  3. Is there a timing issue with "faster" platforms?
8 Posts 2 Posters 1.1k Views 2 Watching
  • N Offline
    N Offline
    Nigel31
    Hi All,
    Thermostat node NOW 2.3.2 - teensy 3.2
    Gateway 2.2.0 - uno clone
    Controller Domoticz, recent build
    I have posted previously with woes getting requesting data or otherwise getting data INTO a particular node, my thermostat.
    This thermostat is software Signed, and in another post I was asking about where signing is actually used, because lots of messages seemed to NOT be signed.
    post here
    I also had issues getting the teensy working with the radio.
    teensy post
    Which I eventually solved by dropping the frequency of the processor to 48Mhz.
    It occurred to me mulling this over in bed, that I had read some older posts about timings relating to a M0 processor, and that how it was resolved by introducing a delay(10) into the core code somewhere, and it was agreed that the issue was related to "timing".
    I thought I would see if I could lower the teensy speed further, so I have, and the results are startling.
    The logs are below, but long story short, running at 48Mhz (the speed at which I could get the RFM69 to work), Getting to the same point in the sketch, where I send the "Boot time" to the controller takes 85878ms
    The same sketch, BUT slowing the processor to 24Mhz takes 30046ms
    And yes I definitely have that the right way round.
    Additionally the node now mostly gets the data sent to it or requested by it.
    You can see this to an extent in the logs, where I request the time (looped 5 times in setup) At the faster speed, the time is almost never received until later in the sketch, and after certain "keys" are successfully exchanged.
    I hope that one or more of the core team will read this, and have some Ideas.
    This post is split, as I can't post over 32kbytes of text
    Kind regards
    Nigel
    • N Offline
      N Offline
      Nigel31
      24Mhz Log
      1304 ?TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      2096 TSF:MSG:READ,0-0-10,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      2096 SGN:SKP:MSG CMD=3,TYPE=8
      2096 TSF:MSG:FPAR OK,ID=0,D=1
      2510 TSF:MSG:READ,4-4-10,s=255,c=3,t=8,pt=1,l=1,sg=0:1
      2510 SGN:SKP:MSG CMD=3,TYPE=8
      3306 TSM:FPAR:OK
      3306 TSM:ID
      3306 TSM:ID:OK
      3306 TSM:UPL
      3306 SGN:SGN:NREQ=0
      3312 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
      3640 TSF:MSG:READ,0-0-10,s=255,c=3,t=25,pt=1,l=1,sg=0:1
      3640 SGN:SKP:MSG CMD=3,TYPE=25
      3640 TSF:MSG:PONG RECV,HP=1
      3640 TSM:UPL:OK
      3641 TSM:READY:ID=10,PAR=0,DIS=1
      3641 SGN:PRE:SGN REQ
      3641 SGN:PRE:WHI NREQ
      3641 SGN:SGN:NREQ=0
      3647 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
      3647 SGN:PRE:XMT,TO=0
      3648 SGN:PRE:WAIT GW
      4079 TSF:MSG:READ,0-0-10,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
      4079 SGN:SKP:MSG CMD=3,TYPE=15
      4079 SGN:SGN:NREQ=0
      4710 TSF:MSG:SEND,10-10-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.2
      4711 SGN:SGN:NREQ=0
      4834 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
      4905 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
      4905 SGN:SKP:MSG CMD=3,TYPE=16
      4906 SGN:SGN:NREQ=0
      5226 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
      5226 SGN:NCE:XMT,TO=10
      5608 TSF:MSG:READ,0-0-10,s=255,c=3,t=6,pt=0,l=1,sg=1:M
      5608 SGN:BND:NONCE=A0F7C4739126DCC8FFF8C2362FA2D4EEADF11ED4190AB1459AAAAAAAAAAAAAAA
      5610 SGN:BND:HMAC=9BE81338877EFE874F06BB1A04505380A33D70758C03AB43E6DAC26F0E56DDE0
      5610 SGN:VER:OK
      LivingRm Thermostat Present, 1.1.12
      5610 SGN:SGN:NREQ=0
      5683 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=0,st=OK:LivingRm Thermostat
      5683 SGN:SGN:NREQ=0
      5819 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=12,pt=0,l=6,sg=0,ft=0,st=OK:1.1.12
      5820 SGN:SGN:NREQ=0
      5977 TSF:MSG:SEND,10-10-0-0,s=0,c=0,t=6,pt=0,l=16,sg=0,ft=0,st=OK:Room Temperature
      6077 SGN:SGN:NREQ=0
      7371 !TSF:MSG:SEND,10-10-0-0,s=5,c=0,t=33,pt=0,l=18,sg=0,ft=0,st=NACK:Thermostat RX RSSI
      7471 SGN:SGN:NREQ=0
      7479 TSF:MSG:SEND,10-10-0-0,s=2,c=0,t=3,pt=0,l=16,sg=0,ft=1,st=OK:Thermostat Relay
      7579 SGN:SGN:NREQ=0
      8739 TSF:MSG:SEND,10-10-0-0,s=3,c=0,t=3,pt=0,l=13,sg=0,ft=0,st=OK:Heat Override
      8840 SGN:SGN:NREQ=0
      10080 !TSF:MSG:SEND,10-10-0-0,s=7,c=0,t=6,pt=0,l=11,sg=0,ft=0,st=NACK:Who is Home
      10180 SGN:SGN:NREQ=0
      10254 TSF:MSG:SEND,10-10-0-0,s=1,c=0,t=14,pt=0,l=13,sg=0,ft=1,st=OK:Temp Setpoint
      10354 SGN:SGN:NREQ=0
      11578 !TSF:MSG:SEND,10-10-0-0,s=6,c=0,t=4,pt=0,l=11,sg=0,ft=0,st=NACK:Oil Tank PC
      11678 SGN:SGN:NREQ=0
      12902 !TSF:MSG:SEND,10-10-0-0,s=12,c=0,t=36,pt=0,l=12,sg=0,ft=1,st=NACK:Display Text
      13002 SGN:SGN:NREQ=0
      13010 TSF:MSG:SEND,10-10-0-0,s=8,c=0,t=3,pt=0,l=14,sg=0,ft=2,st=OK:SP Update Flag
      13110 SGN:SGN:NREQ=0
      14335 TSF:MSG:SEND,10-10-0-0,s=9,c=0,t=3,pt=0,l=13,sg=0,ft=0,st=OK:HotWater Flag
      14436 SGN:SGN:NREQ=0
      15672 !TSF:MSG:SEND,10-10-0-0,s=10,c=0,t=36,pt=0,l=21,sg=0,ft=0,st=NACK:Returned Display Text
      15772 SGN:SGN:NREQ=0
      16996 !TSF:MSG:SEND,10-10-0-0,s=11,c=0,t=36,pt=0,l=8,sg=0,ft=1,st=NACK:BootTime
      LivingRm Thermostat END Present, 1.1.12
      17096 MCO:REG:REQ
      17096 SGN:SGN:NREQ=0
      17102 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=2,st=OK:2
      17359 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
      17360 SGN:SKP:MSG CMD=3,TYPE=16
      17360 SGN:SGN:NREQ=0
      17398 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
      17399 SGN:NCE:XMT,TO=10
      17491 TSF:MSG:READ,0-0-10,s=255,c=3,t=27,pt=1,l=1,sg=1:1
      17492 SGN:BND:NONCE=81EDDA5E5C3E58FF581C825AFD692672D7C406E97307271B86AAAAAAAAAAAAAA
      17494 SGN:BND:HMAC=86BA35CDE1A83AEBD795C850A9B6DE4FAF4A311D8EDEC969DEBC8E7B000BFEF8
      17494 SGN:VER:OK
      17494 MCO:PIM:NODE REG=1
      17494 MCO:BGN:STP
      Loaded values
       :Relay output : 1
      17541 SGN:SGN:NREQ=0
      17548 TSF:MSG:SEND,10-10-0-0,s=7,c=1,t=45,pt=7,l=5,sg=0,ft=0,st=OK:0.0
      17549 SGN:SGN:NREQ=0
      17625 TSF:MSG:SEND,10-10-0-0,s=2,c=2,t=2,pt=0,l=0,sg=0,ft=0,st=OK:
      uplink available
      17721 TSF:MSG:READ,0-0-10,s=2,c=3,t=16,pt=0,l=0,sg=1:
      17721 SGN:SKP:MSG CMD=3,TYPE=16
      17721 SGN:SGN:NREQ=0
      17760 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
      17760 SGN:NCE:XMT,TO=10
      17854 TSF:MSG:READ,0-0-10,s=2,c=2,t=2,pt=0,l=1,sg=1:0
      17855 SGN:BND:NONCE=FAB0FAFA566EB33918E67D902BE5D7B7ABEFACEEBDD07D897FAAAAAAAAAAAAAA
      17857 SGN:BND:HMAC=DDDD34C0FB7050D86BE29336AF71BCBFC08DDE8DAB01133D70FB17F12358BE24
      17857 SGN:VER:OK
      REQ_Msg :2 MsgCmd:2 childID:2 Data:S/0 Data:I/ 0 Data:B/ 0
      19125 SGN:SGN:NREQ=0
      20343 !TSF:MSG:SEND,10-10-0-0,s=2,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=NACK:0
      20343 SGN:SGN:NREQ=0
      20444 TSF:MSG:SEND,10-10-0-0,s=12,c=1,t=47,pt=0,l=8,sg=0,ft=1,st=OK:Boot ...
      REQ DISPLAYTXT
      20445 SGN:SGN:NREQ=0
      21810 !TSF:MSG:SEND,10-10-0-0,s=12,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=NACK:
      Rx Error 1
      22010 SGN:SGN:NREQ=0
      22015 TSF:MSG:SEND,10-10-0-0,s=12,c=2,t=47,pt=0,l=0,sg=0,ft=1,st=OK:
       Request OK ACK Received
      22078 TSF:MSG:READ,0-0-10,s=12,c=3,t=16,pt=0,l=0,sg=1:
      22079 SGN:SKP:MSG CMD=3,TYPE=16
      22079 SGN:SGN:NREQ=0
      22239 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
      22239 SGN:NCE:XMT,TO=10
      Req PC
      22239 SGN:SGN:NREQ=0
      23583 !TSF:MSG:SEND,10-10-0-0,s=6,c=2,t=3,pt=0,l=0,sg=0,ft=0,st=NACK:
      Rx Error 1
      23783 SGN:SGN:NREQ=0
      23788 TSF:MSG:SEND,10-10-0-0,s=6,c=2,t=3,pt=0,l=0,sg=0,ft=1,st=OK:
      23842 TSF:MSG:READ,0-0-10,s=6,c=3,t=16,pt=0,l=0,sg=1:
      23842 SGN:SKP:MSG CMD=3,TYPE=16
      23843 SGN:SGN:NREQ=0
      23858 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
      23858 SGN:NCE:XMT,TO=10
      23986 TSF:MSG:READ,0-0-10,s=6,c=2,t=3,pt=0,l=2,sg=1:65
      23986 SGN:BND:NONCE=66FA19948675FCDD4A73D33EC0C4B5F6F7D57A8A112CE93A1DAAAAAAAAAAAAAA
      23988 SGN:BND:HMAC=E34A8061453CB4DC770DFD3AC83567E58DCA3D42FA7CDB743CDBF40EE9327DD7
      23988 SGN:VER:OK
      REQ_Msg :3 MsgCmd:2 childID:6 Data:S/65 Data:I/ 65 Data:B/ 1
      Req SP
      23989 SGN:SGN:NREQ=0
      24033 TSF:MSG:SEND,10-10-0-0,s=1,c=2,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
      display init
      WD Enabled
      24084 SGN:SGN:NREQ=0
      24090 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
      24095 SGN:SGN:NREQ=0
      24101 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
      24196 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
      24196 SGN:SKP:MSG CMD=3,TYPE=16
      24197 SGN:SGN:NREQ=0
      25447 !TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=NACK:<NONCE>
      25447 !SGN:NCE:XMT,TO=10 FAIL
      Time REQ 1
      26101 SGN:SGN:NREQ=0
      26918 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=1,st=OK:
      26963 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=0:
      26963 SGN:SKP:MSG CMD=3,TYPE=16
      26964 SGN:SGN:NREQ=0
      27232 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
      27233 SGN:NCE:XMT,TO=10
      27326 TSF:MSG:READ,0-0-10,s=255,c=3,t=1,pt=0,l=10,sg=1:1629281252
      27326 SGN:BND:NONCE=96DC361C795A3C064B82B2F1C201D95BF3C78786A2187E36CFAAAAAAAAAAAAAA
      27328 SGN:BND:HMAC=F65B83755837BAF5093BE2D62C9EE70C5B115B1330F9886B6481D8884A9E8E32
      27328 SGN:VER:OK
      Time value received: Time value valid: 1629281252
      10 7 32 18 8 2021
      Boot = 2021:8:18:10:7:32
      27329 SGN:SGN:NREQ=0
      28621 TSF:MSG:SEND,10-10-0-0,s=11,c=1,t=47,pt=0,l=17,sg=0,ft=0,st=OK:2021:8:18:10:7:32
      28621 !MCO:WAI:RC=1
      28622 !MCO:PRO:RC=1
      28622 !MCO:PRO:RC=1
      28622 !MCO:PRO:RC=1
      28622 !MCO:PRO:RC=1
      28622 !MCO:PRO:RC=1
      28622 !MCO:PRO:RC=1
      28622 !MCO:PRO:RC=1
      28622 !MCO:PRO:RC=1
      28622 !MCO:PRO:RC=1
      28622 !MCO:PRO:RC=1
      28622 !MCO:PRO:RC=1
      28623 !MCO:PRO:RC=1
      28623 !MCO:PRO:RC=1
      28623 !MCO:PRO:RC=1
      28623 !MCO:PRO:RC=1
      28623 !MCO:PRO:RC=1
      28623 !MCO:PRO:RC=1
      28623 !MCO:PRO:RC=1
      28623 !MCO:PRO:RC=1
      28623 !MCO:PRO:RC=1
      28623 !MCO:PRO:RC=1
      28623 !MCO:PRO:RC=1
      28623 !MCO:PRO:RC=1
      28624 !MCO:PRO:RC=1
      28624 !MCO:PRO:RC=1
      28624 !MCO:PRO:RC=1
      28624 !MCO:PRO:RC=1
      28624 !MCO:PRO:RC=1
      28624 !MCO:PRO:RC=1
      28624 !MCO:PRO:RC=1
      28624 !MCO:PRO:RC=1
      28624 !MCO:PRO:RC=1
      28624 !MCO:PRO:RC=1
      28624 !MCO:PRO:RC=1
      28624 !MCO:PRO:RC=1
      28625 !MCO:PRO:RC=1
      28625 !MCO:PRO:RC=1
      28625 !MCO:PRO:RC=1
      28625 !MCO:PRO:RC=1
      28625 !MCO:PRO:RC=1
      28625 !MCO:PRO:RC=1
      28625 !MCO:PRO:RC=1
      28625 !MCO:PRO:RC=1
      28625 !MCO:PRO:RC=1
      28625 !MCO:PRO:RC=1
      28625 !MCO:PRO:RC=1
      28625 !MCO:PRO:RC=1
      28626 !MCO:PRO:RC=1
      28626 !MCO:PRO:RC=1
      28626 !MCO:PRO:RC=1
      28626 !MCO:PRO:RC=1
      28626 !MCO:PRO:RC=1
      28626 !MCO:PRO:RC=1
      28626 !MCO:PRO:RC=1
      28626 !MCO:PRO:RC=1
      28626 !MCO:PRO:RC=1
      28626 !MCO:PRO:RC=1
      28626 !MCO:PRO:RC=1
      28626 !MCO:PRO:RC=1
