  3. CAN bus transport implementation
54 Posts 5 Posters 8.4k Views 8 Watching
  • Adam SlowikA
    Adam SlowikA
    Adam Slowik
    So I have pull up some config parameters. Those are defined and briefly described in:
    https://github.com/AdamSlowik/MySensors/blob/development/MyConfig.h
    lines 270-315
    You can set those parameters to different values, but for first run I suggest deploy examples without modifications. By examples I mean those 2 files:
    https://github.com/AdamSlowik/MySensors/blob/development/examples/CANSwitch/CANSwitch.ino
    https://github.com/AdamSlowik/MySensors/blob/development/examples/GatewaySerialCAN/GatewaySerialCAN.ino
    If it fails I would set:
    CAN_CLOCK to MCP_16MHZ
    because i think can module from Your vendor uses 16MHz (My used 8MHz)
    filters are set in:
    https://github.com/AdamSlowik/MySensors/blob/development/hal/transport/CAN/MyTransportCAN.cpp
    line 37 method _initFilters()
    without clear reason (eg. bug) I would recommend to not alter it.
    Filters are set to drop messages not intended for certain node. Thanks to this MCU do not have to handle 'spam'.
    If My answer answers Yours questions then great. If this is insufficient ask for a specific parameter or line in code I will try to answer any questions asap
    • J
      J
      JeeLet
      wrote on last edited by JeeLet
      a start of error messages return (on both sketches)
      IDE version 1.8.19
      for CANSwitch.ino
      the message returns me to the line
      MyTransportCAN.cpp --->
      163 : ",TOTAL=%"PRIu8",CURR=%"PRIu8",TO=%"PRIu8",FROM=%"PRIu8"\n"), header, messageId, totalPartCount,
      228 : ",TOTAL=%"PRIu32",CURR=%"PRIu32",TO=%"PRIu32",FROM=%"PRIu32"\n"), rxId, messageId,
      the one copy (a part) of the IDE
      In file included from /home/mci/Arduino/libraries/MySensors-development/MySensors.h:395:0,
                       from /tmp/arduino_modified_sketch_39381/CANSwitch.ino:43:
      /home/Arduino/libraries/MySensors-development/hal/transport/CAN/MyTransportCAN.cpp:163:17: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
      /home/Arduino/libraries/MySensors-development/hal/transport/CAN/MyTransportCAN.cpp:163:32: war......
      /home/Arduino/libraries/MySensors-development/hal/transport/CAN/MyTransportCAN.cpp:228:18: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
      /home/Arduino/libraries/MySensors-development/hal/transport/CAN/MyTransportCAN.cpp:228:34: warni.....
      • J
        J
        JeeLet
        https://sourcecodeartisan.com/2021/03/06/invalid-suffix-on-literal.html
        for the Error code it is
        a requirement in C++ 11 (or later).
        lines 163 and 228 modify and error resolved
        .../hal.transport/CAN/MyTransportCAN.cpp
        CAN_DEBUG(PSTR("CAN:SND:CANH=%" PRIu32 ",ID=%" PRIu8 ",TOTAL=%" PRIu8 ",CURR=%" PRIu8 ",TO=%" PRIu8 ",FROM=%" PRIu8 "\n"), header, messageId, totalPartCount,
        CAN_DEBUG(PSTR("CAN:RCV:CANH=%" PRIu32 ",ID=%" PRIu32 ",TOTAL=%" PRIu32 ",CURR=%" PRIu32 ",TO=%" PRIu32 ",FROM=%" PRIu32 "\n"), rxId, messageId,
        :+1:
        • J
          J
          JeeLet
          a topo of the day
          on the hardware side, I got screwed with an arduino pin that became too soft, too dilated, look for an hour before understanding why no dialog.
          Otherwise, on the Gateway side, no problem, MyController recognized well.
          and CAN_Switch.ino is good too, my Widget on MyC switches well on the switch change.
          listing of the dialog pour le Node 51 (set up in a fixed place )
          coter log from MyC:
          2022-06-11T18:49:35.167+0200	recd	0;255;3;0;9;1482640 TSF:MSG:READ,51-51-0,s=4,c=1,t=16,pt=1,l=1,sg=0:1
          2022-06-11T18:49:35.170+0200	recd	51;4;1;0;16;1
          2022-06-11T18:49:35.179+0200	recd	0;255;3;0;9;1482653 TSF:MSG:READ,51-51-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
          2022-06-11T18:49:35.182+0200	recd	51;255;3;0;21;0
          coter IDE from MyS:
          67889 TSF:MSG:BC
          68197 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
          68203 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
          68208 TSF:MSG:BC
          68836 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
          68843 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
          68848 TSF:TDI:TSL
          68849 MCO:SLP:WUP=-1 ........ it is incomplete
          well now we have to calm down the CAN bus dialog, the Rx/Tx Led of the gateway looks like a Christmas tree :)
          tomorrow I'll test a CAN_Switch version2 sketch
          • J
            J
            JeeLet
            test with the digital output inputs of 2 Arduino on CAN Bus.
