  3. Soldering station
Soldering station
21 Posts 10 Posters 4.2k Views 9 Watching
  • pihomeP
    pihomeP
    pihome
    i think Weller WS81 is soldering iron but i m looking for hot air version for smd components.
    PiHome - Smart Heating Control
    • pihomeP pihome
      mbj
      @pihome Sorry I missed the little word "smd". It is of course possible to use a soldering station also but is not always so simple. I have used the butane driven Dremel soldering tool mainly because I have nothing else. It is not easy to control the heat with that one.
      • G
        G
        Gerator
        wrote on last edited by Gerator
        Ersa i-con nano is a nice soldering station for 200€.
        By the way... Tip choice is very important too. I very much like beveled tip.
        • skywatchS
          skywatchS
          skywatch
          Weller were the best in the 70's, 80's, 90's and even beyond. - But for an up-to-date picture, see these two videos.....
          https://www.youtube.com/watch?v=8itTKH5tj3s
          https://www.youtube.com/watch?v=XUtj-bWHeKY
          Seems that they may be just a 'name' for Chinese factories to produce lower quality/higher profit products? - Make your own minds up though ;)
          dbemowskD 1 Reply Last reply
          • skywatchS skywatch
            dbemowskD
            dbemowskD
            @skywatch great videos. It brings to light some things that I didn't know about the Weller irons. If I was going to attempt to add my own primary side fuse to my iron, does anyone have any idea of what fuse rating would be good to use?
            skywatchS 1 Reply Last reply
            • dbemowskD dbemowsk
              skywatchS
              skywatchS
              skywatch
              @dbemowsk If the heating element is inductive you will have some inrush current. But most are resistive so I'd try either a 3A fast blow or a 1A anti surge.
              • pihomeP pihome
                as title says can anyone recommend soldering station for smd components, i m checking on amazon but very hard to decide tons of options so what i need to look for and any preference experience you would have?
                bjacobseB
                bjacobseB
                bjacobse
                @pihome
                You need something that have IR underheat, to heat up your PCB from underneath,
                so your hotairgun easily melt solderpaste and don't blow your IC away :-)
                • pihomeP
                  pihomeP
                  pihome
                  @skywatch great video and thank you for sharing,
                  @bjacobse i was thinking something similar to preheat pcb and solder with very low airflow from hotairgun
                  • James LandryJ
                    James LandryJ
                    James Landry
                    The Weller WLC100 is one of top rated soldering stations for light soldering work. This set is a lightweight and quality product for general soldering projects. In fact, it comes with a soldering station, copper ti, iron holder, and cleaning pad for convenient use.
                    • Ethan ChuaE
                      Ethan ChuaE
                      Ethan Chua
                      Hi there,
                      I have been using this cheap one and it has been working quite well! However, I recently saw this hotplate reflow station and I think with a proper stencil / fine solder paste needle it would be miles better than using a hot air gun (after being burned countless times from having to hold the SMD pieces with a tweezer while blowing). Will try building one (albeit shorter as I want it to fit under my electronics microscope) and will let y'all have a look once it's done!
