  3. CAN bus transport implementation
54 Posts 5 Posters 8.4k Views 8 Watching
  • J
    J
    JeeLet
    wrote on last edited by JeeLet
    test with the digital output inputs of 2 Arduino on CAN Bus.
    • status of a button and control of a led with MyC
    a proof in video that it is functional :)
    video
    all is not functional, on the end of the video, the reset or reboot does not work, (but functional with the RS485 bus)
    .... to follow ;)
    (now the Analog values, decimal to test )
    I would like to test the Node to Node with the filtering.
    a question : is it difficult to put the filters on the MySensors sketch ???
    there are still MySensors on the forum ???
    if yes, a help for Adam Slowik would be a great thing.
    implement it in MyS Yes Yes
    • Adam SlowikA
      Adam SlowikA
      Adam Slowik
      @JeeLet as I can see You had bussy weekend. I was AFK so I was unable to respond. Within working days I should be able to respond quicker.
      @JeeLet said in CAN bus transport implementation:
      lines 163 and 228 modify and error resolved
      Can you push Your fix to My repo?
      Great job! I never was at this stage.
      .... to follow
      Can You provide (gateway/node) logs from reset scenario. It would be great to have those logs either for RS485 and CAN so I can compare them.
      Could You describe what kind of test You would like to perform? Right now there is no way to set filters from the sketch. I think it should stay this way.
      Perhaps We have different things in mind when We think about filters. I'll try to describe how I see this.
      When it comes to CAN frame there is header and body. Header contains metadata and body contains data. mcp2515 can filter frames based on header content. Header contains id of destination node. Based on this id filters are set to drop any messages not intended for current node. This way if gateway want to send message to node with id=51 only node with this id receives this message.
      There is exception for this rule. Messages with destination id set to BROADCAST_ADDRESS reaches all nodes.
      With this in mind I see no reason to set filters differently. Of course I can be wrong.
      Composition of header is described in MyTransportCAN.cpp in method _buildHeader()
      As of now my all can modules and arduinos are burried in some box at My attic so I am unable to test anything
      • J
        J
        JeeLet
        "Can you provide logs (gateway/node) from the reset scenario. It would be great to have these logs for RS485 and CAN so I can compare them."
        listing
        Released today 2 gateways connect to MyController
        • UNO_usb - Gateway and RS485 bus
        • UNO_usb - Gateway and CAN Bus
        with connect, a UNO with the basic sketch "RelayWithButtonActuator_base.ino" (slightly modified)
        with ... a Led and a Switch, for each bus.
        The Listing split in several parts
        "Log of the IDE and MyC for the two types of bus (node34 and node 54), CAN and RS485.
        - Listing Action RESET with MyController
        	2 parts for CAN
        	and
        	2 parts for RS485
        and
        - Listing Action On/Off on the node switch or with MyController
        	4 parts for CAN
        	and
        	4 parts for RS485
        No error on the Reset, it works fine, an error from me.
        Oh yes, I even found an error :)
        the sendSketchInfo("test xxxxx", "1.0"); is not up
        see the end of the video
        video
        ....I will answer the other question tomorrow.
        • J
          J
          JeeLet
          @Adam-Slowik "Can you push your patch to my repository? " .... I don't know how
          On the CAN principle
          @Adam-Slowik "Based on this id, the filters are configured to remove all messages not intended for the current node. This way, if the gateway wants to send a message to the node with id = 51, only the node with that id receives that message." ... yes, that's how I see it.
          another way to say/explain it.
          "The philosophy of CAN is to constitute a messaging system.
          The messages (the letter) send on the CAN Bus (the post office), distributed by the CAN Bus (the letter carrier).
          Each (letter) have each an identifier (stamp of the post ☺ ) that ... identifies it.
          And put in the right mailbox (the MCP2515) according to the choice of filter/mask ( color, scent? ☺ ) of the letter."
          So there are two "stratum" of dialogue / work.
          • one on the Can Bus, and another on the Nodes.