            • status of a button and control of a led with MyC
            a proof in video that it is functional :)
            video
            all is not functional, on the end of the video, the reset or reboot does not work, (but functional with the RS485 bus)
            .... to follow ;)
            (now the Analog values, decimal to test )
            I would like to test the Node to Node with the filtering.
            a question : is it difficult to put the filters on the MySensors sketch ???
            there are still MySensors on the forum ???
            if yes, a help for Adam Slowik would be a great thing.
            implement it in MyS Yes Yes
            • Adam SlowikA
              Adam SlowikA
              Adam Slowik
              @JeeLet as I can see You had bussy weekend. I was AFK so I was unable to respond. Within working days I should be able to respond quicker.
              @JeeLet said in CAN bus transport implementation:
              Can you push Your fix to My repo?
              Great job! I never was at this stage.
              .... to follow
              Can You provide (gateway/node) logs from reset scenario. It would be great to have those logs either for RS485 and CAN so I can compare them.
              Could You describe what kind of test You would like to perform? Right now there is no way to set filters from the sketch. I think it should stay this way.
              Perhaps We have different things in mind when We think about filters. I'll try to describe how I see this.
              When it comes to CAN frame there is header and body. Header contains metadata and body contains data. mcp2515 can filter frames based on header content. Header contains id of destination node. Based on this id filters are set to drop any messages not intended for current node. This way if gateway want to send message to node with id=51 only node with this id receives this message.
              There is exception for this rule. Messages with destination id set to BROADCAST_ADDRESS reaches all nodes.
              With this in mind I see no reason to set filters differently. Of course I can be wrong.
              Composition of header is described in MyTransportCAN.cpp in method _buildHeader()
              As of now my all can modules and arduinos are burried in some box at My attic so I am unable to test anything
              • J
                J
                JeeLet
                "Can you provide logs (gateway/node) from the reset scenario. It would be great to have these logs for RS485 and CAN so I can compare them."
                listing
                Released today 2 gateways connect to MyController
                • UNO_usb - Gateway and RS485 bus
                • UNO_usb - Gateway and CAN Bus
                with connect, a UNO with the basic sketch "RelayWithButtonActuator_base.ino" (slightly modified)
                with ... a Led and a Switch, for each bus.
                The Listing split in several parts
                "Log of the IDE and MyC for the two types of bus (node34 and node 54), CAN and RS485.
                - Listing Action RESET with MyController
                	2 parts for CAN
                	and
                	2 parts for RS485
                and
                - Listing Action On/Off on the node switch or with MyController
                	4 parts for CAN
                	and
                	4 parts for RS485
                No error on the Reset, it works fine, an error from me.
                Oh yes, I even found an error :)
                the sendSketchInfo("test xxxxx", "1.0"); is not up
                see the end of the video
                video
                ....I will answer the other question tomorrow.
                • J
                  J
                  JeeLet
                  @Adam-Slowik "Can you push your patch to my repository? " .... I don't know how
                  On the CAN principle
                  @Adam-Slowik "Based on this id, the filters are configured to remove all messages not intended for the current node. This way, if the gateway wants to send a message to the node with id = 51, only the node with that id receives that message." ... yes, that's how I see it.
                  another way to say/explain it.
                  "The philosophy of CAN is to constitute a messaging system.
                  The messages (the letter) send on the CAN Bus (the post office), distributed by the CAN Bus (the letter carrier).
                  Each (letter) have each an identifier (stamp of the post ☺ ) that ... identifies it.
                  And put in the right mailbox (the MCP2515) according to the choice of filter/mask ( color, scent? ☺ ) of the letter."
                  So there are two "stratum" of dialogue / work.
                  • one on the Can Bus, and another on the Nodes.
                  The idea is to relieve the Nodes of unnecessary work/effort with the risks that this brings. Less letter to open :)
                  @Adam-Slowik "... my modules and arduinos are buried in a box in my attic..." ? Arduino 8bit and MySensors is over for you?
                  ( if it's a personal / family reason don't say anything )
                  • J
                    J
                    JeeLet
                    #21
                    I tested my sketch with clock and OLED to see :)
                    bah No the time is not up :(
                    I give this information for an overview, it can help for the continuation (but not to give you work :) )
                    The listing of the messages of mySensors
                    test with "void receiveTime" function (without RTC clock)
                    https://forum.mysensors.org/topic/4809/real-time-clock-module-lcd-display-and-controller-time/8?_=1655208396048
                    ..........Log MyC - terminal ssh  .........
