  3. CAN bus transport implementation
54 Posts 5 Posters 8.4k Views 8 Watching
  • J
    J
    JeeLet
    wrote on last edited by JeeLet
    "Can you provide logs (gateway/node) from the reset scenario. It would be great to have these logs for RS485 and CAN so I can compare them."
    listing
    Released today 2 gateways connect to MyController
    • UNO_usb - Gateway and RS485 bus
    • UNO_usb - Gateway and CAN Bus
    with connect, a UNO with the basic sketch "RelayWithButtonActuator_base.ino" (slightly modified)
    with ... a Led and a Switch, for each bus.
    The Listing split in several parts
    "Log of the IDE and MyC for the two types of bus (node34 and node 54), CAN and RS485.
    - Listing Action RESET with MyController
    	2 parts for CAN
    	and
    	2 parts for RS485
    and
    - Listing Action On/Off on the node switch or with MyController
    	4 parts for CAN
    	and
    	4 parts for RS485
    No error on the Reset, it works fine, an error from me.
    Oh yes, I even found an error :)
    the sendSketchInfo("test xxxxx", "1.0"); is not up
    see the end of the video
    video
    ....I will answer the other question tomorrow.
    • J
      J
      JeeLet
      @Adam-Slowik "Can you push your patch to my repository? " .... I don't know how
      On the CAN principle
      @Adam-Slowik "Based on this id, the filters are configured to remove all messages not intended for the current node. This way, if the gateway wants to send a message to the node with id = 51, only the node with that id receives that message." ... yes, that's how I see it.
      another way to say/explain it.
      "The philosophy of CAN is to constitute a messaging system.
      The messages (the letter) send on the CAN Bus (the post office), distributed by the CAN Bus (the letter carrier).
      Each (letter) have each an identifier (stamp of the post ☺ ) that ... identifies it.
      And put in the right mailbox (the MCP2515) according to the choice of filter/mask ( color, scent? ☺ ) of the letter."
      So there are two "stratum" of dialogue / work.
      • one on the Can Bus, and another on the Nodes.
      The idea is to relieve the Nodes of unnecessary work/effort with the risks that this brings. Less letter to open :)
      @Adam-Slowik "... my modules and arduinos are buried in a box in my attic..." ? Arduino 8bit and MySensors is over for you?
      ( if it's a personal / family reason don't say anything )
      • J
        J
        JeeLet
        #21
        I tested my sketch with clock and OLED to see :)
        bah No the time is not up :(
        I give this information for an overview, it can help for the continuation (but not to give you work :) )
        The listing of the messages of mySensors
        test with "void receiveTime" function (without RTC clock)
        https://forum.mysensors.org/topic/4809/real-time-clock-module-lcd-display-and-controller-time/8?_=1655208396048
        ..........Log MyC - terminal ssh  .........
        2022-06-14T14:01:45.115+0200	recd	0;255;3;0;9;65310350 TSF:MSG:READ,55-55-0,s=255,c=3,t=1,pt=0,l=0,sg=0:
        2022-06-14T14:01:45.119+0200	recd	0;255;3;0;9;65310356 TSF:MSG:ECHO REQ
        2022-06-14T14:01:45.127+0200	recd	0;255;3;0;9;65310360 TSF:MSG:SEND,0-0-55-55,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
        2022-06-14T14:01:45.127+0200	recd	55;255;3;0;1;
        2022-06-14T14:01:45.146+0200	sent	55;255;3;0;1;1655215305
        2022-06-14T14:01:45.160+0200	recd	0;255;3;0;9;65310394 TSF:MSG:SEND,0-0-55-55,s=255,c=3,t=1,pt=0,l=10,sg=0,ft=0,st=OK:1655215305
        ..........Log MyS - terminal IDE .........
             time current:0   -------------------------------------------
        58007 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
        58017 TSF:MSG:READ,0-0-55,s=255,c=3,t=1,pt=0,l=0,sg=0:
        58022 TSF:MSG:ECHO
        avec Bus RS485
        2022-06-14T14:22:41.265+0200	recd	0;255;3;0;9;72000090 TSF:SAN:OK
        2022-06-14T14:22:41.274+0200	recd	0;255;3;0;9;72000096 TSM:READY:NWD REQ
        2022-06-14T14:22:41.298+0200	recd	0;255;3;0;9;72000115 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
        2022-06-14T14:22:41.917+0200	recd	0;255;3;0;9;72000736 TSF:MSG:READ,22-22-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
        2022-06-14T14:22:41.920+0200	recd	22;255;3;0;21;0
           time current:1422   -------------------------------------------
        423956 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=1,l=1,sg=0:0
        423962 TSF:MSG:BC
        424008 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
           requestOn-----------------------------------------
        • Adam SlowikA
          Adam SlowikA
          Adam Slowik
          @JeeLet said in CAN bus transport implementation:
          No it is not over. Right now I don't have enough time. Now I am able to work for let's say 1 hour per week. Probably I will become more active at the end of 2023 :D
          Here You posted RS485 version:
          Could You post here CAN version?
