  3. Home Assistant
  4. Can't find Mysensors in Home Assist
3 Posts 2 Posters 389 Views 2 Watching
  • S Offline
    stewie
    When I go to integrations as per the guide:
    "To integrate your Serial, Ethernet (LAN) or MQTT MySensors Gateway, go to Configuration >> Integrations in the UI, click the button with + sign and from the list of integration select MySensors."
    There is no MySensors to select in the integrations. I have Home Assistant OS 5.9 running on a raspberry pi.
    alexeliteA 1 Reply Last reply
    • S stewie
      alexeliteA Offline
      alexeliteA Offline
      alexelite
      @stewie I've read about another integration that it is available only when advanced mode is on in user profile. Do you have it on? If not, you can try turning it on to see if it becomes available?
      • S Offline
        stewie
        I updated home assist and then the integration appeared. Everything is working now.
        12.2k