      28627 !MCO:PRO:RC=1
      28627 !MCO:PRO:RC=1
      28627 !MCO:PRO:RC=1
      28627 !MCO:PRO:RC=1
      28627 !MCO:PRO:RC=1
      28627 !MCO:PRO:RC=1
      28627 !MCO:PRO:RC=1
      28627 !MCO:PRO:RC=1
      28627 !MCO:PRO:RC=1
      28627 !MCO:PRO:RC=1
      28627 !MCO:PRO:RC=1
      28627 !MCO:PRO:RC=1
      28628 !MCO:PRO:RC=1
      28628 !MCO:PRO:RC=1
      28628 !MCO:PRO:RC=1
      28628 !MCO:PRO:RC=1
      28628 !MCO:PRO:RC=1
      28628 !MCO:PRO:RC=1
      28628 !MCO:PRO:RC=1
      28628 !MCO:PRO:RC=1
      28628 !MCO:PRO:RC=1
      28628 !MCO:PRO:RC=1
      28628 !MCO:PRO:RC=1
      28628 !MCO:PRO:RC=1
      28629 !MCO:PRO:RC=1
      28629 !MCO:PRO:RC=1
      28629 !MCO:PRO:RC=1
      28629 !MCO:PRO:RC=1
      28629 !MCO:PRO:RC=1
      28629 !MCO:PRO:RC=1
      28629 !MCO:PRO:RC=1
      28629 !MCO:PRO:RC=1
      28629 !MCO:PRO:RC=1
      28629 !MCO:PRO:RC=1
      28629 !MCO:PRO:RC=1
      28629 !MCO:PRO:RC=1
      28630 !MCO:PRO:RC=1
      28630 !MCO:PRO:RC=1
      28630 !MCO:PRO:RC=1
      28630 !MCO:PRO:RC=1
      28630 !MCO:PRO:RC=1
      28630 !MCO:PRO:RC=1
      28630 !MCO:PRO:RC=1
      28630 !MCO:PRO:RC=1
      28630 !MCO:PRO:RC=1
      28630 !MCO:PRO:RC=1
      28630 !MCO:PRO:RC=1
      28631 !MCO:PRO:RC=1
      28631 !MCO:PRO:RC=1
      28631 !MCO:PRO:RC=1
      28631 !MCO:PRO:RC=1
      28631 !MCO:PRO:RC=1
      28631 !MCO:PRO:RC=1
      28631 !MCO:PRO:RC=1
      28631 !MCO:PRO:RC=1
      28631 !MCO:PRO:RC=1
      28631 !MCO:PRO:RC=1
      28631 !MCO:PRO:RC=1
      28631 !MCO:PRO:RC=1
      28632 !MCO:PRO:RC=1
      28632 !MCO:PRO:RC=1
      28632 !MCO:PRO:RC=1
      28632 !MCO:PRO:RC=1
      28632 !MCO:PRO:RC=1
      28632 !MCO:PRO:RC=1
      28632 !MCO:PRO:RC=1
      28632 !MCO:PRO:RC=1
      28632 !MCO:PRO:RC=1
      28632 !MCO:PRO:RC=1
      28632 !MCO:PRO:RC=1
      28632 !MCO:PRO:RC=1
      28633 !MCO:PRO:RC=1
      28633 !MCO:PRO:RC=1
      28633 !MCO:PRO:RC=1
      28633 !MCO:PRO:RC=1
      28633 !MCO:PRO:RC=1
      28633 !MCO:PRO:RC=1
      28633 !MCO:PRO:RC=1
      28633 !MCO:PRO:RC=1
      28633 !MCO:PRO:RC=1
      28633 !MCO:PRO:RC=1
      28633 !MCO:PRO:RC=1
      28633 !MCO:PRO:RC=1
      28634 !MCO:PRO:RC=1
      28634 !MCO:PRO:RC=1
      28634 !MCO:PRO:RC=1
      28634 !MCO:PRO:RC=1
      28634 !MCO:PRO:RC=1
      28634 !MCO:PRO:RC=1
      28634 !MCO:PRO:RC=1
      28634 !MCO:PRO:RC=1
      28634 !MCO:PRO:RC=1
      28634 !MCO:PRO:RC=1
      28634 !MCO:PRO:RC=1
      28634 !MCO:PRO:RC=1
      28635 !MCO:PRO:RC=1
      28635 !MCO:PRO:RC=1
      28635 !MCO:PRO:RC=1
      28635 !MCO:PRO:RC=1
      28635 !MCO:PRO:RC=1
      28635 !MCO:PRO:RC=1
      28635 !MCO:PRO:RC=1
      28635 !MCO:PRO:RC=1
      28635 !MCO:PRO:RC=1
      28635 !MCO:PRO:RC=1
      28635 !MCO:PRO:RC=1
      28635 !MCO:PRO:RC=1
      28636 !MCO:PRO:RC=1
      28636 !MCO:PRO:RC=1
      28636 !MCO:PRO:RC=1
      28636 !MCO:PRO:RC=1
      28636 !MCO:PRO:RC=1
      28636 !MCO:PRO:RC=1
      28636 !MCO:PRO:RC=1
      28636 !MCO:PRO:RC=1
      28636 !MCO:PRO:RC=1
      28636 !MCO:PRO:RC=1
      28636 !MCO:PRO:RC=1
      28636 !MCO:PRO:RC=1
      28637 !MCO:PRO:RC=1
      28637 !MCO:PRO:RC=1
      28637 !MCO:PRO:RC=1
      28637 !MCO:PRO:RC=1
      28637 !MCO:PRO:RC=1
      28637 !MCO:PRO:RC=1
      28637 !MCO:PRO:RC=1
      28637 !MCO:PRO:RC=1
      28637 !MCO:PRO:RC=1
      28637 !MCO:PRO:RC=1
      28637 !MCO:PRO:RC=1
      28638 !MCO:PRO:RC=1
      28638 !MCO:PRO:RC=1
      28638 !MCO:PRO:RC=1
      28638 !MCO:PRO:RC=1
      28638 !MCO:PRO:RC=1
      28638 !MCO:PRO:RC=1
      28638 !MCO:PRO:RC=1
      28638 !MCO:PRO:RC=1
      28638 !MCO:PRO:RC=1
      28638 !MCO:PRO:RC=1
      28638 !MCO:PRO:RC=1
      28638 !MCO:PRO:RC=1
      28639 !MCO:PRO:RC=1
      28639 !MCO:PRO:RC=1
      28639 !MCO:PRO:RC=1
      28639 !MCO:PRO:RC=1
      28639 !MCO:PRO:RC=1
      28639 !MCO:PRO:RC=1
      28639 !MCO:PRO:RC=1
      28639 !MCO:PRO:RC=1
      28639 !MCO:PRO:RC=1
      28639 !MCO:PRO:RC=1
      28639 !MCO:PRO:RC=1
      28639 !MCO:PRO:RC=1
      28640 !MCO:PRO:RC=1
      28640 !MCO:PRO:RC=1
      28640 !MCO:PRO:RC=1
      28640 !MCO:PRO:RC=1
      28640 !MCO:PRO:RC=1
      28640 !MCO:PRO:RC=1
      28640 !MCO:PRO:RC=1
      28640 !MCO:PRO:RC=1
      28640 !MCO:PRO:RC=1
      28640 !MCO:PRO:RC=1
      28640 !MCO:PRO:RC=1
      28640 !MCO:PRO:RC=1
      28641 !MCO:PRO:RC=1
      28641 !MCO:PRO:RC=1
      28641 !MCO:PRO:RC=1
      28641 !MCO:PRO:RC=1
      28641 !MCO:PRO:RC=1
      28641 !MCO:PRO:RC=1
      28641 !MCO:PRO:RC=1
      28641 !MCO:PRO:RC=1
      28641 !MCO:PRO:RC=1
      28641 !MCO:PRO:RC=1
      28641 !MCO:PRO:RC=1
      28641 !MCO:PRO:RC=1
      28642 !MCO:PRO:RC=1
      28642 !MCO:PRO:RC=1
      28642 !MCO:PRO:RC=1
      28642 !MCO:PRO:RC=1
      28642 !MCO:PRO:RC=1
      28642 !MCO:PRO:RC=1
      28642 !MCO:PRO:RC=1
      28642 !MCO:PRO:RC=1
      28642 !MCO:PRO:RC=1
      28642 !MCO:PRO:RC=1
      28642 !MCO:PRO:RC=1
      28642 !MCO:PRO:RC=1
      28643 !MCO:PRO:RC=1
      28643 !MCO:PRO:RC=1
      28643 !MCO:PRO:RC=1
      28643 !MCO:PRO:RC=1
      28643 !MCO:PRO:RC=1
      28643 !MCO:PRO:RC=1
      28643 !MCO:PRO:RC=1
      28643 !MCO:PRO:RC=1
      28643 !MCO:PRO:RC=1
      28643 !MCO:PRO:RC=1
      28643 !MCO:PRO:RC=1
      28643 !MCO:PRO:RC=1
      28644 !MCO:PRO:RC=1
      28644 !MCO:PRO:RC=1
      28644 !MCO:PRO:RC=1
      28644 !MCO:PRO:RC=1
      28644 !MCO:PRO:RC=1
      28644 !MCO:PRO:RC=1
      28644 !MCO:PRO:RC=1
      28644 !MCO:PRO:RC=1
      28644 !MCO:PRO:RC=1
      28644 !MCO:PRO:RC=1
      28644 !MCO:PRO:RC=1
      28644 !MCO:PRO:RC=1
      28645 !MCO:PRO:RC=1
      28645 !MCO:PRO:RC=1
      28645 !MCO:PRO:RC=1
      28645 !MCO:PRO:RC=1
      28645 !MCO:PRO:RC=1
      28645 !MCO:PRO:RC=1
      28645 !MCO:PRO:RC=1
      28645 !MCO:PRO:RC=1
      28645 !MCO:PRO:RC=1
      28645 !MCO:PRO:RC=1
      28645 !MCO:PRO:RC=1
      28646 !MCO:PRO:RC=1
      28646 !MCO:PRO:RC=1
      28646 !MCO:PRO:RC=1
      28646 !MCO:PRO:RC=1
      28646 !MCO:PRO:RC=1
      28646 !MCO:PRO:RC=1
      28646 !MCO:PRO:RC=1
      28646 !MCO:PRO:RC=1
      28646 !MCO:PRO:RC=1
      28646 !MCO:PRO:RC=1
      28646 !MCO:PRO:RC=1
      28646 !MCO:PRO:RC=1
      28647 !MCO:PRO:RC=1
      28647 !MCO:PRO:RC=1
      28647 !MCO:PRO:RC=1
      28647 !MCO:PRO:RC=1
      28647 !MCO:PRO:RC=1
      28647 !MCO:PRO:RC=1
      28647 !MCO:PRO:RC=1
      28647 !MCO:PRO:RC=1
      28647 !MCO:PRO:RC=1
      28647 !MCO:PRO:RC=1
      28647 !MCO:PRO:RC=1
      28647 !MCO:PRO:RC=1
      28648 !MCO:PRO:RC=1
      28648 !MCO:PRO:RC=1
      28648 !MCO:PRO:RC=1
      28648 !MCO:PRO:RC=1
      28648 !MCO:PRO:RC=1
      28648 !MCO:PRO:RC=1
      28648 !MCO:PRO:RC=1
      28648 !MCO:PRO:RC=1
      28648 !MCO:PRO:RC=1
      28648 !MCO:PRO:RC=1
      28648 !MCO:PRO:RC=1
      28648 !MCO:PRO:RC=1
      28649 !MCO:PRO:RC=1
      28649 !MCO:PRO:RC=1
      28649 !MCO:PRO:RC=1
      28649 !MCO:PRO:RC=1
      28649 !MCO:PRO:RC=1
      28649 !MCO:PRO:RC=1
      28649 !MCO:PRO:RC=1
      28649 !MCO:PRO:RC=1
      28649 !MCO:PRO:RC=1
      28649 !MCO:PRO:RC=1
      28649 !MCO:PRO:RC=1
      28649 !MCO:PRO:RC=1
      28650 !MCO:PRO:RC=1
      28650 !MCO:PRO:RC=1
      28650 !MCO:PRO:RC=1
      28650 !MCO:PRO:RC=1
      28650 !MCO:PRO:RC=1
      28650 !MCO:PRO:RC=1
      28650 !MCO:PRO:RC=1
      28650 !MCO:PRO:RC=1
      28650 !MCO:PRO:RC=1
      28650 !MCO:PRO:RC=1
      28650 !MCO:PRO:RC=1
      28650 !MCO:PRO:RC=1
      28651 !MCO:PRO:RC=1
      28651 !MCO:PRO:RC=1
      28651 !MCO:PRO:RC=1
      28651 !MCO:PRO:RC=1
      28651 !MCO:PRO:RC=1
      28651 !MCO:PRO:RC=1
      28651 !MCO:PRO:RC=1
      28651 !MCO:PRO:RC=1
      28651 !MCO:PRO:RC=1
      28651 !MCO:PRO:RC=1
      28651 !MCO:PRO:RC=1
      28651 !MCO:PRO:RC=1
      28652 !MCO:PRO:RC=1
      28652 !MCO:PRO:RC=1
      28652 !MCO:PRO:RC=1
      28652 !MCO:PRO:RC=1
      28652 !MCO:PRO:RC=1
      28652 !MCO:PRO:RC=1
      28652 !MCO:PRO:RC=1
      28652 !MCO:PRO:RC=1
      28652 !MCO:PRO:RC=1
      28652 !MCO:PRO:RC=1
      28652 !MCO:PRO:RC=1
      28652 !MCO:PRO:RC=1
      28653 !MCO:PRO:RC=1
      28653 !MCO:PRO:RC=1
      28653 !MCO:PRO:RC=1
      28653 !MCO:PRO:RC=1
      28653 !MCO:PRO:RC=1
      28653 !MCO:PRO:RC=1
      28653 !MCO:PRO:RC=1
      28653 !MCO:PRO:RC=1
      28653 !MCO:PRO:RC=1
      28653 !MCO:PRO:RC=1
      28653 !MCO:PRO:RC=1
      28654 !MCO:PRO:RC=1
      28654 !MCO:PRO:RC=1
      28654 !MCO:PRO:RC=1
      28654 !MCO:PRO:RC=1
      28654 !MCO:PRO:RC=1
      28654 !MCO:PRO:RC=1
      28654 !MCO:PRO:RC=1
      28654 !MCO:PRO:RC=1
      28654 !MCO:PRO:RC=1
      28654 !MCO:PRO:RC=1
      28654 !MCO:PRO:RC=1
      28654 !MCO:PRO:RC=1
      28655 !MCO:PRO:RC=1
      28655 !MCO:PRO:RC=1
      28655 !MCO:PRO:RC=1
      28655 !MCO:PRO:RC=1
      28655 !MCO:PRO:RC=1
      28655 !MCO:PRO:RC=1
      28655 !MCO:PRO:RC=1
      28655 !MCO:PRO:RC=1
      28655 !MCO:PRO:RC=1
      28655 !MCO:PRO:RC=1
      28655 !MCO:PRO:RC=1
      28655 !MCO:PRO:RC=1
      28656 !MCO:PRO:RC=1
      28656 !MCO:PRO:RC=1
      28656 !MCO:PRO:RC=1
      28656 !MCO:PRO:RC=1
      28656 !MCO:PRO:RC=1
      28656 !MCO:PRO:RC=1
      28656 !MCO:PRO:RC=1
      28656 !MCO:PRO:RC=1
      28656 !MCO:PRO:RC=1
      28656 !MCO:PRO:RC=1
      28656 !MCO:PRO:RC=1
      28656 !MCO:PRO:RC=1
      28657 !MCO:PRO:RC=1
      28657 !MCO:PRO:RC=1
      28657 !MCO:PRO:RC=1
      28657 !MCO:PRO:RC=1
      28657 !MCO:PRO:RC=1
      28657 !MCO:PRO:RC=1
      28657 !MCO:PRO:RC=1
      28657 !MCO:PRO:RC=1
      28657 !MCO:PRO:RC=1
      28657 !MCO:PRO:RC=1
      28657 !MCO:PRO:RC=1
      28657 !MCO:PRO:RC=1
      28658 !MCO:PRO:RC=1
      28658 !MCO:PRO:RC=1
      28658 !MCO:PRO:RC=1
      28658 !MCO:PRO:RC=1
      28658 !MCO:PRO:RC=1
      28658 !MCO:PRO:RC=1
      28658 !MCO:PRO:RC=1
      28658 !MCO:PRO:RC=1
      28658 !MCO:PRO:RC=1
      28658 !MCO:PRO:RC=1
      28658 !MCO:PRO:RC=1
      28658 !MCO:PRO:RC=1
      28659 !MCO:PRO:RC=1
      28659 !MCO:PRO:RC=1
      28659 !MCO:PRO:RC=1
      28659 !MCO:PRO:RC=1
      28659 !MCO:PRO:RC=1
      28659 !MCO:PRO:RC=1
      28659 !MCO:PRO:RC=1
      28659 !MCO:PRO:RC=1
      28659 !MCO:PRO:RC=1
      28659 !MCO:PRO:RC=1
      28659 !MCO:PRO:RC=1
      28659 !MCO:PRO:RC=1
      28660 !MCO:PRO:RC=1
      28660 !MCO:PRO:RC=1
      28660 !MCO:PRO:RC=1
      28660 !MCO:PRO:RC=1
      28660 !MCO:PRO:RC=1
      28660 !MCO:PRO:RC=1
      28660 !MCO:PRO:RC=1
      28660 !MCO:PRO:RC=1
      28660 !MCO:PRO:RC=1
      28660 !MCO:PRO:RC=1
      28660 !MCO:PRO:RC=1
      28660 !MCO:PRO:RC=1
      28661 !MCO:PRO:RC=1
      28661 !MCO:PRO:RC=1
      28661 !MCO:PRO:RC=1
      28661 !MCO:PRO:RC=1
      28661 !MCO:PRO:RC=1
      28661 !MCO:PRO:RC=1
      28661 !MCO:PRO:RC=1
      28661 !MCO:PRO:RC=1
      28661 !MCO:PRO:RC=1
      28661 !MCO:PRO:RC=1
      28661 !MCO:PRO:RC=1
      28662 !MCO:PRO:RC=1
      28662 !MCO:PRO:RC=1
      28662 !MCO:PRO:RC=1
      28662 !MCO:PRO:RC=1
      28662 !MCO:PRO:RC=1
      28662 !MCO:PRO:RC=1
      28662 !MCO:PRO:RC=1
      28662 !MCO:PRO:RC=1
      28662 !MCO:PRO:RC=1
      28662 !MCO:PRO:RC=1
      28662 !MCO:PRO:RC=1
      28662 !MCO:PRO:RC=1
      28663 !MCO:PRO:RC=1
      28663 !MCO:PRO:RC=1
      28663 !MCO:PRO:RC=1
      28663 !MCO:PRO:RC=1
      28663 !MCO:PRO:RC=1
      28663 !MCO:PRO:RC=1
      28663 !MCO:PRO:RC=1
      28663 !MCO:PRO:RC=1
      28663 !MCO:PRO:RC=1
      28663 !MCO:PRO:RC=1
      28663 !MCO:PRO:RC=1
      28663 !MCO:PRO:RC=1
      28664 !MCO:PRO:RC=1
      28664 !MCO:PRO:RC=1