          • J
            J
            JeeLet
            #23
            @Adam-Slowik "Could you post the CAN version here?"
            it's the same, except that the bus is not rs485 but CAN :)
            #define MY_NODE_ID 55          /*Node en ID static*/
              #define MY_CAN
              #include "SSD1306Ascii.h"
            but I'll go back to PaulStoffregen's Lib <TimeLib.h> to see if I can simplify the basic sketch of MySensors
            • Adam SlowikA
              Adam SlowikA
              Adam Slowik
              In previous example (with diodes) did You set CAN_CLOCK to MCP_16MHZ?
              • J
                J
                JeeLet
                #25
                no it stayed on 8Mhz ?
                I didn't modify anything (the other sketches work)
                But I just looked at the quartz and it's 16M!! (SW-65-16M)
                I am lost :(
                https://www.gotronic.fr/art-module-bus-can-sbc-can01-28405.htm
                but on the doc there is :
                The 8000000 stands that the MCP2515 operates with a clock of 8 MHz. This
                depends on the quartz used and may need to be adjusted.
                error
                on the official doc it's a 16Mhz like mine.
                • https://www.joy-it.net/en/products/SBC-CAN01
                  OSCILLATOR 16 MHz Crystal Oscillator
                so 8Mhz or 16Mhz?
                and why does it work with the previous sketches?
                • J
                  J
                  JeeLet
                  #26
                  I think the dialogue is good
                  but the problem is the length of the storyline
                  a part of the dialog on the IDE terminal for both types
                  CAN and RS485
                     - IDE terminal sur RS485 :
                  4066 TSF:MSG:ECHO
                  4132 TSF:MSG:READ,0-0-22,s=255,c=3,t=1,pt=0,l=10,sg=0:1655285320
                  8018 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                  8054 TSF:MSG:READ,0-0-22,s=255,c=3,t=1,pt=0,l=0,sg=0:
                  8058 TSF:MSG:ECHO
                  8111 TSF:MSG:READ,0-0-22,s=255,c=3,t=1,pt=0,l=10,sg=0:1655285324
                    newTime:1655285324   -------------------------------------------
                    - IDE terminal sur CAN :
                  22224 MCO:REG:REQ
                  22226 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                  22233 !MCO:PRO:RC=1
                  22235 TSF:MSG:READ,0-0-55,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  22240 MCO:PIM:NODE REG=1
                  28004 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                  28014 TSF:MSG:READ,0-0-55,s=255,c=3,t=1,pt=0,l=0,sg=0:
                  28019 TSF:MSG:ECHO
                    newTime:0   -------------------------------------------
                  sketch
                  void receiveTime(unsigned long controllerTime)   {
                      if (receiveTime) stateCom = true ; else stateCom = false;
                        newTime = controllerTime;
                  Serial.print("  newTime:"); Serial.print(newTime);
                  • J
                    J
                    JeeLet
                    #27
                    frequency change
                    with 16Mhz I have a NACK
                    // #define CAN_CLOCK MCP_16MHZ
                    105 TSM:FPAR
                    18107 ?TSF:MSG:SEND,55-55-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=4,st=NACK:
                    20115 !TSM:FPAR:NO REPLY
                    20117 TSM:FPAR
                    20119 ?TSF:MSG:SEND,55-55-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=5,st=NACK:
                    // #define CAN_CLOCK MCP_8MHZ
                    28019 TSF:MSG:ECHO
                    38005 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                    38016 TSF:MSG:READ,0-0-55,s=255,c=3,t=1,pt=0,l=0,sg=0:
                    https://forum.arduino.cc/t/how-to-set-the-mhz-in-mcp2515-library-file-based-on-crystal-oscillator/628822
                    • J
                      J
                      JeeLet
                      in the sketch I added lines to visualize the buffer data
                      a part of I recopied
                      log IDE :
                         Extended ID: 0x0410FF00  DLC: 8  Data: 0x00 0x00 0xFF 0x0A 0x23 0x14 0xFF 0x00
                      88010 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                      Extended ID: 0x05103700  DLC: 7  Data: 0x00 0x00 0x37 0x02 0x13 0x01 0xFF
                      Extended ID: 0x06303700  DLC: 8  Data: 0x00 0x00 0x37 0x52 0x03 0x01 0xFF 0x31
                      I stop for me, I pause for 1 day or 2 :)
                      • Adam SlowikA
                        Adam SlowikA
                        Adam Slowik
                        I found a bug in my code. Please re-download new version.
                        If something won't work please enable CAN debug by adding:
                        #define MY_DEBUG_VERBOSE_CAN
                        add this to gateway and to node sketch
                        • J
                          J
                          JeeLet
                          #30
                          #define MY_DEBUG_VERBOSE_CAN .....yes yes I already tested it, it's very good.
                          (a very useful function)
                          ..go to
                          • Reloading the CAN-MyS update
                          • ClearEeprom of the GW and Nodes
                          • Reloading of Sketches on GW and Nodes
                          Bravo :woman-lifting-weights:
                          • sendSketchInfo(" text ...."); and well up
                          • requestTime(receiveTime); and functional
                          Ahhhhhh Lovely this is great :rainbow:
                          I offer the coffee crossing :croissant: :coffee:
                          (what was the problem ??? )
                          After the test on the Digital I/O of the Nodes ,
                          now I test the Analog I/O
                          a Super Thank You @Adam-Slowik
                          :+1:
                          • J
                            J
                            JeeLet
                            #31
                            a test with DHT22 probes.
