  3. OpenHAB
  4. OH3 - MySensors Binding
135 Posts 34 Posters 36.0k Views 40 Watching
  • N
    N
    ncollins
    also, is your MQTT broker password protected? if not, remove the username and password from your system broker configuration.
    H 1 Reply Last reply
    • N ncollins
      H
      H
      haloway13
      @ncollins
      I will check tonight.
      I really appreciate all help so far.
      When you refer to the broker password: do you mean when you install the mqtt using the openhabian-config utility from the command line while being logged in with ssh to the Pi?
      N 1 Reply Last reply
      • fabyteF
        fabyteF
        fabyte
        wrote on last edited by fabyte
        #60
        @haloway13 I had exactly the same problem.
        Here is what I did to fix it:
        1. uninstalled the mqtt binding
          1.1 make sure the /opt/openhab/userdata/config/org/openhab/mqttbroker.config is removed
        2. installed the mqtt binding
        3. setup the system broker
        After that, the system broker connection could be established and the Try to restore connection to '192.168.1.151'. Next attempt in 60000ms messaged disappeared.
        Then you can proceed and set up the MySensors MQTT Bridge.
        • H haloway13
          @ncollins
          N
          N
          ncollins
          @haloway13 yeah, when you did the initial mqtt setup, did you protect it with a password? If not, make sure you clear out the username and password from the OpenHAB broker settings. (I’m not sure if it will fail if you provide credentials to an instance that is not password protected)
          • fabyteF fabyte
            H
            H
            haloway13
            @fabyte
            I am not showing such a file as mentioned in 1.1
            2 & 3 refer to using the web interface?
            fabyteF N 2 Replies Last reply
            • H haloway13
              @fabyte
              fabyteF
              fabyteF
              fabyte
              @haloway13 Yes, everything via the web interface
              • H haloway13
                @fabyte
                N
                N
                ncollins
                wrote on last edited by ncollins
                #64
                @haloway13 Here are all of my settings in my sandbox environment.
                A couple things to note, NO MQTT BINDING INSTALLED, no special MQTT thing configured, my mqtt install is not password protected.
                Screen Shot 2021-03-05 at 12.49.22 PM.png Screen Shot 2021-03-05 at 12.53.23 PM.png Screen Shot 2021-03-05 at 12.54.34 PM.png Screen Shot 2021-03-05 at 12.55.27 PM.png Screen Shot 2021-03-05 at 12.55.50 PM.png Screen Shot 2021-03-05 at 1.01.14 PM.png
                My Gateway code:
                //#define MY_RADIO_RF24
                //#define MY_RADIO_RFM95
                #define MY_GATEWAY_ESP8266
                #define MY_BAUD_RATE 9600
                #define MY_MQTT_CLIENT_ID "MYSGW01"
                #define MY_MQTT_PUBLISH_TOPIC_PREFIX "tele/mysgw01-out"
                #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX  "cmnd/mysgw01-in"
                // Set MQTT client id
                // Enable these if your MQTT broker requires username/password
                // Set WIFI SSID and password
                #define MY_WIFI_SSID "--------"
                #define MY_WIFI_PASSWORD "*********"
                // passed to the DHCP server if not static.
                #define MY_HOSTNAME MY_MQTT_CLIENT_ID
                // MQTT broker ip address.
                #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 62
                //MQTT broker if using URL instead of ip address.
