  3. CAN bus transport implementation
54 Posts 5 Posters 8.4k Views 8 Watching
  • J
    J
    JeeLet
    wrote on last edited by JeeLet
    @Adam-Slowik "Can you push your patch to my repository? " .... I don't know how
    On the CAN principle
    @Adam-Slowik "Based on this id, the filters are configured to remove all messages not intended for the current node. This way, if the gateway wants to send a message to the node with id = 51, only the node with that id receives that message." ... yes, that's how I see it.
    another way to say/explain it.
    "The philosophy of CAN is to constitute a messaging system.
    The messages (the letter) send on the CAN Bus (the post office), distributed by the CAN Bus (the letter carrier).
    Each (letter) have each an identifier (stamp of the post ☺ ) that ... identifies it.
    And put in the right mailbox (the MCP2515) according to the choice of filter/mask ( color, scent? ☺ ) of the letter."
    So there are two "stratum" of dialogue / work.
    • one on the Can Bus, and another on the Nodes.
    The idea is to relieve the Nodes of unnecessary work/effort with the risks that this brings. Less letter to open :)
    @Adam-Slowik "... my modules and arduinos are buried in a box in my attic..." ? Arduino 8bit and MySensors is over for you?
    ( if it's a personal / family reason don't say anything )
    • J
      J
      JeeLet
      #21
      I tested my sketch with clock and OLED to see :)
      bah No the time is not up :(
      I give this information for an overview, it can help for the continuation (but not to give you work :) )
      The listing of the messages of mySensors
      test with "void receiveTime" function (without RTC clock)
      https://forum.mysensors.org/topic/4809/real-time-clock-module-lcd-display-and-controller-time/8?_=1655208396048
      ..........Log MyC - terminal ssh  .........
      2022-06-14T14:01:45.115+0200	recd	0;255;3;0;9;65310350 TSF:MSG:READ,55-55-0,s=255,c=3,t=1,pt=0,l=0,sg=0:
      2022-06-14T14:01:45.119+0200	recd	0;255;3;0;9;65310356 TSF:MSG:ECHO REQ
      2022-06-14T14:01:45.127+0200	recd	0;255;3;0;9;65310360 TSF:MSG:SEND,0-0-55-55,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
      2022-06-14T14:01:45.127+0200	recd	55;255;3;0;1;
      2022-06-14T14:01:45.146+0200	sent	55;255;3;0;1;1655215305
      2022-06-14T14:01:45.160+0200	recd	0;255;3;0;9;65310394 TSF:MSG:SEND,0-0-55-55,s=255,c=3,t=1,pt=0,l=10,sg=0,ft=0,st=OK:1655215305
      ..........Log MyS - terminal IDE .........
           time current:0   -------------------------------------------
      58007 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
      58017 TSF:MSG:READ,0-0-55,s=255,c=3,t=1,pt=0,l=0,sg=0:
      58022 TSF:MSG:ECHO
      avec Bus RS485
      2022-06-14T14:22:41.265+0200	recd	0;255;3;0;9;72000090 TSF:SAN:OK
      2022-06-14T14:22:41.274+0200	recd	0;255;3;0;9;72000096 TSM:READY:NWD REQ
      2022-06-14T14:22:41.298+0200	recd	0;255;3;0;9;72000115 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
      2022-06-14T14:22:41.917+0200	recd	0;255;3;0;9;72000736 TSF:MSG:READ,22-22-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
      2022-06-14T14:22:41.920+0200	recd	22;255;3;0;21;0
         time current:1422   -------------------------------------------
      423956 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=1,l=1,sg=0:0
      423962 TSF:MSG:BC
      424008 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
         requestOn-----------------------------------------
      • Adam SlowikA
        Adam SlowikA
        Adam Slowik
        @JeeLet said in CAN bus transport implementation:
        No it is not over. Right now I don't have enough time. Now I am able to work for let's say 1 hour per week. Probably I will become more active at the end of 2023 :D
        Here You posted RS485 version:
        Could You post here CAN version?