          The idea is to relieve the Nodes of unnecessary work/effort with the risks that this brings. Less letter to open :)
          @Adam-Slowik "... my modules and arduinos are buried in a box in my attic..." ? Arduino 8bit and MySensors is over for you?
          ( if it's a personal / family reason don't say anything )
          • J
            J
            JeeLet
            #21
            I tested my sketch with clock and OLED to see :)
            bah No the time is not up :(
            I give this information for an overview, it can help for the continuation (but not to give you work :) )
            The listing of the messages of mySensors
            test with "void receiveTime" function (without RTC clock)
            https://forum.mysensors.org/topic/4809/real-time-clock-module-lcd-display-and-controller-time/8?_=1655208396048
            ..........Log MyC - terminal ssh  .........
            2022-06-14T14:01:45.115+0200	recd	0;255;3;0;9;65310350 TSF:MSG:READ,55-55-0,s=255,c=3,t=1,pt=0,l=0,sg=0:
            2022-06-14T14:01:45.119+0200	recd	0;255;3;0;9;65310356 TSF:MSG:ECHO REQ
            2022-06-14T14:01:45.127+0200	recd	0;255;3;0;9;65310360 TSF:MSG:SEND,0-0-55-55,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
            2022-06-14T14:01:45.127+0200	recd	55;255;3;0;1;
            2022-06-14T14:01:45.146+0200	sent	55;255;3;0;1;1655215305
            2022-06-14T14:01:45.160+0200	recd	0;255;3;0;9;65310394 TSF:MSG:SEND,0-0-55-55,s=255,c=3,t=1,pt=0,l=10,sg=0,ft=0,st=OK:1655215305
            ..........Log MyS - terminal IDE .........
                 time current:0   -------------------------------------------
            58007 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
            58017 TSF:MSG:READ,0-0-55,s=255,c=3,t=1,pt=0,l=0,sg=0:
            58022 TSF:MSG:ECHO
            avec Bus RS485
            2022-06-14T14:22:41.265+0200	recd	0;255;3;0;9;72000090 TSF:SAN:OK
            2022-06-14T14:22:41.274+0200	recd	0;255;3;0;9;72000096 TSM:READY:NWD REQ
            2022-06-14T14:22:41.298+0200	recd	0;255;3;0;9;72000115 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
            2022-06-14T14:22:41.917+0200	recd	0;255;3;0;9;72000736 TSF:MSG:READ,22-22-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
            2022-06-14T14:22:41.920+0200	recd	22;255;3;0;21;0
               time current:1422   -------------------------------------------
            423956 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=1,l=1,sg=0:0
            423962 TSF:MSG:BC
            424008 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
               requestOn-----------------------------------------
            • Adam SlowikA
              Adam SlowikA
              Adam Slowik
              No it is not over. Right now I don't have enough time. Now I am able to work for let's say 1 hour per week. Probably I will become more active at the end of 2023 :D
              Here You posted RS485 version:
              Could You post here CAN version?
              • J
                J
                JeeLet
                #23
                @Adam-Slowik "Could you post the CAN version here?"
                it's the same, except that the bus is not rs485 but CAN :)
                #define MY_NODE_ID 55          /*Node en ID static*/
                  #define MY_CAN
                  #include "SSD1306Ascii.h"
                but I'll go back to PaulStoffregen's Lib <TimeLib.h> to see if I can simplify the basic sketch of MySensors
                • Adam SlowikA
                  Adam SlowikA
                  Adam Slowik
                  In previous example (with diodes) did You set CAN_CLOCK to MCP_16MHZ?
                  • J
                    J
                    JeeLet
                    #25
                    no it stayed on 8Mhz ?
                    I didn't modify anything (the other sketches work)
                    But I just looked at the quartz and it's 16M!! (SW-65-16M)
                    I am lost :(
                    https://www.gotronic.fr/art-module-bus-can-sbc-can01-28405.htm
                    but on the doc there is :
                    The 8000000 stands that the MCP2515 operates with a clock of 8 MHz. This
                    depends on the quartz used and may need to be adjusted.
                    error
                    on the official doc it's a 16Mhz like mine.