                    2022-06-14T14:01:45.115+0200	recd	0;255;3;0;9;65310350 TSF:MSG:READ,55-55-0,s=255,c=3,t=1,pt=0,l=0,sg=0:
                    2022-06-14T14:01:45.119+0200	recd	0;255;3;0;9;65310356 TSF:MSG:ECHO REQ
                    2022-06-14T14:01:45.127+0200	recd	0;255;3;0;9;65310360 TSF:MSG:SEND,0-0-55-55,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                    2022-06-14T14:01:45.127+0200	recd	55;255;3;0;1;
                    2022-06-14T14:01:45.146+0200	sent	55;255;3;0;1;1655215305
                    2022-06-14T14:01:45.160+0200	recd	0;255;3;0;9;65310394 TSF:MSG:SEND,0-0-55-55,s=255,c=3,t=1,pt=0,l=10,sg=0,ft=0,st=OK:1655215305
                    ..........Log MyS - terminal IDE .........
                         time current:0   -------------------------------------------
                    58007 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                    58017 TSF:MSG:READ,0-0-55,s=255,c=3,t=1,pt=0,l=0,sg=0:
                    58022 TSF:MSG:ECHO
                    avec Bus RS485
                    2022-06-14T14:22:41.265+0200	recd	0;255;3;0;9;72000090 TSF:SAN:OK
                    2022-06-14T14:22:41.274+0200	recd	0;255;3;0;9;72000096 TSM:READY:NWD REQ
                    2022-06-14T14:22:41.298+0200	recd	0;255;3;0;9;72000115 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                    2022-06-14T14:22:41.917+0200	recd	0;255;3;0;9;72000736 TSF:MSG:READ,22-22-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
                    2022-06-14T14:22:41.920+0200	recd	22;255;3;0;21;0
                       time current:1422   -------------------------------------------
                    423956 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=1,l=1,sg=0:0
                    423962 TSF:MSG:BC
                    424008 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
                       requestOn-----------------------------------------
                    • Adam SlowikA
                      Adam SlowikA
                      Adam Slowik
                      No it is not over. Right now I don't have enough time. Now I am able to work for let's say 1 hour per week. Probably I will become more active at the end of 2023 :D
                      Here You posted RS485 version:
                      Could You post here CAN version?
                      • J
                        J
                        JeeLet
                        #23
                        @Adam-Slowik "Could you post the CAN version here?"
                        it's the same, except that the bus is not rs485 but CAN :)
                        #define MY_NODE_ID 55          /*Node en ID static*/
                          #define MY_CAN
                          #include "SSD1306Ascii.h"
                        but I'll go back to PaulStoffregen's Lib <TimeLib.h> to see if I can simplify the basic sketch of MySensors
                        • Adam SlowikA
                          Adam SlowikA
                          Adam Slowik
                          In previous example (with diodes) did You set CAN_CLOCK to MCP_16MHZ?
                          • J
                            J
                            JeeLet
                            #25
                            no it stayed on 8Mhz ?
                            I didn't modify anything (the other sketches work)
                            But I just looked at the quartz and it's 16M!! (SW-65-16M)
                            I am lost :(
                            https://www.gotronic.fr/art-module-bus-can-sbc-can01-28405.htm
                            but on the doc there is :
                            The 8000000 stands that the MCP2515 operates with a clock of 8 MHz. This
                            depends on the quartz used and may need to be adjusted.
                            error
                            on the official doc it's a 16Mhz like mine.
                            • https://www.joy-it.net/en/products/SBC-CAN01
                              OSCILLATOR 16 MHz Crystal Oscillator
                            so 8Mhz or 16Mhz?
                            and why does it work with the previous sketches?
