  3. MyController.org
  4. Fields Mysensors
Fields Mysensors
Scheduled Pinned Locked Moved MyController.org
9 Posts 2 Posters 1.1k Views 2 Watching
  • J
    J
    JeeLet
    wrote on last edited by JeeLet
    Hello
    discovering MyController2
    I'm trying to understand how to get the data back
    of Mysensors in the dashboard.
    the question is :
    how to differentiate my sensors in the Widgets?
    in the example of the pdf file https://nsmf01.casimages.com/f/2022/03/24//2203240203102387089992.pdf
    I have two V_TEMP and two V_HUM
    a test by renaming Name :V_TEMP to V_TEMP1 gave nothing, TEMP1 comes back as TEMP
    in short it is the fog
    how do we use the labels?
    I didn't find any doc on the subject with Mysensors
    • J
      J
      JeeLet
      I found it ;)
      in Resource Filters
      Key : sourceid
      Value : 2
      (I update my pdf)
      yeah the doc on the use of
      "Resource Filters" with "Key" "Value"
      values would be nice
      it's really a pity that you can't modify your previous post, too short delay, minimum one month :)
      • J
        J
        JeeLet
        Hello
        a tutorial / help for the structure
        (the skeleton) of a MySensors sketch.
        to go back automatically to MyController
        the nodes and sensors
        here is an example in image (pdf)
        texte du lien
        and the sketch (Mysensors parts only )
        // ------ Mysensors V2 ------- //
          #define MY_NODE_ID 32   /*Node ID static*/
          #define CHILD_ID_R 3    /*Id  Relay*/
          #define CHILD_ID_B 4    /*Id  Door*/
          MyMessage msg(CHILD_ID_R,V_STATUS);
          MyMessage msg1(CHILD_ID_B,V_TRIPPED);
          void setup() { .... }
          void presentation()   {
          sendSketchInfo("DiDo node 32", "2.0");  /* version sketch*/
        //Mysenors save Child and Gw
          present(CHILD_ID_R, S_BINARY);  /*output digital*/
          present(CHILD_ID_B, S_DOOR);    /*input digital*/
          request(CHILD_ID_R, V_STATUS);    /*request value of the controller*/
          request(CHILD_ID_B, V_STATUS);
         void loop()  { ...
        //  send(msg.set(value==HIGH ? 1 : 0));      /*Relay
            send(msg1.set(value==HIGH ? 1 : 0));     /*Door
        void receive(const MyMessage &message)  {
           if (message.type == V_STATUS)
           state = message.getBool ();
           digitalWrite(RELAY_PIN, state?RELAY_ON:RELAY_OFF);  /*Change relay state*/
           if (message.getType()==V_STATUS)
           //digitalWrite(message.getSensor() - RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
        a question : I don't understand the use of
        "message.getType" and "message.getBool" ?
        one instruction too many ??
        thanks
        J 1 Reply Last reply
        • J JeeLet
          Hello
          texte du lien
           void loop()  { ...
          thanks
          J
          J
          jkandasa
          @JeeLet can you add send(msg.set(value==HIGH ? 1 : 0)); // Relay in your setup(){} function?
          • message.getType - returns the type of the message. you can see different types in https://www.mysensors.org/download/serial_api_20 under set, req
          • message.getBool - returns the boolean value of your payload. MySensors sends and receives all the payload in string format. in the arduino sketch with this different type of get functions you can get exact payload without additional steps. more details on https://www.mysensors.org/apidocs/classMyMessage.html
          • J
            J
            JeeLet
            Hello jkandasa
            I spent the day on the Mysensors website copying/translating some parts of the "serial_api_20" doc
            (I have no more eyes :) )
            yes I will add it soon
            you mas understood, I try to write well the code of the sckech
            so that MyCrontroller goes up cleanly the sensors :)
            Merci
            • J
              J
              JeeLet
              exit status 1 : 'value' was not declared in this scope
              but why in the setup ?
              you have to put it in Loop () ?