      28664 !MCO:PRO:RC=1
      28664 !MCO:PRO:RC=1
      28664 !MCO:PRO:RC=1
      28664 !MCO:PRO:RC=1
      28664 !MCO:PRO:RC=1
      28664 !MCO:PRO:RC=1
      28664 !MCO:PRO:RC=1
      28664 !MCO:PRO:RC=1
      28664 !MCO:PRO:RC=1
      28664 !MCO:PRO:RC=1
      28665 !MCO:PRO:RC=1
      28665 !MCO:PRO:RC=1
      28665 !MCO:PRO:RC=1
      28665 !MCO:PRO:RC=1
      28665 !MCO:PRO:RC=1
      28665 !MCO:PRO:RC=1
      28665 !MCO:PRO:RC=1
      28665 !MCO:PRO:RC=1
      28665 !MCO:PRO:RC=1
      28665 !MCO:PRO:RC=1
      28665 !MCO:PRO:RC=1
      28665 !MCO:PRO:RC=1
      28666 !MCO:PRO:RC=1
      28666 !MCO:PRO:RC=1
      28666 !MCO:PRO:RC=1
      28666 !MCO:PRO:RC=1
      28666 !MCO:PRO:RC=1
      28666 !MCO:PRO:RC=1
      28666 !MCO:PRO:RC=1
      28666 !MCO:PRO:RC=1
      28666 !MCO:PRO:RC=1
      28666 !MCO:PRO:RC=1
      28666 !MCO:PRO:RC=1
      28666 !MCO:PRO:RC=1
      28667 !MCO:PRO:RC=1
      28667 !MCO:PRO:RC=1
      28667 !MCO:PRO:RC=1
      28667 !MCO:PRO:RC=1
      28667 !MCO:PRO:RC=1
      28667 !MCO:PRO:RC=1
      28667 !MCO:PRO:RC=1
      28667 !MCO:PRO:RC=1
      28667 !MCO:PRO:RC=1
      28667 !MCO:PRO:RC=1
      28667 !MCO:PRO:RC=1
      28667 !MCO:PRO:RC=1
      28668 !MCO:PRO:RC=1
      28668 !MCO:PRO:RC=1
      28668 !MCO:PRO:RC=1
      28668 !MCO:PRO:RC=1
      28668 !MCO:PRO:RC=1
      28668 !MCO:PRO:RC=1
      28668 !MCO:PRO:RC=1
      28668 !MCO:PRO:RC=1
      28668 !MCO:PRO:RC=1
      28668 !MCO:PRO:RC=1
      28668 !MCO:PRO:RC=1
      28668 !MCO:PRO:RC=1
      28669 !MCO:PRO:RC=1
      28669 !MCO:PRO:RC=1
      28669 !MCO:PRO:RC=1
      28669 !MCO:PRO:RC=1
      28669 !MCO:PRO:RC=1
      28669 !MCO:PRO:RC=1
      28669 !MCO:PRO:RC=1
      28669 !MCO:PRO:RC=1
      28669 !MCO:PRO:RC=1
      28669 !MCO:PRO:RC=1
      28669 !MCO:PRO:RC=1
      28670 !MCO:PRO:RC=1
      28670 !MCO:PRO:RC=1
      28670 !MCO:PRO:RC=1
      28670 !MCO:PRO:RC=1
      28670 !MCO:PRO:RC=1
      28670 !MCO:PRO:RC=1
      28670 !MCO:PRO:RC=1
      28670 !MCO:PRO:RC=1
      28670 !MCO:PRO:RC=1
      28670 !MCO:PRO:RC=1
      28670 !MCO:PRO:RC=1
      28670 !MCO:PRO:RC=1
      28671 !MCO:PRO:RC=1
      28671 !MCO:PRO:RC=1
      28671 !MCO:PRO:RC=1
      28671 !MCO:PRO:RC=1
      28671 !MCO:PRO:RC=1
      28671 !MCO:PRO:RC=1
      28671 !MCO:PRO:RC=1
      28671 !MCO:PRO:RC=1
      28671 !MCO:PRO:RC=1
      28671 !MCO:PRO:RC=1
      28671 !MCO:PRO:RC=1
      28671 !MCO:PRO:RC=1
      28672 !MCO:PRO:RC=1
      28672 !MCO:PRO:RC=1
      28672 !MCO:PRO:RC=1
      28672 !MCO:PRO:RC=1
      28672 !MCO:PRO:RC=1
      28672 !MCO:PRO:RC=1
      28672 !MCO:PRO:RC=1
      28672 !MCO:PRO:RC=1
      28672 !MCO:PRO:RC=1
      28672 !MCO:PRO:RC=1
      28672 !MCO:PRO:RC=1
      28672 !MCO:PRO:RC=1
      28673 !MCO:PRO:RC=1
      28673 !MCO:PRO:RC=1
      28673 !MCO:PRO:RC=1
      28673 !MCO:PRO:RC=1
      28673 !MCO:PRO:RC=1
      28673 !MCO:PRO:RC=1
      28673 !MCO:PRO:RC=1
      28673 !MCO:PRO:RC=1
      28673 !MCO:PRO:RC=1
      28673 !MCO:PRO:RC=1
      28673 !MCO:PRO:RC=1
      28673 !MCO:PRO:RC=1
      28674 !MCO:PRO:RC=1
      28674 !MCO:PRO:RC=1
      28674 !MCO:PRO:RC=1
      28674 !MCO:PRO:RC=1
      28674 !MCO:PRO:RC=1
      28674 !MCO:PRO:RC=1
      28674 !MCO:PRO:RC=1
      28674 !MCO:PRO:RC=1
      28674 !MCO:PRO:RC=1
      28674 !MCO:PRO:RC=1
      28674 !MCO:PRO:RC=1
      28674 !MCO:PRO:RC=1
      28675 !MCO:PRO:RC=1
      28675 !MCO:PRO:RC=1
      28675 !MCO:PRO:RC=1
      28675 !MCO:PRO:RC=1
      28675 !MCO:PRO:RC=1
      28675 !MCO:PRO:RC=1
      28675 !MCO:PRO:RC=1
      28675 !MCO:PRO:RC=1
      28675 !MCO:PRO:RC=1
      28675 !MCO:PRO:RC=1
      28675 !MCO:PRO:RC=1
      28675 !MCO:PRO:RC=1
      28676 !MCO:PRO:RC=1
      28676 !MCO:PRO:RC=1
      28676 !MCO:PRO:RC=1
      28676 !MCO:PRO:RC=1
      28676 !MCO:PRO:RC=1
      28676 !MCO:PRO:RC=1
      28676 !MCO:PRO:RC=1
      28676 !MCO:PRO:RC=1
      28676 !MCO:PRO:RC=1
      28676 !MCO:PRO:RC=1
      28676 !MCO:PRO:RC=1
      28676 !MCO:PRO:RC=1
      28677 !MCO:PRO:RC=1
      28677 !MCO:PRO:RC=1
      28677 !MCO:PRO:RC=1
      28677 !MCO:PRO:RC=1
      28677 !MCO:PRO:RC=1
      28677 !MCO:PRO:RC=1
      28677 !MCO:PRO:RC=1
      28677 !MCO:PRO:RC=1
      28677 !MCO:PRO:RC=1
      28677 !MCO:PRO:RC=1
      28677 !MCO:PRO:RC=1
      28678 !MCO:PRO:RC=1
      28678 !MCO:PRO:RC=1
      28678 !MCO:PRO:RC=1
      28678 !MCO:PRO:RC=1
      28678 !MCO:PRO:RC=1
      28678 !MCO:PRO:RC=1
      28678 !MCO:PRO:RC=1
      28678 !MCO:PRO:RC=1
      28678 !MCO:PRO:RC=1
      28678 !MCO:PRO:RC=1
      28678 !MCO:PRO:RC=1
      28678 !MCO:PRO:RC=1
      28679 !MCO:PRO:RC=1
      28679 !MCO:PRO:RC=1
      28679 !MCO:PRO:RC=1
      28679 !MCO:PRO:RC=1
      28679 !MCO:PRO:RC=1
      28679 !MCO:PRO:RC=1
      28679 !MCO:PRO:RC=1
      28679 !MCO:PRO:RC=1
      28679 !MCO:PRO:RC=1
      28679 !MCO:PRO:RC=1
      28679 !MCO:PRO:RC=1
      28679 !MCO:PRO:RC=1
      28680 !MCO:PRO:RC=1
      28680 !MCO:PRO:RC=1
      28680 !MCO:PRO:RC=1
      28680 !MCO:PRO:RC=1
      28680 !MCO:PRO:RC=1
      28680 !MCO:PRO:RC=1
      28680 !MCO:PRO:RC=1
      28680 !MCO:PRO:RC=1
      28680 !MCO:PRO:RC=1
      28680 !MCO:PRO:RC=1
      28680 !MCO:PRO:RC=1
      28680 !MCO:PRO:RC=1
      28681 !MCO:PRO:RC=1
      28681 !MCO:PRO:RC=1
      28681 !MCO:PRO:RC=1
      28681 !MCO:PRO:RC=1
      28681 !MCO:PRO:RC=1
      28681 !MCO:PRO:RC=1
      28681 !MCO:PRO:RC=1
      28681 !MCO:PRO:RC=1
      28681 !MCO:PRO:RC=1
      28681 !MCO:PRO:RC=1
      28681 !MCO:PRO:RC=1
      28681 !MCO:PRO:RC=1
      28682 !MCO:PRO:RC=1
      28682 !MCO:PRO:RC=1
      28682 !MCO:PRO:RC=1
      28682 !MCO:PRO:RC=1
      28682 !MCO:PRO:RC=1
      28682 !MCO:PRO:RC=1
      28682 !MCO:PRO:RC=1
      28682 !MCO:PRO:RC=1
      28682 !MCO:PRO:RC=1
      28682 !MCO:PRO:RC=1
      28682 !MCO:PRO:RC=1
      28682 !MCO:PRO:RC=1
      28683 !MCO:PRO:RC=1
      28683 !MCO:PRO:RC=1
      28683 !MCO:PRO:RC=1
      28683 !MCO:PRO:RC=1
      28683 !MCO:PRO:RC=1
      28683 !MCO:PRO:RC=1
      28683 !MCO:PRO:RC=1
      28683 !MCO:PRO:RC=1
      28683 !MCO:PRO:RC=1
      28683 !MCO:PRO:RC=1
      28683 !MCO:PRO:RC=1
      28683 !MCO:PRO:RC=1
      28684 !MCO:PRO:RC=1
      28684 !MCO:PRO:RC=1
      28684 !MCO:PRO:RC=1
      28684 !MCO:PRO:RC=1
      28684 !MCO:PRO:RC=1
      28684 !MCO:PRO:RC=1
      28684 !MCO:PRO:RC=1
      28684 !MCO:PRO:RC=1
      28684 !MCO:PRO:RC=1
      28684 !MCO:PRO:RC=1
      28684 !MCO:PRO:RC=1
      28685 !MCO:PRO:RC=1
      28685 !MCO:PRO:RC=1
      28685 !MCO:PRO:RC=1
      28685 !MCO:PRO:RC=1
      28685 !MCO:PRO:RC=1
      28685 !MCO:PRO:RC=1
      28685 !MCO:PRO:RC=1
      28685 !MCO:PRO:RC=1
      28685 !MCO:PRO:RC=1
      28685 !MCO:PRO:RC=1
      28685 !MCO:PRO:RC=1
      28685 !MCO:PRO:RC=1
      28686 !MCO:PRO:RC=1
      28686 !MCO:PRO:RC=1
      28686 !MCO:PRO:RC=1
      28686 !MCO:PRO:RC=1
      28686 !MCO:PRO:RC=1
      28686 !MCO:PRO:RC=1
      28686 !MCO:PRO:RC=1
      28686 !MCO:PRO:RC=1
      28686 !MCO:PRO:RC=1
      28686 !MCO:PRO:RC=1
      28686 !MCO:PRO:RC=1
      28686 !MCO:PRO:RC=1
      28687 !MCO:PRO:RC=1
      28687 !MCO:PRO:RC=1
      28687 !MCO:PRO:RC=1
      28687 !MCO:PRO:RC=1
      28687 !MCO:PRO:RC=1
      28687 !MCO:PRO:RC=1
      28687 !MCO:PRO:RC=1
      28687 !MCO:PRO:RC=1
      28687 !MCO:PRO:RC=1
      28687 !MCO:PRO:RC=1
      28687 !MCO:PRO:RC=1
      28687 !MCO:PRO:RC=1
      28688 !MCO:PRO:RC=1
      28688 !MCO:PRO:RC=1
      28688 !MCO:PRO:RC=1
      28688 !MCO:PRO:RC=1
      28688 !MCO:PRO:RC=1
      28688 !MCO:PRO:RC=1
      28688 !MCO:PRO:RC=1
      28688 !MCO:PRO:RC=1
      28688 !MCO:PRO:RC=1
      28688 !MCO:PRO:RC=1
      28688 !MCO:PRO:RC=1
      28688 !MCO:PRO:RC=1
      28689 !MCO:PRO:RC=1
      28689 !MCO:PRO:RC=1
      28689 !MCO:PRO:RC=1
      28689 !MCO:PRO:RC=1
      28689 !MCO:PRO:RC=1
      28689 !MCO:PRO:RC=1
      28689 !MCO:PRO:RC=1
      28689 !MCO:PRO:RC=1
      28689 !MCO:PRO:RC=1
      28689 !MCO:PRO:RC=1
      28689 !MCO:PRO:RC=1
      28689 !MCO:PRO:RC=1
      28690 !MCO:PRO:RC=1
      28690 !MCO:PRO:RC=1
      28690 !MCO:PRO:RC=1
      28690 !MCO:PRO:RC=1
      28690 !MCO:PRO:RC=1
      28690 !MCO:PRO:RC=1
      28690 !MCO:PRO:RC=1
      28690 !MCO:PRO:RC=1
      28690 !MCO:PRO:RC=1
      28690 !MCO:PRO:RC=1
      28690 !MCO:PRO:RC=1
      28690 !MCO:PRO:RC=1
      28691 !MCO:PRO:RC=1
      28691 !MCO:PRO:RC=1
      28691 !MCO:PRO:RC=1
      28691 !MCO:PRO:RC=1
      28691 !MCO:PRO:RC=1
      28691 !MCO:PRO:RC=1
      28691 !MCO:PRO:RC=1
      28691 !MCO:PRO:RC=1
      28691 !MCO:PRO:RC=1
      28691 !MCO:PRO:RC=1
      28691 !MCO:PRO:RC=1
      28691 !MCO:PRO:RC=1
      28692 !MCO:PRO:RC=1
      28692 !MCO:PRO:RC=1
      28692 !MCO:PRO:RC=1
      28692 !MCO:PRO:RC=1
      28692 !MCO:PRO:RC=1
      28692 !MCO:PRO:RC=1
      28692 !MCO:PRO:RC=1
      28692 !MCO:PRO:RC=1
      28692 !MCO:PRO:RC=1
      28692 !MCO:PRO:RC=1
      28692 !MCO:PRO:RC=1
      28693 !MCO:PRO:RC=1
      28693 !MCO:PRO:RC=1
      28693 !MCO:PRO:RC=1
      28693 !MCO:PRO:RC=1
      28693 !MCO:PRO:RC=1
      28693 !MCO:PRO:RC=1
      28693 !MCO:PRO:RC=1
      28693 !MCO:PRO:RC=1
      28693 !MCO:PRO:RC=1
      28693 !MCO:PRO:RC=1
      28693 !MCO:PRO:RC=1
      28693 !MCO:PRO:RC=1
      28694 !MCO:PRO:RC=1
      28694 !MCO:PRO:RC=1
      28694 !MCO:PRO:RC=1
      28694 !MCO:PRO:RC=1
      28694 !MCO:PRO:RC=1
      28694 !MCO:PRO:RC=1
      28694 !MCO:PRO:RC=1
      28694 !MCO:PRO:RC=1
      28694 !MCO:PRO:RC=1
      28694 !MCO:PRO:RC=1
      28694 !MCO:PRO:RC=1
      28694 !MCO:PRO:RC=1
      28695 !MCO:PRO:RC=1
      28695 !MCO:PRO:RC=1
      28695 !MCO:PRO:RC=1
      28695 !MCO:PRO:RC=1
      28695 !MCO:PRO:RC=1
      28695 !MCO:PRO:RC=1
      28695 !MCO:PRO:RC=1
      28695 !MCO:PRO:RC=1
      28695 !MCO:PRO:RC=1
      28695 !MCO:PRO:RC=1
      28695 !MCO:PRO:RC=1
      28695 !MCO:PRO:RC=1
      28696 !MCO:PRO:RC=1
      28696 !MCO:PRO:RC=1
      28696 !MCO:PRO:RC=1
      28696 !MCO:PRO:RC=1
      28696 !MCO:PRO:RC=1
      28696 !MCO:PRO:RC=1
      28696 !MCO:PRO:RC=1
      28696 !MCO:PRO:RC=1
      28696 !MCO:PRO:RC=1
      28696 !MCO:PRO:RC=1
      28696 !MCO:PRO:RC=1
      28696 !MCO:PRO:RC=1
      28697 !MCO:PRO:RC=1
      28697 !MCO:PRO:RC=1
      28697 !MCO:PRO:RC=1
      28697 !MCO:PRO:RC=1
      28697 !MCO:PRO:RC=1
      28697 !MCO:PRO:RC=1
      28697 !MCO:PRO:RC=1
      28697 !MCO:PRO:RC=1
      28697 !MCO:PRO:RC=1
      28697 !MCO:PRO:RC=1
      28697 !MCO:PRO:RC=1
      28697 !MCO:PRO:RC=1
      28698 !MCO:PRO:RC=1
      28698 !MCO:PRO:RC=1
      28698 !MCO:PRO:RC=1
      28698 !MCO:PRO:RC=1
      28698 !MCO:PRO:RC=1
      28698 !MCO:PRO:RC=1
      28698 !MCO:PRO:RC=1
      28698 !MCO:PRO:RC=1
      28698 !MCO:PRO:RC=1
      28698 !MCO:PRO:RC=1
      28698 !MCO:PRO:RC=1
      28698 !MCO:PRO:RC=1
      28699 !MCO:PRO:RC=1
      28699 !MCO:PRO:RC=1
      28699 !MCO:PRO:RC=1
      28699 !MCO:PRO:RC=1
      28699 !MCO:PRO:RC=1
      28699 !MCO:PRO:RC=1
      28699 !MCO:PRO:RC=1
      28699 !MCO:PRO:RC=1
      28699 !MCO:PRO:RC=1
      28699 !MCO:PRO:RC=1
      28699 !MCO:PRO:RC=1
      28699 !MCO:PRO:RC=1
      28700 !MCO:PRO:RC=1
      28700 !MCO:PRO:RC=1
      28700 !MCO:PRO:RC=1
      28700 !MCO:PRO:RC=1
      28700 !MCO:PRO:RC=1
      28700 !MCO:PRO:RC=1
      28700 !MCO:PRO:RC=1
      28700 !MCO:PRO:RC=1
      28700 !MCO:PRO:RC=1
      28700 !MCO:PRO:RC=1
      28700 !MCO:PRO:RC=1
      28701 !MCO:PRO:RC=1
      28701 !MCO:PRO:RC=1
      28701 !MCO:PRO:RC=1
      28701 !MCO:PRO:RC=1
