  3. Best PC platform for running Esxi/Docker at home?
75 Posts 6 Posters 12.5k Views 5 Watching
    Results are all over the map, but it looks as though idle generally is low across a range of platforms:
    These are all mini-pc's, so it's not surprising that the idle power numbers are low.
    At any rate, it looks as though the idle wattage for just the Ryzen 5 5600X cpu is around 26 watts:
    Not particularly awesome, but it can do a lot more work when needed than the mini-pc's above.
    26w is manageable with a quiet fan. Total system draw will, of course, be a higher number.
    And here are the loaded numbers for contrast and comparison:
    ![alt text](f8d541e7-be24-4935-8f7c-48a86d1bcadf-image.png image url)
    source: https://thinkcomputers.org/amd-ryzen-5-5600x-processor-review/8/
    BearWithBeardB
    BearWithBeardB
    BearWithBeard
    wrote on last edited by BearWithBeard
    @NeverDie said in Best PC platform for running Esxi/Docker at home?:
    See what I mean with "other reviewers may get different results"? ThinkComputers says 26W idle. Tom's Hardware says 13W. AnandTech says 11W. TPU says 50W (whole system). Who is right? It's unfortunate that there is no standard testing procedure every reviewer adheres to.
    Part of the different results may be due to mainboard selection. Some (I don't know how many and if they are rare or the majority) AM4 mainboards seem to be rather power hungry. Especially those with an X570 chipset. Some may add another 10 to 20W to the total power consumption, even if you use the same CPU. See here for example.
    Oh yeah, absolutely! Even under load. My 80W Xeon sitting right next to me here is inaudible for most people unless they hold their ear close to the PC case.
    Oh, and please note that I'm not trying to sell you the 5600X just because I used it as a comparison a few times. IMHO, all CPUs in that category are grossly overpowered for the average home server unless you know that you will need it sooner or later.
      It seems that a minimum of 3 disks is required for running ProxMox: one to boot from, one for ISO's, and one for VM's. I'm surprised it's that literal and not able to partition one disk into 3 equivalent disks. It advises not to use a USB flash for the boot disk.
      mfalkviddM monteM 2 Replies Last reply
        @NeverDie I use proxmox with 2 drives (in mirror, so proxmox only sees 1 drive).
          #21
          Well, good to know for the future. Right now I'm not finding good beginner instructions for a single drive system, or even a two drive system, so I guess I'll just use a cheap SSD over USB 3.0 as the bootdrive. I'll add a second SSD to my Intel NUC, and in theory that should work well enough in the short-term to evaluate ProxMox.
          Presently, running just ProxMox with no VM's and no load: it's drawing 8 watts at idle on on an Intel NUC-6i5SYS (that's a i5-6260u CPU) with 16GB memory and a 1TB Samsung NVME. After adding a SATA SSD and a USB SSD, it should meet the nominal minimum criteria for ProxMox's beginner setup. Not an ideal arrangement, so I'll consider something bigger with more drive bays as a better setup in the future.
            @NeverDie it certainly is possible
              #23
              On second thought, I'll try ProxMox on a system I previously built for Esxi that has 9 drives:
              Out with the old hypervisor and in the with the new! This way I'll have plenty of drives to try BTRFS in a Linux VM and whatever else.
                @NeverDie looks like a Fractal Design Refine case?
                  #25
                  @mfalkvidd said in Best PC platform for running Esxi/Docker at home?:
                  Nope. It's the Nanoxia Deep Silence 6 Super Tower Case. It promised the most soundproofing of nearly any computer case on the market at the time, and the large size makes wiring things up easier than working in cramped quarters. That was six years ago, though, so maybe there's something better available now.
                  The one case that stood out as being better was one that was completely sealed and which had a lot of heatsink fins milled into the outside of its case. Being sealed, I've got to believe it would have had the best soundproofing by far. It looked beautiful but was hugely expensive.
                  I imagine these days a bunch of M.2. nvme's would be the way to go--faster, smaller, and less power.
