  3. How to change Radio ID on Raspberry Pi Gateway with NRF24
4 Posts 2 Posters 621 Views 2 Watching
  • J Offline
    J Offline
    jacmika
    Does anybody know how to change the Radio ID on Raspberry Pi Gateway with NRF24 radio?
    Equivalent to MY_NRF5_ESB_BASE_RADIO_ID for NRF5 nodes.
    • J jacmika
      Welcome to the forum @jacmika !
      You can add options to the configure command like this: --extra-cxxflags="-DMY_RX_MESSAGE_BUFFER_SIZE=\(32\)
      See also the section called ”Advanced” at https://www.mysensors.org/build/raspberry
      • J Offline
        J Offline
        jacmika
        Thank you Mikael,
        Would it be mean that for default Radio ID command is (including closing ")?
        --extra-cxxflags="-MY_RF24_BASE_RADIO_ID=(0x00,0xFC,0xE1,0xA8,0xA8)"
        • J jacmika
          Thank you Mikael,
          @jacmika it would need shell escaping and it is missing the initial D. I would try something like
          --extra-cxxflags="-DMY_RF24_BASE_RADIO_ID=0x00,0xFC,0xE1,0xA8,0xA8
          If I recall correctly, the output of make will show which defines are activated, and what values they have. That's what I usually use to check if I got it right.
