  3. RS485, no communication
9 Posts 4 Posters 1.4k Views 4 Watching
  • V
    V
    vdomos
    I already use mysensors with NRF24L01 and it works well.
    I would like to use mysensors with RS485 nodes but I have communication problems
    I'm using an Arduino Duemilanove (yes, it's old but it still works well), an Arduino Uno compatible board and 2 RS485 modules for testing.
    I used this wiring diagram: https://2.bp.blogspot.com/--MTeYYSu6nE/WViOqBi4T8I/AAAAAAAAUP8/cTphNMowJXUlAOn-oD44f1Wdd2NFrgpXgCLcBGAs/s1600/schemat%2BRS485%2BMySensors.jpg.
    I have exactly the same RS485 modules.
    Here is the gateway code:
    // Enable RS485 transport layer
    #define MY_RS485
    // Define this to enables DE-pin management on defined pin
    #define MY_RS485_DE_PIN 2
    // Set RS485 baud rate to use
    // Enable this if RS485 is connected to a hardware serial port
    //#define MY_RS485_HWSERIAL Serial1
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  5  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  6  // the PCB, on board LED
    And the gataway log:
    Terminal ready
    0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RSNGA---,FQ=16,REL=255,VER=2.3.2
    0;255;3;0;9;5 TSM:INIT
    0;255;3;0;9;7 TSF:WUR:MS=0
    0;255;3;0;9;10 TSM:INIT:TSP OK
    0;255;3;0;9;13 TSM:INIT:GW MODE
    0;255;3;0;9;15 TSM:READY:ID=0,PAR=0,DIS=0
    0;255;3;0;9;19 MCO:REG:NOT NEEDED
    0;255;0;0;18;2.3.2
    0;255;3;0;9;23 MCO:BGN:STP
    0;255;3;0;9;29 MCO:BGN:INIT OK,TSP=1
    0;255;3;0;9;33 TSM:READY:NWD REQ
    0;255;3;0;9;53 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    And the node:
    #define MY_RS485
    #define MY_NODE_ID 20
    static const uint64_t UPDATE_INTERVAL = 10000;
    #define CHILD_ID_VALUE 0
    MyMessage msgVal(CHILD_ID_VALUE, V_VAR1);
      sendSketchInfo("RS485 Node test Sensor", "1.0");
      present(CHILD_ID_VALUE, S_CUSTOM, "Node RS485");
      Serial.println( F("Arduino MySensors RS485 Node test") );    // Fonction F() permet de placer la chaine dans la mémoire eprogramme (Arduino IDE 1.0).
      analogReference(INTERNAL);
      delay(1000);
        Serial.println( F("Loop ...") );
        // Get millis
        long ms = millis();
        Serial.print(F("Millis: "));
        Serial.println(ms);
        send(msgVal.set(ms, 1));
        sleep(UPDATE_INTERVAL);
    And the node log:
    __  __       ____
           |___/                      2.3.2
    16 MCO:BGN:INIT NODE,CP=RSNNA---,FQ=16,REL=255,VER=2.3.2
    26 TSM:INIT
    28 TSF:WUR:MS=0
    29 TSM:INIT:TSP OK
    31 TSM:FPAR
    49 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2057 !TSM:FPAR:NO REPLY
    2059 TSM:FPAR
    2076 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4084 !TSM:FPAR:NO REPLY
    4086 TSM:FPAR
    4104 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6112 !TSM:FPAR:NO REPLY
    6114 TSM:FPAR
    6131 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8139 !TSM:FPAR:FAIL
    8140 TSM:FAIL:CNT=1
    8142 TSM:FAIL:DIS
    8144 TSF:TDI:TSL
    18146 TSM:FAIL:RE-INIT
    18148 TSM:INIT
    18149 TSM:INIT:TSP OK
    18151 TSM:FPAR
    18169 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20178 !TSM:FPAR:NO REPLY
    20180 TSM:FPAR
    20199 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    22206 !TSM:FPAR:NO REPLY
    22208 TSM:FPAR
    To debug, I also use this USB RS485 module: https://www.makershop.de/wp-content/uploads/2016/01/1PC-font-b-USB-b-font-to-font-b-RS485-b-font-font-b-USB-b.jpg, this one is connected to the RS485 bus and I can see with a simple python program the data sent by the node:
    01 ff 00 58 07 02 ff ff ff 02 03 07 ff 03 66 04
    Still nothing is received on the gateway !
    I have checked the wiring several times, and tested with other identical RS485 modules but still the same problem.