      28701 !MCO:PRO:RC=1
      28701 !MCO:PRO:RC=1
      28701 !MCO:PRO:RC=1
      28701 !MCO:PRO:RC=1
      28701 !MCO:PRO:RC=1
      28701 !MCO:PRO:RC=1
      28701 !MCO:PRO:RC=1
      28701 !MCO:PRO:RC=1
      28702 !MCO:PRO:RC=1
      28702 !MCO:PRO:RC=1
      28702 !MCO:PRO:RC=1
      28702 !MCO:PRO:RC=1
      28702 !MCO:PRO:RC=1
      28702 !MCO:PRO:RC=1
      28702 !MCO:PRO:RC=1
      28702 !MCO:PRO:RC=1
      28702 !MCO:PRO:RC=1
      28702 !MCO:PRO:RC=1
      28702 !MCO:PRO:RC=1
      28702 !MCO:PRO:RC=1
      28703 !MCO:PRO:RC=1
      28703 !MCO:PRO:RC=1
      28703 !MCO:PRO:RC=1
      28703 !MCO:PRO:RC=1
      28703 !MCO:PRO:RC=1
      28703 !MCO:PRO:RC=1
      28703 !MCO:PRO:RC=1
      28703 !MCO:PRO:RC=1
      28703 !MCO:PRO:RC=1
      28703 !MCO:PRO:RC=1
      28703 !MCO:PRO:RC=1
      28703 !MCO:PRO:RC=1
      28704 !MCO:PRO:RC=1
      28704 !MCO:PRO:RC=1
      28704 !MCO:PRO:RC=1
      28704 !MCO:PRO:RC=1
      28704 !MCO:PRO:RC=1
      28704 !MCO:PRO:RC=1
      28704 !MCO:PRO:RC=1
      28704 !MCO:PRO:RC=1
      28704 !MCO:PRO:RC=1
      28704 !MCO:PRO:RC=1
      28704 !MCO:PRO:RC=1
      28704 !MCO:PRO:RC=1
      28705 !MCO:PRO:RC=1
      28705 !MCO:PRO:RC=1
      28705 !MCO:PRO:RC=1
      28705 !MCO:PRO:RC=1
      28705 !MCO:PRO:RC=1
      28705 !MCO:PRO:RC=1
      28705 !MCO:PRO:RC=1
      28705 !MCO:PRO:RC=1
      28705 !MCO:PRO:RC=1
      28705 !MCO:PRO:RC=1
      28705 !MCO:PRO:RC=1
      28705 !MCO:PRO:RC=1
      28706 !MCO:PRO:RC=1
      28706 !MCO:PRO:RC=1
      28706 !MCO:PRO:RC=1
      28706 !MCO:PRO:RC=1
      28706 !MCO:PRO:RC=1
      28706 !MCO:PRO:RC=1
      28706 !MCO:PRO:RC=1
      28706 !MCO:PRO:RC=1
      28706 !MCO:PRO:RC=1
      28706 !MCO:PRO:RC=1
      28706 !MCO:PRO:RC=1
      28706 !MCO:PRO:RC=1
      28707 !MCO:PRO:RC=1
      28707 !MCO:PRO:RC=1
      28707 !MCO:PRO:RC=1
      28707 !MCO:PRO:RC=1
      28707 !MCO:PRO:RC=1
      28707 !MCO:PRO:RC=1
      28707 !MCO:PRO:RC=1
      28707 !MCO:PRO:RC=1
      28707 !MCO:PRO:RC=1
      28707 !MCO:PRO:RC=1
      28707 !MCO:PRO:RC=1
      28707 !MCO:PRO:RC=1
      28708 !MCO:PRO:RC=1
      28708 !MCO:PRO:RC=1
      28708 !MCO:PRO:RC=1
      28708 !MCO:PRO:RC=1
      28708 !MCO:PRO:RC=1
      28708 !MCO:PRO:RC=1
      28708 !MCO:PRO:RC=1
      28708 !MCO:PRO:RC=1
      28708 !MCO:PRO:RC=1
      28708 !MCO:PRO:RC=1
      28708 !MCO:PRO:RC=1
      28709 !MCO:PRO:RC=1
      28709 !MCO:PRO:RC=1
      28709 !MCO:PRO:RC=1
      28709 !MCO:PRO:RC=1
      28709 !MCO:PRO:RC=1
      28709 !MCO:PRO:RC=1
      28709 !MCO:PRO:RC=1
      28709 !MCO:PRO:RC=1
      28709 !MCO:PRO:RC=1
      28709 !MCO:PRO:RC=1
      28709 !MCO:PRO:RC=1
      28709 !MCO:PRO:RC=1
      28710 !MCO:PRO:RC=1
      28710 !MCO:PRO:RC=1
      28710 !MCO:PRO:RC=1
      28710 !MCO:PRO:RC=1
      28710 !MCO:PRO:RC=1
      28710 !MCO:PRO:RC=1
      28710 !MCO:PRO:RC=1
      28710 !MCO:PRO:RC=1
      28710 !MCO:PRO:RC=1
      28710 !MCO:PRO:RC=1
      28710 !MCO:PRO:RC=1
      28710 !MCO:PRO:RC=1
      28711 !MCO:PRO:RC=1
      28711 !MCO:PRO:RC=1
      28711 !MCO:PRO:RC=1
      28711 !MCO:PRO:RC=1
      28711 !MCO:PRO:RC=1
      28711 !MCO:PRO:RC=1
      28711 !MCO:PRO:RC=1
      28711 !MCO:PRO:RC=1
      28711 !MCO:PRO:RC=1
      28711 !MCO:PRO:RC=1
      28711 !MCO:PRO:RC=1
      28711 !MCO:PRO:RC=1
      28712 !MCO:PRO:RC=1
      28712 !MCO:PRO:RC=1
      28712 !MCO:PRO:RC=1
      28712 !MCO:PRO:RC=1
      28712 !MCO:PRO:RC=1
      28712 !MCO:PRO:RC=1
      28712 !MCO:PRO:RC=1
      28712 !MCO:PRO:RC=1
      28712 !MCO:PRO:RC=1
      28712 !MCO:PRO:RC=1
      28712 !MCO:PRO:RC=1
      28712 !MCO:PRO:RC=1
      28713 !MCO:PRO:RC=1
      28713 !MCO:PRO:RC=1
      28713 !MCO:PRO:RC=1
      28713 !MCO:PRO:RC=1
      28713 !MCO:PRO:RC=1
      28713 !MCO:PRO:RC=1
      28713 !MCO:PRO:RC=1
      28713 !MCO:PRO:RC=1
      28713 !MCO:PRO:RC=1
      28713 !MCO:PRO:RC=1
      28713 !MCO:PRO:RC=1
      28713 !MCO:PRO:RC=1
      28714 !MCO:PRO:RC=1
      28714 !MCO:PRO:RC=1
      28714 !MCO:PRO:RC=1
      28714 !MCO:PRO:RC=1
      28714 !MCO:PRO:RC=1
      28714 !MCO:PRO:RC=1
      28714 !MCO:PRO:RC=1
      28714 !MCO:PRO:RC=1
      28714 !MCO:PRO:RC=1
      28714 !MCO:PRO:RC=1
      28714 !MCO:PRO:RC=1
      28714 !MCO:PRO:RC=1
      28715 !MCO:PRO:RC=1
      28715 !MCO:PRO:RC=1
      28715 !MCO:PRO:RC=1
      28715 !MCO:PRO:RC=1
      28715 !MCO:PRO:RC=1
      28715 !MCO:PRO:RC=1
      28715 !MCO:PRO:RC=1
      28715 !MCO:PRO:RC=1
      28715 !MCO:PRO:RC=1
      28715 !MCO:PRO:RC=1
      28715 !MCO:PRO:RC=1
      28715 !MCO:PRO:RC=1
      28716 !MCO:PRO:RC=1
      28716 !MCO:PRO:RC=1
      28716 !MCO:PRO:RC=1
      28716 !MCO:PRO:RC=1
      28716 !MCO:PRO:RC=1
      28716 !MCO:PRO:RC=1
      28716 !MCO:PRO:RC=1
      28716 !MCO:PRO:RC=1
      28716 !MCO:PRO:RC=1
      28716 !MCO:PRO:RC=1
      28716 !MCO:PRO:RC=1
      28717 !MCO:PRO:RC=1
      28717 !MCO:PRO:RC=1
      28717 !MCO:PRO:RC=1
      28717 !MCO:PRO:RC=1
      28717 !MCO:PRO:RC=1
      28717 !MCO:PRO:RC=1
      28717 !MCO:PRO:RC=1
      28717 !MCO:PRO:RC=1
      28717 !MCO:PRO:RC=1
      28717 !MCO:PRO:RC=1
      28717 !MCO:PRO:RC=1
      28717 !MCO:PRO:RC=1
      28718 !MCO:PRO:RC=1
      28718 !MCO:PRO:RC=1
      28718 !MCO:PRO:RC=1
      28718 !MCO:PRO:RC=1
      28718 !MCO:PRO:RC=1
      28718 !MCO:PRO:RC=1
      28718 !MCO:PRO:RC=1
      28718 !MCO:PRO:RC=1
      28718 !MCO:PRO:RC=1
      28718 !MCO:PRO:RC=1
      28718 !MCO:PRO:RC=1
      28718 !MCO:PRO:RC=1
      28719 !MCO:PRO:RC=1
      28719 !MCO:PRO:RC=1
      28719 !MCO:PRO:RC=1
      28719 !MCO:PRO:RC=1
      28719 !MCO:PRO:RC=1
      28719 !MCO:PRO:RC=1
      28719 !MCO:PRO:RC=1
      28719 !MCO:PRO:RC=1
      28719 !MCO:PRO:RC=1
      28719 !MCO:PRO:RC=1
      28719 !MCO:PRO:RC=1
      28719 !MCO:PRO:RC=1
      28720 !MCO:PRO:RC=1
      28720 !MCO:PRO:RC=1
      28720 !MCO:PRO:RC=1
      28720 !MCO:PRO:RC=1
      28720 !MCO:PRO:RC=1
      28720 !MCO:PRO:RC=1
      28720 !MCO:PRO:RC=1
      28720 !MCO:PRO:RC=1
      28720 !MCO:PRO:RC=1
      28720 !MCO:PRO:RC=1
      28720 !MCO:PRO:RC=1
      28720 !MCO:PRO:RC=1
      28721 !MCO:PRO:RC=1
      28721 !MCO:PRO:RC=1
      28721 !MCO:PRO:RC=1
      28721 !MCO:PRO:RC=1
      28721 !MCO:PRO:RC=1
      28721 !MCO:PRO:RC=1
      28721 !MCO:PRO:RC=1
      28721 !MCO:PRO:RC=1
      28721 !MCO:PRO:RC=1
      28721 !MCO:PRO:RC=1
      28721 !MCO:PRO:RC=1
      28721 !MCO:PRO:RC=1
      28722 SGN:SGN:NREQ=0
      30046 !TSF:MSG:SEND,10-10-0-0,s=11,c=1,t=47,pt=0,l=17,sg=0,ft=0,st=NACK:2021:8:18:10:7:32
      Resent Dateboot
      Time REQ 2
      Time Received in Setup
      Boot = 2021:8:18:10:7:34
      30046 SGN:SGN:NREQ=0
      31277 !TSF:MSG:SEND,10-10-0-0,s=11,c=1,t=47,pt=0,l=17,sg=0,ft=1,st=NACK:2021:8:18:10:7:34
      31377 SGN:SGN:NREQ=0
      31385 TSF:MSG:SEND,10-10-0-0,s=11,c=1,t=47,pt=0,l=17,sg=0,ft=2,st=OK:2021:8:18:10:7:34
      Resent Dateboot
      31386 MCO:BGN:INIT OK,TSP=1
      TEMP1 SP sent :14.00
      32177 TSF:MSG:READ,0-0-10,s=11,c=1,t=47,pt=0,l=17,sg=0:2021:8:18:10:7:34
      32177 SGN:SKP:ECHO CMD=1,TYPE=47
      32177 TSF:MSG:ECHO
      +Ack/Echo FMGW
      *InMsgty :47 MsgComd:1 childID:11 Data:S/2021:8:18:10:7:34 Data:I/ 2021 Data:B/ 1
      • N Offline
        N Offline
        Nigel31
        48Mhz Log
        1317 TSF:MSG:READ,0-0-10,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        1318 SGN:SKP:MSG CMD=3,TYPE=8
        1318 TSF:MSG:FPAR OK,ID=0,D=1
        2305 TSM:FPAR:OK
        2305 TSM:ID
        2305 TSM:ID:OK
        2305 TSM:UPL
        2305 SGN:SGN:NREQ=0
        5661 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
        6869 TSF:MSG:READ,0-0-10,s=255,c=3,t=25,pt=1,l=1,sg=0:1
        6869 SGN:SKP:MSG CMD=3,TYPE=25
        6869 TSF:MSG:PONG RECV,HP=1
        6869 TSM:UPL:OK
        6869 TSM:READY:ID=10,PAR=0,DIS=1
        6869 SGN:PRE:SGN REQ
        6869 SGN:PRE:WHI NREQ
        6869 SGN:SGN:NREQ=0
        6875 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
        6876 SGN:PRE:XMT,TO=0
        6876 SGN:PRE:WAIT GW
        8084 TSF:MSG:READ,0-0-10,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        8085 SGN:SKP:MSG CMD=3,TYPE=15
        8085 SGN:SGN:NREQ=0
        9091 TSF:MSG:SEND,10-10-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.2
        9091 SGN:SGN:NREQ=0
        9670 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
        10477 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
        10477 SGN:SKP:MSG CMD=3,TYPE=16
        10478 SGN:SGN:NREQ=0
        14347 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
        14348 SGN:NCE:XMT,TO=10
        14348 SGN:SGN:NREQ=0
        16669 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=0,st=OK:LivingRm Thermostat
        16669 SGN:SGN:NREQ=0
        17675 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=12,pt=0,l=6,sg=0,ft=0,st=OK:1.1.12
        17676 SGN:SGN:NREQ=0
        18684 TSF:MSG:SEND,10-10-0-0,s=0,c=0,t=6,pt=0,l=16,sg=0,ft=0,st=OK:Room Temperature
        18784 SGN:SGN:NREQ=0
        19997 TSF:MSG:SEND,10-10-0-0,s=5,c=0,t=33,pt=0,l=18,sg=0,ft=0,st=OK:Thermostat RX RSSI
        20098 SGN:SGN:NREQ=0
        21311 TSF:MSG:SEND,10-10-0-0,s=2,c=0,t=3,pt=0,l=16,sg=0,ft=0,st=OK:Thermostat Relay
        21411 SGN:SGN:NREQ=0
        22951 !TSF:MSG:SEND,10-10-0-0,s=3,c=0,t=3,pt=0,l=13,sg=0,ft=0,st=NACK:Heat Override
        23051 SGN:SGN:NREQ=0
        24058 TSF:MSG:SEND,10-10-0-0,s=7,c=0,t=6,pt=0,l=11,sg=0,ft=1,st=OK:Who is Home
        24158 SGN:SGN:NREQ=0
        26371 TSF:MSG:SEND,10-10-0-0,s=1,c=0,t=14,pt=0,l=13,sg=0,ft=0,st=OK:Temp Setpoint
        26471 SGN:SGN:NREQ=0
        27993 TSF:MSG:SEND,10-10-0-0,s=6,c=0,t=4,pt=0,l=11,sg=0,ft=0,st=OK:Oil Tank PC
        28093 SGN:SGN:NREQ=0
        30157 TSF:MSG:SEND,10-10-0-0,s=12,c=0,t=36,pt=0,l=12,sg=0,ft=0,st=OK:Display Text
        30258 SGN:SGN:NREQ=0
        32593 !TSF:MSG:SEND,10-10-0-0,s=8,c=0,t=3,pt=0,l=14,sg=0,ft=0,st=NACK:SP Update Flag
        32678 !SGN:BND:TMR
        32881 TSF:MSG:READ,0-0-10,s=8,c=0,t=3,pt=0,l=14,sg=0:SP Update Flag
        32881 SGN:SKP:ECHO CMD=0,TYPE=3
        32881 TSF:MSG:ECHO
        +Ack/Echo FMGW
        32882 SGN:SGN:NREQ=0
        35095 TSF:MSG:SEND,10-10-0-0,s=9,c=0,t=3,pt=0,l=13,sg=0,ft=1,st=OK:HotWater Flag
        35195 SGN:SGN:NREQ=0
        37410 TSF:MSG:SEND,10-10-0-0,s=10,c=0,t=36,pt=0,l=21,sg=0,ft=0,st=OK:Returned Display Text
        37510 SGN:SGN:NREQ=0
        39721 TSF:MSG:SEND,10-10-0-0,s=11,c=0,t=36,pt=0,l=8,sg=0,ft=0,st=OK:BootTime
        39821 MCO:REG:REQ
        39821 SGN:SGN:NREQ=0
        39827 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
        41042 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
        41042 SGN:SKP:MSG CMD=3,TYPE=16
        41042 SGN:SGN:NREQ=0
        42840 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
        42841 SGN:NCE:XMT,TO=10
        42841 SGN:SGN:NREQ=0
        43847 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
        45062 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
        45062 SGN:SKP:MSG CMD=3,TYPE=16
        45062 SGN:SGN:NREQ=0
        47526 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
        47527 SGN:NCE:XMT,TO=10
        47527 SGN:SGN:NREQ=0
        48533 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
        49747 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
        49747 SGN:SKP:MSG CMD=3,TYPE=16
        49747 SGN:SGN:NREQ=0
        49898 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
