  3. s_cover commands, doubts??
8 Posts 3 Posters 1.4k Views 3 Watching
  • G Offline
    G Offline
    giva
    wrote on last edited by giva
    what is the correct way to send the commands ,...V_UP V_DOWN V_STOP ..., to controller (vera) ? Indicating the status Open ... closed etc
    MyMessage msg_S_COVER_U(CHILD_PORTAO_INT, V_UP);
    send(msg_S_COVER_U.set(V_UP)); ?
    send(msg_S_COVER_U.set("Up")); ?
    send(msg_S_COVER_U.set(Up)); ?
    send(msg_S_COVER_U.set(UP)); ?
    send(msg_S_COVER_U.set(1)); ?
    I ask this because my home app (homebridge-vera) do not update status . then i look for solution
    skywatchS 1 Reply Last reply
    • G giva
      skywatchS Offline
      skywatchS Offline
      skywatch
      @giva I have similar confusion over this - did you get a solution and if so can you knidly share it? ;)
      I have up. down and stop working from buttons and controller, but can't work out how to get feedback to controller without more child_id's being used.
      G 1 Reply Last reply
      • electrikE Offline
        electrikE Offline
        electrik
        This worked for me in Home Assistant:
        MyMessage fadeCtrl(CHILD_ID_FADE_CTRL, V_PERCENTAGE); // one child ID
          fadeCtrl.setType(V_DOWN);
          send (fadeCtrl.set(true)); // enable down
          fadeCtrl.setType(V_UP);
          send (fadeCtrl.set(false)); // disable up
          fadeCtrl.setType(V_STOP);
          send (fadeCtrl.set(false)); // disable stop
          fadeCtrl.setType(V_STATUS);
          send (fadeCtrl.set(level)); // update position
        • skywatchS skywatch
          G Offline
          G Offline
          giva
          Noble @skywatch , I migrated to home assitant, where everything is easier, faster and more dynamic. I would suggest that you migrate as well. if you have a lot of zwave devices, you can leave them in vera because there is a plugin to integrate vera in the home assistant. in addition to new experiences with mqtt, node red, etc.
          Sorry about my bad English
          • skywatchS Offline
            skywatchS Offline
            skywatch
            @electrik and @giva Thanks for the help - I am trying to work out if the V_UP etc are bidirectional, That is, can controller send V_UP to make blind go up and then when it reaches its up limit can V_UP be used to send that info back to the controller. Are all the V_x in S_COVER binary values?
            @giva As an aside I use MyController (new version 2.0 is in the works) and have no issues with mysensors and NRF24 modules (with occasional corrupted data which I have yet to find the root cause of)...... Thanks for the promotion to nobility, hope I get more money with that! ;)
            • electrikE Offline
              electrikE Offline
              electrik
              @skywatch said in s_cover commands, doubts??:
              Yes, the binary values in fact enable and disable the buttons on the controller. So if the cover is up, you send false for the up child, and the button will be disabled.
              • electrikE electrik
                skywatchS Offline
                skywatchS Offline
                skywatch
                @electrik I have working code but want to re-write it and thinking out loud of ways to accomplish the desired result - thanks for the input.
                  G Offline
                  G Offline
                  giva
                  @skywatch Kkkkkkkkkkkk. Great joke !!
                  12.2k