        • J
          J
          JeeLet
          #23
          @Adam-Slowik "Could you post the CAN version here?"
          it's the same, except that the bus is not rs485 but CAN :)
          #define MY_NODE_ID 55          /*Node en ID static*/
            #define MY_CAN
            #include "SSD1306Ascii.h"
          but I'll go back to PaulStoffregen's Lib <TimeLib.h> to see if I can simplify the basic sketch of MySensors
          • Adam SlowikA
            Adam SlowikA
            Adam Slowik
            In previous example (with diodes) did You set CAN_CLOCK to MCP_16MHZ?
            • J
              J
              JeeLet
              #25
              no it stayed on 8Mhz ?
              I didn't modify anything (the other sketches work)
              But I just looked at the quartz and it's 16M!! (SW-65-16M)
              I am lost :(
              https://www.gotronic.fr/art-module-bus-can-sbc-can01-28405.htm
              but on the doc there is :
              The 8000000 stands that the MCP2515 operates with a clock of 8 MHz. This
              depends on the quartz used and may need to be adjusted.
              error
              on the official doc it's a 16Mhz like mine.
              • https://www.joy-it.net/en/products/SBC-CAN01
                OSCILLATOR 16 MHz Crystal Oscillator
              so 8Mhz or 16Mhz?
              and why does it work with the previous sketches?
              • J
                J
                JeeLet
                #26
                I think the dialogue is good
                but the problem is the length of the storyline
                a part of the dialog on the IDE terminal for both types
                CAN and RS485
                   - IDE terminal sur RS485 :
                4066 TSF:MSG:ECHO
                4132 TSF:MSG:READ,0-0-22,s=255,c=3,t=1,pt=0,l=10,sg=0:1655285320
                8018 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                8054 TSF:MSG:READ,0-0-22,s=255,c=3,t=1,pt=0,l=0,sg=0:
                8058 TSF:MSG:ECHO
                8111 TSF:MSG:READ,0-0-22,s=255,c=3,t=1,pt=0,l=10,sg=0:1655285324
                  newTime:1655285324   -------------------------------------------
                  - IDE terminal sur CAN :
                22224 MCO:REG:REQ
                22226 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                22233 !MCO:PRO:RC=1
                22235 TSF:MSG:READ,0-0-55,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                22240 MCO:PIM:NODE REG=1
                28004 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                28014 TSF:MSG:READ,0-0-55,s=255,c=3,t=1,pt=0,l=0,sg=0:
                28019 TSF:MSG:ECHO
                  newTime:0   -------------------------------------------
                sketch
                void receiveTime(unsigned long controllerTime)   {
                    if (receiveTime) stateCom = true ; else stateCom = false;
                      newTime = controllerTime;
                Serial.print("  newTime:"); Serial.print(newTime);
                • J
                  J
                  JeeLet
                  #27
                  frequency change
                  with 16Mhz I have a NACK
                  // #define CAN_CLOCK MCP_16MHZ
                  105 TSM:FPAR
                  18107 ?TSF:MSG:SEND,55-55-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=4,st=NACK:
                  20115 !TSM:FPAR:NO REPLY
                  20117 TSM:FPAR
                  20119 ?TSF:MSG:SEND,55-55-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=5,st=NACK:
                  // #define CAN_CLOCK MCP_8MHZ
                  28019 TSF:MSG:ECHO
                  38005 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                  38016 TSF:MSG:READ,0-0-55,s=255,c=3,t=1,pt=0,l=0,sg=0:
                  https://forum.arduino.cc/t/how-to-set-the-mhz-in-mcp2515-library-file-based-on-crystal-oscillator/628822
                  • J
                    J
                    JeeLet
                    in the sketch I added lines to visualize the buffer data
                    a part of I recopied
                    log IDE :
                       Extended ID: 0x0410FF00  DLC: 8  Data: 0x00 0x00 0xFF 0x0A 0x23 0x14 0xFF 0x00
                    88010 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                    Extended ID: 0x05103700  DLC: 7  Data: 0x00 0x00 0x37 0x02 0x13 0x01 0xFF
                    Extended ID: 0x06303700  DLC: 8  Data: 0x00 0x00 0x37 0x52 0x03 0x01 0xFF 0x31
                    I stop for me, I pause for 1 day or 2 :)
                    • Adam SlowikA
                      Adam SlowikA
                      Adam Slowik
                      I found a bug in my code. Please re-download new version.