                            • J
                              J
                              JeeLet
                              #26
                              I think the dialogue is good
                              but the problem is the length of the storyline
                              a part of the dialog on the IDE terminal for both types
                              CAN and RS485
                                 - IDE terminal sur RS485 :
                              4066 TSF:MSG:ECHO
                              4132 TSF:MSG:READ,0-0-22,s=255,c=3,t=1,pt=0,l=10,sg=0:1655285320
                              8018 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                              8054 TSF:MSG:READ,0-0-22,s=255,c=3,t=1,pt=0,l=0,sg=0:
                              8058 TSF:MSG:ECHO
                              8111 TSF:MSG:READ,0-0-22,s=255,c=3,t=1,pt=0,l=10,sg=0:1655285324
                                newTime:1655285324   -------------------------------------------
                                - IDE terminal sur CAN :
                              22224 MCO:REG:REQ
                              22226 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                              22233 !MCO:PRO:RC=1
                              22235 TSF:MSG:READ,0-0-55,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                              22240 MCO:PIM:NODE REG=1
                              28004 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                              28014 TSF:MSG:READ,0-0-55,s=255,c=3,t=1,pt=0,l=0,sg=0:
                              28019 TSF:MSG:ECHO
                                newTime:0   -------------------------------------------
                              sketch
                              void receiveTime(unsigned long controllerTime)   {
                                  if (receiveTime) stateCom = true ; else stateCom = false;
                                    newTime = controllerTime;
                              Serial.print("  newTime:"); Serial.print(newTime);
                              • J
                                J
                                JeeLet
                                #27
                                frequency change
                                with 16Mhz I have a NACK
                                // #define CAN_CLOCK MCP_16MHZ
                                105 TSM:FPAR
                                18107 ?TSF:MSG:SEND,55-55-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=4,st=NACK:
                                20115 !TSM:FPAR:NO REPLY
                                20117 TSM:FPAR
                                20119 ?TSF:MSG:SEND,55-55-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=5,st=NACK:
                                // #define CAN_CLOCK MCP_8MHZ
                                28019 TSF:MSG:ECHO
                                38005 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                                38016 TSF:MSG:READ,0-0-55,s=255,c=3,t=1,pt=0,l=0,sg=0:
                                https://forum.arduino.cc/t/how-to-set-the-mhz-in-mcp2515-library-file-based-on-crystal-oscillator/628822
                                • J
                                  J
                                  JeeLet
                                  in the sketch I added lines to visualize the buffer data
                                  a part of I recopied
                                  log IDE :
                                     Extended ID: 0x0410FF00  DLC: 8  Data: 0x00 0x00 0xFF 0x0A 0x23 0x14 0xFF 0x00
                                  88010 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                                  Extended ID: 0x05103700  DLC: 7  Data: 0x00 0x00 0x37 0x02 0x13 0x01 0xFF
                                  Extended ID: 0x06303700  DLC: 8  Data: 0x00 0x00 0x37 0x52 0x03 0x01 0xFF 0x31
                                  I stop for me, I pause for 1 day or 2 :)
                                  • Adam SlowikA
                                    Adam SlowikA
                                    Adam Slowik
                                    I found a bug in my code. Please re-download new version.
                                    If something won't work please enable CAN debug by adding:
                                    #define MY_DEBUG_VERBOSE_CAN
                                    add this to gateway and to node sketch
                                    • J
                                      J
                                      JeeLet
                                      #30
                                      #define MY_DEBUG_VERBOSE_CAN .....yes yes I already tested it, it's very good.
                                      (a very useful function)
                                      ..go to
                                      • Reloading the CAN-MyS update
                                      • ClearEeprom of the GW and Nodes
                                      • Reloading of Sketches on GW and Nodes
                                      Bravo :woman-lifting-weights:
                                      • sendSketchInfo(" text ...."); and well up
                                      • requestTime(receiveTime); and functional
                                      Ahhhhhh Lovely this is great :rainbow:
                                      I offer the coffee crossing :croissant: :coffee:
                                      (what was the problem ??? )
                                      After the test on the Digital I/O of the Nodes ,
                                      now I test the Analog I/O
                                      a Super Thank You @Adam-Slowik
                                      :+1:
                                      • J
                                        J
                                        JeeLet
                                        #31
                                        a test with DHT22 probes.
                                        the values go up well on MyC
                                        real decimal values :)
                                        here is a screen shot
                                        big vue
                                        I have to find another type of probes, the DHT22 give me losses, or my sketch is to review
                                        ReEdit
                                        error :angry:
                                        I got excited too fast
                                        the values are not refreshed.
                                        I look better :eyeglasses:
                                        ReRe-edition
                                        I made a mistake, as I play a little too much with MyController, I add and remove gateways from nodes and other salads.
                                        and well in the end it makes no sense ;)
                                        I cleaned up the Yaml files of MyC and it's better :)
                                        • Adam SlowikA
                                          Adam SlowikA
                                          Adam Slowik
                                          Previous messages used 7 bytes long payload. Single CAN frame is able to transfer 8 bytes. So all messages was contained in single frame. Example with time, used 17 (!) bytes long payload. In order to transfer 17 bytes there is need to split data to 3 messages (8+8+1). Next in the other side of wire You have to concat it. This mechanism of splitting and concating had a bug. For details check last 3 commits (at the bottom)
                                          https://github.com/mysensors/MySensors/compare/development...AdamSlowik:development