                    • https://www.joy-it.net/en/products/SBC-CAN01
                      OSCILLATOR 16 MHz Crystal Oscillator
                    so 8Mhz or 16Mhz?
                    and why does it work with the previous sketches?
                    • J
                      J
                      JeeLet
                      #26
                      I think the dialogue is good
                      but the problem is the length of the storyline
                      a part of the dialog on the IDE terminal for both types
                      CAN and RS485
                         - IDE terminal sur RS485 :
                      4066 TSF:MSG:ECHO
                      4132 TSF:MSG:READ,0-0-22,s=255,c=3,t=1,pt=0,l=10,sg=0:1655285320
                      8018 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                      8054 TSF:MSG:READ,0-0-22,s=255,c=3,t=1,pt=0,l=0,sg=0:
                      8058 TSF:MSG:ECHO
                      8111 TSF:MSG:READ,0-0-22,s=255,c=3,t=1,pt=0,l=10,sg=0:1655285324
                        newTime:1655285324   -------------------------------------------
                        - IDE terminal sur CAN :
                      22224 MCO:REG:REQ
                      22226 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                      22233 !MCO:PRO:RC=1
                      22235 TSF:MSG:READ,0-0-55,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                      22240 MCO:PIM:NODE REG=1
                      28004 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                      28014 TSF:MSG:READ,0-0-55,s=255,c=3,t=1,pt=0,l=0,sg=0:
                      28019 TSF:MSG:ECHO
                        newTime:0   -------------------------------------------
                      sketch
                      void receiveTime(unsigned long controllerTime)   {
                          if (receiveTime) stateCom = true ; else stateCom = false;
                            newTime = controllerTime;
                      Serial.print("  newTime:"); Serial.print(newTime);
                      • J
                        J
                        JeeLet
                        #27
                        frequency change
                        with 16Mhz I have a NACK
                        // #define CAN_CLOCK MCP_16MHZ
                        105 TSM:FPAR
                        18107 ?TSF:MSG:SEND,55-55-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=4,st=NACK:
                        20115 !TSM:FPAR:NO REPLY
                        20117 TSM:FPAR
                        20119 ?TSF:MSG:SEND,55-55-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=5,st=NACK:
                        // #define CAN_CLOCK MCP_8MHZ
                        28019 TSF:MSG:ECHO
                        38005 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                        38016 TSF:MSG:READ,0-0-55,s=255,c=3,t=1,pt=0,l=0,sg=0:
                        https://forum.arduino.cc/t/how-to-set-the-mhz-in-mcp2515-library-file-based-on-crystal-oscillator/628822
                        • J
                          J
                          JeeLet
                          in the sketch I added lines to visualize the buffer data
                          a part of I recopied
                          log IDE :
                             Extended ID: 0x0410FF00  DLC: 8  Data: 0x00 0x00 0xFF 0x0A 0x23 0x14 0xFF 0x00
                          88010 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                          Extended ID: 0x05103700  DLC: 7  Data: 0x00 0x00 0x37 0x02 0x13 0x01 0xFF
                          Extended ID: 0x06303700  DLC: 8  Data: 0x00 0x00 0x37 0x52 0x03 0x01 0xFF 0x31
                          I stop for me, I pause for 1 day or 2 :)
                          • Adam SlowikA
                            Adam SlowikA
                            Adam Slowik
                            I found a bug in my code. Please re-download new version.
                            If something won't work please enable CAN debug by adding:
                            #define MY_DEBUG_VERBOSE_CAN
                            add this to gateway and to node sketch
                            • J
                              J
                              JeeLet
                              #30
                              #define MY_DEBUG_VERBOSE_CAN .....yes yes I already tested it, it's very good.
                              (a very useful function)
                              ..go to
                              • Reloading the CAN-MyS update
                              • ClearEeprom of the GW and Nodes
                              • Reloading of Sketches on GW and Nodes
                              Bravo :woman-lifting-weights:
                              • sendSketchInfo(" text ...."); and well up
                              • requestTime(receiveTime); and functional
                              Ahhhhhh Lovely this is great :rainbow:
                              I offer the coffee crossing :croissant: :coffee:
                              (what was the problem ??? )
                              After the test on the Digital I/O of the Nodes ,
                              now I test the Analog I/O
                              a Super Thank You @Adam-Slowik
                              :+1:
                              • J
                                J
                                JeeLet
                                #31
                                a test with DHT22 probes.
