  3. DIY zigbee sensor?
DIY zigbee sensor?
13 Posts 6 Posters 3.3k Views 7 Watching
  • electrikE
    electrikE
    electrik
    Take a look here: https://diyruz.github.io/
      martin3000
      Thank you!
      He is working with windows software (IAR)?
      This is funny :-)
      • fritsF
        fritsF
        frits
        I recommend this one: https://ptvo.info/
        • fritsF frits
          martin3000
          @frits thank you, I tried to flash the ptvo firmware, and after flashing I found out that the firmware does not contain a boot loader. So my zigbee stick is lost...
          E 1 Reply Last reply
          • fritsF
            fritsF
            frits
            what modules do you use? I work with Ebyte E18MS1xx (CC2530 based) and flash them with a Raspberry Pi or aSmartRF04 clone.
            • M martin3000
              E
              E
              ejlane
              @martin3000 said in DIY zigbee sensor?:
              If you have hardware that can flash it, then you can still recover. Not having a bootloader is only an issue if you don't have the right hardware. And as @frits seemed to be getting at, there are many choices these days where common hardware like a Raspberry Pi or even Arduino can be programmed to act as that special hardware. But even if not, some of the more common platforms you can buy pretty cheap programmers that will do the trick.
              In my experience it's actually fairly rare to truly lock a device to the point where it's not recoverable. At least at this kind of DIY level. (Burning out a chip by putting the wrong power to it is another story... :) )
              • fritsF frits
                martin3000
                @frits I'm using a cc2652rb USB-Stick and I was flashing it via USB.
                fritsF 1 Reply Last reply
                • fritsF
                  fritsF
                  frits
                  Do you have a raspberry pi and your zigbee stick has jtag header? Then you could flash your stick via jtag, look here: https://www.youtube.com/watch?v=0XOozGlbU7U
                  • ranseyerR
                    ranseyerR
                    ranseyer
                    I had no time for testing my designs, but if the is someboby from europe interested it will raise my motivation:
                    (And i could share some PCBs of them)
                    https://github.com/ranseyer/Zigbee-Devices
                    for CC2530:
                    -8 Key Remote
                    -Test/Dev Board
                    (-Cc2538 coordionator)
                    • ranseyerR ranseyer
                      for CC2530:
                      -8 Key Remote
                      -Test/Dev Board
                      In case anyone wants a link to @ranseyer's designs: https://www.openhardware.io/user/897/projects/Ranseyer
                      • ranseyerR
                        ranseyerR
                        ranseyer
                        Thanks ! -but you cant see other projects there than Homematic oder Zigbee Devices... They are actually only in my github repos... https://github.com/ranseyer?tab=repositories
                        • M martin3000
                          fritsF
                          fritsF
                          frits
                          @martin3000 I just noticed that PTVO firmware does support the "serial bootloader":
                          Anyway this feature is not documented too well.