                  I recently set up a Ryzen 3 3100 as a gaming computer for my son, and it's nearly silent even with just a cheap run-of-the-mill computer case. Come to think of it, maybe later tonight I should test its at-the-wall power draw when it's idle.... :smile:
                    #26
                    Reporting back: the entire computer draws 60 watts from the wall when idle, whereas it draws 305 watts if running a fractal graphics benchmark. The takeaway is that even 60 watts can still be nearly silent if the fans and power supply are carefully chosen to be quiet. This particular build uses a refurbished Corsair Ax860i for the power supply, and so at 60 watts its fan doesn't even spin. For the case fan it uses a Phantek PH-F120MP_BK_PWM, which is a very quiet fan and which furthermore spins only when the motherboard gets warm. The CPU fan is just the stock AMD Wraith Stealth cooler that came packaged with the CPU, but also with PWM controlled by the motherboard.
                    • BearWithBeardB
                      BearWithBeardB
                      BearWithBeard
                      #27
                      Building quiet PCs is so addictive. Once you're used to it, every little rattling becomes an annoyance. It didn't took long until I had to get rid of all spinning HDDs in favor of SSDs. And as soon as everything was dead silent... I bought myself a clicky mechanical keyboard, oh well.. :D
                      Nanoxia Deep Silence and Fractal Design Define are indeed nice sound-insulated cases for quiet builds with plenty of space and features.
                      For silent cooling, I can recommend be quiet (especially the Silent Wings fans) and Noctua (basically everything). The latter is quite pricy though.
                        monteM
                        monteM
                        monte
                        Not true. I have 1 SSD running proxmox. And two more disks passed trough to vm's for storage, but the proxmox part is entirely on the small SSD. It is just partitioned using LVM.
                        • monteM monte
                          #29
                          @monte said in Best PC platform for running Esxi/Docker at home?:
                          @monte How did you do it? Did you pre-partition the disk before installing Proxmox, and then Proxmox just found what you did and adopted it, or is it more involved than that?
                          I started with the ProxMox beginner video, which used 3 disks and gave no hints on how to use fewer:
                          https://www.youtube.com/watch?v=I-e1_CTa4s0
                          monteM 1 Reply Last reply
                            monteM
                            monteM
                            monte
                            wrote on last edited by monte
                            #30
                            @NeverDie to be honest, I don't rememver :) It was so long ago, I was just updating the system from then. But I guess there might be an option in the installer... I will try it in vm, you made me curious :)
                            UPDATE: I've just ran the install and it plain and simple, no extra options. It automatically partitioned the disk. The only drawback is that you don't have ability to fine tune the sizes of partitions, but that can be done later with some LVM magic :)
                            • monteM monte
                              That's what I started with too, but then when I went to upload ISO's or create VM's, ProxMox said there was no disk available for that.
                              • monteM
                                monteM
                                monte
                                So to be precise, Proxmox installer creates LMV VG (volume group) called pve, in which it creates LV(logic volume) root, swap and andother volume, which in fact is a pool for another thin volumes that will be created for each VM and container, called data. So ISO's, backups and other stuff related to proxmox itself will be located at root volume.
                                  monteM
                                  monteM
                                  monte
                                  #33
                                  @NeverDie that's strange. What's the size of your disk? Also you can see LVM structure with lvdisplay command. As I've mentioned, you also can manage sizes of said LV's in the console.
                                  • monteM monte
                                    What the size of your disk?
                                    1 terabyte. It's a Samsung nvme SSD.
                                      #35
                                      I've tried googling up instructions on how to do it exactly. It seems that others besides just me have struggled with this as well. The only solution proposed which someone claimed worked, which I haven't yet tried, seems to be to start with a Debian install and then upgrade it to ProxMox. But there were no simple 123 instructions on how to do that either, so I just threw in the towel and decided to go with 3 disks, like in the beginner tutorial.
                                        monteM
                                        monteM
                                        monte
                                        #36
                                        @NeverDie this is completely doable within proxmox installation. Show me please the return of lvdisplay.
                                        Or if you already have set up your system, then let it be :)
                                        • monteM monte
                                          @monte Getting it now. It will look a little screwy because the present incarnation has proxmox on a USB (yeah, I know, heavily not recommended).