        49898 SGN:NCE:XMT,TO=10
        50986 TSF:MSG:READ,0-0-10,s=255,c=3,t=27,pt=1,l=1,sg=1:1
        50987 SGN:BND:NONCE=C13859714FA31337A133BAB1F5CD132246438213AC9B278A5AAAAAAAAAAAAAAA
        50988 SGN:BND:HMAC=F01FDEF38DB44960D2D22E4E38A141D08432DB6DE34268815F1E29133D451B6D
        50988 SGN:VER:OK
        50988 MCO:PIM:NODE REG=1
        50988 MCO:BGN:STP
        Loaded values
         :Relay output : 1
        51035 SGN:SGN:NREQ=0
        51041 TSF:MSG:SEND,10-10-0-0,s=7,c=1,t=45,pt=7,l=5,sg=0,ft=0,st=OK:0.0
        51042 SGN:SGN:NREQ=0
        51445 TSF:MSG:SEND,10-10-0-0,s=2,c=2,t=2,pt=0,l=0,sg=0,ft=0,st=OK:
        uplink available
        52092 TSF:MSG:READ,0-0-10,s=2,c=3,t=16,pt=0,l=0,sg=1:
        52092 SGN:SKP:MSG CMD=3,TYPE=16
        52092 SGN:SGN:NREQ=0
        53101 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
        53102 SGN:NCE:XMT,TO=10
        53102 SGN:SGN:NREQ=0
        54108 TSF:MSG:SEND,10-10-0-0,s=2,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
        54108 SGN:SGN:NREQ=0
        55115 TSF:MSG:SEND,10-10-0-0,s=12,c=1,t=47,pt=0,l=8,sg=0,ft=0,st=OK:Boot ...
        REQ DISPLAYTXT
        55115 SGN:SGN:NREQ=0
        57323 TSF:MSG:SEND,10-10-0-0,s=12,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
        Req PC
        57324 SGN:SGN:NREQ=0
        59532 TSF:MSG:SEND,10-10-0-0,s=6,c=2,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
        Req SP
        59533 SGN:SGN:NREQ=0
        60945 TSF:MSG:SEND,10-10-0-0,s=1,c=2,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
        display init
        WD Enabled
        60996 SGN:SGN:NREQ=0
        63407 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
        63413 SGN:SGN:NREQ=0
        63419 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
        63453 !SGN:BND:TMR
        64020 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
        64021 SGN:SKP:MSG CMD=3,TYPE=16
        64021 SGN:SGN:NREQ=0
        66060 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
        66061 SGN:NCE:XMT,TO=10
        Time REQ 1
        66061 SGN:SGN:NREQ=0
        67066 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
        68098 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
        68099 SGN:SKP:MSG CMD=3,TYPE=16
        68099 SGN:SGN:NREQ=0
        69956 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
        69957 SGN:NCE:XMT,TO=10
        Time REQ 2
        69957 SGN:SGN:NREQ=0
        73296 !TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=NACK:
        Time REQ 3
        75296 SGN:SGN:NREQ=0
        76853 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=1,st=OK:
        76870 !SGN:BND:TMR
        77871 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
        77872 SGN:SKP:MSG CMD=3,TYPE=16
        77872 SGN:SGN:NREQ=0
        80120 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
        80121 SGN:NCE:XMT,TO=10
        Time REQ 4
        80121 SGN:SGN:NREQ=0
        81810 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
        82828 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
        82828 SGN:SKP:MSG CMD=3,TYPE=16
        82828 SGN:SGN:NREQ=0
        83837 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
        83838 SGN:NCE:XMT,TO=10
        Time REQ 5
        Timedout
        83838 MCO:BGN:INIT OK,TSP=1
        84628 TSF:MSG:READ,0-0-10,s=255,c=3,t=1,pt=0,l=10,sg=1:1629281049
        84629 SGN:BND:NONCE=15658CB551D0856E0D3D26A68781A1AAA1D936FC5D7D7FF61DAAAAAAAAAAAAAA
        84630 SGN:BND:HMAC=B47AA377E18CFCB9727224D78769289C4CAADC0D13EBEF44E8C5A371F9303002
        84630 SGN:VER:OK
        Time value received: Time value valid: 1629281049
        10 4 9 18 8 2021
        Boot = 2021:8:18:10:4:9
        84630 SGN:SGN:NREQ=0
        84639 TSF:MSG:SEND,10-10-0-0,s=11,c=1,t=47,pt=0,l=16,sg=0,ft=0,st=OK:2021:8:18:10:4:9
        84639 !MCO:WAI:RC=1
        • N Offline
          N Offline
          Nigel31
          more of the 48Mhz log
          84639 !MCO:PRO:RC=1
          84639 !MCO:PRO:RC=1
          84639 !MCO:PRO:RC=1
          84639 !MCO:PRO:RC=1
          84639 !MCO:PRO:RC=1
          84639 !MCO:PRO:RC=1
          84639 !MCO:PRO:RC=1
          84639 !MCO:PRO:RC=1
          84640 !MCO:PRO:RC=1
          84640 !MCO:PRO:RC=1
          84640 !MCO:PRO:RC=1
          84640 !MCO:PRO:RC=1
          84640 !MCO:PRO:RC=1
          84640 !MCO:PRO:RC=1
          84640 !MCO:PRO:RC=1
          84640 !MCO:PRO:RC=1
          84640 !MCO:PRO:RC=1
          84640 !MCO:PRO:RC=1
          84640 !MCO:PRO:RC=1
          84640 !MCO:PRO:RC=1
          84640 !MCO:PRO:RC=1
          84640 !MCO:PRO:RC=1
          84640 !MCO:PRO:RC=1
          84640 !MCO:PRO:RC=1
          84640 !MCO:PRO:RC=1
          84641 !MCO:PRO:RC=1
          84641 !MCO:PRO:RC=1
          84641 !MCO:PRO:RC=1
          84641 !MCO:PRO:RC=1
          84641 !MCO:PRO:RC=1
          84641 !MCO:PRO:RC=1
          84641 !MCO:PRO:RC=1
          84641 !MCO:PRO:RC=1
          84641 !MCO:PRO:RC=1
          84641 !MCO:PRO:RC=1
          84641 !MCO:PRO:RC=1
          84641 !MCO:PRO:RC=1
          84642 !MCO:PRO:RC=1
          84642 !MCO:PRO:RC=1
          84642 !MCO:PRO:RC=1
          84642 !MCO:PRO:RC=1
          84642 !MCO:PRO:RC=1
          84642 !MCO:PRO:RC=1
          84642 !MCO:PRO:RC=1
          84642 !MCO:PRO:RC=1
          84642 !MCO:PRO:RC=1
          84642 !MCO:PRO:RC=1
          84642 !MCO:PRO:RC=1
          84642 !MCO:PRO:RC=1
          84642 !MCO:PRO:RC=1
          84643 !MCO:PRO:RC=1
          84643 !MCO:PRO:RC=1
          84643 !MCO:PRO:RC=1
          84643 !MCO:PRO:RC=1
          84643 !MCO:PRO:RC=1
          84643 !MCO:PRO:RC=1
          84643 !MCO:PRO:RC=1
          84643 !MCO:PRO:RC=1
          84643 !MCO:PRO:RC=1
          84643 !MCO:PRO:RC=1
          84643 !MCO:PRO:RC=1
          84644 !MCO:PRO:RC=1
          84644 !MCO:PRO:RC=1
          84644 !MCO:PRO:RC=1
          84644 !MCO:PRO:RC=1
          84644 !MCO:PRO:RC=1
          84644 !MCO:PRO:RC=1
          84644 !MCO:PRO:RC=1
          84644 !MCO:PRO:RC=1
          84644 !MCO:PRO:RC=1
          84644 !MCO:PRO:RC=1
          84644 !MCO:PRO:RC=1
          84644 !MCO:PRO:RC=1
          84644 !MCO:PRO:RC=1
          84645 !MCO:PRO:RC=1
          84645 !MCO:PRO:RC=1
          84645 !MCO:PRO:RC=1
          84645 !MCO:PRO:RC=1
          84645 !MCO:PRO:RC=1
          84645 !MCO:PRO:RC=1
          84645 !MCO:PRO:RC=1
          84645 !MCO:PRO:RC=1
          84645 !MCO:PRO:RC=1
          84645 !MCO:PRO:RC=1
          84645 !MCO:PRO:RC=1
          84645 !MCO:PRO:RC=1
          84645 !MCO:PRO:RC=1
          84645 !MCO:PRO:RC=1
          84645 !MCO:PRO:RC=1
          84646 !MCO:PRO:RC=1
          84646 !MCO:PRO:RC=1
          84646 !MCO:PRO:RC=1
          84646 !MCO:PRO:RC=1
          84646 !MCO:PRO:RC=1
          84646 !MCO:PRO:RC=1
          84646 !MCO:PRO:RC=1
          84646 !MCO:PRO:RC=1
          84646 !MCO:PRO:RC=1
          84646 !MCO:PRO:RC=1
          84646 !MCO:PRO:RC=1
          84646 !MCO:PRO:RC=1
          84646 !MCO:PRO:RC=1
          84646 !MCO:PRO:RC=1
          84647 !MCO:PRO:RC=1
          84647 !MCO:PRO:RC=1
          84647 !MCO:PRO:RC=1
          84647 !MCO:PRO:RC=1
          84647 !MCO:PRO:RC=1
          84647 !MCO:PRO:RC=1
          84647 !MCO:PRO:RC=1
          84647 !MCO:PRO:RC=1
          84647 !MCO:PRO:RC=1
          84647 !MCO:PRO:RC=1
          84647 !MCO:PRO:RC=1
          84647 !MCO:PRO:RC=1
          84647 !MCO:PRO:RC=1
          84648 !MCO:PRO:RC=1
          84648 !MCO:PRO:RC=1
          84648 !MCO:PRO:RC=1
          84648 !MCO:PRO:RC=1
          84648 !MCO:PRO:RC=1
          84648 !MCO:PRO:RC=1
          84648 !MCO:PRO:RC=1
          84648 !MCO:PRO:RC=1
          84648 !MCO:PRO:RC=1
          84648 !MCO:PRO:RC=1
          84648 !MCO:PRO:RC=1
          84648 !MCO:PRO:RC=1
          84648 !MCO:PRO:RC=1
          84649 !MCO:PRO:RC=1
          84649 !MCO:PRO:RC=1
          84649 !MCO:PRO:RC=1
          84649 !MCO:PRO:RC=1
          84649 !MCO:PRO:RC=1
          84649 !MCO:PRO:RC=1
          84649 !MCO:PRO:RC=1
          84649 !MCO:PRO:RC=1
          84649 !MCO:PRO:RC=1
          84649 !MCO:PRO:RC=1
          84649 !MCO:PRO:RC=1
          84649 !MCO:PRO:RC=1
          84649 !MCO:PRO:RC=1
          84650 !MCO:PRO:RC=1
          84650 !MCO:PRO:RC=1
          84650 !MCO:PRO:RC=1
          84650 !MCO:PRO:RC=1
          84650 !MCO:PRO:RC=1
          84650 !MCO:PRO:RC=1
          84650 !MCO:PRO:RC=1
          84650 !MCO:PRO:RC=1
          84650 !MCO:PRO:RC=1
          84650 !MCO:PRO:RC=1
          84650 !MCO:PRO:RC=1
          84650 !MCO:PRO:RC=1
          84650 !MCO:PRO:RC=1
          84651 !MCO:PRO:RC=1
          84651 !MCO:PRO:RC=1
          84651 !MCO:PRO:RC=1
          84651 !MCO:PRO:RC=1
          84651 !MCO:PRO:RC=1
          84651 !MCO:PRO:RC=1
          84651 !MCO:PRO:RC=1
          84651 !MCO:PRO:RC=1
          84651 !MCO:PRO:RC=1
          84651 !MCO:PRO:RC=1
          84651 !MCO:PRO:RC=1
          84651 !MCO:PRO:RC=1
          84651 !MCO:PRO:RC=1
          84652 !MCO:PRO:RC=1
          84652 !MCO:PRO:RC=1
          84652 !MCO:PRO:RC=1
          84652 !MCO:PRO:RC=1
          84652 !MCO:PRO:RC=1
          84652 !MCO:PRO:RC=1
          84652 !MCO:PRO:RC=1
          84652 !MCO:PRO:RC=1
          84652 !MCO:PRO:RC=1
          84652 !MCO:PRO:RC=1
          84652 !MCO:PRO:RC=1
          84652 !MCO:PRO:RC=1
          84652 !MCO:PRO:RC=1
          84653 !MCO:PRO:RC=1
          84653 !MCO:PRO:RC=1
          84653 !MCO:PRO:RC=1
          84653 !MCO:PRO:RC=1
          84653 !MCO:PRO:RC=1
          84653 !MCO:PRO:RC=1
          84653 !MCO:PRO:RC=1
          84653 !MCO:PRO:RC=1
          84653 !MCO:PRO:RC=1
          84653 !MCO:PRO:RC=1
          84653 !MCO:PRO:RC=1
          84653 !MCO:PRO:RC=1
          84653 !MCO:PRO:RC=1
          84654 !MCO:PRO:RC=1
          84654 !MCO:PRO:RC=1
          84654 !MCO:PRO:RC=1
          84654 !MCO:PRO:RC=1
          84654 !MCO:PRO:RC=1
          84654 !MCO:PRO:RC=1
          84654 !MCO:PRO:RC=1
          84654 !MCO:PRO:RC=1
          84654 !MCO:PRO:RC=1
          84654 !MCO:PRO:RC=1
          84654 !MCO:PRO:RC=1
          84654 !MCO:PRO:RC=1
          84654 !MCO:PRO:RC=1
          84654 !MCO:PRO:RC=1
          84655 !MCO:PRO:RC=1
          84655 !MCO:PRO:RC=1
          84655 !MCO:PRO:RC=1
          84655 !MCO:PRO:RC=1
          84655 !MCO:PRO:RC=1
          84655 !MCO:PRO:RC=1
          84655 !MCO:PRO:RC=1
          84655 !MCO:PRO:RC=1
          84655 !MCO:PRO:RC=1
          84655 !MCO:PRO:RC=1
          84655 !MCO:PRO:RC=1
          84655 !MCO:PRO:RC=1
          84656 !MCO:PRO:RC=1
          84656 !MCO:PRO:RC=1
          84656 !MCO:PRO:RC=1
          84656 !MCO:PRO:RC=1
          84656 !MCO:PRO:RC=1
          84656 !MCO:PRO:RC=1
          84656 !MCO:PRO:RC=1
          84656 !MCO:PRO:RC=1
          84656 !MCO:PRO:RC=1
          84656 !MCO:PRO:RC=1
          84656 !MCO:PRO:RC=1
          84656 !MCO:PRO:RC=1
          84657 !MCO:PRO:RC=1
          84657 !MCO:PRO:RC=1
          84657 !MCO:PRO:RC=1
          84657 !MCO:PRO:RC=1
          84657 !MCO:PRO:RC=1
          84657 !MCO:PRO:RC=1
          84657 !MCO:PRO:RC=1
          84657 !MCO:PRO:RC=1
          84657 !MCO:PRO:RC=1
          84657 !MCO:PRO:RC=1
          84657 !MCO:PRO:RC=1
          84657 !MCO:PRO:RC=1
          84658 !MCO:PRO:RC=1
          84658 !MCO:PRO:RC=1
          84658 !MCO:PRO:RC=1
          84658 !MCO:PRO:RC=1
          84658 !MCO:PRO:RC=1