                // #define MY_CONTROLLER_URL_ADDRESS "test.mosquitto.org"
                #define MY_PORT 1883
                // Enable inclusion mode
                //#define MY_INCLUSION_MODE_BUTTON_PIN D1
                // Set blinking period
                // Flash leds on rx/tx/err
                //#define MY_DEFAULT_TX_LED_PIN  2  // the PCB, on board LED
                #include <ArduinoOTA.h>
                  pinMode(LED_BUILTIN, OUTPUT);
                 ArduinoOTA.setHostname(MY_HOSTNAME);
                  ArduinoOTA.onStart([]() {
                    Serial.println("ArduinoOTA start");
                  ArduinoOTA.onEnd([]() {
                    Serial.println("\nArduinoOTA end");
                  ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
                    Serial.printf("OTA Progress: %u%%\r", (progress / (total / 100)));
                  ArduinoOTA.onError([](ota_error_t error) {
                    Serial.printf("Error[%u]: ", error);
                    if (error == OTA_AUTH_ERROR) {
                      Serial.println("Auth Failed");
                    } else if (error == OTA_BEGIN_ERROR) {
                      Serial.println("Begin Failed");
                    } else if (error == OTA_CONNECT_ERROR) {
                      Serial.println("Connect Failed");
                    } else if (error == OTA_RECEIVE_ERROR) {
                      Serial.println("Receive Failed");
                    } else if (error == OTA_END_ERROR) {
                      Serial.println("End Failed");
                  ArduinoOTA.begin();
                  sendSketchInfo("MYSGW01-TEST Gateway","1.0");
                  present(0, S_BINARY);
                   ArduinoOTA.handle();
                    if (message.type==V_STATUS) {
                        // Change relay state
                        digitalWrite(LED_BUILTIN, message.getBool() ? LOW:HIGH);
                        // Store state in eeprom
                • N ncollins
                  My Gateway code:
                    ArduinoOTA.begin();
                  H
                  H
                  haloway13
                  wrote on last edited by haloway13
                  #65
                  @ncollins
                  Thank you so much. This has gotten me so much closer to actually getting the test temp and humidity arduino thing working.
                  I am seeing this output from the mysensors gateway:
                  Mar 05 22:55:07 DEBUG GWT:RMQ:OK
                  Mar 05 22:55:07 DEBUG GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
                  Mar 05 22:55:07 DEBUG TSM:READY:NWD REQ
                  Mar 05 22:55:07 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                  Mar 05 22:55:07 DEBUG TSF:MSG:READ,1-1-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
                  Mar 05 22:55:07 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/255/3/0/21,MSG SENT
                  Mar 05 22:55:41 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:34.0
                  Mar 05 22:55:41 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
                  Mar 05 22:55:51 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.8
                  Mar 05 22:55:51 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
                  Mar 05 22:57:01 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:34.1
                  Mar 05 22:57:01 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
                  Mar 05 22:57:11 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:34.0
                  Mar 05 22:57:11 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
                  Mar 05 22:57:41 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.8
                  Mar 05 22:57:41 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
                  Mar 05 22:59:01 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:34.0
                  Mar 05 22:59:01 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
                  Mar 05 22:59:21 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.9
                  Mar 05 22:59:21 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
                  Mar 05 22:59:41 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.8
                  Mar 05 22:59:41 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
                  Mar 05 23:00:51 DEBUG TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:34.0
                  Mar 05 23:00:51 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/1,MSG SENT
                  Mar 05 23:01:11 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.7
                  Mar 05 23:01:11 DEBUG GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/0,MSG SENT
                  Mar 05 23:01:21 DEBUG TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:19.8
                  My Sensors Gateway configuration: not letting me upload the image/screenshot, getting an error.
                  ![0_1615011411135_SS_2021-03-05_23-09-13.jpg](Uploading 100%)
                  Humidity Sensor thing: same problem here.
                  ![0_1615011449159_SS_2021-03-05_23-12-48.jpg](Uploading 100%)
                  I will try to edit this in the morning
                  The short of it is that I am not seeing the values I am expecting from the sensor. I am leaning towards just not identifying the id/node for each of the things/channel.
                  • H
                    H
                    haloway13
                    #66
                    Here is the humidity sensor thing page:
                    Here is the temperature:
                    Do I have the node and child id right? What should I check?
                    Or maybe I need to do a follow on configuration to see the values?
                    Thank you!
                    • H haloway13
                      Thank you!
                      N
                      N
                      ncollins
                      @haloway13 progress!
                      Check the channels tab of your temperature sensor thing:
                      "Add link to item" then follow the directions to create a new item
                      • N ncollins
                        H
                        H
                        haloway13
                        @ncollins
                        I tried just as you describe. However I think something is failing before this should be expected to succeed.
                        Thoughts?
                        openhab> log:tail
                        22:37:44.426 [DEBUG] [s.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
                        22:37:44.428 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Adding consumer for topic: mygateway1-out/+/+/+/+/+
                        22:37:44.434 [WARN ] [protocol.mqtt.MySensorsMqttConnection] - Skipping I_VERSION connection test, not recommended...