                      If something won't work please enable CAN debug by adding:
                      #define MY_DEBUG_VERBOSE_CAN
                      add this to gateway and to node sketch
                      • J
                        J
                        JeeLet
                        #30
                        #define MY_DEBUG_VERBOSE_CAN .....yes yes I already tested it, it's very good.
                        (a very useful function)
                        ..go to
                        • Reloading the CAN-MyS update
                        • ClearEeprom of the GW and Nodes
                        • Reloading of Sketches on GW and Nodes
                        Bravo :woman-lifting-weights:
                        • sendSketchInfo(" text ...."); and well up
                        • requestTime(receiveTime); and functional
                        Ahhhhhh Lovely this is great :rainbow:
                        I offer the coffee crossing :croissant: :coffee:
                        (what was the problem ??? )
                        After the test on the Digital I/O of the Nodes ,
                        now I test the Analog I/O
                        a Super Thank You @Adam-Slowik
                        :+1:
                        • J
                          J
                          JeeLet
                          #31
                          a test with DHT22 probes.
                          the values go up well on MyC
                          real decimal values :)
                          here is a screen shot
                          big vue
                          I have to find another type of probes, the DHT22 give me losses, or my sketch is to review
                          ReEdit
                          error :angry:
                          I got excited too fast
                          the values are not refreshed.
                          I look better :eyeglasses:
                          ReRe-edition
                          I made a mistake, as I play a little too much with MyController, I add and remove gateways from nodes and other salads.
                          and well in the end it makes no sense ;)
                          I cleaned up the Yaml files of MyC and it's better :)
                          • Adam SlowikA
                            Adam SlowikA
                            Adam Slowik
                            Previous messages used 7 bytes long payload. Single CAN frame is able to transfer 8 bytes. So all messages was contained in single frame. Example with time, used 17 (!) bytes long payload. In order to transfer 17 bytes there is need to split data to 3 messages (8+8+1). Next in the other side of wire You have to concat it. This mechanism of splitting and concating had a bug. For details check last 3 commits (at the bottom)
                            https://github.com/mysensors/MySensors/compare/development...AdamSlowik:development
                            • J
                              J
                              JeeLet
                              #33
                              Gateway Logs on MyController
                              (CAN Bus and RS485 Bus)
                              two separate files
                              CAN log
                              RS485 log
                              files split in parts :
                              A : gateways startup
                              B : reboot of the gateways
                              C : launch of MyClock Nodes (id23 and id55)
                              D ; periodic refresh requestTime(receiveTime)
                              E ; send value (1700 and 2100)
                              (I have prepared the work for you to read)
                              a 1st analysis
                              • (at the bottom of the listing, the sending of values "1700 or 2100" with MyC)
                                The RS485 bus dialogues much more, the CAN bus is more timid :)
                              Adam Slowik bravo
                              I test what now???
                              the ACK ??
                              Oh yes, I have to check the disconnection of the nodes.
                              The Gateway gives me the impression that the information does not go back to MyC if a Node is off ???
                              • Adam SlowikA
                                Adam SlowikA
                                Adam Slowik
                                I test what now???
                                I was at similar position some time ago:
                                @Adam-Slowik said in CAN bus transport implementation:
                                Any suggestion what to test next?
                                I have no idea what to test next. I do not use MySensors. I hope this will change in the future, but as of now I'm a newbie.
                                If You won't get any advice from more experienced users I would suggest to do some long running test to see if it's stable. If it's stable try to use it in some real use cases.