          84658 !MCO:PRO:RC=1
          84658 !MCO:PRO:RC=1
          84658 !MCO:PRO:RC=1
          84658 !MCO:PRO:RC=1
          84658 !MCO:PRO:RC=1
          84658 !MCO:PRO:RC=1
          84658 !MCO:PRO:RC=1
          84658 !MCO:PRO:RC=1
          84658 !MCO:PRO:RC=1
          84659 !MCO:PRO:RC=1
          84659 !MCO:PRO:RC=1
          84659 !MCO:PRO:RC=1
          84659 !MCO:PRO:RC=1
          84659 !MCO:PRO:RC=1
          84659 !MCO:PRO:RC=1
          84659 !MCO:PRO:RC=1
          84659 !MCO:PRO:RC=1
          84659 !MCO:PRO:RC=1
          84659 !MCO:PRO:RC=1
          84659 !MCO:PRO:RC=1
          84659 !MCO:PRO:RC=1
          84659 !MCO:PRO:RC=1
          84659 !MCO:PRO:RC=1
          84660 !MCO:PRO:RC=1
          84660 !MCO:PRO:RC=1
          84660 !MCO:PRO:RC=1
          84660 !MCO:PRO:RC=1
          84660 !MCO:PRO:RC=1
          84660 !MCO:PRO:RC=1
          84660 !MCO:PRO:RC=1
          84660 !MCO:PRO:RC=1
          84660 !MCO:PRO:RC=1
          84660 !MCO:PRO:RC=1
          84660 !MCO:PRO:RC=1
          84660 !MCO:PRO:RC=1
          84660 !MCO:PRO:RC=1
          84661 !MCO:PRO:RC=1
          84661 !MCO:PRO:RC=1
          84661 !MCO:PRO:RC=1
          84661 !MCO:PRO:RC=1
          84661 !MCO:PRO:RC=1
          84661 !MCO:PRO:RC=1
          84661 !MCO:PRO:RC=1
          84661 !MCO:PRO:RC=1
          84661 !MCO:PRO:RC=1
          84661 !MCO:PRO:RC=1
          84661 !MCO:PRO:RC=1
          84661 !MCO:PRO:RC=1
          84661 !MCO:PRO:RC=1
          84661 !MCO:PRO:RC=1
          84662 !MCO:PRO:RC=1
          84662 !MCO:PRO:RC=1
          84662 !MCO:PRO:RC=1
          84662 !MCO:PRO:RC=1
          84662 !MCO:PRO:RC=1
          84662 !MCO:PRO:RC=1
          84662 !MCO:PRO:RC=1
          84662 !MCO:PRO:RC=1
          84662 !MCO:PRO:RC=1
          84662 !MCO:PRO:RC=1
          84662 !MCO:PRO:RC=1
          84662 !MCO:PRO:RC=1
          84662 !MCO:PRO:RC=1
          84663 !MCO:PRO:RC=1
          84663 !MCO:PRO:RC=1
          84663 !MCO:PRO:RC=1
          84663 !MCO:PRO:RC=1
          84663 !MCO:PRO:RC=1
          84663 !MCO:PRO:RC=1
          84663 !MCO:PRO:RC=1
          84663 !MCO:PRO:RC=1
          84663 !MCO:PRO:RC=1
          84663 !MCO:PRO:RC=1
          84663 !MCO:PRO:RC=1
          84663 !MCO:PRO:RC=1
          84663 !MCO:PRO:RC=1
          84663 !MCO:PRO:RC=1
          84664 !MCO:PRO:RC=1
          84664 !MCO:PRO:RC=1
          84664 !MCO:PRO:RC=1
          84664 !MCO:PRO:RC=1
          84664 !MCO:PRO:RC=1
          84664 !MCO:PRO:RC=1
          84664 !MCO:PRO:RC=1
          84664 !MCO:PRO:RC=1
          84664 !MCO:PRO:RC=1
          84664 !MCO:PRO:RC=1
          84664 !MCO:PRO:RC=1
          84664 !MCO:PRO:RC=1
          84664 !MCO:PRO:RC=1
          84664 !MCO:PRO:RC=1
          84665 !MCO:PRO:RC=1
          84665 !MCO:PRO:RC=1
          84665 !MCO:PRO:RC=1
          84665 !MCO:PRO:RC=1
          84665 !MCO:PRO:RC=1
          84665 !MCO:PRO:RC=1
          84665 !MCO:PRO:RC=1
          84665 !MCO:PRO:RC=1
          84665 !MCO:PRO:RC=1
          84665 !MCO:PRO:RC=1
          84665 !MCO:PRO:RC=1
          84665 !MCO:PRO:RC=1
          84665 !MCO:PRO:RC=1
          84666 !MCO:PRO:RC=1
          84666 !MCO:PRO:RC=1
          84666 !MCO:PRO:RC=1
          84666 !MCO:PRO:RC=1
          84666 !MCO:PRO:RC=1
          84666 !MCO:PRO:RC=1
          84666 !MCO:PRO:RC=1
          84666 !MCO:PRO:RC=1
          84666 !MCO:PRO:RC=1
          84666 !MCO:PRO:RC=1
          84666 !MCO:PRO:RC=1
          84666 !MCO:PRO:RC=1
          84666 !MCO:PRO:RC=1
          84666 !MCO:PRO:RC=1
          84667 !MCO:PRO:RC=1
          84667 !MCO:PRO:RC=1
          84667 !MCO:PRO:RC=1
          84667 !MCO:PRO:RC=1
          84667 !MCO:PRO:RC=1
          84667 !MCO:PRO:RC=1
          84667 !MCO:PRO:RC=1
          84667 !MCO:PRO:RC=1
          84667 !MCO:PRO:RC=1
          84667 !MCO:PRO:RC=1
          84667 !MCO:PRO:RC=1
          84668 !MCO:PRO:RC=1
          84668 !MCO:PRO:RC=1
          84668 !MCO:PRO:RC=1
          84668 !MCO:PRO:RC=1
          84668 !MCO:PRO:RC=1
          84668 !MCO:PRO:RC=1
          84668 !MCO:PRO:RC=1
          84668 !MCO:PRO:RC=1
          84668 !MCO:PRO:RC=1
          84668 !MCO:PRO:RC=1
          84668 !MCO:PRO:RC=1
          84668 !MCO:PRO:RC=1
          84669 !MCO:PRO:RC=1
          84669 !MCO:PRO:RC=1
          84669 !MCO:PRO:RC=1
          84669 !MCO:PRO:RC=1
          84669 !MCO:PRO:RC=1
          84669 !MCO:PRO:RC=1
          84669 !MCO:PRO:RC=1
          84669 !MCO:PRO:RC=1
          84669 !MCO:PRO:RC=1
          84669 !MCO:PRO:RC=1
          84669 !MCO:PRO:RC=1
          84669 !MCO:PRO:RC=1
          84669 !MCO:PRO:RC=1
          84670 !MCO:PRO:RC=1
          84670 !MCO:PRO:RC=1
          84670 !MCO:PRO:RC=1
          84670 !MCO:PRO:RC=1
          84670 !MCO:PRO:RC=1
          84670 !MCO:PRO:RC=1
          84670 !MCO:PRO:RC=1
          84670 !MCO:PRO:RC=1
          84670 !MCO:PRO:RC=1
          84670 !MCO:PRO:RC=1
          84670 !MCO:PRO:RC=1
          84670 !MCO:PRO:RC=1
          84670 !MCO:PRO:RC=1
          84670 !MCO:PRO:RC=1
          84671 !MCO:PRO:RC=1
          84671 !MCO:PRO:RC=1
          84671 !MCO:PRO:RC=1
          84671 !MCO:PRO:RC=1
          84671 !MCO:PRO:RC=1
          84671 !MCO:PRO:RC=1
          84671 !MCO:PRO:RC=1
          84671 !MCO:PRO:RC=1
          84671 !MCO:PRO:RC=1
          84671 !MCO:PRO:RC=1
          84671 !MCO:PRO:RC=1
          84671 !MCO:PRO:RC=1
          84672 !MCO:PRO:RC=1
          84672 !MCO:PRO:RC=1
          84672 !MCO:PRO:RC=1
          84672 !MCO:PRO:RC=1
          84672 !MCO:PRO:RC=1
          84672 !MCO:PRO:RC=1
          84672 !MCO:PRO:RC=1
          84672 !MCO:PRO:RC=1
          84672 !MCO:PRO:RC=1
          84672 !MCO:PRO:RC=1
          84672 !MCO:PRO:RC=1
          84672 !MCO:PRO:RC=1
          84673 !MCO:PRO:RC=1
          84673 !MCO:PRO:RC=1
          84673 !MCO:PRO:RC=1
          84673 !MCO:PRO:RC=1
          84673 !MCO:PRO:RC=1
          84673 !MCO:PRO:RC=1
          84673 !MCO:PRO:RC=1
          84673 !MCO:PRO:RC=1
          84673 !MCO:PRO:RC=1
          84673 !MCO:PRO:RC=1
          84673 !MCO:PRO:RC=1
          84673 !MCO:PRO:RC=1
          84674 !MCO:PRO:RC=1
          84674 !MCO:PRO:RC=1
          84674 !MCO:PRO:RC=1
          84674 !MCO:PRO:RC=1
          84674 !MCO:PRO:RC=1
          84674 !MCO:PRO:RC=1
          84674 !MCO:PRO:RC=1
          84674 !MCO:PRO:RC=1
          84674 !MCO:PRO:RC=1
          84674 !MCO:PRO:RC=1
          84674 !MCO:PRO:RC=1
          84675 !MCO:PRO:RC=1
          84675 !MCO:PRO:RC=1
          84675 !MCO:PRO:RC=1
          84675 !MCO:PRO:RC=1
          84675 !MCO:PRO:RC=1
          84675 !MCO:PRO:RC=1
          84675 !MCO:PRO:RC=1
          84675 !MCO:PRO:RC=1
          84675 !MCO:PRO:RC=1
          84675 !MCO:PRO:RC=1
          84675 !MCO:PRO:RC=1
          84675 !MCO:PRO:RC=1
          84675 !MCO:PRO:RC=1
          84676 !MCO:PRO:RC=1
          84676 !MCO:PRO:RC=1
          84676 !MCO:PRO:RC=1
          84676 !MCO:PRO:RC=1
          84676 !MCO:PRO:RC=1
          84676 !MCO:PRO:RC=1
          84676 !MCO:PRO:RC=1
          84676 !MCO:PRO:RC=1
          84676 !MCO:PRO:RC=1
          84676 !MCO:PRO:RC=1
          84676 !MCO:PRO:RC=1
          84676 !MCO:PRO:RC=1
          84676 !MCO:PRO:RC=1
          84677 !MCO:PRO:RC=1
          84677 !MCO:PRO:RC=1
          84677 !MCO:PRO:RC=1
          84677 !MCO:PRO:RC=1
          84677 !MCO:PRO:RC=1
          84677 !MCO:PRO:RC=1
          84677 !MCO:PRO:RC=1
          84677 !MCO:PRO:RC=1
          84677 !MCO:PRO:RC=1
          84677 !MCO:PRO:RC=1
          84677 !MCO:PRO:RC=1
          84677 !MCO:PRO:RC=1
          84677 !MCO:PRO:RC=1
          84678 !MCO:PRO:RC=1
          84678 !MCO:PRO:RC=1
          84678 !MCO:PRO:RC=1
          84678 !MCO:PRO:RC=1
          84678 !MCO:PRO:RC=1
          84678 !MCO:PRO:RC=1
          84678 !MCO:PRO:RC=1
          84678 !MCO:PRO:RC=1
          84678 !MCO:PRO:RC=1
          84678 !MCO:PRO:RC=1
          84678 !MCO:PRO:RC=1
          84678 !MCO:PRO:RC=1
          84678 !MCO:PRO:RC=1
          84679 !MCO:PRO:RC=1
          84679 !MCO:PRO:RC=1
          84679 !MCO:PRO:RC=1
          84679 !MCO:PRO:RC=1
          84679 !MCO:PRO:RC=1
          84679 !MCO:PRO:RC=1
          84679 !MCO:PRO:RC=1
          84679 !MCO:PRO:RC=1
          84679 !MCO:PRO:RC=1
          84679 !MCO:PRO:RC=1
          84679 !MCO:PRO:RC=1
          84679 !MCO:PRO:RC=1
          84679 !MCO:PRO:RC=1
          84680 !MCO:PRO:RC=1
          84680 !MCO:PRO:RC=1
          84680 !MCO:PRO:RC=1
          84680 !MCO:PRO:RC=1
          84680 !MCO:PRO:RC=1
          84680 !MCO:PRO:RC=1
          84680 !MCO:PRO:RC=1
          84680 !MCO:PRO:RC=1
          84680 !MCO:PRO:RC=1
          84680 !MCO:PRO:RC=1
          84680 !MCO:PRO:RC=1
          84680 !MCO:PRO:RC=1
          84680 !MCO:PRO:RC=1
          84681 !MCO:PRO:RC=1
          84681 !MCO:PRO:RC=1
          84681 !MCO:PRO:RC=1
          84681 !MCO:PRO:RC=1
          84681 !MCO:PRO:RC=1
          84681 !MCO:PRO:RC=1
          84681 !MCO:PRO:RC=1
          84681 !MCO:PRO:RC=1
          84681 !MCO:PRO:RC=1
          84681 !MCO:PRO:RC=1
          84681 !MCO:PRO:RC=1
          84681 !MCO:PRO:RC=1
          84681 !MCO:PRO:RC=1
          84682 !MCO:PRO:RC=1
          84682 !MCO:PRO:RC=1
          84682 !MCO:PRO:RC=1
          84682 !MCO:PRO:RC=1
          84682 !MCO:PRO:RC=1
          84682 !MCO:PRO:RC=1
          84682 !MCO:PRO:RC=1
          84682 !MCO:PRO:RC=1
          84682 !MCO:PRO:RC=1
          84682 !MCO:PRO:RC=1
          84682 !MCO:PRO:RC=1
          84682 !MCO:PRO:RC=1
          84682 !MCO:PRO:RC=1
          84683 !MCO:PRO:RC=1
          84683 !MCO:PRO:RC=1
          84683 !MCO:PRO:RC=1
          84683 !MCO:PRO:RC=1
          84683 !MCO:PRO:RC=1
          84683 !MCO:PRO:RC=1
          84683 !MCO:PRO:RC=1
          84683 !MCO:PRO:RC=1
          84683 !MCO:PRO:RC=1
          84683 !MCO:PRO:RC=1
          84683 !MCO:PRO:RC=1
          84683 !MCO:PRO:RC=1
          84683 !MCO:PRO:RC=1
          84684 !MCO:PRO:RC=1
          84684 !MCO:PRO:RC=1
          84684 !MCO:PRO:RC=1
          84684 !MCO:PRO:RC=1
          84684 !MCO:PRO:RC=1
          84684 !MCO:PRO:RC=1
          84684 !MCO:PRO:RC=1
          84684 !MCO:PRO:RC=1
          84684 !MCO:PRO:RC=1
          84684 !MCO:PRO:RC=1
          84684 !MCO:PRO:RC=1
          84684 !MCO:PRO:RC=1
          84684 !MCO:PRO:RC=1
          84685 !MCO:PRO:RC=1
          84685 !MCO:PRO:RC=1
          84685 !MCO:PRO:RC=1
          84685 !MCO:PRO:RC=1
          84685 !MCO:PRO:RC=1
          84685 !MCO:PRO:RC=1
          84685 !MCO:PRO:RC=1
          84685 !MCO:PRO:RC=1
          84685 !MCO:PRO:RC=1
          84685 !MCO:PRO:RC=1
          84685 !MCO:PRO:RC=1
          84685 !MCO:PRO:RC=1
          84685 !MCO:PRO:RC=1
          84685 !MCO:PRO:RC=1
          84685 !MCO:PRO:RC=1
          84686 !MCO:PRO:RC=1
          84686 !MCO:PRO:RC=1
          84686 !MCO:PRO:RC=1
          84686 !MCO:PRO:RC=1
          84686 !MCO:PRO:RC=1
          84686 !MCO:PRO:RC=1
          84686 !MCO:PRO:RC=1
          84686 !MCO:PRO:RC=1
          84686 !MCO:PRO:RC=1
          84686 !MCO:PRO:RC=1
          84686 !MCO:PRO:RC=1
          84686 !MCO:PRO:RC=1
          84686 !MCO:PRO:RC=1
          84686 !MCO:PRO:RC=1
          84686 !MCO:PRO:RC=1
          84687 !MCO:PRO:RC=1
          84687 !MCO:PRO:RC=1
          84687 !MCO:PRO:RC=1
          84687 !MCO:PRO:RC=1
          84687 !MCO:PRO:RC=1
          84687 !MCO:PRO:RC=1
          84687 !MCO:PRO:RC=1
