  3. Repeater and blinking leds [SOLVED]
13 Posts 3 Posters 6.2k Views 2 Watching
  • H
    H
    HarryDutch
    wrote on last edited by HarryDutch
    I'm using EasyIoT as controller and have 2 sensors (one in the fridge and one outside) and 1 repeater (for the sensor in the fridge). This all works perfectly well. I'm now trying to achieve that on the repeater a red led blinks if temperature in the fridge drops below 4 °C and a green led blinks if temperature rises above 8 °C. I first made a third test sensor that is simply sending a fixed temperature value to the repeater just to see if the message arrives at the repeater and how it should process there. Node id test node is 3 and node id repeater is 7. This is the code for the test node:
    <pre><code>
    **#include <MySensor.h>
    #define TEMP_CHILD 0
    unsigned long SLEEP_TIME = 60000;
    MyMessage msgTemp(TEMP_CHILD, V_TEMP);
    gw.begin();
    gw.sendSketchInfo("Test Node", "1.0");
    gw.present(TEMP_CHILD, S_TEMP);
    float temperature = 123.0;
    gw.send(msgTemp.setDestination(7).set(temperature,1));
    gw.sleep(SLEEP_TIME); **
    </code></pre>
    In the serial monitor and server console I can see that this test node is sending the fixed value of "123" to destination 7 (repeater):
    send: 3-3-0-7 s=0,c=1,t=0,pt=7,l=5,st=ok:123.0
    And then it stops. I have no idea how to process the incoming message at the repeater side (the blinking leds are not the problem but only the processing of the incoming message). I'm using the default MySensors sketch for the repeater. If someone could point me in the right direction (maybe some example somewhere on this forum. Have looked but cannot find it) I would be very gratefull.
    • rvendrameR
      rvendrameR
      rvendrame
      @HarryDutch
      On the receiver side, during the radio startup, add the name of a subroutine to handle the incoming messages:
      gw.begin( incomingMessage );
      Then you define the subroutine, something like this:
          if (message.type == V_LIGHT ) {
              int state = atoi( message.data );
              digitalWrite( LED_PIN ,  state );
      At the loop routine, you just need to constantly call gw.process. And you should not use sleep, as no message can be received while Arduino+radio are sleeping...
          // Your logic here - read sensors, send status etc
      Hope it helps!
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      • H
        H
        HarryDutch
        @rvendrame
        Thanks for taking your time. But still no luck with this. I now have stripped both the receiver and transmitter sketch to an absolute minimum. Just to see if a message goes from the transmiiting node (3) to the receiving node (7). If a message arrives at node 7 a led will be on for 2 seconds. But that is not working. Is there something wrong in this receiving sketch?
        Receiving sketch:
        <pre><code>
        #define ledPin 6
        pinMode(ledPin, OUTPUT);
        digitalWrite(ledPin, LOW);
        gw.sendSketchInfo("TEST", "1.0");
        digitalWrite(ledPin, HIGH);
        delay(2000);
        </code></pre>
        • rvendrameR
          rvendrameR
          rvendrame
          @HarryDutch, I don't see anything wrong with your receiver sketch. Two suggestions:
          • Are you able to use the serial-monitor at the receiver node, and confirm if any message is arriving there?
          • If you move the code from IncomingMessage() to loop(), does the LED turn on/off? ( just for the sake ... )
          Alexa / Google Home
          • H
            H
            HarryDutch
            Moved code from IncomingMessage() to loop() and the led is on for 2 seconds. So the led is working as it should.
            Did changed things a little bit . Node 2 (temperature/humidity sensor in the fridge) is sending temperature/humidity to controller and temperature to node 3 (the node with the leds).
            gw.send(msgTemp.set(temperature,1));
            gw.send(msgHum.set(humidity, 0));
            gw.send(msgTemp.setDestination(3).set(temperature,1));//SEND TEMPERATURE ALSO TO NODE 3
            This is the output serial monitor node 2:
            sensor started, id 2
            send: 2-2-3-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
            send: 2-2-3-0 s=255,c=3,t=6,pt=1,l=1,st=ok:3
            send: 2-2-3-0 s=255,c=3,t=11,pt=0,l=15,st=ok:Pressure Sensor
            send: 2-2-3-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
            send: 2-2-3-0 s=0,c=0,t=7,pt=0,l=5,st=ok:1.4.1
            send: 2-2-3-0 s=1,c=0,t=6,pt=0,l=5,st=ok:1.4.1
            Temperature = 17.10Humidity = 57.90send: 2-2-3-0 s=1,c=1,t=0,pt=7,l=5,st=fail:17.1
            send: 2-2-3-0 s=0,c=1,t=1,pt=7,l=5,st=ok:58
            send: 2-2-3-3 s=1,c=1,t=0,pt=7,l=5,st=ok:17.1
            Looking at the last line it seems to me that sending the temperature value to node 3 is ok.
