  3. ENC28J60 Ethernet Shield HA reporting !GWT:TSA:ETH FAIL
homeassistantethernetgatewayenc28j60
5 Posts 2 Posters 815 Views 2 Watching
  • Ethan ChuaE
    Ethan ChuaE
    Ethan Chua
    wrote on last edited by Ethan Chua
    Hi there,
    Recently I tried building a RF24 MySensors Ethernet Gateway using a ENC28J60 Nano shield. I had to remap all of the SPI pins of the NRF24L01 (unlike this guide) as the ENC28J60 shield was not playing nice while sharing the MOSI,MISO and SCK pins of the RF24.
    RF24 Pins:
    Pin | From IO | To IO
    CE 9 5
    CS 10 6
    MOSI 11 9
    MISO 12 8
    SCK 13 3
    IRQ 2 2 (no change)
    This was based off this guide which stated that only D10,11,12 & 13 were used for these ENC28J60 nano ethernet shields.
    However now the issue is that although the Ethernet Shield can connect to the network (I can see it's IP on my router dashboard and successfully ping that IP), MY_DEBUG keeps throwing !GWT:TSA:ETH FAIL errors and adding the Gateway to HA has been unsuccessful:
    Here is my Gateway Arduino Sketch:
     * Version 1.0 - Henrik EKblad
     * LED purposes:
    #define MY_RADIO_RF24
    // When ENC28J60 is connected we have to move CE/CSN pins for NRF radio
    #define MY_SOFTSPI
    #define MY_SOFT_SPI_SCK_PIN 3
    #define MY_SOFT_SPI_MISO_PIN 8
    #define MY_SOFT_SPI_MOSI_PIN 9
    #define MY_RF24_CE_PIN 5
    #define MY_RF24_CS_PIN 6
    #define MY_GATEWAY_ENC28J60
    // Gateway IP address
    #define MY_IP_ADDRESS 192,168,0,167
    #define MY_PORT 5003
    #define MY_CONTROLLER_IP_ADDRESS 192,168,0,153
    // Set blinking period
    // Enable inclusion mode
    #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  4  // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN  3  // the PCB, on board LED
    #include <UIPEthernet.h>
    A snippet from my config.yaml:
    mysensors:
      gateways:
        - device: '/dev/ttyUSB0'
          persistence_file: 'mysensors/mysensors.json'
          baud_rate: 115200
        - device: '192.168.0.167'
          persistence_file: 'mysensors/mysensors1.json'
          tcp_port: 5003
      optimistic: false
      persistence: true
      version: 2.3.2
    And the MY_DEBUG logs:
    0 MCO:BGN:INIT GW,CP=RNNGA---,FQ=16,REL=255,VER=2.3.2
    4 TSM:INIT
    5 TSF:WUR:MS=0
    12 TSM:INIT:TSP OK
    13 TSM:INIT:GW MODE
    15 TSM:READY:ID=0,PAR=0,DIS=0
    18 MCO:REG:NOT NEEDED
    71 GWT:TIN:IP=192.168.0.167
    1576 !GWT:TIN:ETH FAIL
    1579 MCO:BGN:STP
    1581 MCO:BGN:INIT OK,TSP=1
    2077 !GWT:TSA:ETH FAIL
    2079 TSM:READY:NWD REQ
    2084 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    2576 !GWT:TSA:ETH FAIL
    3077 !GWT:TSA:ETH FAIL
    3079 TSF:MSG:READ,1-1-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
    3576 !GWT:TPS:ETH FAIL
    3578 TSF:MSG:READ,0-1-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
    3584 TSF:MSG:BC
    4077 !GWT:TSA:ETH FAIL
    4576 !GWT:TSA:ETH FAIL
    5076 !GWT:TSA:ETH FAIL
    5577 !GWT:TSA:ETH FAIL
    6076 !GWT:TSA:ETH FAIL
    6577 !GWT:TSA:ETH FAIL
    7076 !GWT:TSA:ETH FAIL
    7579 !GWT:TSA:ETH FAIL
    8076 !GWT:TSA:ETH FAIL
    8577 !GWT:TSA:ETH FAIL
    Other things I have tried:
    • Swapping out RF24 boards (but from the MY_DEBUG logs it seems the RF24 is not the problem)
    • Downgrading the AVR Boards to 1.6.11 as per this guide but failed as the sketch failed to compile. Error: multiple libraries found for SPI.h.
    • Powering the board via a external power supply
    • Tried both UIPEthernet Libraries (the one from MySensorsArduinoExamples and the one from ntruchsess
    Perhaps it could be that the sketch occupies 80% of storage (with MY_DEBUG)? I am on the verge of just giving up with this problematic setup and use ESP8266 MQTT instead.
    I would like to hear from anyone who has tried a similar setup! Thanks!
    • Ethan ChuaE
      Ethan ChuaE
      Ethan Chua
      After seeing this thread I think I will just give up on this ENC28J60 and get a W5500 instead.
      • Ethan ChuaE Ethan Chua
        @Ethan-Chua I have never used Home Assistant, but it looks like the configuration tells HA to connect to a MySensors gateway server at 192.168.0.167 while the gateway is configured to start as a client and connect to a server at 192.168.0.153. So there are 2 clients, each trying to connect to a server that doesn't exist.
        If that's the case, removing this part should make the connection work:
        Ethan ChuaE 1 Reply Last reply
          Ethan ChuaE
          Ethan ChuaE
          Ethan Chua
          @mfalkvidd said in ENC28J60 Ethernet Shield HA reporting !GWT:TSA:ETH FAIL:
          Ok I must have misunderstood the meaning of MY_CONTROLLER_IP_ADDRESS. Will try and see how it goes.
          UPDATE: It works now thanks @mfalkvidd for your help!
            Great work @Ethan-Chua, thanks for reporting back.