                            the values go up well on MyC
                            real decimal values :)
                            here is a screen shot
                            big vue
                            I have to find another type of probes, the DHT22 give me losses, or my sketch is to review
                            ReEdit
                            error :angry:
                            I got excited too fast
                            the values are not refreshed.
                            I look better :eyeglasses:
                            ReRe-edition
                            I made a mistake, as I play a little too much with MyController, I add and remove gateways from nodes and other salads.
                            and well in the end it makes no sense ;)
                            I cleaned up the Yaml files of MyC and it's better :)
                            • Adam SlowikA
                              Adam SlowikA
                              Adam Slowik
                              Previous messages used 7 bytes long payload. Single CAN frame is able to transfer 8 bytes. So all messages was contained in single frame. Example with time, used 17 (!) bytes long payload. In order to transfer 17 bytes there is need to split data to 3 messages (8+8+1). Next in the other side of wire You have to concat it. This mechanism of splitting and concating had a bug. For details check last 3 commits (at the bottom)
                              https://github.com/mysensors/MySensors/compare/development...AdamSlowik:development
                              • J
                                J
                                JeeLet
                                #33
                                Gateway Logs on MyController
                                (CAN Bus and RS485 Bus)
                                two separate files
                                CAN log
                                RS485 log
                                files split in parts :
                                A : gateways startup
                                B : reboot of the gateways
                                C : launch of MyClock Nodes (id23 and id55)
                                D ; periodic refresh requestTime(receiveTime)
                                E ; send value (1700 and 2100)
                                (I have prepared the work for you to read)
                                a 1st analysis
                                • (at the bottom of the listing, the sending of values "1700 or 2100" with MyC)
                                  The RS485 bus dialogues much more, the CAN bus is more timid :)
                                Adam Slowik bravo
                                I test what now???
                                the ACK ??
                                Oh yes, I have to check the disconnection of the nodes.
                                The Gateway gives me the impression that the information does not go back to MyC if a Node is off ???
                                • Adam SlowikA
                                  Adam SlowikA
                                  Adam Slowik
                                  I test what now???
                                  I was at similar position some time ago:
                                  @Adam-Slowik said in CAN bus transport implementation:
                                  Any suggestion what to test next?
                                  I have no idea what to test next. I do not use MySensors. I hope this will change in the future, but as of now I'm a newbie.
                                  If You won't get any advice from more experienced users I would suggest to do some long running test to see if it's stable. If it's stable try to use it in some real use cases.
                                  If You find any bugs in transmission layer post logs here. I will do My best to support CAN, because I will need it in a future.
                                  • J
                                    J
                                    JeeLet
                                    " I would suggest doing a long term test to see if it is stable." yes I will stress it to see the weakness
                                    ".. If it is stable, try to use it in real use cases." yes that's the point
                                    One last question
                                    I'm going from 8Mhz to 16Mhz (in development/MyConfig.h on line 306)
                                    question: can you explain how I can bring up in the sketch the parameters that are related to the MCP_CAN_lib library
                                    it should not be complicated for me :) it is only text to insert ???
                                    an example with the #define CAN_CLOCK MCP_8MHZ
                                    Thanks Adam Slowik
                                    • Adam SlowikA
                                      Adam SlowikA
                                      Adam Slowik
                                      In My opinion You should not override MyConfig.h. If You want to go for 16MHz You should put:
                                      in Your sketch. Preferably somewhere around line:
                                      #define MY_CAN
                                      If it's a parameter that is listed in MyConfig.h simply define it like 'CAN_CLOCK'. If parameter is not listed in MyConfig please let me know exactly what parameter You would like to modify, then I will try to figure it out.
                                      • J
                                        J
                                        JeeLet
                                        #37
                                        I just did the test, switch to 16Mhz in the file MyConfig.h
                                        it works well, I have no error
                                        I didn't think it was possible, is it incompatible?
                                        overwritten the values of the file MyConfig.h
                                        thank you for the information
                                        • Adam SlowikA
                                          Adam SlowikA
                                          Adam Slowik
                                          I'm not sure if We understood each other. This line #define CAN_CLOCK MCP_16MHZ should be in Your sketch. You should not modify MyConfig.h.
                                          Libraries (in general not only MySensors) should not be modified. MyConfig.h is part of library.
                                          Let's take a look at this code from MyConfig.h
                                          #ifndef CAN_CLOCK
                                          #endif.
                                          This is if statement. If user didn't defined CAN_CLOCK define it as CAN_CLOCK MCP_8MHZ
                                          If user defined (in sketch) CAN_CLOCK then do nothing.
                                          So You can treat MyConfig.h as a set of defaults which can be overridden from sketch.
                                          I have put all relevant (in My opinion) properties from MCP_CAN_lib into MyConfig.h, so You can override them. If I have missed some relevant property please let Me know.