          84687 !MCO:PRO:RC=1
          84687 !MCO:PRO:RC=1
          84687 !MCO:PRO:RC=1
          84687 !MCO:PRO:RC=1
          84687 !MCO:PRO:RC=1
          84687 !MCO:PRO:RC=1
          84688 !MCO:PRO:RC=1
          84688 !MCO:PRO:RC=1
          84688 !MCO:PRO:RC=1
          84688 !MCO:PRO:RC=1
          84688 !MCO:PRO:RC=1
          84688 !MCO:PRO:RC=1
          84688 !MCO:PRO:RC=1
          84688 !MCO:PRO:RC=1
          84688 !MCO:PRO:RC=1
          84688 !MCO:PRO:RC=1
          84688 !MCO:PRO:RC=1
          84688 !MCO:PRO:RC=1
          84688 !MCO:PRO:RC=1
          84689 !MCO:PRO:RC=1
          84689 !MCO:PRO:RC=1
          84689 !MCO:PRO:RC=1
          84689 !MCO:PRO:RC=1
          84689 !MCO:PRO:RC=1
          84689 !MCO:PRO:RC=1
          84689 !MCO:PRO:RC=1
          84689 !MCO:PRO:RC=1
          84689 !MCO:PRO:RC=1
          84689 !MCO:PRO:RC=1
          84689 !MCO:PRO:RC=1
          84689 !MCO:PRO:RC=1
          84690 !MCO:PRO:RC=1
          84690 !MCO:PRO:RC=1
          84690 !MCO:PRO:RC=1
          84690 !MCO:PRO:RC=1
          84690 !MCO:PRO:RC=1
          84690 !MCO:PRO:RC=1
          84690 !MCO:PRO:RC=1
          84690 !MCO:PRO:RC=1
          84690 !MCO:PRO:RC=1
          84690 !MCO:PRO:RC=1
          84690 !MCO:PRO:RC=1
          84690 !MCO:PRO:RC=1
          84691 !MCO:PRO:RC=1
          84691 !MCO:PRO:RC=1
          84691 !MCO:PRO:RC=1
          84691 !MCO:PRO:RC=1
          84691 !MCO:PRO:RC=1
          84691 !MCO:PRO:RC=1
          84691 !MCO:PRO:RC=1
          84691 !MCO:PRO:RC=1
          84691 !MCO:PRO:RC=1
          84691 !MCO:PRO:RC=1
          84691 !MCO:PRO:RC=1
          84691 !MCO:PRO:RC=1
          84691 !MCO:PRO:RC=1
          84691 !MCO:PRO:RC=1
          84692 !MCO:PRO:RC=1
          84692 !MCO:PRO:RC=1
          84692 !MCO:PRO:RC=1
          84692 !MCO:PRO:RC=1
          84692 !MCO:PRO:RC=1
          84692 !MCO:PRO:RC=1
          84692 !MCO:PRO:RC=1
          84692 !MCO:PRO:RC=1
          84692 !MCO:PRO:RC=1
          84692 !MCO:PRO:RC=1
          84692 !MCO:PRO:RC=1
          84692 !MCO:PRO:RC=1
          84692 !MCO:PRO:RC=1
          84692 !MCO:PRO:RC=1
          84693 !MCO:PRO:RC=1
          84693 !MCO:PRO:RC=1
          84693 !MCO:PRO:RC=1
          84693 !MCO:PRO:RC=1
          84693 !MCO:PRO:RC=1
          84693 !MCO:PRO:RC=1
          84693 !MCO:PRO:RC=1
          84693 !MCO:PRO:RC=1
          84693 !MCO:PRO:RC=1
          84693 !MCO:PRO:RC=1
          84693 !MCO:PRO:RC=1
          84693 !MCO:PRO:RC=1
          84693 !MCO:PRO:RC=1
          84694 !MCO:PRO:RC=1
          84694 !MCO:PRO:RC=1
          84694 !MCO:PRO:RC=1
          84694 !MCO:PRO:RC=1
          84694 !MCO:PRO:RC=1
          84694 !MCO:PRO:RC=1
          84694 !MCO:PRO:RC=1
          84694 !MCO:PRO:RC=1
          84694 !MCO:PRO:RC=1
          84694 !MCO:PRO:RC=1
          84694 !MCO:PRO:RC=1
          84694 !MCO:PRO:RC=1
          84694 !MCO:PRO:RC=1
          84695 !MCO:PRO:RC=1
          84695 !MCO:PRO:RC=1
          84695 !MCO:PRO:RC=1
          84695 !MCO:PRO:RC=1
          84695 !MCO:PRO:RC=1
          84695 !MCO:PRO:RC=1
          84695 !MCO:PRO:RC=1
          84695 !MCO:PRO:RC=1
          84695 !MCO:PRO:RC=1
          84695 !MCO:PRO:RC=1
          84695 !MCO:PRO:RC=1
          84695 !MCO:PRO:RC=1
          84695 !MCO:PRO:RC=1
          84695 !MCO:PRO:RC=1
          84696 !MCO:PRO:RC=1
          84696 !MCO:PRO:RC=1
          84696 !MCO:PRO:RC=1
          84696 !MCO:PRO:RC=1
          84696 !MCO:PRO:RC=1
          84696 !MCO:PRO:RC=1
          84696 !MCO:PRO:RC=1
          84696 !MCO:PRO:RC=1
          84696 !MCO:PRO:RC=1
          84696 !MCO:PRO:RC=1
          84696 !MCO:PRO:RC=1
          84696 !MCO:PRO:RC=1
          84696 !MCO:PRO:RC=1
          84696 !MCO:PRO:RC=1
          84697 !MCO:PRO:RC=1
          84697 !MCO:PRO:RC=1
          84697 !MCO:PRO:RC=1
          84697 !MCO:PRO:RC=1
          84697 !MCO:PRO:RC=1
          84697 !MCO:PRO:RC=1
          84697 !MCO:PRO:RC=1
          84697 !MCO:PRO:RC=1
          84697 !MCO:PRO:RC=1
          84697 !MCO:PRO:RC=1
          84697 !MCO:PRO:RC=1
          84697 !MCO:PRO:RC=1
          84697 !MCO:PRO:RC=1
          84698 !MCO:PRO:RC=1
          84698 !MCO:PRO:RC=1
          84698 !MCO:PRO:RC=1
          84698 !MCO:PRO:RC=1
          84698 !MCO:PRO:RC=1
          84698 !MCO:PRO:RC=1
          84698 !MCO:PRO:RC=1
          84698 !MCO:PRO:RC=1
          84698 !MCO:PRO:RC=1
          84698 !MCO:PRO:RC=1
          84698 !MCO:PRO:RC=1
          84698 !MCO:PRO:RC=1
          84698 !MCO:PRO:RC=1
          84699 !MCO:PRO:RC=1
          84699 !MCO:PRO:RC=1
          84699 !MCO:PRO:RC=1
          84699 !MCO:PRO:RC=1
          84699 !MCO:PRO:RC=1
          84699 !MCO:PRO:RC=1
          84699 !MCO:PRO:RC=1
          84699 !MCO:PRO:RC=1
          84699 !MCO:PRO:RC=1
          84699 !MCO:PRO:RC=1
          84699 !MCO:PRO:RC=1
          84699 !MCO:PRO:RC=1
          84699 !MCO:PRO:RC=1
          84700 !MCO:PRO:RC=1
          84700 !MCO:PRO:RC=1
          84700 !MCO:PRO:RC=1
          84700 !MCO:PRO:RC=1
          84700 !MCO:PRO:RC=1
          84700 !MCO:PRO:RC=1
          84700 !MCO:PRO:RC=1
          84700 !MCO:PRO:RC=1
          84700 !MCO:PRO:RC=1
          84700 !MCO:PRO:RC=1
          84700 !MCO:PRO:RC=1
          84700 !MCO:PRO:RC=1
          84700 !MCO:PRO:RC=1
          84700 !MCO:PRO:RC=1
          84700 !MCO:PRO:RC=1
          84701 !MCO:PRO:RC=1
          84701 !MCO:PRO:RC=1
          84701 !MCO:PRO:RC=1
          84701 !MCO:PRO:RC=1
          84701 !MCO:PRO:RC=1
          84701 !MCO:PRO:RC=1
          84701 !MCO:PRO:RC=1
          84701 !MCO:PRO:RC=1
          84701 !MCO:PRO:RC=1
          84701 !MCO:PRO:RC=1
          84701 !MCO:PRO:RC=1
          84701 !MCO:PRO:RC=1
          84702 !MCO:PRO:RC=1
          84702 !MCO:PRO:RC=1
          84702 !MCO:PRO:RC=1
          84702 !MCO:PRO:RC=1
          84702 !MCO:PRO:RC=1
          84702 !MCO:PRO:RC=1
          84702 !MCO:PRO:RC=1
          84702 !MCO:PRO:RC=1
          84702 !MCO:PRO:RC=1
          84702 !MCO:PRO:RC=1
          84702 !MCO:PRO:RC=1
          84702 !MCO:PRO:RC=1
          84702 !MCO:PRO:RC=1
          84702 !MCO:PRO:RC=1
          84703 !MCO:PRO:RC=1
          84703 !MCO:PRO:RC=1
          84703 !MCO:PRO:RC=1
          84703 !MCO:PRO:RC=1
          84703 !MCO:PRO:RC=1
          84703 !MCO:PRO:RC=1
          84703 !MCO:PRO:RC=1
          84703 !MCO:PRO:RC=1
          84703 !MCO:PRO:RC=1
          84703 !MCO:PRO:RC=1
          84703 !MCO:PRO:RC=1
          84703 !MCO:PRO:RC=1
          84703 !MCO:PRO:RC=1
          84704 !MCO:PRO:RC=1
          84704 !MCO:PRO:RC=1
          84704 !MCO:PRO:RC=1
          84704 !MCO:PRO:RC=1
          84704 !MCO:PRO:RC=1
          84704 !MCO:PRO:RC=1
          84704 !MCO:PRO:RC=1
          84704 !MCO:PRO:RC=1
          84704 !MCO:PRO:RC=1
          84704 !MCO:PRO:RC=1
          84704 !MCO:PRO:RC=1
          84704 !MCO:PRO:RC=1
          84704 !MCO:PRO:RC=1
          84704 !MCO:PRO:RC=1
          84704 !MCO:PRO:RC=1
          84705 !MCO:PRO:RC=1
          84705 !MCO:PRO:RC=1
          84705 !MCO:PRO:RC=1
          84705 !MCO:PRO:RC=1
          84705 !MCO:PRO:RC=1
          84705 !MCO:PRO:RC=1
          84705 !MCO:PRO:RC=1
          84705 !MCO:PRO:RC=1
          84705 !MCO:PRO:RC=1
          84705 !MCO:PRO:RC=1
          84705 !MCO:PRO:RC=1
          84705 !MCO:PRO:RC=1
          84705 !MCO:PRO:RC=1
          84706 !MCO:PRO:RC=1
          84706 !MCO:PRO:RC=1
          84706 !MCO:PRO:RC=1
          84706 !MCO:PRO:RC=1
          84706 !MCO:PRO:RC=1
          84706 !MCO:PRO:RC=1
          84706 !MCO:PRO:RC=1
          84706 !MCO:PRO:RC=1
          84706 !MCO:PRO:RC=1
          84706 !MCO:PRO:RC=1
          84706 !MCO:PRO:RC=1
          84706 !MCO:PRO:RC=1
          84706 !MCO:PRO:RC=1
          84706 !MCO:PRO:RC=1
          84707 !MCO:PRO:RC=1
          84707 !MCO:PRO:RC=1
          84707 !MCO:PRO:RC=1
          84707 !MCO:PRO:RC=1
          84707 !MCO:PRO:RC=1
          84707 !MCO:PRO:RC=1
          84707 !MCO:PRO:RC=1
          84707 !MCO:PRO:RC=1
          84707 !MCO:PRO:RC=1
          84707 !MCO:PRO:RC=1
          84707 !MCO:PRO:RC=1
          84707 !MCO:PRO:RC=1
          84708 !MCO:PRO:RC=1
          84708 !MCO:PRO:RC=1
          84708 !MCO:PRO:RC=1
          84708 !MCO:PRO:RC=1
          84708 !MCO:PRO:RC=1
          84708 !MCO:PRO:RC=1
          84708 !MCO:PRO:RC=1
          84709 !MCO:PRO:RC=1
          84709 !MCO:PRO:RC=1
          84709 !MCO:PRO:RC=1
          84709 !MCO:PRO:RC=1
          84709 !MCO:PRO:RC=1
          84709 !MCO:PRO:RC=1
          84709 !MCO:PRO:RC=1
          84709 !MCO:PRO:RC=1
          84709 !MCO:PRO:RC=1
          84710 !MCO:PRO:RC=1
          84710 !MCO:PRO:RC=1
          84710 !MCO:PRO:RC=1
          84710 !MCO:PRO:RC=1
          84710 !MCO:PRO:RC=1
          84710 !MCO:PRO:RC=1
          84710 !MCO:PRO:RC=1
          84710 !MCO:PRO:RC=1
          84710 !MCO:PRO:RC=1
          84710 !MCO:PRO:RC=1
          84710 !MCO:PRO:RC=1
          84710 !MCO:PRO:RC=1
          84710 !MCO:PRO:RC=1
          84711 !MCO:PRO:RC=1
          84711 !MCO:PRO:RC=1
          84711 !MCO:PRO:RC=1
          84711 !MCO:PRO:RC=1
          84711 !MCO:PRO:RC=1
          84711 !MCO:PRO:RC=1
          84711 !MCO:PRO:RC=1
          84711 !MCO:PRO:RC=1
          84711 !MCO:PRO:RC=1
          84711 !MCO:PRO:RC=1
          84711 !MCO:PRO:RC=1
          84711 !MCO:PRO:RC=1
          84712 !MCO:PRO:RC=1
          84712 !MCO:PRO:RC=1
          84712 !MCO:PRO:RC=1
          84712 !MCO:PRO:RC=1
          84712 !MCO:PRO:RC=1
          84712 !MCO:PRO:RC=1
          84712 !MCO:PRO:RC=1
          84712 !MCO:PRO:RC=1
          84712 !MCO:PRO:RC=1
          84712 !MCO:PRO:RC=1
          84712 !MCO:PRO:RC=1
          84712 !MCO:PRO:RC=1
          84712 !MCO:PRO:RC=1
          84713 !MCO:PRO:RC=1
          84713 !MCO:PRO:RC=1
          84713 !MCO:PRO:RC=1
          84713 !MCO:PRO:RC=1
          84713 !MCO:PRO:RC=1
          84713 !MCO:PRO:RC=1
          84713 !MCO:PRO:RC=1
          84713 !MCO:PRO:RC=1
          84713 !MCO:PRO:RC=1
          84713 !MCO:PRO:RC=1
          84713 !MCO:PRO:RC=1
          84713 !MCO:PRO:RC=1
          84714 !MCO:PRO:RC=1
          84714 !MCO:PRO:RC=1
          84714 !MCO:PRO:RC=1
          84714 !MCO:PRO:RC=1
          84714 !MCO:PRO:RC=1
          84714 !MCO:PRO:RC=1
          84714 !MCO:PRO:RC=1
          84714 !MCO:PRO:RC=1
          84714 !MCO:PRO:RC=1
          84714 !MCO:PRO:RC=1
          84714 !MCO:PRO:RC=1
          84714 !MCO:PRO:RC=1
          84714 !MCO:PRO:RC=1
          84715 !MCO:PRO:RC=1
          84715 !MCO:PRO:RC=1
          84715 !MCO:PRO:RC=1
          84715 !MCO:PRO:RC=1
          84715 !MCO:PRO:RC=1
          84715 !MCO:PRO:RC=1
          84715 !MCO:PRO:RC=1
          84715 !MCO:PRO:RC=1
          84715 !MCO:PRO:RC=1
          84715 !MCO:PRO:RC=1
          84715 !MCO:PRO:RC=1
          84715 !MCO:PRO:RC=1
          84715 !MCO:PRO:RC=1
          84716 !MCO:PRO:RC=1
          84716 !MCO:PRO:RC=1
          84716 !MCO:PRO:RC=1
          84716 !MCO:PRO:RC=1
          84716 !MCO:PRO:RC=1
          84716 !MCO:PRO:RC=1
          84716 !MCO:PRO:RC=1
          84716 !MCO:PRO:RC=1
          84716 !MCO:PRO:RC=1
          84716 !MCO:PRO:RC=1
          84716 !MCO:PRO:RC=1
          84716 !MCO:PRO:RC=1
          84716 !MCO:PRO:RC=1
          84716 !MCO:PRO:RC=1
          84717 !MCO:PRO:RC=1
          84717 !MCO:PRO:RC=1
          84717 !MCO:PRO:RC=1
          84717 !MCO:PRO:RC=1