                                If You find any bugs in transmission layer post logs here. I will do My best to support CAN, because I will need it in a future.
                                • J
                                  J
                                  JeeLet
                                  " I would suggest doing a long term test to see if it is stable." yes I will stress it to see the weakness
                                  ".. If it is stable, try to use it in real use cases." yes that's the point
                                  One last question
                                  I'm going from 8Mhz to 16Mhz (in development/MyConfig.h on line 306)
                                  question: can you explain how I can bring up in the sketch the parameters that are related to the MCP_CAN_lib library
                                  it should not be complicated for me :) it is only text to insert ???
                                  an example with the #define CAN_CLOCK MCP_8MHZ
                                  Thanks Adam Slowik
                                  • Adam SlowikA
                                    Adam SlowikA
                                    Adam Slowik
                                    In My opinion You should not override MyConfig.h. If You want to go for 16MHz You should put:
                                    in Your sketch. Preferably somewhere around line:
                                    #define MY_CAN
                                    If it's a parameter that is listed in MyConfig.h simply define it like 'CAN_CLOCK'. If parameter is not listed in MyConfig please let me know exactly what parameter You would like to modify, then I will try to figure it out.
                                    • J
                                      J
                                      JeeLet
                                      #37
                                      I just did the test, switch to 16Mhz in the file MyConfig.h
                                      it works well, I have no error
                                      I didn't think it was possible, is it incompatible?
                                      overwritten the values of the file MyConfig.h
                                      thank you for the information
                                      • Adam SlowikA
                                        Adam SlowikA
                                        Adam Slowik
                                        I'm not sure if We understood each other. This line #define CAN_CLOCK MCP_16MHZ should be in Your sketch. You should not modify MyConfig.h.
                                        Libraries (in general not only MySensors) should not be modified. MyConfig.h is part of library.
                                        Let's take a look at this code from MyConfig.h
                                        #ifndef CAN_CLOCK
                                        #endif.
                                        This is if statement. If user didn't defined CAN_CLOCK define it as CAN_CLOCK MCP_8MHZ
                                        If user defined (in sketch) CAN_CLOCK then do nothing.
                                        So You can treat MyConfig.h as a set of defaults which can be overridden from sketch.
                                        I have put all relevant (in My opinion) properties from MCP_CAN_lib into MyConfig.h, so You can override them. If I have missed some relevant property please let Me know.
                                        • J
                                          J
                                          JeeLet
                                          #39
                                          Thank you for this clarification.
                                          (yes translator and my neuron it gives crooked dialog)
                                          "If I have missed a relevant property, please let me know."
                                          The list of #define go up for the MySensors sketch .
                                          ( if I'm not mistaken ?)
                                          ***for MCP_CAN_lib **************** MyConfig.h line 280 to 315
                                          CAN_INT // Pin for interrupting an incoming message.
                                          CAN_CS // Chip selection pin.
                                          CAN_SPEED // Transmission speed. The allowed values can be found in mcp_can_dfs.h
                                          CAN_CLOCK // Can clock. Allowed values can be found in mcp_can_dfs.h.
                                          CAN_BUF_SIZE // Assembly buffer size. As long messages can be split and arrive mixed with other messages, an assembly buffer is needed.
                                          **** for MyS **************** MyConfig.h line 2492 to 2494
                                            MY_CAN // Set this to use the CAN wire transport for sensor network communication.
                                          MY_DEBUG_VERBOSE_CAN // Set this for verbose debugging printouts related to the %CAN driver.
                                          can be added, for testing and controlling the CAN bus
                                          #define CAN_MSGAVAIL
                                          #define CAN_OK
                                          #define CAN_CTRLERROR
                                          return of the last 24 hours .
                                          CAN bus no error, good dialogue, no hole in the measurements and commands.
                                          the hardware base on the bus is :
                                          gateway + node 55 + node 56 .
                                          I will add another node 57.
                                          I think to go until 6 nodes