                        22:37:44.438 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-mqtt:3976df7e54' changed from INITIALIZING to ONLINE
                        22:37:44.446 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
                        22:37:44.443 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
                        22:37:44.451 [INFO ] [protocol.mqtt.MySensorsMqttConnection] - Successfully connected to MySensors Bridge.
                        22:37:44.454 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
                        22:37:44.460 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=1, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                        22:37:44.464 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={1=MySensorsChild [childId=1, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]}]
                        22:37:44.465 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=0, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                        22:37:44.467 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-1 not registered yet, registering...
                        22:37:44.469 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Merging child map: {1=MySensorsChild [childId=1, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]} with: {0=MySensorsChild [childId=0, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_ID=MySensorsVariableVId [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_TEMP=MySensorsVariableVTemp [value=null]}]}
                        22:37:44.472 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from INITIALIZING to ONLINE
                        22:37:44.474 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-0 not registered yet, registering...
                        22:37:44.479 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from INITIALIZING to ONLINE
                        22:41:47.918 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from ONLINE to UNINITIALIZED
                        22:41:47.936 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
                        22:41:49.778 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from UNINITIALIZED (DISABLED) to INITIALIZING
                        22:41:49.786 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=1, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                        22:41:49.788 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={1=MySensorsChild [childId=1, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]}]
                        22:41:49.791 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-1 not registered yet, registering...
                        22:41:49.795 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from INITIALIZING to ONLINE
                        22:41:51.075 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from ONLINE to UNINITIALIZED
                        22:41:51.090 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
                        22:41:51.806 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from UNINITIALIZED (DISABLED) to INITIALIZING
                        22:41:51.814 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=1, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                        22:41:51.817 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={1=MySensorsChild [childId=1, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]}]
                        22:41:51.819 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-1 not registered yet, registering...
                        22:41:51.825 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:humidity:3976df7e54:529c716d78' changed from INITIALIZING to ONLINE
                        22:42:06.748 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from ONLINE to UNINITIALIZED
                        22:42:06.762 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
                        22:42:07.739 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from UNINITIALIZED (DISABLED) to INITIALIZING
                        22:42:07.749 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=0, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                        22:42:07.751 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={0=MySensorsChild [childId=0, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_ID=MySensorsVariableVId [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_TEMP=MySensorsVariableVTemp [value=null]}]}]
                        22:42:07.753 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-0 not registered yet, registering...
                        22:42:07.756 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:temperature:7c6c709b27' changed from INITIALIZING to ONLINE
                        22:51:49.195 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuation update for thing 1-1: {nodeUpdateTimeout=-1, smartSleep=false, requestHeartbeatResponse=false, childUpdateTimeout=-1, childId=18, nodeId=1, revertState=true, requestAck=false}
                        22:51:49.214 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=18, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                        22:51:49.217 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={18=MySensorsChild [childId=18, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]}]
                        22:51:49.218 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-18 not registered yet, registering...
                        23:01:04.984 [WARN ] [se.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Temperature
                        23:01:08.762 [WARN ] [se.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: TemperatureSensor_Temperature
                        23:04:05.921 [WARN ] [se.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: TemperatureSensor_Variable1
                        23:05:12.626 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuation update for thing 1-18: {nodeUpdateTimeout=-1, smartSleep=false, requestHeartbeatResponse=false, childUpdateTimeout=-1, childId=0, nodeId=1, revertState=true, requestAck=false}
                        23:05:12.636 [DEBUG] [sensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=0, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                        23:05:12.638 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=1, childNumber=1, chidldList={0=MySensorsChild [childId=0, nodeValue={V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_HUM=MySensorsVariableVHum [value=null]}]}]
                        23:05:12.643 [DEBUG] [sensors.handler.MySensorsThingHandler] - Event listener for node 1-0 not registered yet, registering...
                        22:35:59.095 [WARN ] [orsAbstractConnection$MySensorsWriter] - Message returned from queue is null
                        22:37:44.434 [WARN ] [orsAbstractConnection$MySensorsWriter] - Message returned from queue is null
                        • H haloway13
                          @ncollins
                          Thoughts?
                          openhab> log:tail
                          N
                          N
                          ncollins
                          @haloway13 can you send a screenshot of your item?Screen Shot 2021-03-08 at 9.09.23 AM.png
                          • N ncollins
                            H
                            H
                            haloway13
                            @ncollins
                            • H haloway13
                              @ncollins
                              N
                              N
                              ncollins
                              @haloway13 Can you post your sketch?