          84717 !MCO:PRO:RC=1
          84717 !MCO:PRO:RC=1
          84717 !MCO:PRO:RC=1
          84717 !MCO:PRO:RC=1
          84717 !MCO:PRO:RC=1
          84717 !MCO:PRO:RC=1
          84717 !MCO:PRO:RC=1
          84717 !MCO:PRO:RC=1
          84717 !MCO:PRO:RC=1
          84718 !MCO:PRO:RC=1
          84718 !MCO:PRO:RC=1
          84718 !MCO:PRO:RC=1
          84718 !MCO:PRO:RC=1
          84718 !MCO:PRO:RC=1
          84718 !MCO:PRO:RC=1
          84718 !MCO:PRO:RC=1
          84718 !MCO:PRO:RC=1
          84718 !MCO:PRO:RC=1
          84718 !MCO:PRO:RC=1
          84718 !MCO:PRO:RC=1
          84718 !MCO:PRO:RC=1
          84718 !MCO:PRO:RC=1
          84719 !MCO:PRO:RC=1
          84719 !MCO:PRO:RC=1
          84719 !MCO:PRO:RC=1
          84719 !MCO:PRO:RC=1
          84719 !MCO:PRO:RC=1
          84719 !MCO:PRO:RC=1
          84719 !MCO:PRO:RC=1
          84719 !MCO:PRO:RC=1
          84719 !MCO:PRO:RC=1
          84719 !MCO:PRO:RC=1
          84719 !MCO:PRO:RC=1
          84719 !MCO:PRO:RC=1
          84719 !MCO:PRO:RC=1
          84720 !MCO:PRO:RC=1
          84720 !MCO:PRO:RC=1
          84720 !MCO:PRO:RC=1
          84720 !MCO:PRO:RC=1
          84720 !MCO:PRO:RC=1
          84720 !MCO:PRO:RC=1
          84720 !MCO:PRO:RC=1
          84720 !MCO:PRO:RC=1
          84720 !MCO:PRO:RC=1
          84720 !MCO:PRO:RC=1
          84720 !MCO:PRO:RC=1
          84720 !MCO:PRO:RC=1
          84721 !MCO:PRO:RC=1
          84721 !MCO:PRO:RC=1
          84721 !MCO:PRO:RC=1
          84721 !MCO:PRO:RC=1
          84721 !MCO:PRO:RC=1
          84721 !MCO:PRO:RC=1
          84721 !MCO:PRO:RC=1
          84721 !MCO:PRO:RC=1
          84721 !MCO:PRO:RC=1
          84721 !MCO:PRO:RC=1
          84721 !MCO:PRO:RC=1
          84721 !MCO:PRO:RC=1
          84721 !MCO:PRO:RC=1
          84722 !MCO:PRO:RC=1
          84722 !MCO:PRO:RC=1
          84722 !MCO:PRO:RC=1
          84722 !MCO:PRO:RC=1
          84722 !MCO:PRO:RC=1
          84722 !MCO:PRO:RC=1
          84722 !MCO:PRO:RC=1
          84722 !MCO:PRO:RC=1
          84722 !MCO:PRO:RC=1
          84722 !MCO:PRO:RC=1
          84722 !MCO:PRO:RC=1
          84722 !MCO:PRO:RC=1
          84723 !MCO:PRO:RC=1
          84723 !MCO:PRO:RC=1
          84723 !MCO:PRO:RC=1
          84723 !MCO:PRO:RC=1
          84723 !MCO:PRO:RC=1
          84723 !MCO:PRO:RC=1
          84723 !MCO:PRO:RC=1
          84723 !MCO:PRO:RC=1
          84723 !MCO:PRO:RC=1
          84723 !MCO:PRO:RC=1
          84723 !MCO:PRO:RC=1
          84723 !MCO:PRO:RC=1
          84723 !MCO:PRO:RC=1
          84724 !MCO:PRO:RC=1
          84724 !MCO:PRO:RC=1
          84724 !MCO:PRO:RC=1
          84724 !MCO:PRO:RC=1
          84724 !MCO:PRO:RC=1
          84724 !MCO:PRO:RC=1
          84724 !MCO:PRO:RC=1
          84724 !MCO:PRO:RC=1
          84724 !MCO:PRO:RC=1
          84724 !MCO:PRO:RC=1
          84724 !MCO:PRO:RC=1
          84724 !MCO:PRO:RC=1
          84725 !MCO:PRO:RC=1
          84725 !MCO:PRO:RC=1
          84725 !MCO:PRO:RC=1
          84725 !MCO:PRO:RC=1
          84725 !MCO:PRO:RC=1
          84725 !MCO:PRO:RC=1
          84725 !MCO:PRO:RC=1
          84725 !MCO:PRO:RC=1
          84725 !MCO:PRO:RC=1
          84725 !MCO:PRO:RC=1
          84725 !MCO:PRO:RC=1
          84725 !MCO:PRO:RC=1
          84725 !MCO:PRO:RC=1
          84725 !MCO:PRO:RC=1
          84725 !MCO:PRO:RC=1
          84726 !MCO:PRO:RC=1
          84726 !MCO:PRO:RC=1
          84726 !MCO:PRO:RC=1
          84726 !MCO:PRO:RC=1
          84726 !MCO:PRO:RC=1
          84726 !MCO:PRO:RC=1
          84726 !MCO:PRO:RC=1
          84726 !MCO:PRO:RC=1
          84726 !MCO:PRO:RC=1
          84726 !MCO:PRO:RC=1
          84726 !MCO:PRO:RC=1
          84726 !MCO:PRO:RC=1
          84726 !MCO:PRO:RC=1
          84727 !MCO:PRO:RC=1
          84727 !MCO:PRO:RC=1
          84727 !MCO:PRO:RC=1
          84727 !MCO:PRO:RC=1
          84727 !MCO:PRO:RC=1
          84727 !MCO:PRO:RC=1
          84727 !MCO:PRO:RC=1
          84727 !MCO:PRO:RC=1
          84727 !MCO:PRO:RC=1
          84727 !MCO:PRO:RC=1
          84727 !MCO:PRO:RC=1
          84727 !MCO:PRO:RC=1
          84727 !MCO:PRO:RC=1
          84728 !MCO:PRO:RC=1
          84728 !MCO:PRO:RC=1
          84728 !MCO:PRO:RC=1
          84728 !MCO:PRO:RC=1
          84728 !MCO:PRO:RC=1
          84728 !MCO:PRO:RC=1
          84728 !MCO:PRO:RC=1
          84728 !MCO:PRO:RC=1
          84728 !MCO:PRO:RC=1
          84728 !MCO:PRO:RC=1
          84728 !MCO:PRO:RC=1
          84728 !MCO:PRO:RC=1
          84728 !MCO:PRO:RC=1
          84729 !MCO:PRO:RC=1
          84729 !MCO:PRO:RC=1
          84729 !MCO:PRO:RC=1
          84729 !MCO:PRO:RC=1
          84729 !MCO:PRO:RC=1
          84729 !MCO:PRO:RC=1
          84729 !MCO:PRO:RC=1
          84729 !MCO:PRO:RC=1
          84729 !MCO:PRO:RC=1
          84729 !MCO:PRO:RC=1
          84729 !MCO:PRO:RC=1
          84729 !MCO:PRO:RC=1
          84729 !MCO:PRO:RC=1
          84730 !MCO:PRO:RC=1
          84730 !MCO:PRO:RC=1
          84730 !MCO:PRO:RC=1
          84730 !MCO:PRO:RC=1
          84730 !MCO:PRO:RC=1
          84730 !MCO:PRO:RC=1
          84730 !MCO:PRO:RC=1
          84730 !MCO:PRO:RC=1
          84730 !MCO:PRO:RC=1
          84730 !MCO:PRO:RC=1
          84730 !MCO:PRO:RC=1
          84730 !MCO:PRO:RC=1
          84730 !MCO:PRO:RC=1
          84731 !MCO:PRO:RC=1
          84731 !MCO:PRO:RC=1
          84731 !MCO:PRO:RC=1
          84731 !MCO:PRO:RC=1
          84731 !MCO:PRO:RC=1
          84731 !MCO:PRO:RC=1
          84731 !MCO:PRO:RC=1
          84731 !MCO:PRO:RC=1
          84731 !MCO:PRO:RC=1
          84731 !MCO:PRO:RC=1
          84731 !MCO:PRO:RC=1
          84731 !MCO:PRO:RC=1
          84731 !MCO:PRO:RC=1
          84731 !MCO:PRO:RC=1
          84731 !MCO:PRO:RC=1
          84731 !MCO:PRO:RC=1
          84732 !MCO:PRO:RC=1
          84732 !MCO:PRO:RC=1
          84732 !MCO:PRO:RC=1
          84732 !MCO:PRO:RC=1
          84732 !MCO:PRO:RC=1
          84732 !MCO:PRO:RC=1
          84732 !MCO:PRO:RC=1
          84732 !MCO:PRO:RC=1
          84732 !MCO:PRO:RC=1
          84732 !MCO:PRO:RC=1
          84732 !MCO:PRO:RC=1
          84732 !MCO:PRO:RC=1
          84732 !MCO:PRO:RC=1
          84732 !MCO:PRO:RC=1
          84733 !MCO:PRO:RC=1
          84733 !MCO:PRO:RC=1
          84733 !MCO:PRO:RC=1
          84733 !MCO:PRO:RC=1
          84733 !MCO:PRO:RC=1
          84733 !MCO:PRO:RC=1
          84733 !MCO:PRO:RC=1
          84733 !MCO:PRO:RC=1
          84733 !MCO:PRO:RC=1
          84733 !MCO:PRO:RC=1
          84733 !MCO:PRO:RC=1
          84733 !MCO:PRO:RC=1
          84733 !MCO:PRO:RC=1
          84734 !MCO:PRO:RC=1
          84734 !MCO:PRO:RC=1
          84734 !MCO:PRO:RC=1
          84734 !MCO:PRO:RC=1
          84734 !MCO:PRO:RC=1
          84734 !MCO:PRO:RC=1
          84734 !MCO:PRO:RC=1
          84734 !MCO:PRO:RC=1
          84734 !MCO:PRO:RC=1
          84734 !MCO:PRO:RC=1
          84734 !MCO:PRO:RC=1
          84734 !MCO:PRO:RC=1
          84734 !MCO:PRO:RC=1
          84734 !MCO:PRO:RC=1
          84735 !MCO:PRO:RC=1
          84735 !MCO:PRO:RC=1
          84735 !MCO:PRO:RC=1
          84735 !MCO:PRO:RC=1
          84735 !MCO:PRO:RC=1
          84735 !MCO:PRO:RC=1
          84735 !MCO:PRO:RC=1
          84735 !MCO:PRO:RC=1
          84735 !MCO:PRO:RC=1
          84735 !MCO:PRO:RC=1
          84735 !MCO:PRO:RC=1
          84735 !MCO:PRO:RC=1
          84735 !MCO:PRO:RC=1
          84735 !MCO:PRO:RC=1
          84735 !MCO:PRO:RC=1
          84736 !MCO:PRO:RC=1
          84736 !MCO:PRO:RC=1
          84736 !MCO:PRO:RC=1
          84736 !MCO:PRO:RC=1
          84736 !MCO:PRO:RC=1
          84736 !MCO:PRO:RC=1
          84736 !MCO:PRO:RC=1
          84736 !MCO:PRO:RC=1
          84736 !MCO:PRO:RC=1
          84736 !MCO:PRO:RC=1
          84736 !MCO:PRO:RC=1
          84736 !MCO:PRO:RC=1
          84737 !MCO:PRO:RC=1
          84737 !MCO:PRO:RC=1
          84737 !MCO:PRO:RC=1
          84737 !MCO:PRO:RC=1
          84737 !MCO:PRO:RC=1
          84737 !MCO:PRO:RC=1
          84737 !MCO:PRO:RC=1
          84737 !MCO:PRO:RC=1
          84737 !MCO:PRO:RC=1
          84737 !MCO:PRO:RC=1
          84737 !MCO:PRO:RC=1
          84737 !MCO:PRO:RC=1
          84737 !MCO:PRO:RC=1
          84738 !MCO:PRO:RC=1
          84738 !MCO:PRO:RC=1
          84738 !MCO:PRO:RC=1
          84738 !MCO:PRO:RC=1
          84738 !MCO:PRO:RC=1
          84738 !MCO:PRO:RC=1
          84738 !MCO:PRO:RC=1
          84738 !MCO:PRO:RC=1
          84738 !MCO:PRO:RC=1
          84738 !MCO:PRO:RC=1
          84738 !MCO:PRO:RC=1
          84738 !MCO:PRO:RC=1
          84739 SGN:SGN:NREQ=0
          85878 TSF:MSG:SEND,10-10-0-0,s=11,c=1,t=47,pt=0,l=16,sg=0,ft=0,st=OK:2021:8:18:10:4:9
          Resent Dateboot
          SendInterval Timed :TEMPERATURE :1.91
          85883 SGN:SGN:NREQ=0
          88149 TSF:MSG:SEND,10-10-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:1.91
          88160 SGN:SGN:NREQ=0
          89572 TSF:MSG:SEND,10-10-0-0,s=2,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:1
          89572 SGN:SGN:NREQ=0
          93622 TSF:MSG:SEND,10-10-0-0,s=5,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:0
          Setpoint requested :
          93632 SGN:SGN:NREQ=0
          95044 TSF:MSG:SEND,10-10-0-0,s=1,c=2,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
           Request OK ACK Received
          95049 SGN:SGN:NREQ=0
          95055 TSF:MSG:SEND,10-10-0-0,s=6,c=2,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          95055 SGN:SGN:NREQ=0
          96504 TSF:MSG:SEND,10-10-0-0,s=8,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
          SendInterval Timed :TEMPERATURE :19.31
          156806 SGN:SGN:NREQ=0
          157102 TSF:MSG:SEND,10-10-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.31
          157112 SGN:SGN:NREQ=0
          159321 TSF:MSG:SEND,10-10-0-0,s=2,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
          159321 SGN:SGN:NREQ=0
          160733 TSF:MSG:SEND,10-10-0-0,s=5,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:0
          161562 TSF:MSG:READ,0-0-10,s=5,c=1,t=37,pt=2,l=2,sg=0:0
          161562 SGN:SKP:ECHO CMD=1,TYPE=37
          161562 TSF:MSG:ECHO
          +Ack/Echo FMGW
          *InMsgty :37 MsgComd:1 childID:5 Data:S/ Data:I/ 0 Data:B/ 0
          • N Offline
            N Offline
            Nigel31
            No one have any ideas?
            It can't just be me surely?
            regards Nigel
            Y 1 Reply Last reply
            • N Nigel31
              regards Nigel
              Y Offline
              Y Offline
              @Njwyborn judging from the logs, i would suspect that you're at least suffering from this issue https://github.com/mysensors/MySensors/issues/1458, which unfortunately is still open.
              N 1 Reply Last reply
              • Y Yveaux
                N Offline
                N Offline
                Nigel31
                @Yveaux
                Thank you, at least I'm not going mad.
                Would this issue likely be the root cause of the curious inverse clock speed / performance results / performance?
                regards Nigel
                • N Nigel31
                  @Yveaux
                  regards Nigel
                  Y Offline
                  Y Offline
                  @Njwyborn sorry, I don't know. If the stack is called recursively, something is seriously wrong and behavior is undefined I guess.
                  12.2k
