  3. DIY zigbee sensor?
DIY zigbee sensor?
13 Posts 6 Posters 2.8k Views 7 Watching
  • M Offline
    M Offline
    martin3000
    I have built some sensors with wifi based on esp8266/esp32.
    Now I would like to build my own zigbee sensors.
    Are there any programmable zigbee modules with I/O pins?
    • electrikE Offline
      electrikE Offline
      electrik
      Take a look here: https://diyruz.github.io/
      • M Offline
        M Offline
        martin3000
        Thank you!
        He is working with windows software (IAR)?
        This is funny :-)
        • fritsF Offline
          fritsF Offline
          frits
          I recommend this one: https://ptvo.info/
          • fritsF frits
            M Offline
            M Offline
            martin3000
            @frits thank you, I tried to flash the ptvo firmware, and after flashing I found out that the firmware does not contain a boot loader. So my zigbee stick is lost...
            E 1 Reply Last reply
            • fritsF Offline
              fritsF Offline
              frits
              what modules do you use? I work with Ebyte E18MS1xx (CC2530 based) and flash them with a Raspberry Pi or aSmartRF04 clone.
              • M martin3000
                E Offline
                E Offline
                ejlane
                @martin3000 said in DIY zigbee sensor?:
                If you have hardware that can flash it, then you can still recover. Not having a bootloader is only an issue if you don't have the right hardware. And as @frits seemed to be getting at, there are many choices these days where common hardware like a Raspberry Pi or even Arduino can be programmed to act as that special hardware. But even if not, some of the more common platforms you can buy pretty cheap programmers that will do the trick.
                In my experience it's actually fairly rare to truly lock a device to the point where it's not recoverable. At least at this kind of DIY level. (Burning out a chip by putting the wrong power to it is another story... :) )
                • fritsF frits
                  M Offline
                  M Offline
                  martin3000
                  @frits I'm using a cc2652rb USB-Stick and I was flashing it via USB.
                  fritsF 1 Reply Last reply
                  • fritsF Offline
                    fritsF Offline
                    frits
                    Do you have a raspberry pi and your zigbee stick has jtag header? Then you could flash your stick via jtag, look here: https://www.youtube.com/watch?v=0XOozGlbU7U
                    • ranseyerR Offline
                      ranseyerR Offline
                      ranseyer
                      I had no time for testing my designs, but if the is someboby from europe interested it will raise my motivation:
                      (And i could share some PCBs of them)
                      https://github.com/ranseyer/Zigbee-Devices
                      for CC2530:
                      -8 Key Remote
                      -Test/Dev Board
                      (-Cc2538 coordionator)
                      • ranseyerR ranseyer
                        for CC2530:
                        -8 Key Remote
                        -Test/Dev Board
                        In case anyone wants a link to @ranseyer's designs: https://www.openhardware.io/user/897/projects/Ranseyer
                        • ranseyerR Offline
                          ranseyerR Offline
                          ranseyer
                          Thanks ! -but you cant see other projects there than Homematic oder Zigbee Devices... They are actually only in my github repos... https://github.com/ranseyer?tab=repositories
                          • M martin3000
                            fritsF Offline
                            fritsF Offline
                            frits
                            @martin3000 I just noticed that PTVO firmware does support the "serial bootloader":
                            Anyway this feature is not documented too well.
                            12.2k