                                the values go up well on MyC
                                real decimal values :)
                                here is a screen shot
                                big vue
                                I have to find another type of probes, the DHT22 give me losses, or my sketch is to review
                                ReEdit
                                error :angry:
                                I got excited too fast
                                the values are not refreshed.
                                I look better :eyeglasses:
                                ReRe-edition
                                I made a mistake, as I play a little too much with MyController, I add and remove gateways from nodes and other salads.
                                and well in the end it makes no sense ;)
                                I cleaned up the Yaml files of MyC and it's better :)
                                • Adam SlowikA
                                  Adam SlowikA
                                  Adam Slowik
                                  Previous messages used 7 bytes long payload. Single CAN frame is able to transfer 8 bytes. So all messages was contained in single frame. Example with time, used 17 (!) bytes long payload. In order to transfer 17 bytes there is need to split data to 3 messages (8+8+1). Next in the other side of wire You have to concat it. This mechanism of splitting and concating had a bug. For details check last 3 commits (at the bottom)
                                  https://github.com/mysensors/MySensors/compare/development...AdamSlowik:development
                                  • J
                                    J
                                    JeeLet
                                    #33
                                    Gateway Logs on MyController
                                    (CAN Bus and RS485 Bus)
                                    two separate files
                                    CAN log
                                    RS485 log
                                    files split in parts :
                                    A : gateways startup
                                    B : reboot of the gateways
                                    C : launch of MyClock Nodes (id23 and id55)
                                    D ; periodic refresh requestTime(receiveTime)
                                    E ; send value (1700 and 2100)
                                    (I have prepared the work for you to read)
                                    a 1st analysis
                                    • (at the bottom of the listing, the sending of values "1700 or 2100" with MyC)
                                      The RS485 bus dialogues much more, the CAN bus is more timid :)
                                    Adam Slowik bravo
                                    I test what now???
                                    the ACK ??
                                    Oh yes, I have to check the disconnection of the nodes.
                                    The Gateway gives me the impression that the information does not go back to MyC if a Node is off ???
                                    • Adam SlowikA
                                      Adam SlowikA
                                      Adam Slowik
                                      I test what now???
                                      I was at similar position some time ago:
                                      @Adam-Slowik said in CAN bus transport implementation:
                                      Any suggestion what to test next?
                                      I have no idea what to test next. I do not use MySensors. I hope this will change in the future, but as of now I'm a newbie.
                                      If You won't get any advice from more experienced users I would suggest to do some long running test to see if it's stable. If it's stable try to use it in some real use cases.
                                      If You find any bugs in transmission layer post logs here. I will do My best to support CAN, because I will need it in a future.
                                      • J
                                        J
                                        JeeLet
                                        " I would suggest doing a long term test to see if it is stable." yes I will stress it to see the weakness
                                        ".. If it is stable, try to use it in real use cases." yes that's the point
                                        One last question
                                        I'm going from 8Mhz to 16Mhz (in development/MyConfig.h on line 306)
                                        question: can you explain how I can bring up in the sketch the parameters that are related to the MCP_CAN_lib library
                                        it should not be complicated for me :) it is only text to insert ???
                                        an example with the #define CAN_CLOCK MCP_8MHZ
                                        Thanks Adam Slowik
                                        • Adam SlowikA
                                          Adam SlowikA
                                          Adam Slowik
                                          In My opinion You should not override MyConfig.h. If You want to go for 16MHz You should put:
                                          in Your sketch. Preferably somewhere around line:
                                          #define MY_CAN
                                          If it's a parameter that is listed in MyConfig.h simply define it like 'CAN_CLOCK'. If parameter is not listed in MyConfig please let me know exactly what parameter You would like to modify, then I will try to figure it out.