                              Your humidity sensor and your temperature sensor Thing configurations both point to Child Id = 0. I think your humidity sensor should be Child Id = 1.
                              • N ncollins
                                H
                                H
                                haloway13
                                #72
                                @ncollins
                                Fixed the child ID. Good catch. No change.
                                Here is the sketch
                                #define MY_DEBUG 1
                                #define MY_NODE_ID 1
                                #define CHILD_ID_TEMP 0
                                #define CHILD_ID_HUM 1
                                #define DHT_DATA_PIN 3
                                #define SENSOR_TEMP_OFFSET 0
                                /****************** CONSTANTS *********************/
                                static const uint64_t UPDATE_INTERVAL = 10000;
                                /****************** VARIABLES *********************/
                                float lastTemp;
                                float lastHum;
                                float temperature;
                                float humidity;
                                uint8_t nNoUpdatesTemp;
                                uint8_t nNoUpdatesHum;
                                /****************** MESSAGES **********************/
                                DHT dht;
                                present(CHILD_ID_HUM, S_HUM);
                                delay(2000); //Wait 2 seconds before starting sequence
                                if (UPDATE_INTERVAL <= dht.getMinimumSamplingPeriod())
                                dht.setup(DHT_DATA_PIN);
                                sendTemperatureHumiditySensor();
                                wait(UPDATE_INTERVAL);
                                /**************** AUX. FUNCTIONS ******************/
                                void sendTemperatureHumiditySensor()
                                dht.readSensor(true);
                                temperature = dht.getTemperature();
                                humidity = dht.getHumidity();
                                if (isnan(temperature))
                                } else if (temperature != lastTemp || nNoUpdatesTemp == FORCE_UPDATE_N_READS)
                                lastTemp = temperature;
                                nNoUpdatesTemp = 0;
                                #ifdef MY_DEBUG
                                Serial.print("T: ");
                                } else
                                nNoUpdatesTemp++;
                                if (isnan(humidity))
                                } else if (humidity != lastHum || nNoUpdatesHum == FORCE_UPDATE_N_READS)
                                lastHum = humidity;
                                nNoUpdatesHum = 0;
                                #ifdef MY_DEBUG
                                Serial.print("H: ");
                                Serial.println(humidity);
                                } else
                                nNoUpdatesHum++;
                                I am able to see the debug output from the sensors
                                • H haloway13
                                  @ncollins
                                  Here is the sketch
                                  #define MY_DEBUG 1
                                  float lastTemp;
                                  float lastHum;
                                  float temperature;
                                  float humidity;
                                  DHT dht;
                                  nNoUpdatesTemp = 0;
                                  #ifdef MY_DEBUG
                                  } else
                                  nNoUpdatesTemp++;
                                  lastHum = humidity;
                                  nNoUpdatesHum = 0;
                                  #ifdef MY_DEBUG
                                  } else
                                  nNoUpdatesHum++;
                                  N
                                  N
                                  ncollins
                                  @haloway13 I mean, last suggestion is restarting your openhab instance. If that doesn't work, please post your openhab log.
                                  H 2 Replies Last reply
                                  • N ncollins
                                    H
                                    H
                                    haloway13
                                    @ncollins
                                    My sdcard corrupted, had to restart from scratch. Hopefully, I can get back to the same point tonight.
                                    • N ncollins
                                      H
                                      H
                                      haloway13
                                      @ncollins QQ: Did you install mosquitto through the openhabian-config utility?
                                      • H haloway13
                                        H
                                        H
                                        haloway13
                                        @haloway13
                                        I assumed yes since the log was showing no connection to MQTT
                                        I am now getting this error:
                                        20:56:49.983 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.151' with clientid cc150d9b-7fcc-45d0-93d2-00ad80ddb9a9
                                        20:56:50.005 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - {}
                                        com.hivemq.client.mqtt.exceptions.ConnectionClosedException: java.io.IOException: Connection reset by peer
                                        Caused by: java.io.IOException: Connection reset by peer
                                        	at sun.nio.ch.FileDispatcherImpl.read0(Native Method) ~[?:?]
                                        	at sun.nio.ch.SocketDispatcher.read(SocketDispatcher.java:39) ~[?:?]