    Would you have other tracks?
    ps: I use Arduino IDE 1.8.13 and MySensors lib 2.3.2
    • V
      V
      vdomos
      I found my problem
      I added the parent node ID:
      #define MY_PARENT_NODE_ID 0
      in the node sketch and now it works
      C 1 Reply Last reply
      • V vdomos
        I found my problem
        C
        C
        cabat
        @vdomos this is very strange - it works for me without this directive..
        #define MY_BAUD_RATE 9600
        #define MY_NODE_ID 111
        //#define MY_PARENT_NODE_ID 0
        #define MY_OTA_FIRMWARE_FEATURE
        #define MY_OTA_FLASH_SS 16  //  pin A2 of Arduino Pro Mini
        #define MY_OTA_FLASH_JDECID 0xEF30
        #define MY_OTA_RETRY (10u)
        #define MY_OTA_RETRY_DELAY (2000u)
        #define MY_RS485
        #define MY_RS485_DE_PIN 7
          pinMode(6, OUTPUT);
        void before() {
          sendSketchInfo("Test_RS485_OTA", "2.3.2.0.004");
          digitalWrite(6,0);
          wait(100);
          digitalWrite(6,1);
          wait(100);
          digitalWrite(6,0);
          wait(100);
          digitalWrite(6,1);
          sendHeartbeat();
          wait(5000);
        • V
          V
          vdomos
          @cabat , you are right
          I commented on the MY_PARENT_NODE_ID line and after uploading sketch, I still receive on the gateway.
          The problem was elsewhere but I don't understand where
          • V vdomos
            C
            C
            cabat
            @vdomos it is possible to connect the ground wire of the RS485 adapters?
            • V
              V
              vdomos
              @cabat , The Gnd is not needed, only the A and B pins are needed, I think.
              I tested a 2nd node with the same sketch, only the "MY_NODE_ID" was changed.
              It works perfectly without needing the "MY_PARENT_NODE_ID" directive.
              Both nodes are communicating well with the gateway now.
              • Q
                Q
                qobouky
                I have the same issue.
                I used example library and upload Serial Gateway RS485 and Motion Sensor RS485. Both to Arduino UNO. Wiring according to (https://forum.mysensors.org/assets/uploads/files/1585670689122-example-rs485-mqtt.p)
                Gateway Log
                0;255;0;0;18;2.3.2
                NOD Log
                26 TSM:INIT
                28 TSF:WUR:MS=0
                29 TSM:INIT:TSP OK
                31 TSF:SID:OK,ID=123
                32 TSM:FPAR
                51 ?TSF:MSG:SEND,123-123-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                2059 !TSM:FPAR:NO REPLY
                2061 TSM:FPAR
                2078 ?TSF:MSG:SEND,123-123-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                4086 !TSM:FPAR:NO REPLY
                4088 TSM:FPAR
                4106 ?TSF:MSG:SEND,123-123-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                6114 !TSM:FPAR:NO REPLY
                6116 TSM:FPAR
                6133 ?TSF:MSG:SEND,123-123-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                8141 !TSM:FPAR:FAIL
                8142 TSM:FAIL:CNT=1
                8144 TSM:FAIL:DIS
                8146 TSF:TDI:TSL
                18148 TSM:FAIL:RE-INIT
                18150 TSM:INIT
                18151 TSM:INIT:TSP OK
                18153 TSF:SID:OK,ID=123
                18155 TSM:FPAR
                18173 ?TSF:MSG:SEND,123-123-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                20182 !TSM:FPAR:NO REPLY
                Try with NODE ID definition or without
                Thnak you for any help!!
                • A
                  ArduiSens
                  hello, maybe a hardware issue
                  please check
                  Ref https://forum.mysensors.org/topic/4854/building-a-wired-rs485-sensor-network/99
                  he 510 ohm pull up and pull down resistors are usually mounted on the master side. Theoretically it
                  would be best to install it in the middle of your bus line. The 120 ohm termination resistor must always
                  be used on distances greater than 1 meter and/or baud rates higher than 9600. It’s best to install it as a
                  norm as noise and reflections will cause havoc on your communication once implemented in the field.
                  The termination resistors should be mounted at both ends of the bus line. Please note that adding bias
                  resistors will load the driver IC output. With the indicated values the max number of units on the bus
                  line is limited to eight 12kΩ, sixteen 24kΩ, or thirty-two 48kΩ units.
                  For further protection transient suppressors can be installed across the differential lines, from the Vcc to
                  D+ and from GND to D-.!
                  MySensors 2.3.2; contr:Domoticz; layer: RS485, nRF24; gw: Ethernet, Serial
                  • Q
                    Q
                    qobouky
                    This solved my issue!! Thank you!!
