  3. Node to Node ACK
Node to Node ACK
5 Posts 3 Posters 776 Views 3 Watching
  • anderBAKEA Offline
    anderBAKEA Offline
    anderBAKE
    Evenin' all. I'm using the following to confirm messages are successfully sent.
    void Resend(MyMessage &msg) {
      int repeatDelay = 1000;
      boolean sendOK = false;
      unsigned long lastWhile;
      while (sendOK == false) {
        if ((millis() - lastWhile) >= repeatDelay) {
          if (send(msg) == true) sendOK = true;
          else repeatDelay += 1000;
          lastWhile = millis();
    Here's the full code.
    #define MY_RADIO_RF24
    #define MY_NODE_ID 22
    #define SENSOR_NAME "Master Bedroom Sensors"
    #define SENSOR_VERSION "2.1"
    #define DHT_DATA_PIN 3
    #define SENSOR_TEMP_OFFSET 0
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #include <avr/wdt.h>
    DHT dht;
    int lastTemp, lastHum;
    unsigned long lastLoop;
      sendSketchInfo(SENSOR_NAME, SENSOR_VERSION);
      present(CHILD_ID_HUM, S_HUM, "Humidity");
      present(CHILD_ID_TEMP, S_TEMP, "Temperature");
      wdt_enable(WDTO_8S);
      dht.setup(DHT_DATA_PIN);
      if ((millis() - lastLoop) >= 10000) {
        dht.readSensor(true);
        int temperature = lrint(dht.toFahrenheit(dht.getTemperature()) + SENSOR_TEMP_OFFSET);
        if (temperature > 1 && temperature != lastTemp) {
          lastTemp = temperature;
          Resend(msgTemp.setDestination(26).setSensor(101).set(lastTemp));
          Resend(msgTemp.set(lastTemp));
        int humidity = lrint(dht.getHumidity());
        if (!isnan(humidity) && humidity != lastHum) {
          lastHum = humidity;
          Resend(msgTemp.setDestination(26).setSensor(100).set(lastHum));
          Resend(msgHum.set(lastHum));
        lastLoop = millis();
      wdt_reset();
    This works very well for messages sent to the gateway; however, it is not catching node-2-node failures.
    10041 !TSF:MSG:SEND,22-22-26-26,s=101,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=NACK:70
    10048 !TSF:RTE:N2N FAIL
    10052 TSF:MSG:SEND,22-22-0-26,s=101,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=OK:70
    10094 !TSF:MSG:SEND,22-22-26-26,s=100,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=NACK:58
    10101 !TSF:RTE:N2N FAIL
    I shut down node 26 in order to reproduce the errors. Is there a way to catch these failures?
    mfalkviddM BearWithBeardB 2 Replies Last reply
    • anderBAKEA anderBAKE
      DHT dht;
            lastHum = humidity;
        wdt_reset();
      Welcome to the forum @anderBAKE
      Multiple people have tried, but I don't think anyone has been able to make it work.
      Some threads
      https://forum.mysensors.org/post/99252
      https://forum.mysensors.org/post/99485
      https://forum.mysensors.org/post/102134
        DHT dht;
              lastHum = humidity;
          wdt_reset();
        BearWithBeardB Offline
        BearWithBeard
        wrote on last edited by BearWithBeard
        @anderBAKE When a node to node communication fails, MySensors will automatically fall back to the default route via the node's parent, so that ultimately the gateway can try to reach the destination node. I'm not sure if you can change that behaviour without touching the library code. But if you don't mind, a small change in MyTransport.cpp should do the trick.
        Change the following starting on line 548...
        if (destination > GATEWAY_ADDRESS && destination < BROADCAST_ADDRESS) {
        	// node2node traffic: assume node is in vincinity. If transmission fails, hand over to parent
        	if (transportSendWrite(destination, message)) {
        		TRANSPORT_DEBUG(PSTR("TSF:RTE:N2N OK\n"));
        		return true;
        	TRANSPORT_DEBUG(PSTR("!TSF:RTE:N2N FAIL\n"));
        to the following...
        		return true;
        		return false;
        This will drop out of the transportRouteMessage() function returning false to the send() function if the N2N communication failed.
        Note that, after this change, the node will not fall back to the default transport route anymore.
        Maybe this could be made an optional feature by introducing something like #define MY_DISABLE_N2N_FALLBACK to MyConfig.h?
        anderBAKEA 2 Replies Last reply
        • BearWithBeardB BearWithBeard
          		return true;
          to the following...
          		return true;
          		return false;
          anderBAKEA Offline
          anderBAKEA Offline
          anderBAKE
          @mfalkvidd said in Node to Node ACK:
          Some threads
          @mfalkvidd thanks! The first link is where I got the inspiration for my resend loop. I'll look into the other links after work today.
          @BearWithBeard said in Node to Node ACK:
          		return true;
          to the following...
          		return true;
          		return false;
          @BearWithBeard very interesting. I'll definitely be looking into this this evening as well.
          Thank you both for the speedy replies!
            		return true;
            to the following...
            		return true;
            		return false;
            anderBAKEA Offline
            anderBAKEA Offline
            anderBAKE
            @BearWithBeard Making the change that you suggested returns the expected results! Thanks for suggestion.