                                        	at sun.nio.ch.IOUtil.readIntoNativeBuffer(IOUtil.java:276) ~[?:?]
                                        	at sun.nio.ch.IOUtil.read(IOUtil.java:233) ~[?:?]
                                        	at sun.nio.ch.IOUtil.read(IOUtil.java:223) ~[?:?]
                                        	at sun.nio.ch.SocketChannelImpl.read(SocketChannelImpl.java:358) ~[?:?]
                                        	at io.netty.buffer.PooledByteBuf.setBytes(PooledByteBuf.java:247) ~[bundleFile:4.1.42.Final]
                                        	at io.netty.buffer.AbstractByteBuf.writeBytes(AbstractByteBuf.java:1147) ~[bundleFile:4.1.42.Final]
                                        	at io.netty.channel.socket.nio.NioSocketChannel.doReadBytes(NioSocketChannel.java:347) ~[bundleFile:4.1.42.Final]
                                        	at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:148) [bundleFile:4.1.42.Final]
                                        	at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:700) [bundleFile:4.1.42.Final]
                                        	at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:635) [bundleFile:4.1.42.Final]
                                        	at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:552) [bundleFile:4.1.42.Final]
                                        	at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:514) [bundleFile:4.1.42.Final]
                                        	at io.netty.util.concurrent.SingleThreadEventExecutor$6.run(SingleThreadEventExecutor.java:1044) [bundleFile:4.1.42.Final]
                                        	at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) [bundleFile:4.1.42.Final]
                                        	at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30) [bundleFile:4.1.42.Final]
                                        	at java.lang.Thread.run(Thread.java:834) [?:?]
                                        • H haloway13
                                          @haloway13
                                          H
                                          H
                                          haloway13
                                          #77
                                          @haloway13
                                          @ncollins
                                          Woot!!! massive success!!!
                                          in /srv/openhab-userdata/config/org/openhab/mqttbroker.config
                                          added at the end secure="false"
                                          as you suggested.
                                          21:42:04.192 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'HumiditySensor_Humidity' changed from 33.1 to 33.3
                                          21:42:54.224 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mygateway1-out/1/1/1/0/1, Message: 33.2
                                          21:42:54.226 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Message topic part: 1/1/1/0/1
                                          21:42:54.228 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 1;1;1;0;1;33.2
                                          21:42:54.231 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;1;33.2
                                          21:42:54.234 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                                          21:42:54.236 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Child 1 found in node 1
                                          21:42:54.238 [DEBUG] [sensors.handler.MySensorsThingHandler] - Updating channel: hum(V_HUM) value to: 33.2
                                          21:42:54.244 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'HumiditySensor_Humidity' changed from 33.3 to 33.2
                                          21:42:54.246 [DEBUG] [sensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/1 to 2021-03-11T21:42:54.000-0700
                                          21:43:04.250 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mygateway1-out/1/1/1/0/1, Message: 33.3
                                          21:43:04.252 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Message topic part: 1/1/1/0/1
                                          21:43:04.253 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 1;1;1;0;1;33.3
                                          21:43:04.260 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;1;33.3
                                          21:43:04.262 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                                          21:43:04.263 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Child 1 found in node 1
                                          21:43:04.265 [DEBUG] [sensors.handler.MySensorsThingHandler] - Updating channel: hum(V_HUM) value to: 33.3
                                          21:43:04.270 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'HumiditySensor_Humidity' changed from 33.2 to 33.3
                                          21:43:04.271 [DEBUG] [sensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/1 to 2021-03-11T21:43:04.000-0700
                                          21:43:14.266 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mygateway1-out/1/1/1/0/1, Message: 33.2
                                          21:43:14.268 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Message topic part: 1/1/1/0/1
                                          21:43:14.271 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 1;1;1;0;1;33.2
                                          21:43:14.276 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;1;33.2
                                          21:43:14.278 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                                          21:43:14.280 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Child 1 found in node 1
                                          21:43:14.281 [DEBUG] [sensors.handler.MySensorsThingHandler] - Updating channel: hum(V_HUM) value to: 33.2
                                          21:43:14.285 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'HumiditySensor_Humidity' changed from 33.3 to 33.2
                                          21:43:14.286 [DEBUG] [sensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/1 to 2021-03-11T21:43:14.000-0700