            Node 3 (also a repeater) has now a copy of the Relay Actuator sketch where I have changes relays into leds. There are 3 leds that I can now switch on and off by using the controller. This is working. This is the code for the function IncomingMessage():
            **void incomingMessage(const MyMessage &message) {
            if (message.type==V_LIGHT) {
            digitalWrite(message.sensor-1+LED_1, message.getBool()?LED_ON:LED_OFF);
            // ==== THIS IS NOT WORKING ==========================
            if (message.type==V_TEMP) {
            digitalWrite(6, HIGH);
            delay(2000);
            digitalWrite(6, LOW);
            And this the output of the serial monitor of node 3:
            **repeater started, id 3
            send: 3-3-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
            send: 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
            send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=3,st=ok:LED
            send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
            send: 3-3-0-0 s=1,c=0,t=3,pt=0,l=5,st=ok:1.4.1
            send: 3-3-0-0 s=2,c=0,t=3,pt=0,l=5,st=ok:1.4.1
            send: 3-3-0-0 s=3,c=0,t=3,pt=0,l=5,st=ok:1.4.1
            read: 2-2-0 s=255,c=0,t=17,pt=0,l=5:1.4.1
            send: 2-3-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
            read: 2-2-0 s=255,c=3,t=6,pt=1,l=1:3
            send: 2-3-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:3
            read: 2-2-0 s=255,c=3,t=11,pt=0,l=15:Pressure Sensor
            send: 2-3-0-0 s=255,c=3,t=11,pt=0,l=15,st=ok:Pressure Sensor
            read: 2-2-0 s=255,c=3,t=12,pt=0,l=3:1.0
            send: 2-3-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
            read: 2-2-0 s=0,c=0,t=7,pt=0,l=5:1.4.1
            send: 2-3-0-0 s=0,c=0,t=7,pt=0,l=5,st=fail:1.4.1
            read: 2-2-0 s=1,c=1,t=0,pt=7,l=5:19.4
            send: 2-3-0-0 s=1,c=1,t=0,pt=7,l=5,st=ok:19.4
            read: 2-2-0 s=0,c=1,t=1,pt=7,l=5:51
            send: 2-3-0-0 s=0,c=1,t=1,pt=7,l=5,st=fail:51
            • rvendrameR
              rvendrameR
              rvendrame
              Well...
              • Try put some delay() between sending each message (or leave just a single message to node 3).
              • The relay sketch also acts like a repeater, maybe it is trying to send the message to 'node 3' to GW instead? Try to disable the repeater function:
                   gw.begin(incomingMessage, AUTO, false );
              Alexa / Google Home
              • H
                H
                HarryDutch
                @rvendrame
                Really appriciate your assistance. All this MySensors stuff is working perfectly well, so not getting this node to node communication right is driving me nuts!
                First thing tomorrow I will try your suggestions. Thanks again.
                • ChaoticC
                  ChaoticC
                  Chaotic
                  I'm interested in the concept of node to node messages but for your use case couldn't you just have the gateway send the message to toggle the LEDs once the message gets there?
                  So
                  Node inside fridge -> Relay -> Gateway -> LED Node
                  rather than
                  Node inside fridge -> LED Node
                  which is what it seems like you are attempting to do.
                  Also I had not thought of putting a node in a fridge before but I'll be looking into that now.
                  • rvendrameR
                    rvendrameR
                    rvendrame
                    @Chaotic , I was about to suggest the same to @HarryDutch , however it seems he wants to take the GW out of the equation (for some reason that we don't know).
                    By putting the GW in the middle it should work perfectly well, I do agree with you.
                    Alexa / Google Home
                    • H
                      H
                      HarryDutch
                      @rvendrame and Chaotic
                      You're both right of course. I'm now using the automation function in EasyIoT and that's working. So Node inside fridge -> Relay -> Gateway -> LED Node. On the other hand: node to node communication should be possible so I will do some more testing to see if I can get it to work. Thanks for now.
                      ChaoticC 1 Reply Last reply
                      • H HarryDutch
                        ChaoticC
                        ChaoticC
                        Chaotic
                        wrote on last edited by Chaotic
                        @HarryDutch
                        I wasn't saying don't look at the problem. I think Node to Node communication should work.
                        It just this comic
                        XKCD Comic
                        comes to mind
                        At a certain point you have to realize you are solving the problem out of principle (which is a valid reason) rather than to solve the problem.
                        • H
                          H
                          HarryDutch
                          @Chaotic
                          Hahaha. I've printed your comic. It's hanging now in front of me to remind me that there are different ways to solve a problem. By using the GW I now have a perfectly working project. Thanks for pointing me into the right direction. But I will still try to get the node to node communication working although it's no longer a problem!
                          • H HarryDutch
                            @Chaotic
                            ChaoticC
                            ChaoticC
                            Chaotic
                            @HarryDutch The comic is actually from XKCD if you click the image it should take you to the actual site.
