  3. Multilayer PCB vs Flexible PCB
6 Posts 3 Posters 999 Views 3 Watching
  • J Offline
    J Offline
    Jasonkeel
    Does anyone know in what specific application you would use a multi-layer PCB vs. a flexible PCB? Any example would be very helpful.
    P 1 Reply Last reply
    • J Jasonkeel
      P Offline
      P Offline
      PeteKnight
      @Jasonkeel obviously one is rigid and the other is flexible!
      Flexible PCBs are found in things like RGB LED strips, where components need to be mounted to a flexible substrate, whereas rigid single/multi layer PCBs are used for the majority of PCB designs because you want the substrate material to be rigid and easy to mount in enclosures.
      Mounting discreet non-flexible components onto a flexible substrate has its issues, as the pads that connect to the components can tear if the pcb is bent through too tight a radius.
      Pete.
      • B Offline
        B Offline
        bjacobse
        Inside Hearing aids, the PCB are "mainly" only flexible PCB as the PCB must bend and follow the mechanical shape, think this picture gives an idea
        https://www.manualslib.com/manual/1902167/Oticon-Aurora-Minirite-312-T-Rc.html
        • J Offline
          J Offline
          Jasonkeel
          Thank you @PeteKnight for giving me such a easy to understand explanation.
          • J Offline
            J Offline
            Jasonkeel
            Thanks @bjacobse. I tried even before to understand from pictures but I'm still a learner so can not understand much.
            B 1 Reply Last reply
            • J Jasonkeel
              B Offline
              B Offline
              bjacobse
              @Jasonkeel
              The green is the flex PCB,, as you can se how it' turn 90degree a few timesScreenshot from 2021-03-23 19-08-12.png