              //-----------Mars.2022------- Node 32 --------- MySensors DI DO MyController -----------------//
                // #define MY_DEBUG                  /*Enable debug prints to serial monitor*/
                //  #define   MY_DEBUG_OTA_DISABLE_ECHO  //envoyer des messages sans demander à la destination de renvoyer le message
              // Mysensors advanced settings
                //  #define MY_TRANSPORT_WAIT_READY_MS 3000 /*Tempo d'attente de mis en Com, des millisecondes - à placer avant Mysensors.h*/
                //  #define  MY_SPLASH_SCREEN_DISABLED /*désactive écran de démarrage MySensors (économie 120oct. en flash)*/
                  #define MY_NODE_ID 32                   /*Node en ID static*/
              /* ----- Module TTL-RS485 ----*/
                #define MY_RS485                  /*Apl du transport RS485 (protocol?)*/
                #define MY_RS485_DE_PIN 2         /*Cmd DE pin*/
                #define MY_RS485_BAUD_RATE 9600   /*Set RS485 baud rate to use*/
                #define MY_REPEATER_FEATURE       /*Activer fonctionnalité de répéteur du nœud*/
              // ------ objet ------
                #define RELAY_PIN   7    /*Pin Relay-DO*/
                #define BBUTTON_PIN 6    /*Pin boton-DI*/
                #define CHILD_ID_R 3    /*Id du Relay*/
                #define CHILD_ID_B 4    /*Id du bouton poussoir*/
                #define RELAY_ON 1
                #define RELAY_OFF 0
              //----- Instancier objet Bounce ------
                  Bounce debouncer = Bounce();
                  int oldValue=0;
                  bool state;
              // ------ Mysensors -------
                MyMessage msg(CHILD_ID_R,V_STATUS);   /*Relay*/
                MyMessage msg1(CHILD_ID_B,V_TRIPPED);  /*Boton*/
               void setup()  {
                  pinMode (RELAY_PIN,OUTPUT);         /*config pin relay*/
                  digitalWrite(RELAY_PIN, RELAY_OFF); /*désactive Relay au démarrage*/
                  pinMode(BBUTTON_PIN,INPUT_PULLUP) ;   /*Configure Pin en input et Active pull-up interne*/
                  debouncer.attach(BBUTTON_PIN);        /*configurez l'instance Bounce*/
                  debouncer.interval(5);                /*interval in ms*/
                sendSketchInfo("DiDo node 32", "2.0");  /*info version sketch à la passerelle*/
              /*Mysenors Enregistre Child and Gw*/
                present(CHILD_ID_R, S_BINARY);    /*Relay*/
                present(CHILD_ID_B, S_DOOR);      /*Boton*/
              /* requetes/demandes à un noeud ou GW une variable*/
                request(CHILD_ID_R, V_STATUS);   /*Relay*/
                request(CHILD_ID_B, V_STATUS);  /*Boton*/
               void loop()  {
              /*Vérifie un changement d'etat sur les entrées numérique et envoye la nouvelle valeur*/
                  debouncer.update();             /*Update the Bounce instances*/
                  int value = debouncer.read();   /*Get the updated value*/
              /*Relay*/
              //    if (valueR != oldValueR) {
              //    send(msg.set(valueR==HIGH ? 1 : 0));   /*Envoyer la nouvelle valeur*/
              //    Serial.println ("Changement d'etat bouton A");
              //    oldValueR = valueR;
              /*bouton*/
                  if (value != oldValue) {
                   send(msg1.set(value==HIGH ? 1 : 0));    // Envoyer la nouvelle valeur
                   Serial.println ("Changement d'etat bouton ");
                   oldValue = value;
                // attente qu'un seul type de message du contrôleur , vérifier.
                  if (message.isAck()) {
                  Serial.println("Ceci est un accusé de réception de la passerelle");
                  if (message.type == V_STATUS) //V_STATUS ancien V_LIGHT
                  digitalWrite(RELAY_PIN, state?RELAY_ON:RELAY_OFF);  // Changer l'état du relais
              //if (message.getType()==V_STATUS) {
                  // Change relay state
                //  digitalWrite(message.getSensor() - RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
              // -------------------- END PGM ---------------------------
              • J JeeLet
                  #define RELAY_ON 1
                  #define RELAY_OFF 0
                    int oldValue=0;
                    bool state;
                 void setup()  {
                 void loop()  {
                /*Relay*/
                /*bouton*/
                     oldValue = value;
                J
                J
                jkandasa
                wrote on last edited by jkandasa
                @JeeLet the value, you have to set.
                V_STATUS is not available in MyController, since it is not reported yet.
                adding in setup sends the data only once. If you would like to retain the old status from MyController in your node, remove the send(msg.set(value==HIGH ? 1 : 0)); from your setup and create V_STATUS manually in MyController
                • add new field in Resources >> Fields >> Add,
                • J
                  J
                  JeeLet
                  can be the good solution to put everything back to MyController
                  without doing anything :)
                   bool info;
                  Void setup  {......
                    //info send to gateway
                     send(msg.set(info));
                     send(msgx.set(info)); //pour d'autres
                  to be seen later
                  • J
                    J
                    JeeLet
                    https://forum.mycontroller.org/
                    integration of motioneye in MyC
                    Base OdroidC2/Armbian buster et Cam arducam (libcamera) :clown_face:
