:04.984 [WARN ] [se.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Temperature
                                    23:01:08.762 [WARN ] [se.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: TemperatureSensor_Temperature
                                    23:04:05.921 [WARN ] [se.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: TemperatureSensor_Variable1
                                    23:05:12.626 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuation update for thing 1-18: {nodeUpdateTimeout=-1, smartSleep=false, requestHeartbeatResponse=false, childUpdateTimeout=-1, childId=0, nodeId=1, revertState=true, requestAck=false}
                                    23:05:12.636 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=0, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                                    23:05:12.638 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={0=MySensorsChild [childId=0, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]}]
                                    23:05:12.643 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-0 not registered yet, registering...
                                    22:35:59.095 [WARN ] [orsAbstractConnection$MySensorsWriter] - Message returned from queue is null
                                    22:37:44.434 [WARN ] [orsAbstractConnection$MySensorsWriter] - Message returned from queue is null
                                    • H haloway13
                                      @ncollins
                                      Thoughts?
                                      openhab> log:tail
                                      N
                                      N
                                      ncollins
                                      @haloway13 can you send a screenshot of your item?Screen Shot 2021-03-08 at 9.09.23 AM.png
                                      • N ncollins
                                        H
                                        H
                                        haloway13
                                        @ncollins
                                        • H haloway13
                                          @ncollins
                                          N
                                          N
                                          ncollins
                                          @haloway13 Can you post your sketch?
                                          Your humidity sensor and your temperature sensor Thing configurations both point to Child Id = 0. I think your humidity sensor should be Child Id = 1.
